[GRASS-SVN] r34676 - in grass/trunk: lib/vector/vedit vector/v.edit
svn_grass at osgeo.org
Tue Dec 2 13:55:29 EST 2008
Author: martinl
Date: 2008-12-02 13:55:29 -0500 (Tue, 02 Dec 2008)
New Revision: 34676
grass/trunk/lib/vector/vedit/cats.c
grass/trunk/vector/v.edit/main.c
v.edit: don't print warning when cat is not deleted
(merge from devbr6, r34675)
Modified: grass/trunk/lib/vector/vedit/cats.c
--- grass/trunk/lib/vector/vedit/cats.c 2008-12-02 18:53:06 UTC (rev 34675)
+++ grass/trunk/lib/vector/vedit/cats.c 2008-12-02 18:55:29 UTC (rev 34676)
@@ -63,7 +63,7 @@
/* add new category */
if (!del) {
if (Vect_cat_set(Cats, layer, cat) < 1) {
- G_warning(_("Unable to set category %d for line %d"),
+ G_warning(_("Unable to set category %d for (feature id %d)"),
cat, line);
else {
@@ -71,11 +71,7 @@
else { /* delete old category */
- if (Vect_field_cat_del(Cats, layer, cat) == 0) {
- G_warning(_("Unable to delete layer/category %d/%d line %d"),
- layer, cat, line);
- else {
+ if (Vect_field_cat_del(Cats, layer, cat) == 1) {
rewrite = 1;
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c 2008-12-02 18:53:06 UTC (rev 34675)
+++ grass/trunk/vector/v.edit/main.c 2008-12-02 18:55:29 UTC (rev 34676)
@@ -178,6 +178,7 @@
if (action_mode != MODE_CREATE && action_mode != MODE_ADD) {
/* select lines */
List = Vect_new_list();
+ G_message(_("Selecting features..."));
if (action_mode == MODE_COPY && BgMap && BgMap[0]) {
List = select_lines(BgMap[0], action_mode, ¶ms, thresh, List);
