[GRASS-SVN] r34870 - in grass/trunk: imagery/i.cluster
	imagery/i.gensig imagery/i.gensigset imagery/i.maxlik
	imagery/i.smap/bouman imagery/i.smap/shapiro raster/r.composite
    svn_grass at osgeo.org
    Sun Dec 14 09:20:47 EST 2008
Author: martinl
Date: 2008-12-14 09:20:47 -0500 (Sun, 14 Dec 2008)
New Revision: 34870
   grass/trunk/imagery/i.cluster/main.c
   grass/trunk/imagery/i.gensig/check.c
   grass/trunk/imagery/i.gensig/covariance.c
   grass/trunk/imagery/i.gensig/get_train.c
   grass/trunk/imagery/i.gensig/main.c
   grass/trunk/imagery/i.gensig/means.c
   grass/trunk/imagery/i.gensig/openfiles.c
   grass/trunk/imagery/i.gensig/parse.c
   grass/trunk/imagery/i.gensig/read_train.c
   grass/trunk/imagery/i.gensig/write_sig.c
   grass/trunk/imagery/i.gensigset/get_train.c
   grass/trunk/imagery/i.gensigset/main.c
   grass/trunk/imagery/i.gensigset/openfiles.c
   grass/trunk/imagery/i.gensigset/parse.c
   grass/trunk/imagery/i.gensigset/read_data.c
   grass/trunk/imagery/i.gensigset/read_train.c
   grass/trunk/imagery/i.gensigset/subcluster.c
   grass/trunk/imagery/i.gensigset/write_sig.c
   grass/trunk/imagery/i.maxlik/main.c
   grass/trunk/imagery/i.smap/bouman/decimate.c
   grass/trunk/imagery/i.smap/bouman/interp.c
   grass/trunk/imagery/i.smap/bouman/model.c
   grass/trunk/imagery/i.smap/bouman/multialloc.c
   grass/trunk/imagery/i.smap/bouman/read_block.c
   grass/trunk/imagery/i.smap/bouman/segment.c
   grass/trunk/imagery/i.smap/shapiro/closefiles.c
   grass/trunk/imagery/i.smap/shapiro/main.c
   grass/trunk/imagery/i.smap/shapiro/openfiles.c
   grass/trunk/imagery/i.smap/shapiro/parse.c
   grass/trunk/imagery/i.smap/shapiro/read_sig.c
   grass/trunk/imagery/i.smap/shapiro/write_img.c
   grass/trunk/raster/r.composite/main.c
imagery modules: message/paramaters standardization
	(merge from devbr6, r34868)
Modified: grass/trunk/imagery/i.cluster/main.c
--- grass/trunk/imagery/i.cluster/main.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.cluster/main.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -81,14 +81,12 @@
     parm.group_name = G_define_standard_option(G_OPT_I_GROUP);
-    parm.subgroup_name = G_define_option();
-    parm.subgroup_name->key = "subgroup";
-    parm.subgroup_name->type = TYPE_STRING;
-    parm.subgroup_name->required = YES;
-    parm.subgroup_name->description = _("Name of subgroup in the above group");
-    parm.out_sig = G_define_standard_option(G_OPT_F_OUTPUT);
+    parm.subgroup_name = G_define_standard_option(G_OPT_I_SUBGROUP);
+    parm.out_sig = G_define_option();
     parm.out_sig->key = "signaturefile";
+    parm.out_sig->type = TYPE_STRING;
+    parm.out_sig->key_desc = "name";
     parm.out_sig->required = YES;
     parm.out_sig->description = _("Name for output file containing result signatures");
@@ -100,9 +98,11 @@
     parm.class->description = _("Initial number of classes");
     parm.class->guisection = _("Settings");
-    parm.seed_sig = G_define_standard_option(G_OPT_F_INPUT);
+    parm.seed_sig = G_define_option();
     parm.seed_sig->key = "seed";
     parm.seed_sig->required = NO;
+    parm.seed_sig->type = TYPE_STRING;
+    parm.seed_sig->key_desc = "name";
     parm.seed_sig->description = _("Name of file containing initial signatures");
     parm.sample_interval = G_define_option();
Modified: grass/trunk/imagery/i.gensig/check.c
--- grass/trunk/imagery/i.gensig/check.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensig/check.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -18,19 +18,19 @@
 	copy_covariances(temp.sig[0].var, S->sig[i].var, S->nbands);
 	if (!can_invert(temp.sig[0].var, S->nbands)) {
 	    S->sig[i].status = -1;
-	    G_message(_("Signature [%d] not invertible."), i + 1);
+	    G_important_message(_("Signature %d not invertible"), i + 1);
 	    continue;
 	if (!eigen(temp.sig[0].var, lambda, S->nbands)) {
-	    G_message(_("Signature [%d] can't get eigen values."), i + 1);
+	    G_important_message(_("Signature %d unable to get eigen values"), i + 1);
 	    continue;
 	for (j = 0; j < S->nbands; j++) {
 	    if (lambda[j] <= 0.0) {
-		G_message(_("Signature [%d] not positive definite."), i + 1);
+		G_important_message(_("Signature %d not positive definite"), i + 1);
 		break;
Modified: grass/trunk/imagery/i.gensig/covariance.c
--- grass/trunk/imagery/i.gensig/covariance.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensig/covariance.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -24,10 +24,7 @@
     ncols = G_window_cols();
     class = (CELL *) G_calloc(ncols, sizeof(CELL));
-    if (S->nsigs == 1)
-	G_message(_("Calculating class covariance matrix..."));
-    else
-	G_message(_("Calculating class covariance matrices..."));
+    G_message(_("Calculating class covariance matrices..."));
     for (row = 0; row < nrows; row++) {
 	G_percent(row, nrows, 2);
@@ -35,7 +32,8 @@
 	for (b = 0; b < files->nbands; b++)	/* NOTE: files->nbands == S->nbands */
 	    if (G_get_d_raster_row
 		(files->band_fd[b], files->band_cell[b], row) < 0)
-		exit(1);
+		G_fatal_error(_("Unable to read raster map row %d"),
+			      row);
 	for (b1 = 0; b1 < files->nbands; b1++) {
 	    cell1 = files->band_cell[b1];
 	    for (b2 = 0; b2 <= b1; b2++) {	/* only need to calculate the lower half */
@@ -52,7 +50,8 @@
-    G_percent(row, nrows, 2);
+    G_percent(nrows, nrows, 2);
     for (n = 0; n < S->nsigs; n++)	/* for each signature (aka class) */
 	for (b1 = 0; b1 < S->nbands; b1++)
Modified: grass/trunk/imagery/i.gensig/get_train.c
--- grass/trunk/imagery/i.gensig/get_train.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensig/get_train.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -26,7 +26,7 @@
     /* determine the categories in the map */
     I_init_signatures(S, files->nbands);
     G_init_cell_stats(&cell_stats);
-    G_message(_("Finding training classes ..."));
+    G_message(_("Finding training classes..."));
 	if (G_get_c_raster_row(fd, cell, row) < 0)
@@ -34,7 +34,7 @@
 			  row);
 	G_update_cell_stats(cell, ncols, &cell_stats);
     /* convert this to an array */
     G_rewind_cell_stats(&cell_stats);
@@ -51,12 +51,12 @@
 	    n++;
 	else
-	    G_warning(_("Training class [%d] only has one cell - this class will be ignored."),
+	    G_warning(_("Training class %d only has one cell - this class will be ignored"),
 		      cat);
     if (n == 0)
-	G_fatal_error(_("Training map has no classes."));
+	G_fatal_error(_("Training map has no classes"));
     list = (CELL *) G_calloc(n, sizeof(CELL));
     n = 0;
@@ -71,9 +71,9 @@
     files->training_cats = list;
     if (files->ncats == 1)
-	G_message(_("1 class."));
+	G_message(_("1 class found"));
     else
-	G_message(_("%d classes."), files->ncats);
+	G_message(_("%d classes found"), files->ncats);
     return 0;
Modified: grass/trunk/imagery/i.gensig/main.c
--- grass/trunk/imagery/i.gensig/main.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensig/main.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -36,9 +36,9 @@
     G_gisinit(argv[0]);
     module = G_define_module();
-    module->keywords = _("imagery");
+    module->keywords = _("imagery, classification, supervised, MLC");
     module->description =
-	_("Generates statistics for i.maxlik " "from raster map layer.");
+	_("Generates statistics for i.maxlik from raster map.");
     parse(argc, argv, &parms);
     openfiles(&parms, &files);
@@ -50,5 +50,7 @@
     check_signatures(&S);
     write_sigfile(&parms, &S);
-    exit(0);
+    G_done_msg(" ");
+    exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.gensig/means.c
--- grass/trunk/imagery/i.gensig/means.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensig/means.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -22,10 +22,7 @@
-	G_message(_("Calculating class mean ..."));
-    else
-	G_message(_("Calculating class means ..."));
+    G_message(_("Calculating class means..."));
@@ -46,7 +43,8 @@
 	for (b = 0; b < S->nbands; b++)	/* for each band file */
 	    S->sig[n].mean[b] /= S->sig[n].npoints;
Modified: grass/trunk/imagery/i.gensig/openfiles.c
--- grass/trunk/imagery/i.gensig/openfiles.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensig/openfiles.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -13,11 +13,11 @@
     if (!I_get_subgroup_ref(parms->group, parms->subgroup, &Ref))
-	G_fatal_error(_("Unable to read REF file for subgroup [%s] in group [%s]."),
+	G_fatal_error(_("Unable to read REF file for subgroup <%s> in group <%s>"),
 		      parms->subgroup, parms->group);
     if (Ref.nfiles <= 0)
-	G_fatal_error(_("Subgroup [%s] in group [%s] contains no files."),
+	G_fatal_error(_("Subgroup <%s> in group <%s> contains no raster maps."),
     /* allocate file descriptors, and array of io buffers */
Modified: grass/trunk/imagery/i.gensig/parse.c
--- grass/trunk/imagery/i.gensig/parse.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensig/parse.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -9,34 +9,22 @@
     struct Option *group, *subgroup, *sigfile, *trainingmap;
-    trainingmap = G_define_option();
+    trainingmap = G_define_standard_option(G_OPT_R_MAP);
     trainingmap->key = "trainingmap";
     trainingmap->description = _("Ground truth training map");
-    trainingmap->required = YES;
-    trainingmap->type = TYPE_STRING;
-    trainingmap->gisprompt = "old,cell,raster";
-    group = G_define_option();
-    group->key = "group";
-    group->description = _("Imagery group");
-    group->required = YES;
-    group->type = TYPE_STRING;
-    group->gisprompt = "old,group,group";
+    group = G_define_standard_option(G_OPT_I_GROUP);
-    subgroup = G_define_option();
-    subgroup->key = "subgroup";
-    subgroup->description = _("Subgroup containing image files");
-    subgroup->required = YES;
-    subgroup->type = TYPE_STRING;
+    subgroup = G_define_standard_option(G_OPT_I_SUBGROUP);
     sigfile = G_define_option();
     sigfile->key = "signaturefile";
-    sigfile->description = _("Resultant signature file");
+    sigfile->description = _("Name for output file containing result signatures");
     sigfile->required = YES;
     sigfile->type = TYPE_STRING;
     if (G_parser(argc, argv))
-	exit(1);
+	exit(EXIT_FAILURE);
     parms->training_map = trainingmap->answer;
     parms->group = group->answer;
Modified: grass/trunk/imagery/i.gensig/read_train.c
--- grass/trunk/imagery/i.gensig/read_train.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensig/read_train.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -1,12 +1,14 @@
 #include <stdlib.h>
 #include <grass/imagery.h>
+#include <grass/glocale.h>
 #include "files.h"
 #include "local_proto.h"
 int read_training_map(CELL * class, int row, int ncols, struct files *files)
     if (G_get_c_raster_row(files->train_fd, files->train_cell, row) < 0)
-	exit(1);
+		      row);
     lookup_class(files->train_cell, ncols, files->training_cats, files->ncats,
 		 class);
Modified: grass/trunk/imagery/i.gensig/write_sig.c
--- grass/trunk/imagery/i.gensig/write_sig.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensig/write_sig.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -12,13 +12,11 @@
     fd = I_fopen_signature_file_new(parms->group, parms->subgroup,
 				    parms->sigfile);
     if (fd == NULL)
-	G_fatal_error(_("Unable to create signature file [%s] for "
-			"subgroup [%s] in group [%s]."),
-		      parms->sigfile, parms->subgroup, parms->group);
-    G_message(_("Writing signature file [%s] ..."), parms->sigfile);
+	G_fatal_error(_("Unable to create signature file <%s>"),
+		      parms->sigfile);
+    G_verbose_message(_("Writing signatures..."));
     I_write_signatures(fd, S);
-    G_message(_("Done."));
     return 0;
Modified: grass/trunk/imagery/i.gensigset/get_train.c
--- grass/trunk/imagery/i.gensigset/get_train.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensigset/get_train.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include "files.h"
 #include "parms.h"
@@ -28,14 +29,15 @@
     I_SetSigTitle(S, G_get_cats_title(&files->training_labels));
-    fprintf(stderr, "Finding training classes ...");
-	    exit(1);
+	    G_fatal_error(_("Unable to read raster map <%s> row %d"), cell,
+			  row);
@@ -52,14 +54,12 @@
 	    n++;
 	else
-	    fprintf(stderr,
-		    "WARNING: Training class [%d] only has one cell - this class will be ignored\n",
-		    cat);
+		      cat);
     if (n == 0) {
-	fprintf(stderr, "ERROR: training map has no classes\n");
-	exit(1);
@@ -73,8 +73,11 @@
     files->ncats = n;
-    fprintf(stderr, "%d class%s\n", files->ncats,
-	    files->ncats == 1 ? "" : "es");
+    if (files->ncats == 1)
+    else
     return 0;
Modified: grass/trunk/imagery/i.gensigset/main.c
--- grass/trunk/imagery/i.gensigset/main.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensigset/main.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -37,9 +37,9 @@
     G_gisinit(argv[0]);
+    module->keywords = _("imagery, classification, supervised, SMAP");
-	"Generate statistics for i.smap from raster map layer.";
+	_("Generates statistics for i.smap from raster map.");
@@ -49,12 +49,15 @@
     read_data(&files, &S);
     for (i = 0; i < S.nclasses; i++) {
-	fprintf(stderr, "Clustering class %d, with %d pixels\n",
-		i + 1, S.ClassSig[i].ClassData.npixels);
+	G_message(_("Clustering class %d (%d pixels)..."),
+		  i + 1, S.ClassSig[i].ClassData.npixels);
 	subcluster(&S, i, &junk, parms.maxsubclasses);
-	fprintf(stderr, " Solution: Number of subclasses is %d\n",
-		S.ClassSig[i].nsubclasses);
+	G_message(_("Number of subclasses is %d"),
+		  S.ClassSig[i].nsubclasses);
-    exit(0);
+    G_done_msg(" ");
Modified: grass/trunk/imagery/i.gensigset/openfiles.c
--- grass/trunk/imagery/i.gensigset/openfiles.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensigset/openfiles.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -12,16 +12,12 @@
     if (!I_get_subgroup_ref(parms->group, parms->subgroup, &Ref)) {
-	fprintf(stderr,
-		"ERROR: unable to read REF file for subgroup [%s] in group [%s]\n",
-		parms->subgroup, parms->group);
-	exit(1);
+		      parms->subgroup, parms->group);
     if (Ref.nfiles <= 0) {
-	fprintf(stderr,
-		"ERROR: subgroup [%s] in group [%s] contains no files\n",
-	exit(1);
Modified: grass/trunk/imagery/i.gensigset/parse.c
--- grass/trunk/imagery/i.gensigset/parse.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensigset/parse.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -1,47 +1,36 @@
 #include <stdlib.h>
 #include <grass/gis.h>
 #include "parms.h"
 int parse(int argc, char *argv[], struct parms *parms)
     struct Option *group, *subgroup, *sigfile, *trainingmap, *maxsig;
-    trainingmap->description = "ground truth training map";
+    trainingmap->description = _("Ground truth training map");
-    group->description = "imagery group";
-    subgroup->description = "subgroup containing image files";
-    sigfile->description = "resultant signature file";
     maxsig = G_define_option();
     maxsig->key = "maxsig";
-    maxsig->description = "maximum number of sub-signatures in any class";
+    maxsig->description = _("Maximum number of sub-signatures in any class");
     maxsig->required = NO;
     maxsig->type = TYPE_INTEGER;
     maxsig->answer = "10";
-	exit(1);
@@ -50,23 +39,18 @@
     /* check all the inputs */
     if (G_find_cell(parms->training_map, "") == NULL) {
-	fprintf(stderr, "ERROR: training map [%s] not found\n",
-		parms->training_map);
-	exit(1);
+	G_fatal_error(_("Raster map <%s> not found"), parms->training_map);
     if (!I_find_group(parms->group)) {
-	fprintf(stderr, "ERROR: group [%s] not found\n", parms->group);
-	exit(1);
+	G_fatal_error(_("Group <%s> not found"), parms->group);
     if (!I_find_subgroup(parms->group, parms->subgroup)) {
-	fprintf(stderr, "ERROR: subgroup [%s] not found\n", parms->subgroup);
-	exit(1);
+	G_fatal_error(_("Subgroup <%s> not found"), parms->subgroup);
     if (sscanf(maxsig->answer, "%d", &parms->maxsubclasses) != 1 ||
 	parms->maxsubclasses <= 0) {
-	fprintf(stderr, "ERROR: illegal number of sub-signatures [%s]\n",
-		maxsig->answer);
-	exit(1);
+	G_fatal_error(_("Illegal number of sub-signatures (%s)"),
+		      maxsig->answer);
     return 0;
Modified: grass/trunk/imagery/i.gensigset/read_data.c
--- grass/trunk/imagery/i.gensigset/read_data.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensigset/read_data.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include "files.h"
 /* #include "local_proto.h" */
@@ -15,7 +16,7 @@
-    fprintf(stderr, "Reading image data ...");
+    G_message(_("Reading raster maps..."));
@@ -23,7 +24,8 @@
-		exit(1);
+			      row);
 	for (col = 0; col < ncols; col++) {
 	    n = class[col];
@@ -39,7 +41,7 @@
 	    Data->count++;
     G_free(class);
     return 0;
Modified: grass/trunk/imagery/i.gensigset/read_train.c
--- grass/trunk/imagery/i.gensigset/read_train.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensigset/read_train.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -1,12 +1,14 @@
 #include <stdlib.h>
 #include "files.h"
-	exit(1);
+		      row);
 		 class);
Modified: grass/trunk/imagery/i.gensigset/subcluster.c
--- grass/trunk/imagery/i.gensigset/subcluster.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensigset/subcluster.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -2,9 +2,9 @@
 #include <stdlib.h>
-#define PI M_PI
 #define ZERO 1e-10
 #define SMALLEST_SUBCLUST 1
@@ -19,8 +19,6 @@
 static void add_SubSigs();
 static void copy_ClassSig();
 static void copy_SubSig();
-static void list_Sig();
-static void print_class();
 static int total_nulls, *n_nulls;
@@ -66,15 +64,15 @@
     /* compute number of data points */
     ndata_points = Sig->ClassData.npixels * nbands - total_nulls;
     if (ndata_points <= 1)
-	G_fatal_error("Not enough data points!");
+	G_fatal_error("Not enough data points");
     /* Check for too few pixels */
     *Max_num = (ndata_points + 1) / nparams_clust - 1;
     if (maxsubclasses > *Max_num / 2)
 	maxsubclasses = *Max_num / 2;
     if (maxsubclasses < 1) {
-	fprintf(stderr, "\nWarning: Not enough pixels in class %d\n",
-		Class_Index + 1);
+	G_warning(_("Not enough pixels in class %d"),
+		  Class_Index + 1);
 	Sig->nsubclasses = 0;
 	Sig->used = 0;
 	return;
@@ -83,10 +81,10 @@
     /* check for too many subclasses */
     if (Sig->nsubclasses > maxsubclasses) {
 	Sig->nsubclasses = maxsubclasses;
-	fprintf(stderr, "\nWarning: Too many subclasses for class index %d\n",
-		Class_Index + 1);
-	fprintf(stderr, "         number of subclasses set to %d\n\n",
-		Sig->nsubclasses);
+	G_warning(_("Too many subclasses for class index %d"),
+		  Class_Index + 1);
+	G_message(_("Number of subclasses set to %d"),
+		  Sig->nsubclasses);
@@ -95,16 +93,16 @@
     /* EM algorithm */
     min_riss = refine_clusters(Sig, nbands);
-    fprintf(stderr, "Subclasses = %d; Rissanen = %f; ", Sig->nsubclasses,
-	    min_riss);
+    G_debug(1, "Subclasses = %d Rissanen = %f", Sig->nsubclasses,
+	      min_riss);
     copy_ClassSig(Sig, min_Sig, nbands);
     while (Sig->nsubclasses > 1) {
 	reduce_order(Sig, nbands, &min_i, &min_j);
-	fprintf(stderr, "Combining Subclasses (%d,%d)\n", min_i + 1,
-		min_j + 1);
+	G_verbose_message(_("Combining subclasses (%d,%d)..."), min_i + 1,
+			  min_j + 1);
 	rissanen = refine_clusters(Sig, nbands);
+	G_debug(1, "Subclasses = %d; Rissanen = %f", Sig->nsubclasses,
 		rissanen);
 	if (rissanen < min_riss) {
 	    min_riss = rissanen;
@@ -310,9 +308,9 @@
 	/* For small subclusters */
 	else {
-	    fprintf(stderr, "Warning: subsignature %d only contains ", i);
-	    fprintf(stderr, " %f pixels\n", Sig->SubSig[i].N);
+	    G_warning(_("Subsignature %d only contains %f pixels"),
+		      i, Sig->SubSig[i].N);
 	    Sig->SubSig[i].pi = 0;
 	    for (b1 = 0; b1 < nbands; b1++)
@@ -545,8 +543,8 @@
 	    if (Sig->nsubclasses == 1) {
 		Sig->nsubclasses--;
 		singular = 2;
-		fprintf(stderr, "\nError: unreliable clustering\n");
-		fprintf(stderr, "try a smaller initial number of clusters\n");
+		G_warning(_("Unreliable clustering. "
+			    "Try a smaller initial number of clusters"));
 	    else {
 		for (j = i; j < Sig->nsubclasses - 1; j++)
@@ -554,17 +552,15 @@
 				nbands);
 		Sig->nsubclasses--;
 		singular = 1;
-		fprintf(stderr,
-			"Warning: Removed a singular subsignature; number %d;",
-			i + 1);
-		fprintf(stderr, " %d remain\n", Sig->nsubclasses);
+		G_warning(_("Removed a singular subsignature number %d (%d remain)"),
+			  i + 1, Sig->nsubclasses);
 		if (Sig->nsubclasses < 0)	/* MN added 12/2001: to avoid endless loop */
 		    Sig->nsubclasses = 1;
 	else {
 	    Sig->SubSig[i].cnst =
-		(-nbands / 2.0) * log(2 * PI) - 0.5 * log(det);
+		(-nbands / 2.0) * log(2 * M_PI) - 0.5 * log(det);
 	    i++;
     } while (i < Sig->nsubclasses);
@@ -654,42 +650,3 @@
-static void list_Sig(struct ClassSig *Sig, int nbands)
-    int i, j, k;
-    for (i = 0; i < Sig->nsubclasses; i++) {
-	fprintf(stderr, "Subclass %d: pi = %f, ", i + 1, Sig->SubSig[i].pi);
-	fprintf(stderr, "cnst = %f\n", Sig->SubSig[i].cnst);
-	for (j = 0; j < nbands; j++) {
-	    fprintf(stderr, "%f;    ", Sig->SubSig[i].means[j]);
-	    for (k = 0; k < nbands; k++)
-		fprintf(stderr, "%f ", Sig->SubSig[i].R[j][k]);
-	    fprintf(stderr, "\n");
-static void print_class(struct ClassSig *Sig, char *fname)
-    FILE *fp;
-    int s, i;
-    if ((fp = fopen(fname, "w")) == NULL) {
-	fprintf(stderr, "can't open data file\n");
-	exit(1);
-    for (s = 0; s < Sig->ClassData.npixels; s++) {
-	/* fprintf(fp,"Pixel number %d:  ", s); */
-	    fprintf(fp, "%f  ", Sig->ClassData.p[s][i]);
-	fprintf(fp, "\n");
-    fclose(fp);
Modified: grass/trunk/imagery/i.gensigset/write_sig.c
--- grass/trunk/imagery/i.gensigset/write_sig.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.gensigset/write_sig.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include "parms.h"
 int write_sigfile(struct parms *parms, struct SigSet *S)
@@ -9,17 +10,12 @@
     fd = I_fopen_sigset_file_new(parms->group, parms->subgroup,
 				 parms->sigfile);
     if (fd == NULL) {
-	fprintf(stderr, "ERROR: unable to create signature file [%s] ",
-		parms->sigfile);
-	fprintf(stderr, "for subgroup [%s] in group [%s]\n", parms->subgroup,
-		parms->group);
-	exit(1);
-    fprintf(stderr, "Writing signature file [%s] ...", parms->sigfile);
-    fflush(stderr);
+		      parms->sigfile);
     I_WriteSigSet(fd, S);
     fclose(fd);
     return 0;
Modified: grass/trunk/imagery/i.maxlik/main.c
--- grass/trunk/imagery/i.maxlik/main.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.maxlik/main.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -56,7 +56,7 @@
     G_gisinit(argv[0]);
-    module->keywords = _("imagery, classification");
+    module->keywords = _("imagery, classification, MLC");
     module->label =
 	_("Classifies the cell spectral reflectances in imagery data.");
@@ -65,15 +65,13 @@
     parm.group = G_define_standard_option(G_OPT_I_GROUP);
-    parm.subgroup = G_define_option();
-    parm.subgroup->key = "subgroup";
-    parm.subgroup->type = TYPE_STRING;
-    parm.subgroup->required = YES;
-    parm.subgroup->description = _("Name of subgroup in the above group");
+    parm.subgroup = G_define_standard_option(G_OPT_I_SUBGROUP);
-    parm.sigfile = G_define_standard_option(G_OPT_F_INPUT);
+    parm.sigfile = G_define_option();
     parm.sigfile->key = "sigfile";
     parm.sigfile->required = YES;
+    parm.sigfile->type = TYPE_STRING;
+    parm.sigfile->key_desc = "name";
     parm.sigfile->label = _("Name of file containing signatures");
     parm.sigfile->description = _("Generated by either i.cluster, i.class, or i.gensig");
@@ -104,7 +102,7 @@
-	G_percent(row+1, nrows, 2);
+	G_percent(row, nrows, 2);
 	for (band = 0; band < Ref.nfiles; band++)
 	    if (G_get_d_raster_row(cellfd[band], cell[band], row) < 0)
@@ -116,7 +114,8 @@
 	if (reject_fd > 0)
 	    G_put_raster_row(reject_fd, reject_cell, CELL_TYPE);
     G_close_cell(class_fd);
     if (reject_fd > 0)
 	G_close_cell(reject_fd);
Modified: grass/trunk/imagery/i.smap/bouman/decimate.c
--- grass/trunk/imagery/i.smap/bouman/decimate.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.smap/bouman/decimate.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -26,8 +26,8 @@
     reg_to_wdht(region, &wd, &ht);
     while ((wd > 2) && (ht > 2)) {
 	if (vlevel >= 2)
-	    G_message("D = %d  alpha = %f; 1-alpha = %f", D, alpha[D],
-		      1 - alpha[D]);
+	    G_debug(1, "D = %d  alpha = %f; 1-alpha = %f", D, alpha[D],
+		    1 - alpha[D]);
 	decimate(ll_pym[D], region, M, ll_pym[D + 1], alpha[D]);
 	dec_reg(region);
Modified: grass/trunk/imagery/i.smap/bouman/interp.c
--- grass/trunk/imagery/i.smap/bouman/interp.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.smap/bouman/interp.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -100,7 +100,7 @@
     /* Interpolate the classification at each resolution */
     for (D--; D >= 0; D--) {
 	if (vlevel >= 2)
-	    G_message(_("\nResolution = %d; period = %d"), D, period[D]);
+	    G_debug(1, "Resolution = %d; period = %d", D, period[D]);
 	for (j = 0; j < 3; j++)
 	    alpha[j] *= (1 - EM_PRECISION * 10);
@@ -114,7 +114,7 @@
 	    if (vlevel >= 4)
 		print_N(N);
 	    if (vlevel >= 4)
-		G_message("log likelihood = %f\n", log_like(N, alpha, M));
+		G_debug(1, "log likelihood = %f", log_like(N, alpha, M));
 		tmp[j] = alpha[j];
@@ -122,7 +122,7 @@
 	    if (vlevel >= 2)
 		print_alpha(alpha);
 	    if (vlevel >= 4)
 	    for (diff1 = j = 0; j < 3; j++)
 		diff1 += fabs(tmp[j] - alpha[j]);
@@ -174,14 +174,12 @@
     int n0, n1, n2;
-    G_message(_("Class transition statistics."));
+    G_debug(2, "Class transition statistics");
     for (n0 = 0; n0 < 2; n0++) {
 	for (n1 = 0; n1 < 3; n1++) {
 	    for (n2 = 0; n2 < 2; n2++)
-		fprintf(stderr, "%f ", N[n0][n1][n2]);
+		G_debug(3, "   %f", N[n0][n1][n2]);
@@ -190,9 +188,9 @@
 			   /* prints out transition parameters. */
 			   double *alpha)
-    G_message(_("Transition probabilities: %f %f %f; %f"),
-	      alpha[0], alpha[1], alpha[2],
-	      1.0 - alpha[0] - 2 * alpha[1] - alpha[2]);
+    G_debug(1, "Transition probabilities: %f %f %f; %f",
+	    alpha[0], alpha[1], alpha[2],
+	    1.0 - alpha[0] - 2 * alpha[1] - alpha[2]);
@@ -236,7 +234,7 @@
     alpha2 = alpha[2];
     Constant = (1 - alpha0 - 2 * alpha1 - alpha2) / M;
     if (Constant < 0)
-	G_fatal_error(_("interp: invalid parameter values."));
+	G_fatal_error(_("Invalid parameter values"));
     /* precompute logs and zero static vector */
     for (nn0 = 0; nn0 < 2; nn0++)
Modified: grass/trunk/imagery/i.smap/bouman/model.c
--- grass/trunk/imagery/i.smap/bouman/model.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.smap/bouman/model.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -35,7 +35,7 @@
 		for (b2 = 0; b2 < nbands; b2++) {
 		    if (SubS->R[b1][b2] != SubS->R[b2][b1])
-			G_warning(_("\nNonsymetric covariance for class [%d] subclass [%d]."),
+			G_warning(_("Nonsymetric covariance for class %d subclass %d"),
 				  m + 1, i + 1);
 		    SubS->Rinv[b1][b2] = SubS->R[b1][b2];
@@ -45,7 +45,7 @@
 	    eigen(SubS->Rinv, lambda, nbands);
 	    for (b1 = 0; b1 < nbands; b1++) {
 		if (lambda[b1] <= 0.0)
-		    G_warning(_("Nonpositive eigenvalues for class [%d] subclass [%d]."),
+		    G_warning(_("Nonpositive eigenvalues for class %d subclass %d"),
 			      m + 1, i + 1);
Modified: grass/trunk/imagery/i.smap/bouman/multialloc.c
--- grass/trunk/imagery/i.smap/bouman/multialloc.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.smap/bouman/multialloc.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -112,7 +112,7 @@
     char *pt;
     if ((pt = multialloc(size, 2, ht, wd)) == NULL)
-	G_fatal_error(_("get_img: out of memory."));
+	G_fatal_error(_("Out of memory"));
     return ((unsigned char **)pt);
Modified: grass/trunk/imagery/i.smap/bouman/read_block.c
--- grass/trunk/imagery/i.smap/bouman/read_block.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.smap/bouman/read_block.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include "bouman.h"
 #include "region.h"
@@ -12,7 +13,8 @@
 	for (row = region->ymin; row < region->ymax; row++) {
 	    if (G_get_d_raster_row(files->band_fd[band], files->cellbuf, row)
 		< 0)
-		exit(1);
+			      row);
 	    for (col = region->xmin; col < region->xmax; col++)
 		img[band][row][col] = files->cellbuf[col];
Modified: grass/trunk/imagery/i.smap/bouman/segment.c
--- grass/trunk/imagery/i.smap/bouman/segment.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.smap/bouman/segment.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -34,6 +34,7 @@
     int quiet;			/* be quiet when running? */
     DCELL ***img;		/* multispectral image, img[band][i][j] */
+    int last_row;
     int wd, ht;			/* image width and height */
     struct Region region;	/* specifies image subregion */
     int nbands;			/* number of bands */
@@ -66,7 +67,7 @@
     /* Check for too many classes */
     if (nclasses > 256)
-	G_fatal_error(_("Number of classes must be < 256!"));
+	G_fatal_error(_("Number of classes must be < 256"));
     /* allocate alpha_dec parameters */
     D = levels(block_size, block_size);
@@ -88,11 +89,12 @@
     /* tiled segmentation */
     init_reg(®ion, wd, ht, block_size);
     extract_init(S);
+    last_row = -1;
     do {
-	if (vlevel >= 1)
-	    G_message(_("Processing rows %d-%d (of %d), cols=%d-%d (of %d)"),
-		      region.ymin + 1, region.ymax, ht,
-		      region.xmin + 1, region.xmax, wd);
+	if (vlevel >= 1 && last_row != region.ymin)
+	    G_message(_("Processing rows %d-%d (of %d)..."),
+		      region.ymin + 1, region.ymax, ht);
+	last_row = region.ymin;
 	shift_img(img, nbands, ®ion, block_size);
 	/* this reads grass images into the block defined in region */
 	read_block(img, ®ion, files);
Modified: grass/trunk/imagery/i.smap/shapiro/closefiles.c
--- grass/trunk/imagery/i.smap/shapiro/closefiles.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.smap/shapiro/closefiles.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -10,8 +10,7 @@
     int n;
-    if (parms->quiet)
-	G_message(_("Creating support files for <%s>..."), parms->output_map);
+    G_debug(1, "Creating support files for <%s>...", parms->output_map);
     for (n = 0; n < files->nbands; n++)
 	G_close_cell(files->band_fd[n]);
Modified: grass/trunk/imagery/i.smap/shapiro/main.c
--- grass/trunk/imagery/i.smap/shapiro/main.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.smap/shapiro/main.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -11,7 +11,7 @@
  *               Jan-Oliver Wagner <jan intevation.de>
  * PURPOSE:      segment multispectral images using a spectral class model
  *               known as a Gaussian mixture distribution
- * COPYRIGHT:    (C) 1999-2006 by the GRASS Development Team
+ * COPYRIGHT:    (C) 1999-2008 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -35,7 +35,7 @@
     G_gisinit(argv[0]);
 	_("Performs contextual image classification "
 	  "using sequential maximum a posteriori (SMAP) estimation.");
@@ -48,5 +48,8 @@
     segment(&S, &parms, &files);
     closefiles(&parms, &files);
+    G_done_msg(" ");
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.smap/shapiro/openfiles.c
--- grass/trunk/imagery/i.smap/shapiro/openfiles.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.smap/shapiro/openfiles.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -12,11 +12,11 @@
+	G_fatal_error(_("Subgroup <%s> in group <%s> contains no raster maps"),
     /* allocate file descriptors, and io buffer */
Modified: grass/trunk/imagery/i.smap/shapiro/parse.c
--- grass/trunk/imagery/i.smap/shapiro/parse.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.smap/shapiro/parse.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -18,11 +18,14 @@
-    sigfile->description = _("Name of imagery signaturefile");
+    sigfile->label = _("Name of file containing signatures");
+    sigfile->description = _("Generated by i.gensigset");
+    output = G_define_standard_option(G_OPT_R_OUTPUT);
     blocksize = G_define_option();
     blocksize->key = "blocksize";
     blocksize->description = _("Size of submatrix to process at one time");
@@ -30,8 +33,6 @@
     blocksize->type = TYPE_INTEGER;
     blocksize->answer = "128";
-    output = G_define_standard_option(G_OPT_R_OUTPUT);
     ml = G_define_flag();
     ml->key = 'm';
     ml->description =
@@ -54,10 +55,10 @@
-	G_fatal_error(_("Group [%s] not found."), parms->group);
-	G_fatal_error(_("Subgroup [%s] not found."), parms->subgroup);
     if (sscanf(blocksize->answer, "%d", &parms->blocksize) != 1
 	|| parms->blocksize <= 8)
Modified: grass/trunk/imagery/i.smap/shapiro/read_sig.c
--- grass/trunk/imagery/i.smap/shapiro/read_sig.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.smap/shapiro/read_sig.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -10,21 +10,21 @@
     struct Ref Ref;
     fd = I_fopen_sigset_file_old(parms->group, parms->subgroup,
 				 parms->sigfile);
     if (fd == NULL)
-	G_fatal_error(_("Signature file [%s] is missing or not readable."),
+	G_fatal_error(_("Unable to read signature file <%s>"),
 		      parms->sigfile);
     if (I_ReadSigSet(fd, S) < 0 || Ref.nfiles != S->nbands)
-	G_fatal_error(_("Signature file [%s] is invalid."), parms->sigfile);
+	G_fatal_error(_("Signature file <%s> is invalid"), parms->sigfile);
     fclose(fd);
Modified: grass/trunk/imagery/i.smap/shapiro/write_img.c
--- grass/trunk/imagery/i.smap/shapiro/write_img.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/imagery/i.smap/shapiro/write_img.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -9,22 +9,19 @@
 {				/* files: contains file to output */
     int row, col;
-    if (!parms->quiet)
-	G_message(_("Writing [%s] ..."), parms->output_map);
+    G_message(_("Writing raster map <%s>..."), parms->output_map);
 	    int class = (int)img[row][col];
 	    G_debug(3, "class: [%d] row/col: [%d][%d]", class, row, col);
 	    files->outbuf[col] = (CELL) S->ClassSig[class].classnum;
 	G_put_raster_row(files->output_fd, files->outbuf, CELL_TYPE);
     return 0;
Modified: grass/trunk/raster/r.composite/main.c
--- grass/trunk/raster/r.composite/main.c	2008-12-14 14:19:36 UTC (rev 34869)
+++ grass/trunk/raster/r.composite/main.c	2008-12-14 14:20:47 UTC (rev 34870)
@@ -7,7 +7,7 @@
  *               layer using a quantisation of the RGB color space.
  *               Using Floyd-Steinberg dithering
- * COPYRIGHT:    (C) 2001 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2001-2008 by the GRASS Development Team
@@ -70,24 +70,21 @@
     module->keywords = _("raster, composite");
-	_("Combines red, green and blue map layers into "
+	_("Combines red, green and blue raster maps into "
 	  "a single composite raster map.");
     for (i = 0; i < 3; i++) {
 	struct Option *opt;
 	char buff[80];
-	B[i].opt_name = opt = G_define_option();
+	B[i].opt_name = opt = G_define_standard_option(G_OPT_R_INPUT);
 	sprintf(buff, "%s", color_names[i]);
 	opt->key = G_store(buff);
-	opt->type = TYPE_STRING;
 	opt->answer = NULL;
-	opt->required = YES;
-	opt->gisprompt = "old,cell,raster";
-	sprintf(buff, _("Name of raster map layer to be used for <%s>"),
+	sprintf(buff, _("Name of raster map to be used for <%s>"),
 		color_names[i]);
 	opt->description = G_store(buff);
@@ -100,6 +97,7 @@
     opt_lev->answer = "32";
     opt_lev->description =
 	_("Number of levels to be used for each component");
+    opt_lev->guisection = _("Levels");
 	struct Option *opt;
@@ -117,10 +115,10 @@
 	sprintf(buff, _("Number of levels to be used for <%s>"),
 		color_names[i]);
+	opt->guisection = _("Levels");
     opt_out = G_define_standard_option(G_OPT_R_OUTPUT);
-    opt_out->description = _("Name of raster map to contain results");
     flg_d = G_define_flag();
     flg_d->key = 'd';
@@ -161,7 +159,7 @@
 	/* Reading color lookup table */
 	if (G_read_colors(b->name, "", &b->colors) == -1)
-	    G_fatal_error(_("Color file for <%s> not available"), b->name);
+	    G_fatal_error(_("Unable to read color file of raster map <%s>"), b->name);
 	    b->array[j] = (i == j)
@@ -250,9 +248,8 @@
 	if (G_put_raster_row(out_file, out_array, CELL_TYPE) < 0)
 	    G_fatal_error(_("Failed writing raster map <%s>"), out_name);
+    G_percent(window.rows, window.rows, 1);
-    G_percent(window.rows, window.rows, 5);
     /* Close the input files */
 	G_close_cell(B[i].file);
@@ -264,7 +261,7 @@
     G_command_history(&history);
     G_write_history(out_name, &history);
-    G_done_msg(" ");
+    G_done_msg(_("Raster map <%s> created."), out_name);
     exit(EXIT_SUCCESS);
@@ -305,6 +302,5 @@
 	    i += nr;
-    G_percent(nb, nb, 5);
+    G_percent(nb, nb, 1);
