[GRASS-SVN] r33141 - in grass/trunk: . include lib/gis
raster/r.external
svn_grass at osgeo.org
Thu Aug 28 12:33:59 EDT 2008
Author: glynn
Date: 2008-08-28 12:33:59 -0400 (Thu, 28 Aug 2008)
New Revision: 33141
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/include/config.h.in
grass/trunk/include/gis.h
grass/trunk/include/gisdefs.h
grass/trunk/lib/gis/G.h
grass/trunk/lib/gis/Makefile
grass/trunk/lib/gis/closecell.c
grass/trunk/lib/gis/gdal.c
grass/trunk/lib/gis/get_row.c
grass/trunk/lib/gis/opencell.c
grass/trunk/raster/r.external/Makefile
Add HAVE_GDAL
Enable GDAL-link/r.external functionality
Improve failure mode if GDAL links are used in a version built without GDAL
Modified: grass/trunk/configure
--- grass/trunk/configure 2008-08-28 15:44:48 UTC (rev 33140)
+++ grass/trunk/configure 2008-08-28 16:33:59 UTC (rev 33141)
@@ -7224,6 +7224,11 @@
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
echo "configure:7226: checking whether to use GDAL" >&5
+GDAL_LIBS=
+GDAL_CFLAGS=
+USE_GDAL=
+USE_OGR=
if test "`basename xx/$with_gdal`" = "gdal-config" ; then
GDAL_CONFIG="$with_gdal"
fi
@@ -7235,7 +7240,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7239: checking for $ac_word" >&5
+echo "configure:7244: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -7270,11 +7275,6 @@
{ echo "configure: error: *** couldn't find gdal-config" 1>&2; exit 1; }
fi
- GDAL_LIBS=
- GDAL_CFLAGS=
- USE_GDAL=
- USE_OGR=
if test "$GDAL_CONFIG" != "" ; then
GDAL_LIBS=`"$GDAL_CONFIG" --libs`
GDAL_DEP_LIBS=`"$GDAL_CONFIG" --dep-libs`
@@ -7336,17 +7336,22 @@
LIBS=${ac_save_libs}
CFLAGS=${ac_save_cflags}
+ cat >> confdefs.h <<\EOF
+#define HAVE_GDAL 1
+EOF
fi
# Enable TIFF option
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7350: checking whether to use TIFF" >&5
+echo "configure:7355: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7366,7 +7371,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7370: checking for location of TIFF includes" >&5
+echo "configure:7375: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7392,15 +7397,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:7396: checking for $ac_hdr" >&5
+echo "configure:7401: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 7399 "configure"
+#line 7404 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7409: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7434,7 +7439,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7438: checking for location of TIFF library" >&5
+echo "configure:7443: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7465,13 +7470,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7469: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7474: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ltiff $LIBS"
-#line 7475 "configure"
+#line 7480 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7482,7 +7487,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7501,13 +7506,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:7505: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7510: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7511 "configure"
+#line 7516 "configure"
@@ -7518,7 +7523,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7537,13 +7542,13 @@
-echo "configure:7541: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7546: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7547 "configure"
+#line 7552 "configure"
@@ -7554,7 +7559,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7573,13 +7578,13 @@
-echo "configure:7577: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7582: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7583 "configure"
+#line 7588 "configure"
@@ -7590,7 +7595,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7594: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7609,13 +7614,13 @@
-echo "configure:7613: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7618: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 7619 "configure"
+#line 7624 "configure"
@@ -7626,7 +7631,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7630: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7645,13 +7650,13 @@
-echo "configure:7649: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7654: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 7655 "configure"
+#line 7660 "configure"
@@ -7662,7 +7667,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7666: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7681,13 +7686,13 @@
-echo "configure:7685: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7690: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 7691 "configure"
+#line 7696 "configure"
@@ -7698,7 +7703,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7717,13 +7722,13 @@
-echo "configure:7721: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7726: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 7727 "configure"
+#line 7732 "configure"
@@ -7734,7 +7739,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7832,7 +7837,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7836: checking whether to use PNG" >&5
+echo "configure:7841: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7851,7 +7856,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7855: checking for location of PNG includes" >&5
+echo "configure:7860: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7877,15 +7882,15 @@
do
-echo "configure:7881: checking for $ac_hdr" >&5
+echo "configure:7886: checking for $ac_hdr" >&5
-#line 7884 "configure"
+#line 7889 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7889: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7894: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7919,7 +7924,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7923: checking for location of PNG library" >&5
+echo "configure:7928: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7944,13 +7949,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7948: checking for png_read_image in -lpng" >&5
+echo "configure:7953: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7954 "configure"
+#line 7959 "configure"
@@ -7961,7 +7966,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8003,7 +8008,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8007: checking whether to use Tcl/Tk" >&5
+echo "configure:8012: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -8023,7 +8028,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8027: checking for location of Tcl/Tk includes" >&5
+echo "configure:8032: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8049,15 +8054,15 @@
do
-echo "configure:8053: checking for $ac_hdr" >&5
+echo "configure:8058: checking for $ac_hdr" >&5
-#line 8056 "configure"
+#line 8061 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8061: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8066: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8094,15 +8099,15 @@
do
-echo "configure:8098: checking for $ac_hdr" >&5
+echo "configure:8103: checking for $ac_hdr" >&5
-#line 8101 "configure"
+#line 8106 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8106: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8111: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8136,7 +8141,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8140: checking Tcl version" >&5
+echo "configure:8145: checking Tcl version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -8144,7 +8149,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 8148 "configure"
+#line 8153 "configure"
#include <stdio.h>
@@ -8156,7 +8161,7 @@
EOF
-if { (eval echo configure:8160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -8174,7 +8179,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8178: checking Tk version" >&5
+echo "configure:8183: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8182,7 +8187,7 @@
else
-#line 8186 "configure"
+#line 8191 "configure"
#include <stdio.h>
@@ -8194,7 +8199,7 @@
EOF
-if { (eval echo configure:8198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -8223,7 +8228,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8227: checking for location of Tcl/Tk library" >&5
+echo "configure:8232: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8253,13 +8258,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8257: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8262: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 8263 "configure"
+#line 8268 "configure"
@@ -8270,7 +8275,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8289,13 +8294,13 @@
-echo "configure:8293: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8298: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8299 "configure"
+#line 8304 "configure"
@@ -8306,7 +8311,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8310: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8333,13 +8338,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8337: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8342: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8343 "configure"
+#line 8348 "configure"
@@ -8350,7 +8355,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8369,13 +8374,13 @@
-echo "configure:8373: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8378: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8379 "configure"
+#line 8384 "configure"
@@ -8386,7 +8391,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8413,13 +8418,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8417: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8422: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8423 "configure"
+#line 8428 "configure"
@@ -8430,7 +8435,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8449,13 +8454,13 @@
-echo "configure:8453: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8458: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8459 "configure"
+#line 8464 "configure"
@@ -8466,7 +8471,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8544,13 +8549,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8548: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8553: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8554 "configure"
+#line 8559 "configure"
@@ -8561,7 +8566,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8580,13 +8585,13 @@
-echo "configure:8584: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8589: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8590 "configure"
+#line 8595 "configure"
@@ -8597,7 +8602,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8624,13 +8629,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8628: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:8633: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 8634 "configure"
+#line 8639 "configure"
@@ -8641,7 +8646,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8660,13 +8665,13 @@
-echo "configure:8664: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:8669: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8670 "configure"
+#line 8675 "configure"
@@ -8677,7 +8682,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8704,13 +8709,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8708: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:8713: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 8714 "configure"
+#line 8719 "configure"
@@ -8721,7 +8726,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8740,13 +8745,13 @@
-echo "configure:8744: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:8749: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8750 "configure"
+#line 8755 "configure"
@@ -8757,7 +8762,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8849,7 +8854,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8853: checking whether to use PostgreSQL" >&5
+echo "configure:8858: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -8876,7 +8881,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8880: checking for location of PostgreSQL includes" >&5
+echo "configure:8885: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8902,15 +8907,15 @@
do
-echo "configure:8906: checking for $ac_hdr" >&5
+echo "configure:8911: checking for $ac_hdr" >&5
-#line 8909 "configure"
+#line 8914 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8914: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8919: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8948,7 +8953,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8952: checking for location of PostgreSQL library" >&5
+echo "configure:8957: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8977,13 +8982,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8981: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8986: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 8987 "configure"
+#line 8992 "configure"
@@ -8994,7 +8999,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9013,13 +9018,13 @@
-echo "configure:9017: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9022: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9023 "configure"
+#line 9028 "configure"
@@ -9030,7 +9035,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9049,13 +9054,13 @@
-echo "configure:9053: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9058: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9059 "configure"
+#line 9064 "configure"
@@ -9066,7 +9071,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9085,13 +9090,13 @@
-echo "configure:9089: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9094: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9095 "configure"
+#line 9100 "configure"
@@ -9102,7 +9107,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9159,13 +9164,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9163: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9168: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9169 "configure"
+#line 9174 "configure"
@@ -9176,7 +9181,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9198,13 +9203,13 @@
-echo "configure:9202: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9207: checking for PQcmdTuples in -lpq" >&5
-#line 9208 "configure"
+#line 9213 "configure"
@@ -9215,7 +9220,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9258,7 +9263,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9262: checking whether to use MySQL" >&5
+echo "configure:9267: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9278,7 +9283,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9282: checking for location of MySQL includes" >&5
+echo "configure:9287: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9304,15 +9309,15 @@
do
-echo "configure:9308: checking for $ac_hdr" >&5
+echo "configure:9313: checking for $ac_hdr" >&5
-#line 9311 "configure"
+#line 9316 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9321: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9349,7 +9354,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9353: checking for location of MySQL library" >&5
+echo "configure:9358: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9380,13 +9385,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9384: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9389: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9390 "configure"
+#line 9395 "configure"
@@ -9397,7 +9402,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9416,13 +9421,13 @@
-echo "configure:9420: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9425: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9426 "configure"
+#line 9431 "configure"
@@ -9433,7 +9438,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9452,13 +9457,13 @@
-echo "configure:9456: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9461: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9462 "configure"
+#line 9467 "configure"
@@ -9469,7 +9474,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9488,13 +9493,13 @@
-echo "configure:9492: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9497: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9498 "configure"
+#line 9503 "configure"
@@ -9505,7 +9510,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9524,13 +9529,13 @@
-echo "configure:9528: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9533: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9534 "configure"
+#line 9539 "configure"
@@ -9541,7 +9546,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9560,13 +9565,13 @@
-echo "configure:9564: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9569: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9570 "configure"
+#line 9575 "configure"
@@ -9577,7 +9582,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9596,13 +9601,13 @@
-echo "configure:9600: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9605: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9606 "configure"
+#line 9611 "configure"
@@ -9613,7 +9618,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9632,13 +9637,13 @@
-echo "configure:9636: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9641: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9642 "configure"
+#line 9647 "configure"
@@ -9649,7 +9654,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9739,7 +9744,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:9743: checking for $ac_word" >&5
+echo "configure:9748: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -9788,10 +9793,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9792: checking for mysql_server_init" >&5
+echo "configure:9797: checking for mysql_server_init" >&5
-#line 9795 "configure"
+#line 9800 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -9817,7 +9822,7 @@
; return 0; }
EOF
-if { (eval echo configure:9821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -9869,7 +9874,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9873: checking whether to use SQLite" >&5
+echo "configure:9878: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -9889,7 +9894,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9893: checking for location of SQLite includes" >&5
+echo "configure:9898: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9915,15 +9920,15 @@
do
-echo "configure:9919: checking for $ac_hdr" >&5
+echo "configure:9924: checking for $ac_hdr" >&5
-#line 9922 "configure"
+#line 9927 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9927: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9932: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9966,7 +9971,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9970: checking for location of SQLite library" >&5
+echo "configure:9975: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9993,13 +9998,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9997: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10002: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10003 "configure"
+#line 10008 "configure"
@@ -10010,7 +10015,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10029,13 +10034,13 @@
-echo "configure:10033: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10038: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10039 "configure"
+#line 10044 "configure"
@@ -10046,7 +10051,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10099,7 +10104,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10103: checking whether to use FFMPEG" >&5
+echo "configure:10108: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10119,7 +10124,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10123: checking for location of FFMPEG includes" >&5
+echo "configure:10128: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10145,15 +10150,15 @@
do
-echo "configure:10149: checking for $ac_hdr" >&5
+echo "configure:10154: checking for $ac_hdr" >&5
-#line 10152 "configure"
+#line 10157 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10157: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10162: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10189,15 +10194,15 @@
do
-echo "configure:10193: checking for $ac_hdr" >&5
+echo "configure:10198: checking for $ac_hdr" >&5
-#line 10196 "configure"
+#line 10201 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10201: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10206: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10233,15 +10238,15 @@
do
-echo "configure:10237: checking for $ac_hdr" >&5
+echo "configure:10242: checking for $ac_hdr" >&5
-#line 10240 "configure"
+#line 10245 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10245: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10250: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10284,7 +10289,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10288: checking for location of FFMPEG library" >&5
+echo "configure:10293: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10311,13 +10316,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10315: checking for av_free in -lavutil" >&5
+echo "configure:10320: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10321 "configure"
+#line 10326 "configure"
@@ -10328,7 +10333,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10332: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10347,13 +10352,13 @@
-echo "configure:10351: checking for av_free in -lavutil" >&5
+echo "configure:10356: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10357 "configure"
+#line 10362 "configure"
@@ -10364,7 +10369,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10409,13 +10414,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10413: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10418: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10419 "configure"
+#line 10424 "configure"
@@ -10426,7 +10431,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10445,13 +10450,13 @@
-echo "configure:10449: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10454: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10455 "configure"
+#line 10460 "configure"
@@ -10462,7 +10467,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10466: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10507,13 +10512,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10511: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10516: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10517 "configure"
+#line 10522 "configure"
@@ -10524,7 +10529,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10543,13 +10548,13 @@
-echo "configure:10547: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10552: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10553 "configure"
+#line 10558 "configure"
@@ -10560,7 +10565,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10620,7 +10625,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10624: checking whether to use OpenGL" >&5
+echo "configure:10629: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10654,7 +10659,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10658: checking for location of OpenGL includes" >&5
+echo "configure:10663: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10680,15 +10685,15 @@
do
-echo "configure:10684: checking for $ac_hdr" >&5
+echo "configure:10689: checking for $ac_hdr" >&5
-#line 10687 "configure"
+#line 10692 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10692: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10722,7 +10727,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10726: checking for location of OpenGL library" >&5
+echo "configure:10731: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10751,13 +10756,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10755: checking for glBegin in -lGL" >&5
+echo "configure:10760: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10761 "configure"
+#line 10766 "configure"
@@ -10768,7 +10773,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10787,13 +10792,13 @@
-echo "configure:10791: checking for glBegin in -lGL" >&5
+echo "configure:10796: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10797 "configure"
+#line 10802 "configure"
@@ -10804,7 +10809,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10823,13 +10828,13 @@
-echo "configure:10827: checking for glBegin in -lGL" >&5
+echo "configure:10832: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10833 "configure"
+#line 10838 "configure"
@@ -10840,7 +10845,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10859,13 +10864,13 @@
-echo "configure:10863: checking for glBegin in -lGL" >&5
+echo "configure:10868: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10869 "configure"
+#line 10874 "configure"
@@ -10876,7 +10881,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10938,13 +10943,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:10942: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10947: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10948 "configure"
+#line 10953 "configure"
@@ -10955,7 +10960,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:10959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10974,13 +10979,13 @@
-echo "configure:10978: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10983: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 10984 "configure"
+#line 10989 "configure"
@@ -10991,7 +10996,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:10995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11038,10 +11043,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11042: checking for glXCreatePbuffer" >&5
+echo "configure:11047: checking for glXCreatePbuffer" >&5
-#line 11045 "configure"
+#line 11050 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11064,7 +11069,7 @@
; return 0; }
EOF
-if { (eval echo configure:11068: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11101,10 +11106,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11105: checking for glXCreateGLXPixmap" >&5
+echo "configure:11110: checking for glXCreateGLXPixmap" >&5
-#line 11108 "configure"
+#line 11113 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11127,7 +11132,7 @@
; return 0; }
EOF
-if { (eval echo configure:11131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11170,7 +11175,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:11174: checking for location of OpenGL framework" >&5
+echo "configure:11179: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -11194,15 +11199,15 @@
do
-echo "configure:11198: checking for $ac_hdr" >&5
+echo "configure:11203: checking for $ac_hdr" >&5
-#line 11201 "configure"
+#line 11206 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11206: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11211: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11238,10 +11243,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11242: checking for glBegin" >&5
+echo "configure:11247: checking for glBegin" >&5
-#line 11245 "configure"
+#line 11250 "configure"
which can conflict with char glBegin(); below. */
@@ -11264,7 +11269,7 @@
; return 0; }
EOF
-if { (eval echo configure:11268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11301,10 +11306,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11305: checking for gluBeginCurve" >&5
+echo "configure:11310: checking for gluBeginCurve" >&5
-#line 11308 "configure"
+#line 11313 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11327,7 +11332,7 @@
; return 0; }
EOF
-if { (eval echo configure:11331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11375,7 +11380,7 @@
-echo "configure:11379: checking for location of OpenGL includes" >&5
+echo "configure:11384: checking for location of OpenGL includes" >&5
@@ -11401,15 +11406,15 @@
do
-echo "configure:11405: checking for $ac_hdr" >&5
+echo "configure:11410: checking for $ac_hdr" >&5
-#line 11408 "configure"
+#line 11413 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11413: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11418: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11443,7 +11448,7 @@
-echo "configure:11447: checking for location of OpenGL library" >&5
+echo "configure:11452: checking for location of OpenGL library" >&5
@@ -11468,18 +11473,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11472: checking for OpenGL library" >&5
+echo "configure:11477: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11476 "configure"
+#line 11481 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11503,18 +11508,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11507: checking for GLU library" >&5
+echo "configure:11512: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11511 "configure"
+#line 11516 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11563,7 +11568,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11567: checking whether to use ODBC" >&5
+echo "configure:11572: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11582,7 +11587,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11586: checking for location of ODBC includes" >&5
+echo "configure:11591: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11608,15 +11613,15 @@
do
-echo "configure:11612: checking for $ac_hdr" >&5
+echo "configure:11617: checking for $ac_hdr" >&5
-#line 11615 "configure"
+#line 11620 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11620: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11625: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11650,7 +11655,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11654: checking for location of ODBC library" >&5
+echo "configure:11659: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11675,13 +11680,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11679: checking for SQLConnect in -lodbc" >&5
+echo "configure:11684: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 11685 "configure"
+#line 11690 "configure"
@@ -11692,7 +11697,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11717,13 +11722,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11721: checking for SQLConnect in -liodbc" >&5
+echo "configure:11726: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 11727 "configure"
+#line 11732 "configure"
@@ -11734,7 +11739,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11759,11 +11764,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:11763: checking for ODBC library" >&5
+echo "configure:11768: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 11767 "configure"
+#line 11772 "configure"
#include <windows.h>
#include <sql.h>
@@ -11771,7 +11776,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:11775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11820,7 +11825,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11824: checking whether to use FFTW" >&5
+echo "configure:11829: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -11839,7 +11844,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11843: checking for location of FFTW includes" >&5
+echo "configure:11848: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11865,15 +11870,15 @@
do
-echo "configure:11869: checking for $ac_hdr" >&5
+echo "configure:11874: checking for $ac_hdr" >&5
-#line 11872 "configure"
+#line 11877 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11877: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11882: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11901,15 +11906,15 @@
do
-echo "configure:11905: checking for $ac_hdr" >&5
+echo "configure:11910: checking for $ac_hdr" >&5
-#line 11908 "configure"
+#line 11913 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11913: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11918: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11937,15 +11942,15 @@
do
-echo "configure:11941: checking for $ac_hdr" >&5
+echo "configure:11946: checking for $ac_hdr" >&5
-#line 11944 "configure"
+#line 11949 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11949: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11954: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11991,7 +11996,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:11995: checking for location of FFTW library" >&5
+echo "configure:12000: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12016,13 +12021,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12020: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12025: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12026 "configure"
+#line 12031 "configure"
@@ -12033,7 +12038,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12058,13 +12063,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12062: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12067: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12068 "configure"
+#line 12073 "configure"
@@ -12075,7 +12080,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12100,13 +12105,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12104: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12109: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12110 "configure"
+#line 12115 "configure"
@@ -12117,7 +12122,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12174,7 +12179,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12178: checking whether to use BLAS" >&5
+echo "configure:12183: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12195,7 +12200,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12199: checking for location of BLAS includes" >&5
+echo "configure:12204: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12215,7 +12220,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12219: checking for location of BLAS library" >&5
+echo "configure:12224: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12241,15 +12246,15 @@
do
-echo "configure:12245: checking for $ac_hdr" >&5
+echo "configure:12250: checking for $ac_hdr" >&5
-#line 12248 "configure"
+#line 12253 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12253: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12284,13 +12289,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12288: checking for dnrm2_ in -lblas" >&5
+echo "configure:12293: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12294 "configure"
+#line 12299 "configure"
@@ -12301,7 +12306,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12310: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12320,13 +12325,13 @@
-echo "configure:12324: checking for dnrm2_ in -lblas" >&5
+echo "configure:12329: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12330 "configure"
+#line 12335 "configure"
@@ -12337,7 +12342,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12346: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12381,13 +12386,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12385: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12390: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12391 "configure"
+#line 12396 "configure"
@@ -12398,7 +12403,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12413,13 +12418,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12417: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12422: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12423 "configure"
+#line 12428 "configure"
@@ -12430,7 +12435,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12445,13 +12450,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12449: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12454: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 12455 "configure"
+#line 12460 "configure"
#include "confdefs.h"
@@ -12462,7 +12467,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12466: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12507,16 +12512,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12511: checking for sgemm in $vlib_flags" >&5
+echo "configure:12516: checking for sgemm in $vlib_flags" >&5
-#line 12513 "configure"
+#line 12518 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12534,13 +12539,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12538: checking for sgemm_ in -lblas" >&5
+echo "configure:12543: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lblas $LIBS"
-#line 12544 "configure"
+#line 12549 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12551,7 +12556,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12566,13 +12571,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12570: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12575: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12576 "configure"
+#line 12581 "configure"
@@ -12583,7 +12588,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12598,13 +12603,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12602: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12607: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12608 "configure"
+#line 12613 "configure"
@@ -12615,7 +12620,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12624: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12649,13 +12654,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12653: checking for acosp in -lsunmath" >&5
+echo "configure:12658: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 12659 "configure"
+#line 12664 "configure"
@@ -12666,7 +12671,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12670: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12681,13 +12686,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12685: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12690: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 12691 "configure"
+#line 12696 "configure"
@@ -12698,7 +12703,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12728,13 +12733,13 @@
# Generic BLAS library
-echo "configure:12732: checking for sgemm_ in -lblas" >&5
+echo "configure:12737: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 12738 "configure"
+#line 12743 "configure"
@@ -12745,7 +12750,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12784,7 +12789,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12788: checking whether to use LAPACK" >&5
+echo "configure:12793: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -12809,7 +12814,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12813: checking for location of LAPACK includes" >&5
+echo "configure:12818: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12829,7 +12834,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12833: checking for location of LAPACK library" >&5
+echo "configure:12838: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12855,15 +12860,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:12859: checking for $ac_hdr" >&5
+echo "configure:12864: checking for $ac_hdr" >&5
-#line 12862 "configure"
+#line 12867 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12867: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12872: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -12895,10 +12900,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12899: checking for dsegv_" >&5
+echo "configure:12904: checking for dsegv_" >&5
-#line 12902 "configure"
+#line 12907 "configure"
which can conflict with char dsegv_(); below. */
@@ -12921,7 +12926,7 @@
; return 0; }
EOF
-if { (eval echo configure:12925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -12948,13 +12953,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12952: checking for desgv_ in -llapack" >&5
+echo "configure:12957: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 12958 "configure"
+#line 12963 "configure"
@@ -12965,7 +12970,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:12969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12997,13 +13002,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13001: checking for dgesv_ in -llapack" >&5
+echo "configure:13006: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13007 "configure"
+#line 13012 "configure"
@@ -13014,7 +13019,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13033,13 +13038,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:13037: checking for dgesv_ in -llapack" >&5
+echo "configure:13042: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13043 "configure"
+#line 13048 "configure"
@@ -13050,7 +13055,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13106,7 +13111,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13110: checking whether to use Motif" >&5
+echo "configure:13115: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -13125,7 +13130,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13129: checking for location of Motif includes" >&5
+echo "configure:13134: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13151,15 +13156,15 @@
do
-echo "configure:13155: checking for $ac_hdr" >&5
+echo "configure:13160: checking for $ac_hdr" >&5
-#line 13158 "configure"
+#line 13163 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13163: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13168: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13193,7 +13198,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13197: checking for location of Motif library" >&5
+echo "configure:13202: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13218,13 +13223,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13222: checking for XmStringCreate in -lXm" >&5
+echo "configure:13227: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 13228 "configure"
+#line 13233 "configure"
@@ -13235,7 +13240,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:13239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13276,7 +13281,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13280: checking whether to use Cairo" >&5
+echo "configure:13285: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -13297,7 +13302,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13301: checking for location of cairo includes" >&5
+echo "configure:13306: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13323,15 +13328,15 @@
do
-echo "configure:13327: checking for $ac_hdr" >&5
+echo "configure:13332: checking for $ac_hdr" >&5
-#line 13330 "configure"
+#line 13335 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13335: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13340: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13367,7 +13372,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13371: checking for location of cairo library" >&5
+echo "configure:13376: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13387,7 +13392,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13391: checking for cairo linking flags" >&5
+echo "configure:13396: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13403,10 +13408,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13407: checking for cairo_create" >&5
+echo "configure:13412: checking for cairo_create" >&5
-#line 13410 "configure"
+#line 13415 "configure"
which can conflict with char cairo_create(); below. */
@@ -13429,7 +13434,7 @@
; return 0; }
EOF
-if { (eval echo configure:13433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13472,7 +13477,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13476: checking whether to use FreeType" >&5
+echo "configure:13481: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -13491,7 +13496,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13495: checking for location of FreeType includes" >&5
+echo "configure:13500: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13517,15 +13522,15 @@
do
-echo "configure:13521: checking for $ac_hdr" >&5
+echo "configure:13526: checking for $ac_hdr" >&5
-#line 13524 "configure"
+#line 13529 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13529: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13534: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13559,7 +13564,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13563: checking for location of FreeType library" >&5
+echo "configure:13568: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13584,13 +13589,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13588: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13593: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 13594 "configure"
+#line 13599 "configure"
@@ -13601,7 +13606,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:13605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13642,7 +13647,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13646: checking whether to use NLS" >&5
+echo "configure:13651: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -13662,10 +13667,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13666: checking for gettext" >&5
+echo "configure:13671: checking for gettext" >&5
-#line 13669 "configure"
+#line 13674 "configure"
which can conflict with char gettext(); below. */
@@ -13688,7 +13693,7 @@
; return 0; }
EOF
-if { (eval echo configure:13692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13697: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -13706,13 +13711,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13710: checking for gettext in -lintl" >&5
+echo "configure:13715: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 13716 "configure"
+#line 13721 "configure"
@@ -13723,7 +13728,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:13727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13758,7 +13763,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13762: checking whether to use C++" >&5
+echo "configure:13767: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -13774,7 +13779,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13778: checking for $ac_word" >&5
+echo "configure:13783: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13803,7 +13808,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13807: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13812: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13814,12 +13819,12 @@
cat > conftest.$ac_ext << EOF
-#line 13818 "configure"
+#line 13823 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:13823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -13845,19 +13850,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13849: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13854: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13854: checking whether we are using GNU C++" >&5
+echo "configure:13859: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13861: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13866: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -13875,7 +13880,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13879: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13884: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13916,7 +13921,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13920: checking whether to use openDWG" >&5
+echo "configure:13925: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -13936,7 +13941,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:13940: checking for location of openDGW includes" >&5
+echo "configure:13945: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -13962,15 +13967,15 @@
do
-echo "configure:13966: checking for $ac_hdr" >&5
+echo "configure:13971: checking for $ac_hdr" >&5
-#line 13969 "configure"
+#line 13974 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13974: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13979: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14004,7 +14009,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14008: checking for location of openDWG library" >&5
+echo "configure:14013: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14051,7 +14056,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14055: checking for special C compiler options needed for large files" >&5
+echo "configure:14060: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -14059,7 +14064,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 14063 "configure"
+#line 14068 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -14075,7 +14080,7 @@
; return 0; }
EOF
-if { (eval echo configure:14079: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14084: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -14084,7 +14089,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 14088 "configure"
+#line 14093 "configure"
@@ -14100,7 +14105,7 @@
; return 0; }
EOF
-if { (eval echo configure:14104: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14109: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -14120,11 +14125,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14124: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14129: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 14128 "configure"
+#line 14133 "configure"
@@ -14140,14 +14145,14 @@
; return 0; }
EOF
-if { (eval echo configure:14144: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14149: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 14151 "configure"
+#line 14156 "configure"
#define _FILE_OFFSET_BITS 64
@@ -14165,7 +14170,7 @@
; return 0; }
EOF
-if { (eval echo configure:14169: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14174: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -14184,11 +14189,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14188: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14193: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 14192 "configure"
+#line 14197 "configure"
@@ -14204,14 +14209,14 @@
; return 0; }
EOF
-if { (eval echo configure:14208: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14213: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14215 "configure"
+#line 14220 "configure"
#define _LARGE_FILES 1
@@ -14229,7 +14234,7 @@
; return 0; }
EOF
-if { (eval echo configure:14233: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14238: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -14248,25 +14253,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14252: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14257: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 14256 "configure"
+#line 14261 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14263: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14268: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14270 "configure"
+#line 14275 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -14275,7 +14280,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14279: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14284: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -14296,10 +14301,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14300: checking if system supports Large Files at all" >&5
+echo "configure:14305: checking if system supports Large Files at all" >&5
-#line 14303 "configure"
+#line 14308 "configure"
#include <stdio.h>
@@ -14331,7 +14336,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:14335: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14340: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -14360,7 +14365,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14364: checking whether to use Python" >&5
+echo "configure:14369: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -14380,7 +14385,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:14384: checking for $ac_word" >&5
+echo "configure:14389: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -14425,15 +14430,15 @@
do
-echo "configure:14429: checking for $ac_hdr" >&5
+echo "configure:14434: checking for $ac_hdr" >&5
-#line 14432 "configure"
+#line 14437 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14437: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14442: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14473,7 +14478,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:14477: checking for $ac_word" >&5
+echo "configure:14482: checking for $ac_word" >&5
case "$SWIG" in
@@ -14519,7 +14524,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14523: checking whether to use wxWidgets" >&5
+echo "configure:14528: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -14539,7 +14544,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:14543: checking for $ac_word" >&5
+echo "configure:14548: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -14587,7 +14592,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14591: checking wxWidgets version" >&5
+echo "configure:14596: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -14610,15 +14615,15 @@
do
-echo "configure:14614: checking for $ac_hdr" >&5
+echo "configure:14619: checking for $ac_hdr" >&5
-#line 14617 "configure"
+#line 14622 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14622: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14627: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14654,15 +14659,15 @@
do
-echo "configure:14658: checking for $ac_hdr" >&5
+echo "configure:14663: checking for $ac_hdr" >&5
-#line 14661 "configure"
+#line 14666 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14666: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14671: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2008-08-28 15:44:48 UTC (rev 33140)
+++ grass/trunk/configure.in 2008-08-28 16:33:59 UTC (rev 33141)
@@ -636,6 +636,11 @@
AC_MSG_CHECKING(whether to use GDAL)
+GDAL_LIBS=
+GDAL_CFLAGS=
+USE_GDAL=
+USE_OGR=
if test "`basename xx/$with_gdal`" = "gdal-config" ; then
GDAL_CONFIG="$with_gdal"
fi
@@ -650,11 +655,6 @@
AC_MSG_ERROR([*** couldn't find gdal-config])
fi
- GDAL_LIBS=
- GDAL_CFLAGS=
- USE_GDAL=
- USE_OGR=
if test "$GDAL_CONFIG" != "" ; then
GDAL_LIBS=`"$GDAL_CONFIG" --libs`
GDAL_DEP_LIBS=`"$GDAL_CONFIG" --dep-libs`
@@ -680,12 +680,14 @@
LIBS=${ac_save_libs}
CFLAGS=${ac_save_cflags}
- AC_SUBST(GDAL_LIBS)
- AC_SUBST(GDAL_CFLAGS)
- AC_SUBST(USE_GDAL)
- AC_SUBST(USE_OGR)
+ AC_DEFINE(HAVE_GDAL)
fi
+AC_SUBST(GDAL_LIBS)
+AC_SUBST(GDAL_CFLAGS)
+AC_SUBST(USE_GDAL)
+AC_SUBST(USE_OGR)
# Enable TIFF option
LOC_CHECK_USE(tiff,TIFF,USE_TIFF)
Modified: grass/trunk/include/config.h.in
--- grass/trunk/include/config.h.in 2008-08-28 15:44:48 UTC (rev 33140)
+++ grass/trunk/include/config.h.in 2008-08-28 16:33:59 UTC (rev 33141)
@@ -137,6 +137,9 @@
/* define if SQLite is to be used */
#undef HAVE_SQLITE
+/* define if GDAL is to be used */
+#undef HAVE_GDAL
/* define if OGR is to be used */
#undef HAVE_OGR
Modified: grass/trunk/include/gis.h
--- grass/trunk/include/gis.h 2008-08-28 15:44:48 UTC (rev 33140)
+++ grass/trunk/include/gis.h 2008-08-28 16:33:59 UTC (rev 33141)
@@ -28,10 +28,6 @@
#include <grass/config.h>
#include <grass/datetime.h>
-#ifdef GDAL_LINK
-#include <gdal.h>
-#endif
/*=========================== Constants/Defines ============================*/
#if !defined __GNUC__ || __GNUC__ < 2
@@ -627,17 +623,7 @@
int count;
-#ifdef GDAL_LINK
-struct GDAL_link
- char *filename;
- int band_num;
- DCELL null_val;
- GDALDatasetH data;
- GDALRasterBandH band;
- GDALDataType type;
-#endif
+struct GDAL_link;
/*============================== Prototypes ================================*/
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2008-08-28 15:44:48 UTC (rev 33140)
+++ grass/trunk/include/gisdefs.h 2008-08-28 16:33:59 UTC (rev 33141)
@@ -513,10 +513,8 @@
void G_fpreclass_perform_id(const struct FPReclass *, const CELL *, DCELL *,
int);
/* gdal.c */
-#ifdef GDAL_LINK
struct GDAL_link *G_get_gdal_link(const char *, const char *);
void G_close_gdal_link(struct GDAL_link *);
-#endif
/* geodesic.c */
int G_begin_geodesic_equation(double, double, double, double);
Modified: grass/trunk/lib/gis/G.h
--- grass/trunk/lib/gis/G.h 2008-08-28 15:44:48 UTC (rev 33140)
+++ grass/trunk/lib/gis/G.h 2008-08-28 16:33:59 UTC (rev 33141)
@@ -1,6 +1,10 @@
+#include <grass/config.h>
#include <grass/gis.h>
#include <rpc/types.h>
#include <rpc/xdr.h>
+#ifdef HAVE_GDAL
+#include <gdal.h>
+#endif
#define XDR_FLOAT_NBYTES 4
#define XDR_DOUBLE_NBYTES 8
@@ -14,6 +18,18 @@
typedef int COLUMN_MAPPING;
+struct GDAL_link
+ char *filename;
+ int band_num;
+ DCELL null_val;
+#ifdef HAVE_GDAL
+ GDALDatasetH data;
+ GDALRasterBandH band;
+ GDALDataType type;
+#endif
struct fileinfo /* Information for opened cell files */
int open_mode; /* see defines below */
@@ -44,9 +60,7 @@
unsigned char *null_work_buf; /* data buffer for reading null rows */
int min_null_row; /* Minimum row null row number in memory */
struct Quant quant;
-#ifdef GDAL_LINK
struct GDAL_link *gdal;
-#endif
struct G__ /* Structure of library globals */
Modified: grass/trunk/lib/gis/Makefile
--- grass/trunk/lib/gis/Makefile 2008-08-28 15:44:48 UTC (rev 33140)
+++ grass/trunk/lib/gis/Makefile 2008-08-28 16:33:59 UTC (rev 33141)
@@ -17,7 +17,7 @@
EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
endif
-ifneq ($(GDAL_LINK),)
+ifneq ($(USE_GDAL),)
EXTRA_CFLAGS += -DGDAL_LINK
EXTRA_INC += $(PROJINC) $(GDALCFLAGS)
EXTRA_LIBS += $(GDALLIBS)
Modified: grass/trunk/lib/gis/closecell.c
--- grass/trunk/lib/gis/closecell.c 2008-08-28 15:44:48 UTC (rev 33140)
+++ grass/trunk/lib/gis/closecell.c 2008-08-28 16:33:59 UTC (rev 33141)
@@ -134,10 +134,8 @@
This is obsolete since now the mask_bus is always allocated
-#ifdef GDAL_LINK
if (fcb->gdal)
G_close_gdal_link(fcb->gdal);
-#endif
for (i = 0; i < NULL_ROWS_INMEM; i++)
G_free(fcb->NULL_ROWS[i]);
Modified: grass/trunk/lib/gis/gdal.c
--- grass/trunk/lib/gis/gdal.c 2008-08-28 15:44:48 UTC (rev 33140)
+++ grass/trunk/lib/gis/gdal.c 2008-08-28 16:33:59 UTC (rev 33141)
@@ -1,20 +1,23 @@
+#include <stdlib.h>
+#include <string.h>
+#include "G.h"
-#ifdef GDAL_LINK
-#include <gdal.h>
struct GDAL_link *G_get_gdal_link(const char *name, const char *mapset)
+#ifdef HAVE_GDAL
static int initialized;
- const char *filename;
- int band_num;
GDALDatasetH data;
GDALDataType type;
+ RASTER_MAP_TYPE req_type;
+#endif
+ const char *filename;
+ int band_num;
- RASTER_MAP_TYPE map_type, req_type;
+ RASTER_MAP_TYPE map_type;
FILE *fp;
struct Key_Value *key_val;
const char *p;
@@ -55,12 +58,12 @@
else
null_val = atof(p);
+#ifdef HAVE_GDAL
p = G_find_key_value("type", key_val);
if (!p)
return NULL;
type = atoi(p);
switch (type) {
case GDT_Byte:
case GDT_Int16:
@@ -96,24 +99,27 @@
GDALClose(data);
return NULL;
+#endif
gdal = G_calloc(1, sizeof(struct GDAL_link));
gdal->filename = G_store(filename);
gdal->band_num = band_num;
gdal->null_val = null_val;
+#ifdef HAVE_GDAL
gdal->data = data;
gdal->band = band;
gdal->type = type;
+#endif
return gdal;
void G_close_gdal_link(struct GDAL_link *gdal)
+#ifdef HAVE_GDAL
GDALClose(gdal->data);
+#endif
G_free(gdal->filename);
G_free(gdal);
-#endif
Modified: grass/trunk/lib/gis/get_row.c
--- grass/trunk/lib/gis/get_row.c 2008-08-28 15:44:48 UTC (rev 33140)
+++ grass/trunk/lib/gis/get_row.c 2008-08-28 16:33:59 UTC (rev 33141)
@@ -198,7 +198,7 @@
-#ifdef GDAL_LINK
+#ifdef HAVE_GDAL
static int read_data_gdal(int fd, int row, unsigned char *data_buf, int *nbytes)
struct fileinfo *fcb = &G__.fileinfo[fd];
@@ -222,7 +222,7 @@
-#ifdef GDAL_LINK
+#ifdef HAVE_GDAL
if (fcb->gdal)
return read_data_gdal(fd, row, data_buf, nbytes);
#endif
@@ -373,7 +373,7 @@
-#ifdef GDAL_LINK
+#ifdef HAVE_GDAL
@@ -489,13 +489,13 @@
static void (*cell_values_type[3]) () = {
cell_values_int, cell_values_float, cell_values_double};
-#ifdef GDAL_LINK
+#ifdef HAVE_GDAL
static void (*gdal_values_type[3]) () = {
gdal_values_int, gdal_values_float, gdal_values_double};
#endif
-#ifdef GDAL_LINK
+#ifdef HAVE_GDAL
if (fcb->gdal)
(gdal_values_type[fcb->map_type]) (fd, fcb->data, fcb->col_map,
fcb->cur_nbytes, cell,
@@ -1130,7 +1130,7 @@
-#ifdef GDAL_LINK
+#ifdef HAVE_GDAL
static void get_null_value_row_gdal(int fd, char *flags, int row)
@@ -1177,7 +1177,7 @@
static void get_null_value_row(int fd, char *flags, int row, int with_mask)
-#ifdef GDAL_LINK
+#ifdef HAVE_GDAL
if (fcb->gdal)
get_null_value_row_gdal(fd, flags, row);
Modified: grass/trunk/lib/gis/opencell.c
--- grass/trunk/lib/gis/opencell.c 2008-08-28 15:44:48 UTC (rev 33140)
+++ grass/trunk/lib/gis/opencell.c 2008-08-28 16:33:59 UTC (rev 33141)
@@ -159,9 +159,7 @@
RASTER_MAP_TYPE MAP_TYPE;
struct Reclass reclass;
char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
-#ifdef GDAL_LINK
-#endif
/* make sure window is set */
G__init_window();
@@ -255,15 +253,21 @@
MAP_NBYTES = CELL_nbytes;
-#ifdef GDAL_LINK
- gdal = G_get_gdal_link(name, mapset);
- if (gdal)
+ gdal = G_get_gdal_link(r_name, r_mapset);
+ if (gdal) {
+#ifdef HAVE_GDAL
/* dummy descriptor to reserve the fileinfo slot */
fd = open("/dev/null", O_RDONLY);
+#else
+ G_warning(_("map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"),
+ r_name, r_mapset);
+ return -1;
+#endif
else
-#endif
- /* now actually open file for reading */
- fd = G_open_old(cell_dir, r_name, r_mapset);
+ /* now actually open file for reading */
+ fd = G_open_old(cell_dir, r_name, r_mapset);
if (fd < 0)
return -1;
@@ -297,16 +301,14 @@
if ((fcb->reclass_flag = reclass_flag))
G_copy(&fcb->reclass, &reclass, sizeof(reclass));
-#ifdef GDAL_LINK
if (gdal)
fcb->gdal = gdal;
else
-#endif
- /* check for compressed data format, making initial reads if necessary */
- if (G__check_format(fd) < 0) {
- close(fd); /* warning issued by check_format() */
- return -1;
+ /* check for compressed data format, making initial reads if necessary */
+ if (G__check_format(fd) < 0) {
+ close(fd); /* warning issued by check_format() */
+ return -1;
/* create the mapping from cell file to window */
G__create_window_mapping(fd);
Modified: grass/trunk/raster/r.external/Makefile
--- grass/trunk/raster/r.external/Makefile 2008-08-28 15:44:48 UTC (rev 33140)
+++ grass/trunk/raster/r.external/Makefile 2008-08-28 16:33:59 UTC (rev 33141)
@@ -8,4 +8,8 @@
include $(MODULE_TOPDIR)/include/Make/Module.make
default: cmd
+else
+default:
+endif
