[GRASS-SVN] r33140 - grass/trunk/general/g.proj
svn_grass at osgeo.org
Thu Aug 28 11:44:48 EDT 2008
Author: glynn
Date: 2008-08-28 11:44:48 -0400 (Thu, 28 Aug 2008)
New Revision: 33140
grass/trunk/general/g.proj/main.c
Fix unused variable warnings #ifndef HAVE_OGR
Modified: grass/trunk/general/g.proj/main.c
--- grass/trunk/general/g.proj/main.c 2008-08-28 15:43:44 UTC (rev 33139)
+++ grass/trunk/general/g.proj/main.c 2008-08-28 15:44:48 UTC (rev 33140)
@@ -31,18 +31,22 @@
*printproj4, /* Print projection in PROJ.4 format */
*datuminfo, /* Check if datum information is present */
*create, /* Create new projection files */
+#ifdef HAVE_OGR
*printwkt, /* Print projection in WKT format */
*esristyle, /* Use ESRI-style WKT format */
+#endif
*dontprettify, /* Print 'flat' output (no linebreaks) */
*forcedatumtrans; /* Force override of datumtrans parameters */
struct Option *location, /* Name of new location to create */
+#ifdef HAVE_OGR
*inepsg, /* EPSG projection code */
- *dtrans, /* index to datum transform option */
*inwkt, /* Input file with projection in WKT format */
*inproj4, /* Projection in PROJ.4 format */
- *ingeo; /* Input geo-referenced file readable by
+ *ingeo, /* Input geo-referenced file readable by
* GDAL or OGR */
+#endif
+ *dtrans; /* index to datum transform option */
struct GModule *module;
int formats;
