[GRASS-SVN] r34675 - in grass/branches/develbranch_6: lib/vector/vedit vector/v.edit
Tue Dec 2 13:53:07 EST 2008
Author: martinl
Date: 2008-12-02 13:53:06 -0500 (Tue, 02 Dec 2008)
New Revision: 34675
   grass/branches/develbranch_6/lib/vector/vedit/cats.c
   grass/branches/develbranch_6/vector/v.edit/main.c
v.edit: don't print warning when cat is not deleted
Modified: grass/branches/develbranch_6/lib/vector/vedit/cats.c
--- grass/branches/develbranch_6/lib/vector/vedit/cats.c	2008-12-02 17:36:51 UTC (rev 34674)
+++ grass/branches/develbranch_6/lib/vector/vedit/cats.c	2008-12-02 18:53:06 UTC (rev 34675)
@@ -63,7 +63,7 @@
 		/* add new category */
 		if (!del) {
 		    if (Vect_cat_set(Cats, layer, cat) < 1) {
-			G_warning(_("Unable to set category %d for line %d"),
+			G_warning(_("Unable to set category %d for (feature id %d)"),
 				  cat, line);
 		    else {
@@ -71,11 +71,7 @@
 		else {		/* delete old category */
-		    if (Vect_field_cat_del(Cats, layer, cat) == 0) {
-			G_warning(_("Unable to delete layer/category %d/%d line %d"),
-				  layer, cat, line);
-		    else {
+		    if (Vect_field_cat_del(Cats, layer, cat) == 1) {
 			rewrite = 1;
Modified: grass/branches/develbranch_6/vector/v.edit/main.c
--- grass/branches/develbranch_6/vector/v.edit/main.c	2008-12-02 17:36:51 UTC (rev 34674)
+++ grass/branches/develbranch_6/vector/v.edit/main.c	2008-12-02 18:53:06 UTC (rev 34675)
@@ -200,6 +200,7 @@
     if (action_mode != MODE_CREATE && action_mode != MODE_ADD) {
 	/* select lines */
 	List = Vect_new_list();
+	G_message(_("Selecting features..."));
 	if (action_mode == MODE_COPY && BgMap && BgMap[0]) {
 	    List = select_lines(BgMap[0], action_mode, &params, thresh, List);
