[GRASS-SVN] r32819 - grass/trunk/lib/g3d
Sat Aug 16 12:05:36 EDT 2008
Author: glynn
Date: 2008-08-16 12:05:36 -0400 (Sat, 16 Aug 2008)
New Revision: 32819
   grass/trunk/lib/g3d/g3dcats.c
   grass/trunk/lib/g3d/g3dcolor.c
   grass/trunk/lib/g3d/g3dhistory.c
   grass/trunk/lib/g3d/g3dmask.c
   grass/trunk/lib/g3d/g3dopen.c
   grass/trunk/lib/g3d/g3drange.c
Fix handling of grid3 elements
Modified: grass/trunk/lib/g3d/g3dcats.c
--- grass/trunk/lib/g3d/g3dcats.c	2008-08-16 16:03:50 UTC (rev 32818)
+++ grass/trunk/lib/g3d/g3dcats.c	2008-08-16 16:05:36 UTC (rev 32819)
@@ -30,19 +30,10 @@
     int i;
     const char *descr;
     DCELL val1, val2;
-    char str1[100], str2[100], buf[200], buf2[200], xname[GNAME_MAX],
-	xmapset[GMAPSET_MAX];
+    char str1[100], str2[100];
-    if (G__name_is_fully_qualified(name, xname, xmapset)) {
-	sprintf(buf, "%s/%s", G3D_DIRECTORY, xname);
-	sprintf(buf2, "%s@%s", G3D_CATS_ELEMENT, xmapset);	/* == cats at mapset */
-    else {
-	sprintf(buf, "%s/%s", G3D_DIRECTORY, name);
-	sprintf(buf2, "%s", G3D_CATS_ELEMENT);
-    if (!(fd = G_fopen_new(buf, buf2)))
+    fd = G_fopen_new_misc(G3D_DIRECTORY, G3D_CATS_ELEMENT, name);
+    if (!fd)
 	return -1;
     /* write # cats - note # indicate 3.0 or later */
@@ -86,22 +77,14 @@
  /* adapted from G__read_cats */
     FILE *fd;
-    char buff[1024], buf2[200], xname[GNAME_MAX], xmapset[GMAPSET_MAX];
+    char buff[1024];
     CELL cat;
     DCELL val1, val2;
     int old;
     long num = -1;
-	sprintf(buff, "%s/%s", G3D_DIRECTORY, xname);
-    else {
-	sprintf(buff, "%s/%s", G3D_DIRECTORY, name);
-    if (!(fd = G_fopen_old(buff, buf2, mapset)))
+    fd = G_fopen_old_misc(G3D_DIRECTORY, G3D_CATS_ELEMENT, name, mapset);
+    if (!fd)
 	return -2;
     /* Read the number of categories */
Modified: grass/trunk/lib/g3d/g3dcolor.c
--- grass/trunk/lib/g3d/g3dcolor.c	2008-08-16 16:03:50 UTC (rev 32818)
+++ grass/trunk/lib/g3d/g3dcolor.c	2008-08-16 16:05:36 UTC (rev 32819)
@@ -8,10 +8,10 @@
 #include <rpc/types.h>
 #include <rpc/xdr.h>
 #include <grass/gis.h>
+#include <grass/glocale.h>
 #include "G3d_intern.h"
-static int read_colors(const char *, const char *, const char *,
-		       struct Colors *);
+static int read_colors(const char *, const char *, struct Colors *);
 static int read_new_colors(FILE *, struct Colors *);
 static int read_old_colors(FILE *, struct Colors *);
@@ -20,25 +20,7 @@
 int G3d_removeColor(const char *name)
  /* adapted from G_remove_colr */
-    char buf[200], secondary[500], buf2[200], xname[GNAME_MAX],
-	sprintf(buf2, "%s@%s", G3D_COLOR_ELEMENT, xmapset);	/* == color at mapset */
-    else {
-	sprintf(buf2, "%s", G3D_COLOR_ELEMENT);
-    G_remove(buf, buf2);
-    sprintf(secondary, "%s/%s/%s",
-	    G3D_DIRECTORY, G3D_COLOR2_DIRECTORY, G_mapset());
-    G_remove(secondary, name);
-    return 0;
+    return G_remove_misc(G3D_DIRECTORY, G3D_COLOR_ELEMENT, name);
@@ -47,37 +29,15 @@
 G3d_readColors(const char *name, const char *mapset, struct Colors *colors)
  /* adapted from G_read_colors */
-    char buf[512], buf2[200];
     const char *err;
-    char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
     struct FPRange drange;
     DCELL dmin, dmax;
     G_init_colors(colors);
-	if (strcmp(xmapset, mapset) != 0)
-	    return -1;
-	name = xname;
-    sprintf(buf, "%s/%s/%s", G3D_DIRECTORY, G3D_COLOR2_DIRECTORY, mapset);
-    if (read_colors(buf, name, G_mapset(), colors) >= 0)
-	return 1;
     G_mark_colors_as_fp(colors);
-    /* now look for the regular color table */
-    /*if (G__name_is_fully_qualified (name, xname, xmapset)) {
-       sprintf (buf, "%s/%s", G3D_DIRECTORY, xname);
-       sprintf (buf2, "%s@%s", G3D_COLOR_ELEMENT, xmapset); // == color at mapset
-       //} else { */
-    switch (read_colors(buf, buf2, mapset, colors)) {
+    switch (read_colors(name, mapset, colors)) {
     case -2:
 	if (G3d_readRange(name, mapset, &drange) >= 0) {
 	    G_get_fp_range_min_max(&drange, &dmin, &dmax);
@@ -98,14 +58,15 @@
     return -1;
-static int read_colors(const char *element, const char *name,
-		       const char *mapset, struct Colors *colors)
+static int read_colors(const char *name, const char *mapset,
+		       struct Colors *colors)
     FILE *fd;
     int stat;
     char buf[1024];
-    if (!(fd = G_fopen_old(element, name, mapset)))
+    fd = G_fopen_old_misc(G3D_DIRECTORY, G3D_COLOR_ELEMENT, name, mapset);
+    if (!fd)
 	return -2;
@@ -364,46 +325,21 @@
 G3d_writeColors(const char *name, const char *mapset, struct Colors *colors)
  /* adapted from G_write_colors */
-    char element[512], buf[512], buf2[200];
     FILE *fd;
     int stat;
-	    return -1;
-	name = xname;
+    if (strcmp(mapset, G_mapset()) != 0) {
+	G_warning(_("mapset <%s> is not the current mapset"), mapset);
+	return -1;
-     * if mapset is current mapset, remove colr2 file (created by pre 3.0 grass)
-     *    and then write original color table
-     * else write secondary color table
+    fd = G_fopen_new_misc(G3D_DIRECTORY, G3D_COLOR_ELEMENT, name);
+    if (!fd)
+	return -1;
-    sprintf(element, "%s/%s/%s", G3D_DIRECTORY, G3D_COLOR2_DIRECTORY, mapset);
-    if (strcmp(mapset, G_mapset()) == 0) {
-	G_remove(element, name);	/* get rid of existing colr2, if any */
-	else {
-	    return -1;
-    else {
-	if (!(fd = G_fopen_new(element, name)))
-	    return -1;
     stat = G__write_colors(fd, colors);
     fclose(fd);
     return stat;
Modified: grass/trunk/lib/g3d/g3dhistory.c
--- grass/trunk/lib/g3d/g3dhistory.c	2008-08-16 16:03:50 UTC (rev 32818)
+++ grass/trunk/lib/g3d/g3dhistory.c	2008-08-16 16:05:36 UTC (rev 32819)
@@ -60,29 +60,17 @@
  *  \return int
-int G3d_readHistory(const char *name, const char *mapset,
-		    struct History *hist)
+int G3d_readHistory(const char *name, const char *mapset, struct History *hist)
 /* This function is adapted from G_read_history */
     FILE *fd;
     G_zero(hist, sizeof(struct History));
-    /*this construct takes care of the correct history file path */
-	sprintf(buf2, "%s@%s", G3D_HISTORY_ELEMENT, xmapset);	/* == hist at mapset */
-    else {
-	sprintf(buf2, "%s", G3D_HISTORY_ELEMENT);
+    fd = G_fopen_old_misc(G3D_DIRECTORY, G3D_HISTORY_ELEMENT, name, mapset);
+    if (!fd)
 	return -2;
     if (!G_getl(hist->mapid, sizeof(hist->mapid), fd)) {
 	SimpleErrorMessage(fd, name, mapset);
 	return -1;
@@ -164,18 +152,9 @@
     FILE *fd;
     int i;
-    char buf[200], buf2[200], xname[GNAME_MAX], xmapset[GMAPSET_MAX];
-    else {
+    fd = G_fopen_new_misc(G3D_DIRECTORY, G3D_HISTORY_ELEMENT, name);
+    if (!fd)
 	return -1;
     fprintf(fd, "%s\n", hist->mapid);
Modified: grass/trunk/lib/g3d/g3dmask.c
--- grass/trunk/lib/g3d/g3dmask.c	2008-08-16 16:03:50 UTC (rev 32818)
+++ grass/trunk/lib/g3d/g3dmask.c	2008-08-16 16:05:36 UTC (rev 32819)
@@ -61,19 +61,16 @@
  *  \return int
-int G3d_maskFileExists()
+int G3d_maskFileExists(void)
-    char buf[200];
-    sprintf(buf, "%s/%s", G3D_DIRECTORY, G3D_MASK_MAP);
-    return (G_find_file(buf, G3D_CELL_ELEMENT, G_mapset()) != NULL);
+    return G_find_file_misc(G3D_DIRECTORY, G3D_CELL_ELEMENT, G3D_MASK_MAP, G_mapset()) != NULL;
 static int maskOpenOldCacheDefault = G3D_USE_CACHE_DEFAULT;
-int G3d_maskOpenOld()
+int G3d_maskOpenOld(void)
     G3D_Region region;
Modified: grass/trunk/lib/g3d/g3dopen.c
--- grass/trunk/lib/g3d/g3dopen.c	2008-08-16 16:03:50 UTC (rev 32818)
+++ grass/trunk/lib/g3d/g3dopen.c	2008-08-16 16:05:36 UTC (rev 32819)
@@ -12,7 +12,7 @@
 void *G3d_openCellOldNoHeader(const char *name, const char *mapset)
     G3D_Map *map;
+    char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
     G3d_initDefaults();
@@ -27,20 +27,12 @@
 	return (void *)NULL;
-	sprintf(buf2, "%s@%s", G3D_CELL_ELEMENT, xmapset);	/* == cell at mapset */
-	map->fileName = G_store(xname);
-    else {
-	sprintf(buf2, "%s", G3D_CELL_ELEMENT);
-	map->fileName = G_store(name);
+    G__unqualified_name(name, mapset, xname, xmapset);
-    map->mapset = G_store(mapset);
+    map->fileName = G_store(xname);
+    map->mapset = G_store(xmapset);
-    map->data_fd = G_open_old(buf, buf2, mapset);
+    map->data_fd = G_open_old_misc(G3D_DIRECTORY, G3D_CELL_ELEMENT, xname, xmapset);
     if (map->data_fd < 0) {
 	G3d_error(_("G3d_openCellOldNoHeader: error in G_open_old"));
@@ -233,12 +225,14 @@
-    else
-    map->mapset = G_store(G_mapset());
+    if (G__unqualified_name(name, G_mapset(), xname, xmapset) < 0) {
+	G_warning(_("map <%s> is not in the current mapset"), name);
+	return (void *)NULL;
     map->tempName = G_tempfile();
     map->data_fd = open(map->tempName, O_RDWR | O_CREAT | O_TRUNC, 0666);
Modified: grass/trunk/lib/g3d/g3drange.c
--- grass/trunk/lib/g3d/g3drange.c	2008-08-16 16:03:50 UTC (rev 32818)
+++ grass/trunk/lib/g3d/g3drange.c	2008-08-16 16:05:36 UTC (rev 32819)
@@ -5,6 +5,7 @@
@@ -58,9 +59,6 @@
  /* adapted from G_read_fp_range */
     int fd;
-    char buf[GNAME_MAX + sizeof(G3D_DIRECTORY) + 2],
-	buf2[GMAPSET_MAX + sizeof(G3D_RANGE_ELEMENT) + 2];
     char xdr_buf[100];
     DCELL dcell1, dcell2;
     XDR xdr_str;
@@ -69,42 +67,32 @@
     fd = -1;
-	sprintf(buf2, "%s@%s", G3D_RANGE_ELEMENT, xmapset);	/* == range at mapset */
+    fd = G_open_old_misc(G3D_DIRECTORY, G3D_RANGE_ELEMENT, name, mapset);
+    if (fd < 0) {
+	G_warning(_("Unable to open range file for [%s in %s]"), name, mapset);
+	return -1;
-    else {
-	sprintf(buf2, "%s", G3D_RANGE_ELEMENT);
+    if (read(fd, xdr_buf, 2 * G3D_XDR_DOUBLE_LENGTH) != 2 * G3D_XDR_DOUBLE_LENGTH) {
+	close(fd);
+	G_warning(_("Error reading range file for [%s in %s]"), name, mapset);
+	return 2;
-    if (G_find_file2(buf, buf2, mapset)) {
-	fd = G_open_old(buf, buf2, mapset);
-	if (fd < 0)
-	    goto error;
+    xdrmem_create(&xdr_str, xdr_buf, (u_int) G3D_XDR_DOUBLE_LENGTH * 2,
+		  XDR_DECODE);
-	if (read(fd, xdr_buf, 2 * G3D_XDR_DOUBLE_LENGTH) !=
-	    2 * G3D_XDR_DOUBLE_LENGTH)
-	    return 2;
-	xdrmem_create(&xdr_str, xdr_buf, (u_int) G3D_XDR_DOUBLE_LENGTH * 2,
-		      XDR_DECODE);
-	/* if the f_range file exists, but empty */
-	if (!xdr_double(&xdr_str, &dcell1) || !xdr_double(&xdr_str, &dcell2))
-	    goto error;
-	G_update_fp_range(dcell1, drange);
-	G_update_fp_range(dcell2, drange);
+    /* if the f_range file exists, but empty */
+    if (!xdr_double(&xdr_str, &dcell1) || !xdr_double(&xdr_str, &dcell2)) {
 	close(fd);
-	return 1;
+	return -1;
-  error:
-    if (fd > 0)
-	close(fd);
-    G_warning("can't read range file for [%s in %s]", name, mapset);
-    return -1;
+    G_update_fp_range(dcell1, drange);
+    G_update_fp_range(dcell2, drange);
+    close(fd);
+    return 1;
@@ -156,26 +144,16 @@
 static int writeRange(const char *name, struct FPRange *range)
  /* adapted from G_write_fp_range */
     char xdr_buf[100];
     int fd;
     XDR xdr_str;
+    fd = G_open_new_misc(G3D_DIRECTORY, G3D_RANGE_ELEMENT, name);
+    if (fd < 0) {
+	G_warning(_("Unable to open range file for <%s>"), name);
+	return -1;
-    else {
-    fd = G_open_new(buf, buf2);
-    if (fd < 0)
-	goto error;
     if (range->first_time) {
 	/* if range hasn't been updated, write empty file meaning NULLs */
 	close(fd);
@@ -190,14 +168,16 @@
     if (!xdr_double(&xdr_str, &(range->max)))
 	goto error;
-    write(fd, xdr_buf, G3D_XDR_DOUBLE_LENGTH * 2);
+    if (write(fd, xdr_buf, G3D_XDR_DOUBLE_LENGTH * 2) != G3D_XDR_DOUBLE_LENGTH * 2)
+	goto error;
     close(fd);
     return 0;
   error:
-    G_remove(buf, buf2);	/* remove the old file with this name */
-    sprintf(buf, "can't write range file for [%s in %s]", name, G_mapset());
-    G_warning(buf);
+    close(fd);
+    G_remove_misc(G3D_DIRECTORY, G3D_RANGE_ELEMENT, name);	/* remove the old file with this name */
+    G_warning("can't write range file for [%s in %s]", name, G_mapset());
     return -1;
