[GRASS-SVN] r32728 - in grass/trunk/gui/wxpython: gui_modules nviz
Tue Aug 12 17:03:16 EDT 2008
Author: martinl
Date: 2008-08-12 17:03:16 -0400 (Tue, 12 Aug 2008)
New Revision: 32728
   grass/trunk/gui/wxpython/gui_modules/nviz.py
   grass/trunk/gui/wxpython/nviz/nviz.h
   grass/trunk/gui/wxpython/nviz/volume.cpp
wxGUI/nviz: volume updates: delete isosurface, dialog layout
(merge from devbr6, r32727)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-08-12 21:00:07 UTC (rev 32727)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-08-12 21:03:16 UTC (rev 32728)
@@ -409,7 +409,8 @@
             elif type == '3d-raster':
                 data[nvizType] = {}
-                for sec in ('attribute', 'draw', 'position'):
+                for sec in ('attribute', 'draw', 'position',
+                            'isosurface', 'slice'):
                     data[nvizType][sec] = {}
                 # reset to default properties
@@ -487,7 +488,7 @@
         # set default/workspace layer properties
         data = self.SetLayerData(item, id, nvizType)
+        print data
         # update properties
         self.UpdateLayerProperties(item)
@@ -626,15 +627,13 @@
         # attributes
-        data['attribute']['shine'] = {}
-        data['attribute']['shine']['map'] = \
-            UserSettings.Get(group='nviz', key='surface', subkey=['shine', 'map'])
-        data['attribute']['shine']['value'] = \
-            UserSettings.Get(group='nviz', key='surface', subkey=['shine', 'value'])
-        self.update.append('surface:attribute:shine')
+        for attrb in ('shine', ):
+            data['attribute'][attrb] = {}
+            for key, value in UserSettings.Get(group='nviz', key='volume',
+                                               subkey=attrb).iteritems():
+                data['attribute'][attrb][key] = value
+                self.update.append('surface:attribute:%s' % value)#
         # draw
@@ -864,6 +863,16 @@
                 self.update.append('volume:draw:%s' % control)
             data['draw'][control] = { 'value' : value }
+        # isosurface attributes
+                ### self.update.append('volume:attribute:%s' % value)
     def Reset(self):
         """Reset (unload data)"""
         self.nvizClass.Reset()
@@ -1223,7 +1232,7 @@
                            range=(0, 1),
                            bind=(self.OnViewChange, self.OnViewChanged, self.OnViewChangedSpin))
         self.CreateControl(panel, dict=self.win['view'], name='z-exag', sliderHor=False,
-                           range=(1, 1),
+                           range=(0, 1),
         heightSizer = wx.GridBagSizer(vgap=3, hgap=3)
         heightSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Height:")),
@@ -1332,7 +1341,7 @@
             if code != 'mask':
                 use.Append(item=_('constant'))
             self.win['surface'][code]['use'] = use.GetId()
-            use.Bind(wx.EVT_CHOICE, self.OnSurfaceUse)
+            use.Bind(wx.EVT_CHOICE, self.OnMapObjUse)
             gridSizer.Add(item=use, flag=wx.ALIGN_CENTER_VERTICAL,
                           pos=(row, 1))
@@ -1859,7 +1868,8 @@
         gridSizer = wx.GridBagSizer(vgap=3, hgap=3)
         # list
-        isolevel = IsoSurfList(parent=panel, size=(300, 150))
+        isolevel = IsoSurfList(parent=panel, win=self.win['volume'],
+                               size=(300, 150))
         self.win['volume']['isosurfs'] = isolevel.GetId()
         gridSizer.Add(item=isolevel, pos=(0, 0), span=(4, 1))
@@ -1930,7 +1940,7 @@
             if use:
                 self.win['volume'][code]['use'] = use.GetId()
                               pos=(row, 1))
@@ -1938,7 +1948,7 @@
                 map = gselect.Select(parent=panel, id=wx.ID_ANY,
                                      # size=globalvar.DIALOG_GSELECT_SIZE,
                                      size=(200, -1),
-                                     type="raster")
+                                     type="grid3")
                 self.win['volume'][code]['map'] = map.GetId() - 1 # FIXME
                 map.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
                 gridSizer.Add(item=map, flag=wx.ALIGN_CENTER_VERTICAL,
@@ -2578,7 +2588,7 @@
         self.Hide()
-    def OnSurfaceUse(self, event):
+    def OnMapObjUse(self, event):
         """Surface attribute -- use -- map/constant"""
         if not self.mapWindow.init:
             return
@@ -2588,31 +2598,34 @@
         # find attribute row
         attrb = self.__GetWindowName(self.win['surface'], event.GetId())
         if not attrb:
-            return
+            attrb = self.__GetWindowName(self.win['volume'], event.GetId())
+            nvizType = 'volume'
+        else:
+            nvizType = 'surface'
         selection = event.GetSelection()
-        if self.win['surface'][attrb]['required']: # no 'unset'
+        if self.win[nvizType][attrb]['required']: # no 'unset'
             selection += 1
         if selection == 0: # unset
             useMap = None
             value = ''
         elif selection == 1: # map
             useMap = True
-            value = self.FindWindowById(self.win['surface'][attrb]['map']).GetValue()
+            value = self.FindWindowById(self.win[nvizType][attrb]['map']).GetValue()
         elif selection == 2: # constant
             useMap = False
             if attrb == 'color':
-                value = self.FindWindowById(self.win['surface'][attrb]['const']).GetColour()
+                value = self.FindWindowById(self.win[nvizType][attrb]['const']).GetColour()
                 value = str(value[0]) + ':' + str(value[1]) + ':' + str(value[2])
             else:
-                value = self.FindWindowById(self.win['surface'][attrb]['const']).GetValue()
+                value = self.FindWindowById(self.win[nvizType][attrb]['const']).GetValue()
-        self.SetMapObjUseMap(nvizType='surface',
+        self.SetMapObjUseMap(nvizType=nvizType,
                              attrb=attrb, map=useMap)
         self.mapWindow.update.append('surface:attribute:%s' % attrb)
         data = self.mapWindow.GetSelectedLayer(type='nviz')
-        data['surface']['attribute'][attrb] = { 'map' : useMap,
+        data[nvizType]['attribute'][attrb] = { 'map' : useMap,
                                                 'value' : str(value),
         self.mapWindow.UpdateLayerProperties()
@@ -3022,6 +3035,7 @@
         list.Append("%s %s" % (_("Level"), str(level)))
         list.Check(list.GetCount()-1)
+        list.SetSelection(list.GetCount()-1)
         # add isosurface
         layer = self.mapWindow.GetSelectedLayer()
@@ -3034,6 +3048,10 @@
         # disable add button on max
         if list.GetCount() >= wxnviz.MAX_ISOSURFS:
             self.FindWindowById(event.GetId()).Enable(False)
+        # disable 'move-down'
+        moveDown = self.parent.FindWindowById(self.win['volume']['btnIsosurfMoveDown'])
+        if not moveDown.IsEnabled():
+            moveDown.Enable(False)
         # enable delete & move buttons
         btnDelete = self.FindWindowById(self.win['volume']['btnIsosurfDelete'])
@@ -3041,11 +3059,12 @@
             btnDelete.Enable(True)
         if list.GetCount() > 1:
             btnMoveUp = self.FindWindowById(self.win['volume']['btnIsosurfMoveUp'])
-            btnMoveDown = self.FindWindowById(self.win['volume']['btnIsosurfMoveDown'])
             if not btnMoveUp.IsEnabled():
                 btnMoveUp.Enable(True)
-                btnMoveDown.Enable(True)
+        if self.parent.autoRender.IsChecked():
+            self.mapWindow.Refresh(False)
         event.Skip()
     def OnVolumeIsosurfDelete(self, event):
@@ -3053,12 +3072,32 @@
         list = self.FindWindowById(self.win['volume']['isosurfs'])
         btn = self.FindWindowById(event.GetId())
+        # remove item from list
+        isosurfId = list.GetSelection()
+        list.Delete(isosurfId)
+        # select last item
+        if list.GetCount() > 0:
+        # delete isosurface
+        layer = self.mapWindow.GetSelectedLayer()
+        data = self.mapWindow.GetSelectedLayer(type='nviz')['volume']
+        id = data['object']['id']
+        self.mapWindow.nvizClass.DeleteIsosurface(id, isosurfId)
+        # update buttons
         if list.GetCount() < 1:
             btn.Enable(False)
         elif list.GetCount() < 2:
             self.FindWindowById(self.win['volume']['btnIsosurfMoveUp']).Enable(False)
             self.FindWindowById(self.win['volume']['btnIsosurfMoveDown']).Enable(False)
+        event.Skip()
     def OnVolumeIsosurfMoveUp(self, event):
         """Move isosurface up in the list"""
         pass
@@ -3337,8 +3376,35 @@
             else:
                 win.SetValue(dict['value'])
-        self.FindWindowById(self.win['volume']['color']['map']).SetValue("precip3d.500z50 at PERMANENT")
+        for attr in ('color', ): # required
+            if layer and layer.type == '3d-raster':
+                self.FindWindowById(self.win['volume'][attr]['map']).SetValue(layer.name)
+            else:
+                self.FindWindowById(self.win['volume'][attr]['map']).SetValue('')
+            self.SetMapObjUseMap(nvizType='volume',
+                                 attrb=attr, map=True) # -> map
+        if data['attribute'].has_key('color'):
+            value = data['attribute']['color']['value']
+            if data['attribute']['color']['map']:
+                self.FindWindowById(self.win['volume']['color']['map']).SetValue(value)
+            else: # constant
+                color = map(int, value.split(':'))
+                self.FindWindowById(self.win['volume']['color']['const']).SetColour(color)
+                                 attrb=attr, map=data['attribute']['color']['map'])
+                             attrb='shine', map=data['attribute']['shine']['map'])
+        value = data['attribute']['shine']['value']
+        if data['attribute']['shine']['map']:
+            self.FindWindowById(self.win['volume']['shine']['map']).SetValue(value)
+        else:
+            self.FindWindowById(self.win['volume']['shine']['const']).SetValue(value)
     def SetPage(self, name):
         """Get named page"""
         self.notebook.SetSelection(self.page[name]['id'])
@@ -3416,6 +3482,35 @@
 class IsoSurfList(wx.CheckListBox):
     """List of loaded volume isosurfaces (volume properties page)"""
-    def __init__(self, parent, id=wx.ID_ANY, size=wx.DefaultSize):
+    def __init__(self, parent, win, id=wx.ID_ANY, size=wx.DefaultSize):
+        self.parent = parent
+        self.win = win
         wx.CheckListBox.__init__(self, parent, id, size=size)
+        self.Bind(wx.EVT_CHECKLISTBOX, self.OnCheck)
+        self.Bind(wx.EVT_LISTBOX, self.OnSelect)
+    def OnCheck(self, event):
+        """Item checked/unchecked -> load/delete surface"""
+        print event.IsChecked()
+    def OnSelect(self, event):
+        """Item selected"""
+        winUp = self.parent.FindWindowById(self.win['btnIsosurfMoveUp'])
+        winDown = self.parent.FindWindowById(self.win['btnIsosurfMoveDown'])
+        selection = event.GetSelection()
+        if selection == 0:
+            winUp.Enable(False)
+            if not winDown.IsEnabled():
+                winDown.Enable()
+        elif selection == self.GetCount() - 1:
+            winDown.Enable(False)
+            if not winUp.IsEnabled():
+                winUp.Enable()
+        else:
+                winDown.Enable()
+                winUp.Enable()
Modified: grass/trunk/gui/wxpython/nviz/nviz.h
--- grass/trunk/gui/wxpython/nviz/nviz.h	2008-08-12 21:00:07 UTC (rev 32727)
+++ grass/trunk/gui/wxpython/nviz/nviz.h	2008-08-12 21:03:16 UTC (rev 32728)
@@ -101,6 +101,7 @@
     /* volume */
     int AddIsosurface(int, int);
+    int DeleteIsosurface(int, int);
     int SetIsosurfaceColor(int, int, bool, const char *);
Modified: grass/trunk/gui/wxpython/nviz/volume.cpp
--- grass/trunk/gui/wxpython/nviz/volume.cpp	2008-08-12 21:00:07 UTC (rev 32727)
+++ grass/trunk/gui/wxpython/nviz/volume.cpp	2008-08-12 21:03:16 UTC (rev 32728)
@@ -45,6 +45,33 @@
 				     ATT_TOPO, level);
+   \brief Delete isosurface
+   \param id volume id
+   \param isosurf_id isosurface id
+   \return 1 on success
+   \return -1 volume not found
+   \return -2 isosurface not found
+   \return -3 on failure
+int Nviz::DeleteIsosurface(int id, int isosurf_id)
+    int ret;
+    if (!GVL_vol_exists(id))
+	return -1;
+    if (isosurf_id > GVL_isosurf_num_isosurfs(id))
+	return -2;
+    ret = GVL_isosurf_del(id, isosurf_id);
+    return ret < 0 ? -3 : 1;
   \brief Set surface color
