[GRASS-SVN] r32975 - in grass-addons/gipe: i.water i.wi
svn_grass at osgeo.org
Thu Aug 21 10:12:59 EDT 2008
Author: ychemin
Date: 2008-08-21 10:12:59 -0400 (Thu, 21 Aug 2008)
New Revision: 32975
grass-addons/gipe/i.water/main.c
grass-addons/gipe/i.wi/lswi.c
grass-addons/gipe/i.wi/main.c
code cleaning, upgrade, standardization
Modified: grass-addons/gipe/i.water/main.c
--- grass-addons/gipe/i.water/main.c 2008-08-21 14:08:23 UTC (rev 32974)
+++ grass-addons/gipe/i.water/main.c 2008-08-21 14:12:59 UTC (rev 32975)
@@ -26,8 +26,8 @@
int main(int argc, char *argv[])
- struct Cell_head cellhd; //region+header info
- char *mapset; // mapset name
+ struct Cell_head cellhd; /*region+header info*/
+ char *mapset; /*mapset name*/
int nrows, ncols;
int row,col;
@@ -35,13 +35,13 @@
struct Option *input1, *input2, *input3, *output1;
struct Flag *flag1;
- struct History history; //metadata
+ struct History history; /*metadata*/
/* FMEO Declarations*****************/
- char *name; // input raster name
- char *result1; //output raster name
- //File Descriptors
+ char *name; /*input raster name*/
+ char *result1; /*output raster name*/
+ /*File Descriptors*/
int infd_ndvi, infd_albedo, infd_ref7;
int outfd1;
@@ -64,23 +64,20 @@
/* Define the different options */
input1 = G_define_standard_option(G_OPT_R_INPUT) ;
input1->key = _("ndvi");
- input1->description=_("Name of the NDVI map [-]");
- input1->answer =_("ndvi");
+ input1->description=_("Name of the NDVI layer [-]");
input2 = G_define_standard_option(G_OPT_R_INPUT) ;
input2->key =_("albedo");
input2->required = NO ;
- input2->description=_("Name of the Albedo map [-]");
+ input2->description=_("Name of the Albedo layer [-]");
input3 = G_define_standard_option(G_OPT_R_INPUT) ;
input3->key =_("Modref7");
input3->required = NO ;
- input3->description=_("Name of the Modis surface reflectance band 7 [-]");
+ input3->description=_("Name of the Modis surface reflectance band 7 layer [-]");
output1 = G_define_standard_option(G_OPT_R_OUTPUT) ;
- output1->key =_("water");
output1->description=_("Name of the output water layer [0/1]");
- output1->answer =_("water");
if (G_parser(argc, argv))
exit (EXIT_FAILURE);
Modified: grass-addons/gipe/i.wi/lswi.c
--- grass-addons/gipe/i.wi/lswi.c 2008-08-21 14:08:23 UTC (rev 32974)
+++ grass-addons/gipe/i.wi/lswi.c 2008-08-21 14:12:59 UTC (rev 32975)
@@ -2,13 +2,13 @@
#include<math.h>
#include<stdlib.h>
-// Land Surface Water Index (LWSI)
-// a kind of Normalized Difference Water Index
-// Xiao X., Boles S., Frolking S., Salas W., Moore B., Li C., et al. (2002)
-// Landscape-scale characterization of cropland in China using vegetation and Landsat TM images.
-// International Journal of Remote Sensing, 23:3579-3594.
+/* Land Surface Water Index (LWSI)
+ * a kind of Normalized Difference Water Index
+ * Xiao X., Boles S., Frolking S., Salas W., Moore B., Li C., et al. (2002)
+ * Landscape-scale characterization of cropland in China using vegetation and Landsat TM images.
+ * International Journal of Remote Sensing, 23:3579-3594.
double ls_wi( double nirchan, double swirchan )
double result;
Modified: grass-addons/gipe/i.wi/main.c
--- grass-addons/gipe/i.wi/main.c 2008-08-21 14:08:23 UTC (rev 32974)
+++ grass-addons/gipe/i.wi/main.c 2008-08-21 14:12:59 UTC (rev 32975)
@@ -22,24 +22,24 @@
int nrows, ncols;
int row,col;
- char *wiflag;// Switch for particular index
+ char *wiflag;/*Switch for particular index*/
struct GModule *module;
struct Option *input1,*input2,*input3, *output;
struct Flag *flag1;
- struct Colors colors; //Color rules
+ struct Colors colors; /*Color rules*/
- char *result; //output raster name
+ char *result; /*output raster name*/
int infd_nirchan, infd_swirchan;
int outfd;
@@ -72,18 +72,13 @@
input2->key = _("nir");
input2->description=_("Name of the NIR Channel surface reflectance map [0.0;1.0]");
- input2->answer =_("nirchan");
input3->key =_("swir");
input3->description=_("Name of the SWIR Channel surface reflectance map [0.0;1.0]");
- input3->answer =_("swirchan");
output= G_define_standard_option(G_OPT_R_OUTPUT) ;
- output->key =_("wi");
output->description=_("Name of the output wi layer");
- output->answer =_("wi");
@@ -129,7 +124,6 @@
DCELL d_nirchan;
DCELL d_swirchan;
G_percent(row,nrows,2);
-// printf("row = %i/%i\n",row,nrows);
if(G_get_raster_row(infd_nirchan,inrast_nirchan,row,data_type_nirchan)<0)
G_fatal_error(_("Could not read from <%s>"),nirchan);
if(G_get_raster_row(infd_swirchan,inrast_swirchan,row,data_type_swirchan)<0)
@@ -159,8 +153,6 @@
d_swirchan = ((DCELL *) inrast_swirchan)[col];
break;
- // printf("col=%i/%i ",col,ncols);
- // to change to multiple to output files.
if(G_is_d_null_value(&d_nirchan)||
G_is_d_null_value(&d_swirchan)){
G_set_d_null_value(&outrast[col],1);
