[GRASS-SVN] r32976 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules vdigit
svn_grass at osgeo.org
Thu Aug 21 10:22:29 EDT 2008
Author: martinl
Date: 2008-08-21 10:22:29 -0400 (Thu, 21 Aug 2008)
New Revision: 32976
grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
grass/branches/develbranch_6/gui/wxpython/vdigit/driver_draw.cpp
grass/branches/develbranch_6/gui/wxpython/vdigit/driver_select.cpp
wxGUI/vdigit: highlight areas instead of centroids if area fill is enabled
cosmetics in dbm module
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2008-08-21 14:12:59 UTC (rev 32975)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2008-08-21 14:22:29 UTC (rev 32976)
@@ -921,8 +921,8 @@
menu.Append(self.popupDataID5, _("Select all"))
menu.Append(self.popupDataID6, _("Deselect all"))
menu.AppendSeparator()
- menu.Append(self.popupDataID7, _("Display selected"))
- menu.Append(self.popupDataID8, _("Display selected and zoom"))
+ menu.Append(self.popupDataID7, _("Highlight selected"))
+ menu.Append(self.popupDataID8, _("Highlight selected and zoom"))
if not self.map or len(list.GetSelectedItems()) == 0:
menu.Enable(self.popupDataID7, False)
menu.Enable(self.popupDataID8, False)
@@ -2598,7 +2598,7 @@
'table=%s' % table,
'key=%s' % key,
'layer=%d' % layer])
if connectCmd.returncode == 0:
# update dialog (only for new layer)
self.parentDialog.UpdateDialog(layer=layer)
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h 2008-08-21 14:12:59 UTC (rev 32975)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h 2008-08-21 14:22:29 UTC (rev 32976)
@@ -148,7 +148,7 @@
void PrintIds();
/* select feature */
- bool IsSelected(int);
+ bool IsSelected(int, bool force=false);
bool IsDuplicated(int);
std::vector<int> ListToVector(struct ilist *);
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver_draw.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver_draw.cpp 2008-08-21 14:12:59 UTC (rev 32975)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver_draw.cpp 2008-08-21 14:22:29 UTC (rev 32976)
@@ -62,9 +62,10 @@
struct ilist *listAreas, *listCentroids;
struct line_pnts *points, *ipoints, **isles;
- wxBrush *fillArea, *fillIsle;
+ wxBrush *fillArea, *fillAreaSelected, *fillIsle;
fillArea = new wxBrush(settings.area.color);
+ fillAreaSelected = new wxBrush(settings.highlight);
fillIsle = new wxBrush(*wxWHITE_BRUSH);
listAreas = Vect_new_list();
@@ -123,7 +124,14 @@
if (draw) {
- dc->SetBrush(*fillArea);
+ int cat;
+ cat = Vect_get_area_cat(mapInfo, area, 1); /* TODO: field */
+ if (cat > -1 && IsSelected(cat, true)) {
+ dc->SetBrush(*fillAreaSelected);
+ else {
+ dc->SetBrush(*fillArea);
dc->SetPen(*wxTRANSPARENT_PEN);
DrawArea(points);
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver_select.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver_select.cpp 2008-08-21 14:12:59 UTC (rev 32975)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver_select.cpp 2008-08-21 14:22:29 UTC (rev 32976)
@@ -156,15 +156,15 @@
\return true if vector object is selected
\return false if vector object is not selected
-bool DisplayDriver::IsSelected(int line)
+bool DisplayDriver::IsSelected(int line, bool force)
- if (selected.isId) {
+ if (selected.isId || force) {
if (Vect_val_in_list(selected.values, line))
return true;
else {
for (int i = 0; i < cats->n_cats; i++) {
- if (cats->field[i] == 1 &&
+ if (cats->field[i] == 1 && /* TODO: field */
Vect_val_in_list(selected.values, cats->cat[i]))
return true;
@@ -415,6 +415,8 @@
std::vector<int> DisplayDriver::GetRegionSelected()
+ int line, area;
std::vector<int> region;
BOUND_BOX region_box, line_box;
@@ -454,11 +456,20 @@
else {
list = selected.values;
for (int i = 0; i < list->n_values; i++) {
- if (!Vect_get_line_box(mapInfo, list->value[i], &line_box))
- continue;
+ line = list->value[i];
+ area = Vect_get_centroid_area(mapInfo, line);
+ if (area > 0) {
+ if (!Vect_get_area_box(mapInfo, area, &line_box))
+ continue;
+ else {
+ if (!Vect_get_line_box(mapInfo, line, &line_box))
+ continue;
if (i == 0) {
Vect_box_copy(®ion_box, &line_box);
@@ -466,7 +477,7 @@
Vect_box_extend(®ion_box, &line_box);
if (list && list != selected.values) {
Vect_destroy_list(list);
