[GRASS-SVN] r32820 - in grass/trunk: doc/raster/r.example general/g.region imagery/i.cca imagery/i.fft imagery/i.ifft imagery/i.zc raster/r.average raster/r.bitpattern raster/r.buffer raster/r.clump raster/r.cost raster/r.in.ascii raster/r.in.gdal raster/r.in.mat raster/r.kappa raster/r.los raster/r.median raster/r.mode raster/r.neighbors raster/r.random raster/r.random.cells raster/r.random.surface raster/r.reclass raster/r.recode raster/r.resample raster/r.rescale raster/r.rescale.eq raster/r.slope.aspect raster/r.surf.fractal raster/r.surf.gauss raster/r.surf.idw raster/r.surf.idw2 raster/r.surf.random raster/r.texture raster/r.to.rast3 raster/r.to.rast3elev raster/r.walk raster/r.water.outlet raster/r.watershed/ram raster/r.watershed/seg raster/wildfire/r.ros raster/wildfire/r.spread raster/wildfire/r.spreadpath raster3d/r3.cross.rast raster3d/r3.mkdspf raster3d/r3.showdspf raster3d/r3.to.rast swig/perl/R_slope_aspect/r_slope_aspect vector/v.edit vector/v.in.ogr vector/v.kernel vector/v.surf.idw vector/v.to.rast3
Sat Aug 16 12:08:09 EDT 2008
Author: glynn
Date: 2008-08-16 12:08:08 -0400 (Sat, 16 Aug 2008)
New Revision: 32820
Removed:
   grass/trunk/raster/r.surf.fractal/interface.c
   grass/trunk/doc/raster/r.example/main.c
   grass/trunk/general/g.region/main.c
   grass/trunk/imagery/i.cca/main.c
   grass/trunk/imagery/i.fft/main.c
   grass/trunk/imagery/i.ifft/main.c
   grass/trunk/imagery/i.zc/main.c
   grass/trunk/raster/r.average/main.c
   grass/trunk/raster/r.bitpattern/main.c
   grass/trunk/raster/r.buffer/main.c
   grass/trunk/raster/r.clump/main.c
   grass/trunk/raster/r.cost/main.c
   grass/trunk/raster/r.in.ascii/main.c
   grass/trunk/raster/r.in.gdal/main.c
   grass/trunk/raster/r.in.mat/main.c
   grass/trunk/raster/r.kappa/main.c
   grass/trunk/raster/r.los/main.c
   grass/trunk/raster/r.median/main.c
   grass/trunk/raster/r.mode/main.c
   grass/trunk/raster/r.neighbors/main.c
   grass/trunk/raster/r.random.cells/init.c
   grass/trunk/raster/r.random.surface/init.c
   grass/trunk/raster/r.random.surface/local_proto.h
   grass/trunk/raster/r.random.surface/main.c
   grass/trunk/raster/r.random.surface/ransurf.h
   grass/trunk/raster/r.random/main.c
   grass/trunk/raster/r.reclass/main.c
   grass/trunk/raster/r.recode/main.c
   grass/trunk/raster/r.resample/main.c
   grass/trunk/raster/r.rescale.eq/main.c
   grass/trunk/raster/r.rescale/main.c
   grass/trunk/raster/r.slope.aspect/opennew.c
   grass/trunk/raster/r.surf.fractal/main.c
   grass/trunk/raster/r.surf.gauss/main.c
   grass/trunk/raster/r.surf.idw/main.c
   grass/trunk/raster/r.surf.idw2/main.c
   grass/trunk/raster/r.surf.random/main.c
   grass/trunk/raster/r.texture/main.c
   grass/trunk/raster/r.to.rast3/main.c
   grass/trunk/raster/r.to.rast3elev/main.c
   grass/trunk/raster/r.walk/main.c
   grass/trunk/raster/r.water.outlet/legal.c
   grass/trunk/raster/r.water.outlet/main.c
   grass/trunk/raster/r.watershed/ram/Gwater.h
   grass/trunk/raster/r.watershed/ram/init_vars.c
   grass/trunk/raster/r.watershed/seg/Gwater.h
   grass/trunk/raster/r.watershed/seg/init_vars.c
   grass/trunk/raster/wildfire/r.ros/main.c
   grass/trunk/raster/wildfire/r.spread/main.c
   grass/trunk/raster/wildfire/r.spreadpath/main.c
   grass/trunk/raster3d/r3.cross.rast/main.c
   grass/trunk/raster3d/r3.mkdspf/r3_find.c
   grass/trunk/raster3d/r3.showdspf/r3_find.c
   grass/trunk/raster3d/r3.to.rast/main.c
   grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/opennew.c
   grass/trunk/vector/v.edit/main.c
   grass/trunk/vector/v.in.ogr/main.c
   grass/trunk/vector/v.kernel/main.c
   grass/trunk/vector/v.surf.idw/main.c
   grass/trunk/vector/v.to.rast3/main.c
G_legal_filename() is for files, not maps
Modified: grass/trunk/doc/raster/r.example/main.c
--- grass/trunk/doc/raster/r.example/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/doc/raster/r.example/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -110,10 +110,6 @@
     if (mapset == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), name);
-    if (G_legal_filename(result) < 0)
-	G_fatal_error(_("<%s> is an illegal file name"), result);
     /* determine the inputmap type (CELL/FCELL/DCELL) */
     data_type = G_raster_map_type(name, mapset);
Modified: grass/trunk/general/g.region/main.c
--- grass/trunk/general/g.region/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/general/g.region/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -778,8 +778,6 @@
     /* save= */
     if ((name = parm.save->answer)) {
-	if (G_legal_filename(name) < 0)
-	    G_fatal_error(_("<%s> is an illegal region name"), name);
 	G_copy(&temp_window, &window, sizeof(window));
 	adjust_window(&temp_window, 0, 0, 0);
 	if (G__put_window(&temp_window, "windows", name) < 0)
Modified: grass/trunk/imagery/i.cca/main.c
--- grass/trunk/imagery/i.cca/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/imagery/i.cca/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -103,18 +103,6 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-    if (G_legal_filename(grp_opt->answer) < 0)
-	G_fatal_error(_("Illegal group name <%s>"), grp_opt->answer);
-    if (G_legal_filename(subgrp_opt->answer) < 0)
-	G_fatal_error(_("Illegal subgroup name <%s>"), subgrp_opt->answer);
-    if (G_legal_filename(sig_opt->answer) < 0)
-	G_fatal_error(_("Illegal signature file name <%s>"), sig_opt->answer);
-    if (G_legal_filename(out_opt->answer) < 0)
-	G_fatal_error(_("Illegal output file name <%s>"), out_opt->answer);
     /* check group, subgroup */
     I_init_group_ref(&refs);
     if (I_find_group(grp_opt->answer) <= 0)
Modified: grass/trunk/imagery/i.fft/main.c
--- grass/trunk/imagery/i.fft/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/imagery/i.fft/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -125,15 +125,6 @@
 	G_warning(_("Raster MASK found, consider to remove "
 		    "(see man-page). Will continue..."));
-    /* check command line args for validity */
-    if (G_legal_filename(Cellmap_real) < 0)
-	G_fatal_error(_("Illegal file name for real part: %s"), Cellmap_real);
-    if (G_legal_filename(Cellmap_imag) < 0)
-	G_fatal_error(_("Illegal file name for imaginary part: %s"),
-		      Cellmap_imag);
     sscanf(op4->answer, "%d", &Range);
     if (Range <= 0)
 	G_fatal_error(_("Range less than or equal to zero not allowed."));
Modified: grass/trunk/imagery/i.ifft/main.c
--- grass/trunk/imagery/i.ifft/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/imagery/i.ifft/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -102,10 +102,6 @@
 			  imagmapset)) == NULL)
 	G_fatal_error(_("Unable to open imaginary-image in the cell_misc directory.\nInput map probably wasn't created by i.fft"));
-    if (G_legal_filename(Cellmap_orig) < 0)
-	G_fatal_error(_("<%s> is an illegal file name"), Cellmap_orig);
     /* get and compare the original window data */
     get_orig_window(&orig_wind, realmapset, imagmapset);
Modified: grass/trunk/imagery/i.zc/main.c
--- grass/trunk/imagery/i.zc/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/imagery/i.zc/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -107,10 +107,6 @@
     if (inputfd < 0)
 	exit(EXIT_FAILURE);
-    if (G_legal_filename(output_map->answer) < 0)
-	G_fatal_error(_("<%s> is an illegal file name"), output_map->answer);
     sscanf(threshold->answer, "%1lf", &Thresh);
     if (Thresh <= 0.0)
 	G_fatal_error(_("Threshold less than or equal to zero not allowed"));
Modified: grass/trunk/raster/r.average/main.c
--- grass/trunk/raster/r.average/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.average/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -74,9 +74,6 @@
     if (!(mapset = G_find_cell(covermap->answer, "")))
 	G_fatal_error(_("Raster map <%s> not found"), covermap->answer);
-    if (G_legal_filename(outputmap->answer) < 0)
-	G_fatal_error(_("<%s> is an illegal file name"), outputmap->answer);
     if ((usecats = flag_c->answer)) {
 	if (G_read_cats(covermap->answer, mapset, &cats) < 0)
 	    G_fatal_error(_("Error reading category file for <%s>"),
Modified: grass/trunk/raster/r.bitpattern/main.c
--- grass/trunk/raster/r.bitpattern/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.bitpattern/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -100,9 +100,6 @@
     if (mapset == NULL)
     /*if Gispf() error */
     if ((infd = G_open_cell_old(name, mapset)) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), name);
Modified: grass/trunk/raster/r.buffer/main.c
--- grass/trunk/raster/r.buffer/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.buffer/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -99,9 +99,6 @@
     if (mapset == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), input);
-    if (G_legal_filename(output) < 0)
-	G_fatal_error(_("<%s> is an illegal file name"), output);
     /* parse units */
     if (opt4->answer == NULL)
 	units = "meters";
Modified: grass/trunk/raster/r.clump/main.c
--- grass/trunk/raster/r.clump/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.clump/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -72,9 +72,6 @@
     if (!mapset)
 	G_fatal_error(_("Raster map <%s> not found"), INPUT);
-    if (G_legal_filename(OUTPUT) < 0)
-	G_fatal_error(_("<%s> is an illegal file name"), OUTPUT);
     in_fd = G_open_cell_old(name, mapset);
     if (in_fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), INPUT);
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.cost/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -316,11 +316,6 @@
     if (cost_mapset == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), cost_layer);
-    /*  Check if specified output layer name is legal   */
-    if (G_legal_filename(cum_cost_layer) < 0)
-	G_fatal_error(_("<%s> is an illegal file name"), cum_cost_layer);
     /*  Find number of rows and columns in window    */
     nrows = G_window_rows();
Modified: grass/trunk/raster/r.in.ascii/main.c
--- grass/trunk/raster/r.in.ascii/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.in.ascii/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -199,8 +199,6 @@
     rast_ptr = G_allocate_raster_buf(data_type);
     rast = rast_ptr;
     cf = G_open_raster_new(output, data_type);
     if (cf < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), output);
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.in.gdal/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -195,17 +195,12 @@
 	exit(EXIT_SUCCESS);
-    if (!input) {
+    if (!input)
 	G_fatal_error(_("Required parameter <%s> not set"), parm.input->key);
-    if (!output) {
+    if (!output)
 	G_fatal_error(_("Name for output raster map not specified"));
     if (!parm.outloc->answer) {	/* Check if the map exists */
 	if (G_find_cell2(output, G_mapset())) {
 	    if (overwrite)
Modified: grass/trunk/raster/r.in.mat/main.c
--- grass/trunk/raster/r.in.mat/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.in.mat/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -368,8 +368,6 @@
     G_strip(map_name);		/* remove leading and trailing whitespace */
-    if (G_legal_filename(map_name) != 1)
-	G_fatal_error(_("<%s> is an illegal file name"), map_name);
     /* set region info */
Modified: grass/trunk/raster/r.kappa/main.c
--- grass/trunk/raster/r.kappa/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.kappa/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -95,15 +95,7 @@
     for (i = 0; i < 2; i++)
 	layer(maps[i]);
-    if (parms.output->answer) {
-	output = parms.output->answer;
-	if (G_legal_filename(output) < 0) {
-			  parms.output->answer);
-    else
-	output = NULL;
+    output = parms.output->answer;
     title = parms.titles->answer;
Modified: grass/trunk/raster/r.los/main.c
--- grass/trunk/raster/r.los/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.los/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -174,10 +174,6 @@
 	    G_fatal_error(_("Raster map <%s> not found"), patt_layer);
-    /* check if specified output layer name is legal    */
-    if (G_legal_filename(out_layer) < 0)
-	G_fatal_error(_("<%s> is an illegal file name"), out_layer);
     /*  read header info for elevation layer        */
     if (G_get_cellhd(elev_layer, old_mapset, &cellhd_elev) < 0)
 	G_fatal_error(_("[%s]: Cannot read map header"), elev_layer);
Modified: grass/trunk/raster/r.median/main.c
--- grass/trunk/raster/r.median/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.median/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -73,8 +73,7 @@
     cover_mapset = G_find_cell2(covermap, "");
     if (cover_mapset == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), covermap);
-    if (G_legal_filename(outmap) < 0)
-	G_fatal_error(_("<%s> is an illegal file name"), outmap);
     if (strcmp(G_mapset(), base_mapset) == 0 && strcmp(basemap, outmap) == 0)
 	G_fatal_error(_("Base map and output map <%s> must be different"),
 		      outmap);
Modified: grass/trunk/raster/r.mode/main.c
--- grass/trunk/raster/r.mode/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.mode/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -90,9 +90,7 @@
     if (cover_mapset == NULL) {
 	G_fatal_error(_("%s: cover raster map not found"), covermap);
-    if (G_legal_filename(outmap) < 0) {
     if (strcmp(G_mapset(), base_mapset) == 0 && strcmp(basemap, outmap) == 0) {
 	G_fatal_error(_("%s: base map and output map must be different"),
 		      outmap);
Modified: grass/trunk/raster/r.neighbors/main.c
--- grass/trunk/raster/r.neighbors/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.neighbors/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -176,9 +176,6 @@
 	G_fatal_error(_("Raster map <%s> not found"), p);
     p = ncb.newcell.name = parm.output->answer;
-    if (G_legal_filename(p) < 0) {
-	G_fatal_error(_("<%s> is an illegal file name"), p);
     ncb.newcell.mapset = G_mapset();
     if (!flag.align->answer) {
Modified: grass/trunk/raster/r.random/main.c
--- grass/trunk/raster/r.random/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.random/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -136,16 +136,6 @@
 	G_fatal_error(_("Note: one (or both) of %s and %s must be specified"),
 		      parm.raster->key, parm.sites->key);
-    if (myState.outraster)
-	if (G_legal_filename(myState.outraster) < 0)
-			  myState.outraster);
-    if (myState.outvector)
-	if (G_legal_filename(myState.outvector) < 0)
-			  myState.outvector);
     /* look for n[%] */
     percent = has_percent(parm.npoints->answer);
     if (percent) {
Modified: grass/trunk/raster/r.random.cells/init.c
--- grass/trunk/raster/r.random.cells/init.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.random.cells/init.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -13,7 +13,6 @@
 /* function prototypes */
 static int comp_array(const void *p1, const void *p2);
-static void IsLegal(char *Name);
 void Init(int argc, char **argv)
@@ -98,13 +97,6 @@
 	CellCount = Rs * Cs;
-    if (!Output->answer) {
-	G_fatal_error("There should be an output map");
-    else {
-	IsLegal(Output->answer);
     sscanf(Distance->answer, "%lf", &MaxDist);
     if (MaxDist < 0.0)
 	G_fatal_error("distance must be >= 0.0");
@@ -157,10 +149,3 @@
     return (0);
-    if (G_legal_filename(Name) == -1)
-	G_fatal_error("%s: map name [%s] not legal for GRASS",
-		      G_program_name(), Name);
Modified: grass/trunk/raster/r.random.surface/init.c
--- grass/trunk/raster/r.random.surface/init.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.random.surface/init.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -15,17 +15,9 @@
 #include "local_proto.h"
-/* function prototypes */
-void Init(int argc, char **argv)
+void Init(void)
-    struct Option *Output;
-    /*    struct Option     *TheoryS; */
-    struct Option *range_high_stuff;
-    struct Option *SeedStuff;
     struct Cell_head Region;
     int row, col, i, j, NumWeight, NumDist, NumExp;
     char *Name, *Number, String[80];
@@ -34,69 +26,6 @@
     FUNCTION(Init);
-    Output = G_define_option();
-    Output->key = "output";
-    Output->type = TYPE_STRING;
-    Output->required = YES;
-    Output->multiple = YES;
-    Output->description = "Names of the resulting maps";
-    Output->gisprompt = "new,cell,raster";
-       TheoryS              = G_define_option() ;
-       TheoryS->key         = "theoretical_correlogram";
-       TheoryS->type        = TYPE_STRING;
-       TheoryS->required    = NO;
-       TheoryS->multiple    = NO;
-       TheoryS->description = "Name of the resulting theoretical correlogram map";
-       TheoryS->gisprompt  = "new,cell,raster" ;
-    Distance = G_define_option();
-    Distance->key = "distance";
-    Distance->type = TYPE_DOUBLE;
-    Distance->required = NO;
-    Distance->multiple = NO;
-    Distance->description =
-	"Input value: max. distance of spatial correlation (value >= 0.0, default [0.0])";
-    Exponent = G_define_option();
-    Exponent->key = "exponent";
-    Exponent->type = TYPE_DOUBLE;
-    Exponent->multiple = NO;
-    Exponent->required = NO;
-    Exponent->description =
-	"Input value: distance decay exponent (value > 0.0), default [1.0])";
-    Weight = G_define_option();
-    Weight->key = "flat";
-    Weight->type = TYPE_DOUBLE;
-    Weight->multiple = NO;
-    Weight->required = NO;
-    Weight->description =
-	"Input value: distance filter remains flat before beginning exponent, default [0.0]";
-    SeedStuff = G_define_option();
-    SeedStuff->key = "seed";
-    SeedStuff->type = TYPE_INTEGER;
-    SeedStuff->required = NO;
-    SeedStuff->description =
-	"Input value: random seed (SEED_MIN >= value >= SEED_MAX), default [random]";
-    range_high_stuff = G_define_option();
-    range_high_stuff->key = "high";
-    range_high_stuff->type = TYPE_INTEGER;
-    range_high_stuff->required = NO;
-    range_high_stuff->description =
-	"Input value: maximum cell value of distribution, default [255]";
-    Uniform = G_define_flag();
-    Uniform->key = 'u';
-    Uniform->description = "Uniformly distributed cell values";
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
     Rs = G_window_rows();
     Cs = G_window_cols();
     Surface = (double **)G_malloc(Rs * sizeof(double *));
@@ -153,7 +82,6 @@
     NumMaps = 0;
     OutNames = (char **)G_malloc(sizeof(char *));
     for (i = 0; (Name = Output->answers[i]); i++) {
-	IsLegal(Name);
 	for (j = i - 1; j >= 0; j--) {
 	    if (strcmp(OutNames[j], Name) == 0)
 		G_fatal_error
@@ -170,12 +98,6 @@
 	G_fatal_error("%s: requires an output map", G_program_name());
     Theory = 0;
-       TheoryName = TheoryS->answer;
-       if (G_legal_filename (TheoryName) != -1) {
-       Theory++;
     NumSeeds = 0;
     Seeds = (int *)G_malloc(NumMaps * sizeof(int));
     if (!SeedStuff->answers) {
@@ -412,10 +334,3 @@
     AllMaxDist *= 2.0;
Modified: grass/trunk/raster/r.random.surface/local_proto.h
--- grass/trunk/raster/r.random.surface/local_proto.h	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.random.surface/local_proto.h	2008-08-16 16:08:08 UTC (rev 32820)
@@ -28,7 +28,7 @@
 void GenNorm(void);
 /* init.c */
-void Init(int argc, char **argv);
+void Init(void);
 /* makebigf.c */
 void MakeBigF(void);
Modified: grass/trunk/raster/r.random.surface/main.c
--- grass/trunk/raster/r.random.surface/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.random.surface/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -42,14 +42,15 @@
 char Buf[240], **OutNames, *TheoryName, *Mapset;
 struct Flag *Uniform;
-    /* please, remove before GRASS 7 released */
 struct Option *Distance, *Exponent, *Weight;
+struct Option *Output;
+struct Option *range_high_stuff;
+struct Option *SeedStuff;
 int main(int argc, char **argv)
     struct GModule *module;
     int DoMap, DoFilter, MapSeed;
-    double ran1();
     FUNCTION(main);
@@ -60,7 +61,59 @@
     module->description =
 	_("Generates random surface(s) with spatial dependence.");
-    Init(argc, argv);
+    Output = G_define_option();
+    Output->key = "output";
+    Output->type = TYPE_STRING;
+    Output->required = YES;
+    Output->multiple = YES;
+    Output->description = "Names of the resulting maps";
+    Output->gisprompt = "new,cell,raster";
+    Distance = G_define_option();
+    Distance->key = "distance";
+    Distance->type = TYPE_DOUBLE;
+    Distance->required = NO;
+    Distance->multiple = NO;
+    Distance->description =
+	"Input value: max. distance of spatial correlation (value >= 0.0, default [0.0])";
+    Exponent = G_define_option();
+    Exponent->key = "exponent";
+    Exponent->type = TYPE_DOUBLE;
+    Exponent->multiple = NO;
+    Exponent->required = NO;
+    Exponent->description =
+	"Input value: distance decay exponent (value > 0.0), default [1.0])";
+    Weight = G_define_option();
+    Weight->key = "flat";
+    Weight->type = TYPE_DOUBLE;
+    Weight->multiple = NO;
+    Weight->required = NO;
+    Weight->description =
+	"Input value: distance filter remains flat before beginning exponent, default [0.0]";
+    SeedStuff = G_define_option();
+    SeedStuff->key = "seed";
+    SeedStuff->type = TYPE_INTEGER;
+    SeedStuff->required = NO;
+    SeedStuff->description =
+	"Input value: random seed (SEED_MIN >= value >= SEED_MAX), default [random]";
+    range_high_stuff = G_define_option();
+    range_high_stuff->key = "high";
+    range_high_stuff->type = TYPE_INTEGER;
+    range_high_stuff->required = NO;
+    range_high_stuff->description =
+	"Input value: maximum cell value of distribution, default [255]";
+    Uniform = G_define_flag();
+    Uniform->key = 'u';
+    Uniform->description = "Uniformly distributed cell values";
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
     if (Uniform->answer)
 	GenNorm();
     CalcSD();
Modified: grass/trunk/raster/r.random.surface/ransurf.h
--- grass/trunk/raster/r.random.surface/ransurf.h	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.random.surface/ransurf.h	2008-08-16 16:08:08 UTC (rev 32820)
@@ -50,6 +50,9 @@
 extern struct Flag *Verbose;
 extern struct Option *Distance, *Exponent, *Weight;
+extern struct Option *Output;
+extern struct Option *range_high_stuff;
+extern struct Option *SeedStuff;
 #ifdef DEBUG
 #define INDX(a,b) (printf("(a)[%d]:%lf ",(b),(a)[(b)]))
Modified: grass/trunk/raster/r.reclass/main.c
--- grass/trunk/raster/r.reclass/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.reclass/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -77,9 +77,6 @@
     if (old_mapset == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), parm.input->answer);
-    if (G_legal_filename(parm.output->answer) < 0)
-	G_fatal_error(_("<%s> is an illegal file name"), parm.output->answer);
     if (strcmp(parm.input->answer, parm.output->answer) == 0 &&
 	strcmp(old_mapset, G_mapset()) == 0)
 	G_fatal_error(_("Input map can NOT be the same as output map"));
Modified: grass/trunk/raster/r.recode/main.c
--- grass/trunk/raster/r.recode/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.recode/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -90,9 +90,6 @@
     if (mapset == NULL)
     if (strcmp(name, result) == 0 && strcmp(mapset, G_mapset()) == 0)
Modified: grass/trunk/raster/r.resample/main.c
--- grass/trunk/raster/r.resample/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.resample/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -82,9 +82,6 @@
     if (mapset == NULL)
-	G_fatal_error("<%s> is an illegal file name", result);
     hist_ok = G_read_history(name, mapset, &hist) >= 0;
     colr_ok = G_read_colors(name, mapset, &colr) > 0;
     cats_ok = G_read_cats(name, mapset, &cats) >= 0;
Modified: grass/trunk/raster/r.rescale/main.c
--- grass/trunk/raster/r.rescale/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.rescale/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -94,10 +94,6 @@
 	sprintf(buf, "%s - not found\n", old_name);
 	G_fatal_error(buf);
-    if (G_legal_filename(new_name) < 0) {
-	sprintf(buf, "%s - illegal map name\n", new_name);
-	G_fatal_error(buf);
     if (parm.from->answer) {
 	sscanf(parm.from->answers[0], "%ld", &old_min);
Modified: grass/trunk/raster/r.rescale.eq/main.c
--- grass/trunk/raster/r.rescale.eq/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.rescale.eq/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -98,10 +98,6 @@
 	G_fatal_error(buf);
     get_stats(old_name, mapset, &statf);
Modified: grass/trunk/raster/r.slope.aspect/opennew.c
--- grass/trunk/raster/r.slope.aspect/opennew.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.slope.aspect/opennew.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -7,9 +7,6 @@
     int fd;
-	G_fatal_error(_("<%s> is an illegal file name"), name);
     if (wr_type < 0)		/* default fp type */
 	fd = G_open_fp_cell_new(name);
     else
Deleted: grass/trunk/raster/r.surf.fractal/interface.c
--- grass/trunk/raster/r.surf.fractal/interface.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.surf.fractal/interface.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -1,111 +0,0 @@
-/***      Function to get input from user and check files can be opened   ***/
-/***                    Jo Wood,  V1.0, 13th September 1994               ***/
-#include <stdlib.h>
-#include <stdio.h>
-#include "frac.h"
-#include <grass/gis.h>
-#include <grass/glocale.h>
-int interface(int argc,		/* Number of command line arguments     */
-	      char *argv[]	/* Contents of command line arguments.  */
-    /*                               INITIALISE                            */
-    struct GModule *module;
-    struct Option *rast_out;	/* Structure for output raster     */
-    struct Option *frac_dim;	/* Fractal dimension of surface.   */
-    struct Option *num_images;	/* Number of images to produce.    */
-    G_gisinit(argv[0]);		/* Link with GRASS interface.      */
-    module = G_define_module();
-    module->keywords = _("raster");
-    module->description =
-	_("Creates a fractal surface of a given fractal dimension.");
-    /*                              SET PARSER OPTIONS                     */
-    rast_out = G_define_option();
-    frac_dim = G_define_option();
-    num_images = G_define_option();
-    /* Each option needs a 'key' (short description),
-       a 'description` (a longer one),
-       a 'type' (eg intiger, or string),
-       and an indication whether manditory or not */
-    rast_out->key = "out";
-    rast_out->description = _("Name of fractal surface raster layer");
-    rast_out->type = TYPE_STRING;
-    rast_out->required = YES;
-    frac_dim->key = "d";
-    frac_dim->description = _("Fractal dimension of surface (2 < D < 3)");
-    frac_dim->type = TYPE_DOUBLE;
-    frac_dim->required = NO;
-    frac_dim->answer = "2.05";
-    num_images->key = "n";
-    num_images->description = _("Number of intermediate images to produce");
-    num_images->type = TYPE_INTEGER;
-    num_images->required = NO;
-    num_images->answer = "0";
-    if (G_parser(argc, argv))	/* Performs the prompting for      */
-	exit(EXIT_FAILURE);	/* keyboard input.                 */
-    rast_out_name = rast_out->answer;
-    sscanf(frac_dim->answer, "%lf", &H);
-    H = 3.0 - H;
-    Steps = atoi(num_images->answer) + 1;
-    G_message(_("Steps=%d"), Steps);
-    /*                  CHECK OUTPUT RASTER FILE DOES NOT EXIST           */
-    mapset_out = G_mapset();	/* Set output to current mapset.  */
-    if (G_legal_filename(rast_out_name) == '\0') {
-	G_fatal_error(_("<%s> is an illegal file name"), rast_out_name);
-    /*               CHECK FRACTAL DIMENSION IS WITHIN LIMITS             */
-    if ((H <= 0) || (H >= 1)) {
-	G_fatal_error(_("Fractal dimension of [%.2lf] must be between 2 and 3."),
-		      3.0 - H);
-    /*        MAKE SURE NUMBER OF IMAGES <= NUMBER OF FOURIER COEFF.      */
-    /* TODO */
-    return 0;
Modified: grass/trunk/raster/r.surf.fractal/main.c
--- grass/trunk/raster/r.surf.fractal/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.surf.fractal/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -12,6 +12,7 @@
+#include <grass/glocale.h>
 #include "frac.h"
 char
@@ -26,8 +27,61 @@
 int main(int argc, char *argv[])
+    struct GModule *module;
+    struct Option *rast_out;	/* Structure for output raster     */
+    struct Option *frac_dim;	/* Fractal dimension of surface.   */
+    struct Option *num_images;	/* Number of images to produce.    */
-    interface(argc, argv);
+    G_gisinit(argv[0]);		/* Link with GRASS interface.      */
+    module = G_define_module();
+    module->keywords = _("raster");
+    module->description =
+	_("Creates a fractal surface of a given fractal dimension.");
+    rast_out = G_define_option();
+    rast_out->key = "out";
+    rast_out->description = _("Name of fractal surface raster layer");
+    rast_out->type = TYPE_STRING;
+    rast_out->required = YES;
+    frac_dim = G_define_option();
+    frac_dim->key = "d";
+    frac_dim->description = _("Fractal dimension of surface (2 < D < 3)");
+    frac_dim->type = TYPE_DOUBLE;
+    frac_dim->required = NO;
+    frac_dim->answer = "2.05";
+    num_images = G_define_option();
+    num_images->key = "n";
+    num_images->description = _("Number of intermediate images to produce");
+    num_images->type = TYPE_INTEGER;
+    num_images->required = NO;
+    num_images->answer = "0";
+    if (G_parser(argc, argv))	/* Performs the prompting for      */
+	exit(EXIT_FAILURE);	/* keyboard input.                 */
+    rast_out_name = rast_out->answer;
+    sscanf(frac_dim->answer, "%lf", &H);
+    H = 3.0 - H;
+    Steps = atoi(num_images->answer) + 1;
+    G_message(_("Steps=%d"), Steps);
+    mapset_out = G_mapset();	/* Set output to current mapset.  */
+    /*               CHECK FRACTAL DIMENSION IS WITHIN LIMITS             */
+    if ((H <= 0) || (H >= 1)) {
+	G_fatal_error(_("Fractal dimension of [%.2lf] must be between 2 and 3."),
+		      3.0 - H);
     process();
     return EXIT_SUCCESS;
Modified: grass/trunk/raster/r.surf.gauss/main.c
--- grass/trunk/raster/r.surf.gauss/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.surf.gauss/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -72,10 +72,6 @@
     sscanf(mean->answer, "%lf", &gauss_mean);
     sscanf(sigma->answer, "%lf", &gauss_sigma);
-    /****** CHECK THE CELL FILE (OUT) DOES NOT ALREADY EXIST******/
-    if (G_legal_filename(out->answer) == '\0')
-	G_fatal_error(_("<%s> is an illegal file name"), out->answer);
     /****** CREATE THE RANDOM CELL FILE  ******/
     gaussurf(out->answer, gauss_mean, gauss_sigma);
Modified: grass/trunk/raster/r.surf.idw/main.c
--- grass/trunk/raster/r.surf.idw/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.surf.idw/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -143,10 +143,6 @@
     if (layer_mapset == NULL)
     /*  find number of rows and columns in window                   */
     ncols = G_window_cols();
Modified: grass/trunk/raster/r.surf.idw2/main.c
--- grass/trunk/raster/r.surf.idw2/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.surf.idw2/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -79,9 +79,6 @@
     if ((G_projection() == PROJECTION_LL))
 	G_fatal_error(_("Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"));
     if (sscanf(parm.npoints->answer, "%d", &search_points) != 1 ||
 	search_points < 1)
 	G_fatal_error(_("%s=%s - illegal number of interpolation points"),
Modified: grass/trunk/raster/r.surf.random/main.c
--- grass/trunk/raster/r.surf.random/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.surf.random/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -69,10 +69,6 @@
 	exit(EXIT_FAILURE);	/* Returns a 0 if sucessful */
-    if (G_legal_filename(out->answer) != 1)
-	G_fatal_error("Illegal file name. Please try another.");
     randsurf(out->answer, atoi(min->answer), atoi(max->answer),
 	     i_flag->answer);
Modified: grass/trunk/raster/r.texture/main.c
--- grass/trunk/raster/r.texture/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.texture/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -212,9 +212,6 @@
     if (mapset == NULL)
Modified: grass/trunk/raster/r.to.rast3/main.c
--- grass/trunk/raster/r.to.rast3/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.to.rast3/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -235,10 +235,6 @@
     if (fd == NULL)
 	fatal_error(map, NULL, 0, _("Out of memory"));
-    if (G_legal_filename(param.output->answer) < 0)
-	fatal_error(map, NULL, 0, _("Illegal output file name"));
     mapset = NULL;
     name = NULL;
Modified: grass/trunk/raster/r.to.rast3elev/main.c
--- grass/trunk/raster/r.to.rast3elev/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.to.rast3elev/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -468,10 +468,6 @@
 	G_set_window(&window2d);
-	G3d_fatalError(_("<%s> is an illegal file name"),
-		       param.output->answer);
     G_debug(2, "Open 3d raster map %s", param.output->answer);
     /*open G3D output map */
Modified: grass/trunk/raster/r.walk/main.c
--- grass/trunk/raster/r.walk/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.walk/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -538,11 +538,6 @@
Modified: grass/trunk/raster/r.water.outlet/legal.c
--- grass/trunk/raster/r.water.outlet/legal.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.water.outlet/legal.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -2,18 +2,6 @@
-int do_legal(char *file_name)
-    char *buf;
-    if (G_legal_filename(file_name) == -1) {
-	G_asprintf(&buf, _("<%s> is an illegal file name"), file_name);
-    return 0;
 char *do_exist(char *file_name)
     char *buf, *file_mapset;
Modified: grass/trunk/raster/r.water.outlet/main.c
--- grass/trunk/raster/r.water.outlet/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.water.outlet/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -125,7 +125,7 @@
     dr_f = ba_f = N_f = E_f = errr = 0;
     drain_mapset = do_exist(drain_name);
-    do_legal(basin_name);
     total = nrows * ncols;
Modified: grass/trunk/raster/r.watershed/ram/Gwater.h
--- grass/trunk/raster/r.watershed/ram/Gwater.h	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.watershed/ram/Gwater.h	2008-08-16 16:08:08 UTC (rev 32820)
@@ -99,7 +99,6 @@
 /* init_vars.c */
 int init_vars(int, char *[]);
-int do_legal(char *);
 char *do_exist(char *);
 /* no_stream.c */
Modified: grass/trunk/raster/r.watershed/ram/init_vars.c
--- grass/trunk/raster/r.watershed/ram/init_vars.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.watershed/ram/init_vars.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -83,20 +83,6 @@
 	tot_parts++;
     G_message(_("SECTION 1a (of %1d): Initiating Memory."), tot_parts);
     this_mapset = G_mapset();
-    if (asp_flag)
-	do_legal(asp_name);
-    if (bas_flag)
-	do_legal(bas_name);
-    if (seg_flag)
-	do_legal(seg_name);
-    if (haf_flag)
-	do_legal(haf_name);
-    if (sl_flag)
-	do_legal(sl_name);
-    if (sg_flag)
-	do_legal(sg_name);
-    if (ls_flag)
-	do_legal(ls_name);
     if (sl_flag || sg_flag || ls_flag)
 	er_flag = 1;
     ele_mapset = do_exist(ele_name);
@@ -382,14 +368,6 @@
     return 0;
-	G_fatal_error(_("<%s> is an illegal file name"), file_name);
-    return 0;
     char *file_mapset = G_find_cell2(file_name, "");
Modified: grass/trunk/raster/r.watershed/seg/Gwater.h
--- grass/trunk/raster/r.watershed/seg/Gwater.h	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.watershed/seg/Gwater.h	2008-08-16 16:08:08 UTC (rev 32820)
@@ -92,7 +92,6 @@
 /* init_vars.c */
 /* no_stream.c */
Modified: grass/trunk/raster/r.watershed/seg/init_vars.c
--- grass/trunk/raster/r.watershed/seg/init_vars.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/r.watershed/seg/init_vars.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -10,8 +10,7 @@
     SHORT r, c;
     int fd, num_cseg_total, num_cseg, num_cseg_bytes;
     CELL *buf, alt_value, wat_value, asp_value, worked_value;
-    extern FILE *fopen();
-    char MASK_flag, *do_exist();
+    char MASK_flag;
     G_gisinit(argv[0]);
     ele_flag = wat_flag = asp_flag = pit_flag = run_flag = ril_flag = 0;
@@ -89,20 +88,6 @@
 	      tot_parts);
-    if (asp_flag)
-    if (bas_flag)
-    if (seg_flag)
-    if (haf_flag)
-    if (sl_flag)
-    if (sg_flag)
-    if (ls_flag)
 	er_flag = 1;
@@ -411,14 +396,6 @@
     return 0;
-    return 0;
Modified: grass/trunk/raster/wildfire/r.ros/main.c
--- grass/trunk/raster/wildfire/r.ros/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/wildfire/r.ros/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -410,10 +410,6 @@
-    /*  Check if specified output layer name IS LEGAL  */
-	G_fatal_error("%s - illegal name", parm.output->answer);
     /*assign names of the three output ROS layers */
     sprintf(name_base, "%s.base", parm.output->answer);
     sprintf(name_max, "%s.max", parm.output->answer);
Modified: grass/trunk/raster/wildfire/r.spread/main.c
--- grass/trunk/raster/wildfire/r.spread/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/wildfire/r.spread/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -337,9 +337,7 @@
     /*  Get database window parameters  */
     if (G_get_window(&window) < 0) {
-	sprintf(buf, "can't read current window parameters");
+	G_fatal_error("can't read current window parameters");
@@ -359,136 +357,64 @@
     /*  Check if input layers exists in data base  */
     if (G_find_cell2(max_layer, "") == NULL) {
-	sprintf(buf, "Raster map <%s> not found", max_layer);
+	G_fatal_error("Raster map <%s> not found", max_layer);
     if (G_find_cell2(dir_layer, "") == NULL) {
-	sprintf(buf, _("Raster map <%s> not found"), dir_layer);
+	G_fatal_error(_("Raster map <%s> not found"), dir_layer);
     if (G_find_cell2(base_layer, "") == NULL) {
-	sprintf(buf, _("Raster map <%s> not found"), base_layer);
+	G_fatal_error(_("Raster map <%s> not found"), base_layer);
     if (G_find_cell2(start_layer, "") == NULL) {
-	sprintf(buf, _("Raster map <%s> not found"), start_layer);
+	G_fatal_error(_("Raster map <%s> not found"), start_layer);
     if (spotting) {
 	if (G_find_cell2(spotdist_layer, "") == NULL) {
-	    sprintf(buf, _("Raster map <%s> not found"), spotdist_layer);
+	    G_fatal_error(_("Raster map <%s> not found"), spotdist_layer);
 	if (G_find_cell2(velocity_layer, "") == NULL) {
-	    sprintf(buf, _("Raster map <%s> not found"), velocity_layer);
+	    G_fatal_error(_("Raster map <%s> not found"), velocity_layer);
 	if (G_find_cell2(mois_layer, "") == NULL) {
-	    sprintf(buf, _("Raster map <%s> not found"), mois_layer);
+	    G_fatal_error(_("Raster map <%s> not found"), mois_layer);
-    /*  Check if specified output layer names ARE LEGAL or EXISTS   */
-    if (G_legal_filename(out_layer) < 0) {
-	sprintf(buf, _("<%s> is an illegal file name"), out_layer);
-    if (G_find_cell2(out_layer, G_mapset())) {
-	sprintf(buf,
-		_("Raster map <%s> already exists in mapset <%s>, select another name"),
-		out_layer, G_mapset());
-    if (x_out) {
-	if (G_legal_filename(x_out_layer) < 0) {
-	    sprintf(buf, _("<%s> is an illegal file name"), x_out_layer);
-	if (G_find_cell2(x_out_layer, G_mapset())) {
-	    sprintf(buf,
-		    x_out_layer, G_mapset());
-    if (y_out) {
-	if (G_legal_filename(y_out_layer) < 0) {
-	    sprintf(buf, _("<%s> is an illegal file name"), y_out_layer);
-	if (G_find_cell2(y_out_layer, G_mapset())) {
-	    sprintf(buf,
-		    y_out_layer, G_mapset());
     /*  Open input cell layers for reading  */
     max_fd = G_open_cell_old(max_layer, G_find_cell2(max_layer, ""));
     if (max_fd < 0) {
-	sprintf(buf, _("Unable to open raster map <%s>"), max_layer);
+	G_fatal_error(_("Unable to open raster map <%s>"), max_layer);
     dir_fd = G_open_cell_old(dir_layer, G_find_cell2(dir_layer, ""));
     if (dir_fd < 0) {
-	sprintf(buf, _("Unable to open raster map <%s>"), dir_layer);
+	G_fatal_error(_("Unable to open raster map <%s>"), dir_layer);
     base_fd = G_open_cell_old(base_layer, G_find_cell2(base_layer, ""));
     if (base_fd < 0) {
-	sprintf(buf, _("Unable to open raster map <%s>"), base_layer);
+	G_fatal_error(_("Unable to open raster map <%s>"), base_layer);
     if (spotting) {
 	spotdist_fd =
 	    G_open_cell_old(spotdist_layer, G_find_cell2(spotdist_layer, ""));
 	if (spotdist_fd < 0) {
-	    sprintf(buf, _("Unable to open raster map <%s>"), spotdist_layer);
+	    G_fatal_error(_("Unable to open raster map <%s>"), spotdist_layer);
 	velocity_fd =
 	    G_open_cell_old(velocity_layer, G_find_cell2(velocity_layer, ""));
 	if (velocity_fd < 0) {
-	    sprintf(buf, _("Unable to open raster map <%s>"), velocity_layer);
+	    G_fatal_error(_("Unable to open raster map <%s>"), velocity_layer);
 	mois_fd = G_open_cell_old(mois_layer, G_find_cell2(mois_layer, ""));
 	if (mois_fd < 0) {
-	    sprintf(buf, _("Unable to open raster map <%s>"), mois_layer);
+	    G_fatal_error(_("Unable to open raster map <%s>"), mois_layer);
@@ -558,9 +484,7 @@
     start_fd = G_open_cell_old(start_layer, G_find_cell2(start_layer, ""));
     if (start_fd < 0) {
-	sprintf(buf, _("Unable to open raster map <%s>"), start_layer);
+	G_fatal_error(_("Unable to open raster map <%s>"), start_layer);
     G_read_range(start_layer, G_find_file("cell", start_layer, ""), &range);
Modified: grass/trunk/raster/wildfire/r.spreadpath/main.c
--- grass/trunk/raster/wildfire/r.spreadpath/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster/wildfire/r.spreadpath/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -274,13 +274,6 @@
     else
 	flag = 3;		/* output layer does not previously exist */
-    if (flag == 3) {
-	if (G_legal_filename(path_layer) < 0)
-	    G_fatal_error("%s - illegal name", path_layer);
     /* If the output layer containing the starting positions */
     /* create a linked list of of them  */
     if (flag == 1) {
Modified: grass/trunk/raster3d/r3.cross.rast/main.c
--- grass/trunk/raster3d/r3.cross.rast/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster3d/r3.cross.rast/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -344,10 +344,6 @@
-	/*Filename check for output map */
-	    fatal_error(map, elevfd, -1, _("Illegal output file name"));
 	if (G_find_cell2(param.output->answer, ""))
 	    G_message(_("Output map already exists. Will be overwritten!"));
Modified: grass/trunk/raster3d/r3.mkdspf/r3_find.c
--- grass/trunk/raster3d/r3.mkdspf/r3_find.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster3d/r3.mkdspf/r3_find.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -30,9 +30,6 @@
 /* return NULL on error: otherwise returns dspout */
 char *check_get_any_dspname(char *dspf, char *g3f, char *mset)
-    if (!G_legal_filename(dspf))
-	return (NULL);
     if (!G_find_grid3(g3f, ""))
 	G_fatal_error("[%s] 3D raster map not found", g3f);
Modified: grass/trunk/raster3d/r3.showdspf/r3_find.c
--- grass/trunk/raster3d/r3.showdspf/r3_find.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster3d/r3.showdspf/r3_find.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -35,9 +35,6 @@
     char element[200], question[200];
     static char dspout[200];
-	return (NULL);
     if (!G_find_grid3(g3f, "")) {
 	fprintf(stderr, "[%s] 3D raster map not found\n", g3f);
 	return (NULL);
Modified: grass/trunk/raster3d/r3.to.rast/main.c
--- grass/trunk/raster3d/r3.to.rast/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/raster3d/r3.to.rast/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -298,9 +298,6 @@
     if (fd == NULL)
     G_message(_("Creating %i raster maps"), region.depths);
     /*Loop over all output maps! open */
Modified: grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/opennew.c
--- grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/opennew.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/opennew.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -7,9 +7,6 @@
     int fd;
     else
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/vector/v.edit/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -82,11 +82,6 @@
     if (action_mode == MODE_CREATE) {
 	int overwrite;
-	if (G_legal_filename(params.map->answer) == -1) {
-			  params.map->answer);
 	overwrite = G_check_overwrite(argc, argv);
 	if (G_find_vector2(params.map->answer, G_mapset())) {
 	    if (!overwrite)
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/vector/v.in.ogr/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -327,9 +327,6 @@
 	G_fatal_error(_("Required parameter <%s> not set"), out_opt->key);
-	G_fatal_error(_("<%s> is an illegal file name"), out_opt->answer);
     if (!outloc_opt->answer) {	/* Check if the map exists */
 	if (G_find_vector2(out_opt->answer, G_mapset())) {
 	    if (overwrite)
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/vector/v.kernel/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -246,10 +246,6 @@
     else {
 	/* check and open the name of output map */
 	if (!flag_q->answer) {
-			      out_opt->answer);
 	    G_set_fp_type(DCELL_TYPE);
 	    if ((fdout = G_open_raster_new(out_opt->answer, DCELL_TYPE)) < 0)
Modified: grass/trunk/vector/v.surf.idw/main.c
--- grass/trunk/vector/v.surf.idw/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/vector/v.surf.idw/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -119,9 +119,6 @@
 	exit(EXIT_FAILURE);
 	search_points < 1)
Modified: grass/trunk/vector/v.to.rast3/main.c
--- grass/trunk/vector/v.to.rast3/main.c	2008-08-16 16:05:36 UTC (rev 32819)
+++ grass/trunk/vector/v.to.rast3/main.c	2008-08-16 16:08:08 UTC (rev 32820)
@@ -65,9 +65,6 @@
 	exit(EXIT_FAILURE);
     G3d_getWindow(&region);
     G3d_readWindow(&region, NULL);
