[GRASS-SVN] r34871 - grass/trunk/imagery/i.smap
Sun Dec 14 09:29:10 EST 2008
Author: martinl
Date: 2008-12-14 09:29:09 -0500 (Sun, 14 Dec 2008)
New Revision: 34871
Added:
   grass/trunk/imagery/i.smap/alpha_max.c
   grass/trunk/imagery/i.smap/bouman.h
   grass/trunk/imagery/i.smap/closefiles.c
   grass/trunk/imagery/i.smap/decimate.c
   grass/trunk/imagery/i.smap/eigen.c
   grass/trunk/imagery/i.smap/history.c
   grass/trunk/imagery/i.smap/i.smap.html
   grass/trunk/imagery/i.smap/interp.c
   grass/trunk/imagery/i.smap/invert.c
   grass/trunk/imagery/i.smap/labels.c
   grass/trunk/imagery/i.smap/local_proto.h
   grass/trunk/imagery/i.smap/main.c
   grass/trunk/imagery/i.smap/model.c
   grass/trunk/imagery/i.smap/multialloc.c
   grass/trunk/imagery/i.smap/opencell.c
   grass/trunk/imagery/i.smap/openfiles.c
   grass/trunk/imagery/i.smap/parse.c
   grass/trunk/imagery/i.smap/read_block.c
   grass/trunk/imagery/i.smap/read_sig.c
   grass/trunk/imagery/i.smap/reg_util.c
   grass/trunk/imagery/i.smap/region.h
   grass/trunk/imagery/i.smap/segment.c
   grass/trunk/imagery/i.smap/solve.c
   grass/trunk/imagery/i.smap/write_img.c
Removed:
   grass/trunk/imagery/i.smap/bouman/
   grass/trunk/imagery/i.smap/shapiro/
   grass/trunk/imagery/i.smap/Makefile
i.smap: remove redundant 'bouman' and 'shapiro' directories
Modified: grass/trunk/imagery/i.smap/Makefile
--- grass/trunk/imagery/i.smap/Makefile	2008-12-14 14:20:47 UTC (rev 34870)
+++ grass/trunk/imagery/i.smap/Makefile	2008-12-14 14:29:09 UTC (rev 34871)
@@ -1,14 +1,14 @@
 MODULE_TOPDIR = ../..
-SUBDIRS = \
-	bouman \
-	shapiro
+PGM = i.smap
-include $(MODULE_TOPDIR)/include/Make/Dir.make
+LIBES     = $(IMAGERYLIB) $(GISLIB) $(GMATHLIB)
+DEPENDENCIES= $(IMAGERYDEP) $(GISDEP) $(GMATHDEP)
-default: parsubdirs
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
-shapiro: bouman
Copied: grass/trunk/imagery/i.smap/alpha_max.c (from rev 34868, grass/trunk/imagery/i.smap/bouman/alpha_max.c)
--- grass/trunk/imagery/i.smap/alpha_max.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/alpha_max.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,161 @@
+#include <stdio.h>
+#include <math.h>
+#include "bouman.h"
+/* Global Variables: These variables are required as inputs  *
+ * to the function called by ``solve''. Since the function is   *
+ * called by a pointer, side inputs must be passed as global    *
+ * variables root finding                                       */
+static double ***N_glb;		/* N_glb[2][3][2] rate statistics */
+static double *b_glb;		/* line search direction */
+static double eps_glb;		/* precision */
+static int M_glb;		/* number of classes */
+void alpha_max(double ***N,	/* Transition probability statistics; N2[2][3][2] */
+	       double *a,	/* Transition probability parameters; a[3] */
+	       int M,		/* Number of class types */
+	       double eps	/* Precision of convergence */
+    double b[3];
+    /*       b[0] = 0.4;
+       b[1] = 0.6/2;
+       b[2] = 0.0; */
+    b[0] = 3.0;
+    b[1] = 2.0;
+    b[2] = 0.0;
+    line_search(N, a, M, b, eps);
+void line_search(
+		    /* line_search determines the maximum value of the log likelihood       *
+		     * along the direction b, subject to the constraint a[0]+2*a[1]+a[3]<1. */
+		    double ***N,	/* Transition probability statistics; N2[2][3][2] */
+		    double *b,	/* direction of search */
+    int code;			/* error code for solve subroutine */
+    double x;			/* distance along line */
+    double max;			/* maximum value for x */
+    normalize(b);
+    a[0] = eps * b[0];
+    a[1] = eps * b[1];
+    a[2] = eps * b[2];
+    /* enforce condition [1,2,1][a[0],a[1],a[2]]^t <1-eps */
+    max = (1 - eps) / (b[0] + 2 * b[1] + b[2]);
+    /* set global variables for solve routine */
+    N_glb = N;
+    b_glb = b;
+    eps_glb = eps;
+    M_glb = M;
+    /* minimize on line. Avoid singular boundary */
+    x = solve(func, eps, max, eps, &code);
+    /* If derivative was positive on line, x=max. */
+    if (code == 1)
+	x = max;
+    /* If derivative was negative on line. */
+    if (code == -1)
+	x = 0.0;
+    /* compute a */
+    a[0] = x * b[0];
+    a[1] = x * b[1];
+    a[2] = x * b[2];
+int normalize(
+		 /* normalize the vector b[3]. Return 0 if null vector */
+		 double b[3]
+    double norm;
+    norm = sqrt(b[0] * b[0] + b[1] * b[1] + b[2] * b[2]);
+    if (norm == 0)
+	return (0);
+    b[0] = b[0] / norm;
+    b[1] = b[1] / norm;
+    b[2] = b[2] / norm;
+    return (1);
+double func(double x)
+    double tmp[3], grad[3];
+    tmp[0] = x * b_glb[0];
+    tmp[1] = x * b_glb[1];
+    tmp[2] = x * b_glb[2];
+    gradient(grad, N_glb, tmp, M_glb);
+    return (b_glb[0] * grad[0] + b_glb[1] * grad[1] + b_glb[2] * grad[2]);
+double log_like(
+		   /* compute log likelihood being maximized. This subroutine *
+		    * is useful for debuging since the log likelihood must be *
+		    * monotonically decreasing.                               */
+		   double ***N,	/* transition statistics */
+		   double a[3],	/* transition parameters */
+		   int M	/* number of classes */
+    double iM, tmp, sum;
+    int n1, n2, n3;
+    iM = 1.0 / M;
+    sum = 0;
+    for (n1 = 0; n1 <= 1; n1++)
+	for (n2 = 0; n2 <= 2; n2++)
+	    for (n3 = 0; n3 <= 1; n3++) {
+		tmp =
+		    log(a[0] * (n1 - iM) + a[1] * (n2 - 2.0 * iM) +
+			a[2] * (n3 - iM) + iM);
+		sum += N[n1][n2][n3] * tmp;
+    return (sum);
+void gradient(
+		 /* computes the gradient of the log likelihood being maximized. */
+		 double grad[3],	/* gradient vector; output */
+		 double ***N,	/* transition statistics; input */
+		 double a[3],	/* transition parameters; input */
+    double iM, tmp;
+    int n1, n2, n3;
+    iM = 1.0 / M;
+    grad[0] = grad[1] = grad[2] = 0;
+		tmp =
+		    a[0] * (n1 - iM) + a[1] * (n2 - 2.0 * iM) + a[2] * (n3 -
+									iM) +
+		    iM;
+		tmp = 1 / tmp;
+		grad[0] += tmp * (n1 - iM) * N[n1][n2][n3];
+		grad[1] += tmp * (n2 - 2.0 * iM) * N[n1][n2][n3];
+		grad[2] += tmp * (n3 - iM) * N[n1][n2][n3];
Property changes on: grass/trunk/imagery/i.smap/alpha_max.c
___________________________________________________________________
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/bouman.h (from rev 34868, grass/trunk/imagery/i.smap/bouman/bouman.h)
--- grass/trunk/imagery/i.smap/bouman.h	                        (rev 0)
+++ grass/trunk/imagery/i.smap/bouman.h	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,77 @@
+#include <math.h>
+#include <string.h>
+#include <grass/gis.h>
+#define LIKELIHOOD float
+struct files
+    int output_fd;
+    struct Categories output_labels;
+    int *band_fd;
+    int nbands;
+    DCELL *cellbuf;
+    CELL *outbuf;
+    char *isdata;
+struct parms
+    char *output_map;
+    char *group;
+    char *subgroup;
+    char *sigfile;
+    int blocksize;
+    int quiet;
+    int ml;
+/* parse.c */
+int parse(int, char *[], struct parms *);
+/* closefiles.c */
+int closefiles(struct parms *, struct files *);
+/* openfiles.c */
+int openfiles(struct parms *, struct files *);
+/* Suboutines in alpha_max.c */
+void alpha_max(double ***, double *, int, double);
+void line_search(double ***, double *, int, double *, double);
+int normalize(double[3]);
+double func(double);
+double log_like(double ***, double[3], int);
+void gradient(double[3], double ***, double[3], int);
+/* Subroutines in multialloc.c */
+char *multialloc(size_t, int, ...);
+void multifree(char *, int);
+unsigned char **get_img(int, int, size_t);
+void free_img(unsigned char **);
+/* Subroutine in solve.c */
+double solve(double (*)(double), double, double, double, int *);
+/* Subroutine in eigen.c */
+int eigen(double **, double *, int);
+/* Subroutine in invert.c */
+int invert(double **, int);
+#ifdef GRASS_IMAGERY_H
+int segment(struct SigSet *, struct parms *, struct files *);
+/* read_sig.c */
+int read_signatures(struct parms *, struct SigSet *);
+/* labels.c */
+int create_output_labels(struct SigSet *, struct files *);
+/* write_img.c */
+int write_img(unsigned char **, int, int, struct SigSet *, struct parms *,
+	      struct files *);
+#endif
+/*  Look for prototypes that use the Region structure in region.h */
Property changes on: grass/trunk/imagery/i.smap/bouman.h
   + text/x-chdr
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/closefiles.c (from rev 34870, grass/trunk/imagery/i.smap/shapiro/closefiles.c)
--- grass/trunk/imagery/i.smap/closefiles.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/closefiles.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,24 @@
+#include <unistd.h>
+#include <grass/glocale.h>
+#include <grass/imagery.h>
+#include "local_proto.h"
+int closefiles(struct parms *parms, struct files *files)
+    int n;
+    G_debug(1, "Creating support files for <%s>...", parms->output_map);
+    for (n = 0; n < files->nbands; n++)
+	G_close_cell(files->band_fd[n]);
+    G_close_cell(files->output_fd);
+    G_write_cats(parms->output_map, &files->output_labels);
+    make_history(parms->output_map,
+		 parms->group, parms->subgroup, parms->sigfile);
+    return 0;
Property changes on: grass/trunk/imagery/i.smap/closefiles.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/decimate.c (from rev 34870, grass/trunk/imagery/i.smap/bouman/decimate.c)
--- grass/trunk/imagery/i.smap/decimate.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/decimate.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,229 @@
+#include "region.h"
+static void decimate(LIKELIHOOD ***, struct Region *, int, LIKELIHOOD ***,
+		     double);
+static void up_ll(LIKELIHOOD *, int, double, LIKELIHOOD *);
+void make_pyramid(LIKELIHOOD **** ll_pym,	/* log likelihood pyramid, ll_pym[scale][i][j][class] */
+		  struct Region *region,	/* specifies image subregion */
+		  int M,	/* number of classes */
+		  double *alpha,	/* decimation parameters */
+		  int vlevel	/* verbose operation */
+    int D;
+    int wd, ht;
+    struct Region region_buff;
+    /* save region stucture */
+    copy_reg(region, &region_buff);
+    D = 0;
+    reg_to_wdht(region, &wd, &ht);
+    while ((wd > 2) && (ht > 2)) {
+	if (vlevel >= 2)
+	    G_debug(1, "D = %d  alpha = %f; 1-alpha = %f", D, alpha[D],
+		    1 - alpha[D]);
+	decimate(ll_pym[D], region, M, ll_pym[D + 1], alpha[D]);
+	dec_reg(region);
+	D++;
+    /* restore region structure */
+    copy_reg(&region_buff, region);
+			/* decimate statistics ll1 to form ll2 */
+			LIKELIHOOD *** ll1,	/* log likelihood ll1[i][j][class], at fine resolution */
+			struct Region *region1,	/* specifies image subregion */
+			LIKELIHOOD *** ll2,	/* loglikelihood ll1[i][j][class], at coarse resolution */
+			double alpha	/* transition parameter */
+    struct Region *region2, reg_spc;	/* coarse resolution region */
+    int wflag, hflag;		/* flags indicate odd number of pixels */
+    int i, j, m;
+    LIKELIHOOD *node;		/* coarse resolution point */
+    LIKELIHOOD *pt1, *pt2, *pt3, *pt4;	/* fine resolution neighbors */
+    region2 = &reg_spc;
+    copy_reg(region1, region2);
+    dec_reg(region2);
+    wflag = region1->xmax & 1;
+    hflag = region1->ymax & 1;
+    for (i = region2->ymin; i < region2->ymax; i++)
+	for (j = region2->xmin; j < region2->xmax; j++) {
+	    pt1 = ll1[2 * i][2 * j];
+	    pt2 = ll1[2 * i][2 * j + 1];
+	    pt3 = ll1[2 * i + 1][2 * j];
+	    pt4 = ll1[2 * i + 1][2 * j + 1];
+	    node = ll2[i][j];
+	    for (m = 0; m < M; m++)
+		node[m] = 0.0;
+	    up_ll(pt1, M, alpha, node);
+	    up_ll(pt2, M, alpha, node);
+	    up_ll(pt3, M, alpha, node);
+	    up_ll(pt4, M, alpha, node);
+    if (wflag) {
+	for (i = region2->ymin; i < region2->ymax; i++) {
+	    node = ll2[i][region2->xmax - 1];
+		node[m] = 0.0;
+	    pt1 = ll1[2 * i][region1->xmax - 1];
+	    pt2 = ll1[2 * i + 1][region1->xmax - 1];
+    if (hflag) {
+	    node = ll2[region2->ymax - 1][j];
+		node[m] = 0.0;
+	    pt1 = ll1[region1->ymax - 1][2 * j];
+	    pt2 = ll1[region1->ymax - 1][2 * j + 1];
+    if (hflag && wflag) {
+	node = ll2[region2->ymax - 1][region2->xmax - 1];
+	    node[m] = 0.0;
+	pt1 = ll1[region1->ymax - 1][region1->xmax - 1];
+static void up_ll(LIKELIHOOD * pt1,	/* array of log likelihood values, pt1[class] */
+		  int M, double alpha, LIKELIHOOD * pt2	/* array of log likelihood values, pt2[class] */
+    static int m;
+    static double sum, max, cprob[256];
+    if (alpha != 1.0) {
+	max = pt1[0];
+	for (m = 1; m < M; m++)
+	    if (pt1[m] > max)
+		max = pt1[m];
+	sum = 0;
+	for (m = 0; m < M; m++) {
+	    cprob[m] = exp(pt1[m] - max);
+	    sum += cprob[m];
+	sum = ((1 - alpha) * sum) / M;
+	    pt2[m] += log(sum + alpha * cprob[m]) + max;
+    else {
+	    pt2[m] += pt1[m];
+char ***get_pyramid(int w0, int h0, size_t size)
+    char ***pym;
+    int D, wn, hn;
+    D = levels(w0, h0);
+    pym = (char ***)G_malloc((D + 1) * sizeof(char *));
+    D = 0;
+    wn = w0;
+    hn = h0;
+    pym[D] = (char **)get_img(wn, hn, size);
+    while ((wn > 2) && (hn > 2)) {
+	D++;
+	wn = wn / 2;
+	hn = hn / 2;
+    return (pym);
+void free_pyramid(char *pym, int wd, int ht)
+    unsigned char ***pt;
+    int i, D;
+    pt = (unsigned char ***)pym;
+    D = levels(wd, ht);
+    for (i = 0; i <= D; i++)
+	free_img(pt[i]);
+    G_free(pym);
+char ****get_cubic_pyramid(int w0, int h0, int M, size_t size)
+    char ****pym;
+    int D, wn, hn;
+    pym = (char ****)G_malloc((D + 1) * sizeof(char *));
+    D = 0;
+    wn = w0;
+    hn = h0;
+    pym[D] = (char ***)multialloc(size, 3, hn, wn, M);
+	D++;
+	wn = wn / 2;
+	hn = hn / 2;
+    return (pym);
+void free_cubic_pyramid(char *pym, int wd, int ht, int M)
+    int i, D;
+    char **pt;
+    pt = (char **)pym;
+	multifree(pt[i], M);
+    G_free(pym);
+int levels(int wd, int ht)
+    int D;
+    D = 0;
+	D++;
+	wd = wd / 2;
+	ht = ht / 2;
+    return (D);
Property changes on: grass/trunk/imagery/i.smap/decimate.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/eigen.c (from rev 34868, grass/trunk/imagery/i.smap/bouman/eigen.c)
--- grass/trunk/imagery/i.smap/eigen.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/eigen.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,33 @@
+int eigen(
+	     /* Computes eigenvalues (and eigen vectors if desired) for      *
+	      *  symmetric matices.                                          */
+	     double **M,	/* Input matrix */
+	     double *lambda,	/* Output eigenvalues */
+	     int n		/* Input matrix dimension */
+    int i, j;
+    double **a, *e;
+    a = G_alloc_matrix(n, n);
+    e = G_alloc_vector(n);
+    for (i = 0; i < n; i++)
+	for (j = 0; j < n; j++)
+	    a[i][j] = M[i][j];
+    G_tred2(a, n, lambda, e);
+    G_tqli(lambda, e, n, a);
+    /* Returns eigenvectors */
+    /*      for(i=0; i<n; i++)
+       for(j=0; j<n; j++)
+       M[i][j] = a[i][j]; */
+    G_free_matrix(a);
+    G_free_vector(e);
+    return 0;
Property changes on: grass/trunk/imagery/i.smap/eigen.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/history.c (from rev 34868, grass/trunk/imagery/i.smap/shapiro/history.c)
--- grass/trunk/imagery/i.smap/history.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/history.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,12 @@
+void make_history(const char *name, const char *group, const char *subgroup, const char *sigfile)
+    struct History hist;
+    if (G_read_history(name, G_mapset(), &hist) >= 0) {
+	sprintf(hist.datsrc_1, "Group/subgroup: %s/%s", group, subgroup);
+	sprintf(hist.datsrc_2, "Sigset file: %s", sigfile);
+	G_write_history(name, &hist);
Property changes on: grass/trunk/imagery/i.smap/history.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/i.smap.html (from rev 34868, grass/trunk/imagery/i.smap/shapiro/i.smap.html)
--- grass/trunk/imagery/i.smap/i.smap.html	                        (rev 0)
+++ grass/trunk/imagery/i.smap/i.smap.html	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,198 @@
+<H2>DESCRIPTION</H2>
+The <EM>i.smap</EM> program is used to segment
+multispectral images using a spectral class model known as
+a Gaussian mixture distribution.  Since Gaussian mixture
+distributions include conventional multivariate Gaussian
+distributions, this program may also be used to segment
+multispectral images based on simple spectral mean and
+covariance parameters.
+<P>
+<EM>i.smap</EM> has two modes of operation.  The first mode
+is the sequential maximum a posteriori (SMAP) mode
+[<A HREF="#ref1">1</A>,<A HREF="#ref2">2</A>].  The SMAP
+segmentation algorithm attempts to improve segmentation
+accuracy by segmenting the image into regions rather than
+segmenting each pixel separately
+(see <A HREF="#notes">NOTES</A>).
+<P>
+The second mode is the more conventional maximum likelihood (ML)
+classification which classifies each pixel separately,
+but requires somewhat less computation. This mode is selected with
+the <B>-m</B> flag (see <A HREF="#mflag.html">below</A>).
+<H2>OPTIONS</H2>
+<H3>Flags:</H3>
+<DL>
+<DT><B>-m</B>
+<DD>Use maximum likelihood estimation (instead of smap).
+Normal operation is to use SMAP estimation (see
+<A HREF="#notes">NOTES</A>).
+<DT><B>-q</B>
+<DD>Run quietly, without printing messages about program
+progress.  Without this flag, messages will be printed (to
+stderr) as the program progresses.
+</DL>
+<H3>Parameters:</H3>
+<DL>
+<DT><B>group=</B><EM>name</EM>
+<DD>imagery group<BR>
+The imagery group that defines the image to be classified.
+<DT><B>subgroup=</B><EM>name</EM>
+<DD>imagery subgroup<BR>
+The subgroup within the group specified that specifies the
+subset of the band files that are to be used as image data
+to be classified.
+<DT><B>signaturefile=</B><EM>name</EM>
+<DD>imagery signaturefile<BR>
+The signature file that contains the spectral signatures (i.e., the
+statistics) for the classes to be identified in the image.
+This signature file is produced by the program
+<EM><A HREF="i.gensigset.html">i.gensigset</A></EM>
+<DT><B>blocksize=</B><EM>value</EM>
+<DD>size of submatrix to process at one time<BR>
+default: 128<BR>
+This option specifies the size of the "window" to be used when
+reading the image data.
+<P>
+This program was written to be nice about memory usage
+without influencing the resultant classification. This
+option allows the user to control how much memory is used.
+More memory may mean faster (or slower) operation depending
+on how much real memory your machine has and how much
+virtual memory the program uses.
+<P>
+The size of the submatrix used in segmenting the image has
+a principle function of controlling memory usage; however,
+it also can have a subtle effect on the quality of the
+segmentation in the smap mode.  The smoothing parameters
+for the smap segmentation are estimated separately for each
+submatrix.  Therefore, if the image has regions with
+qualitatively different behavior, (e.g., natural woodlands
+and man-made agricultural fields) it may be useful to use a
+submatrix small enough so that different smoothing
+parameters may be used for each distinctive region of the
+image.
+<P>
+The submatrix size has no effect on the performance of the
+ML segmentation method.
+<DT><B>output=</B><EM>name</EM>
+<DD>output raster map.<BR>
+The name of a raster map that will contain the
+classification results.  This new raster map layer will
+contain categories that can be related to landcover
+categories on the ground.
+</DL>
+<H2>INTERACTIVE MODE</H2>
+If none of the arguments are specified on the command line,
+<EM>i.smap</EM> will interactively prompt for the names of
+the maps and files.
+<A NAME="notes"></A><H2>NOTES</H2>
+The SMAP algorithm exploits the fact that nearby pixels in
+an image are likely to have the same class.  It works by
+segmenting the image at various scales or resolutions and
+using the coarse scale segmentations to guide the finer
+scale segmentations.  In addition to reducing the number of
+misclassifications, the SMAP algorithm generally produces
+segmentations with larger connected regions of a fixed
+class which may be useful in some applications.
+<P>
+The amount of smoothing that is performed in the
+segmentation is dependent of the behavior of the data in
+the image.  If the data suggests that the nearby pixels
+often change class, then the algorithm will adaptively
+reduce the amount of smoothing.  This ensures that
+excessively large regions are not formed.
+<P>
+The module i.smap does not support MASKed or NULL cells. Therefore
+it might be necessary to create a copy of the classification results
+using e.g. r.mapcalc.
+<p>
+r.mapcalc  MASKed_map=classification results
+<H2>REFERENCES</H2>
+<OL>
+<LI>C. Bouman and M. Shapiro,
+"Multispectral Image Segmentation using a Multiscale Image Model",
+<EM>Proc. of IEEE Int'l Conf. on Acoust., Speech and Sig. Proc.,</EM>
+pp. III-565 - III-568, San Francisco, California, March
+23-26, 1992.
+<LI>C. Bouman and M. Shapiro 1994,
+"A Multiscale Random Field
+Model for Bayesian Image Segmentation",
+<EM>IEEE Trans. on Image Processing., 3(2), 162-177"</EM>
+<LI>McCauley, J.D. and B.A. Engel 1995,
+"Comparison of Scene Segmentations: SMAP, ECHO and Maximum Likelyhood",
+<EM>IEEE Trans. on Geoscience and Remote Sensing, 33(6): 1313-1316.</EM>
+</OL>
+<H2>SEE ALSO</H2>
+<EM><A HREF="i.group.html">i.group</A></EM>
+for creating groups and subgroups
+<P>
+<EM><A HREF="r.mapcalc.html">r.mapcalc</A></EM>
+to copy classification result in order to cut out MASKed subareas
+<P>
+to generate the signature file required by this program
+<H2>AUTHORS</H2>
+<a href="http://dynamo.ecn.purdue.edu/~bouman/software/segmentation/">Charles Bouman,
+School of Electrical Engineering, Purdue University</a>
+<BR>
+Michael Shapiro,
+U.S.Army Construction Engineering
+Research Laboratory
+<p><i>Last changed: $Date$</i>
Property changes on: grass/trunk/imagery/i.smap/i.smap.html
   + text/html
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/interp.c (from rev 34870, grass/trunk/imagery/i.smap/bouman/interp.c)
--- grass/trunk/imagery/i.smap/interp.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/interp.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,382 @@
+#include <stdlib.h>
+#include <math.h>
+#define EM_PRECISION 1e-4
+#define ML_PRECISION 1e-6
+static void seq_MAP_routine(unsigned char ***, struct Region *,
+			    LIKELIHOOD ****, int, double *, int);
+static double alpha_dec_max(double ***);
+static void print_N(double ***);
+static void print_alpha(double *);
+static void interp(unsigned char **, struct Region *, unsigned char **,
+		   LIKELIHOOD ***, int, double *, int, double ***, int);
+void MLE(unsigned char **, LIKELIHOOD ***, struct Region *, int);
+static int up_char(int, int, struct Region *, unsigned char **,
+		   unsigned char **);
+void seq_MAP(unsigned char ***sf_pym,	/* pyramid of segmentations */
+	     LIKELIHOOD **** ll_pym,	/* pyramid of class statistics */
+	     double *alpha_dec,	/* decimation parameters returned by seq_MAP */
+	     int vlevel		/* verbose output */
+    int repeat;
+    /* Repeat segmentation to get values for alpha_dec */
+    for (repeat = 0; repeat < 2; repeat++) {
+	/* Construct image log likelihood pyramid */
+	make_pyramid(ll_pym, region, M, alpha_dec, vlevel);
+	if (vlevel >= 2)
+	    G_message(_("pyramid constructed."));
+	/* Perform sequential MAP segmentation using EM algorithm */
+	seq_MAP_routine(sf_pym, region, ll_pym, M, alpha_dec, vlevel);
+static void seq_MAP_routine(unsigned char ***sf_pym,	/* pyramid of segmentations */
+    int j, k;			/* loop index */
+    int wd, ht;			/* width and height at each resolution */
+    int *period;		/* sampling period at each resolution */
+    int D;			/* number of resolutions -1 */
+    double ***N;		/* transition probability statistics; N[2][3][2] */
+    double alpha[3];		/* transition probability parameters */
+    double tmp[3];		/* temporary transition probability parameters */
+    double diff1;		/* change in parameter estimates */
+    double diff2;		/* change in log likelihood */
+    struct Region *regionary;	/* array of region stuctures */
+    /* determine number of resolutions */
+    D = levels_reg(region);
+    /* allocate memory */
+    if ((N = (double ***)multialloc(sizeof(double), 3, 2, 3, 2)) == NULL)
+	G_fatal_error(_("Unable to allocate memory"));
+    regionary = (struct Region *)G_malloc((D + 1) * sizeof(struct Region));
+    period = (int *)G_malloc(D * sizeof(int));
+    /* Compute the image region at each resolution.       */
+    k = 0;
+    copy_reg(region, &(regionary[k]));
+    reg_to_wdht(&(regionary[k]), &wd, &ht);
+	copy_reg(&(regionary[k]), &(regionary[k + 1]));
+	dec_reg(&(regionary[k + 1]));
+	reg_to_wdht(&(regionary[k + 1]), &wd, &ht);
+	k++;
+    /* Compute sampling period for EM algorithm at each resolution. */
+    for (k = 0; k < D; k++) {
+	period[k] = (int)pow(2.0, (D - k - 2) / 2.0);
+	if (period[k] < 1)
+	    period[k] = 1;
+    /* Compute Maximum Likelihood estimate at coarsest resolution */
+    MLE(sf_pym[D], ll_pym[D], &(regionary[D]), M);
+    /* Initialize the transition parameters */
+    alpha[0] = 0.5 * (3.0 / 7.0);
+    alpha[1] = 0.5 * (2.0 / 7.0);
+    alpha[2] = 0.0;
+    /* Interpolate the classification at each resolution */
+    for (D--; D >= 0; D--) {
+	if (vlevel >= 2)
+	    G_debug(1, "Resolution = %d; period = %d", D, period[D]);
+	for (j = 0; j < 3; j++)
+	    alpha[j] *= (1 - EM_PRECISION * 10);
+	if (vlevel >= 4)
+	    print_alpha(alpha);
+	/* Apply EM algorithm to estimate alpha. Continue for *
+	 * fixed number of iterations or until convergence.   */
+	do {
+	    interp(sf_pym[D], &(regionary[D]), sf_pym[D + 1], ll_pym[D], M,
+		   alpha, period[D], N, 1);
+	    if (vlevel >= 4)
+		print_N(N);
+	    if (vlevel >= 4)
+		G_debug(1, "log likelihood = %f", log_like(N, alpha, M));
+		tmp[j] = alpha[j];
+	    alpha_max(N, alpha, M, ML_PRECISION);
+	    if (vlevel >= 2)
+	    if (vlevel >= 4)
+	    for (diff1 = j = 0; j < 3; j++)
+		diff1 += fabs(tmp[j] - alpha[j]);
+	    diff2 = log_like(N, alpha, M) - log_like(N, tmp, M);
+	} while ((diff1 > EM_PRECISION) && (diff2 > 0));
+	interp(sf_pym[D], &(regionary[D]), sf_pym[D + 1], ll_pym[D], M, alpha,
+	       1, N, 0);
+	alpha_dec[D] = alpha_dec_max(N);
+	if (vlevel >= 4)
+	    print_N(N);
+	if (vlevel >= 2) {
+    /* free up N */
+    G_free((char *)regionary);
+    G_free((char *)period);
+    multifree((char *)N, 3);
+static double alpha_dec_max(double ***N)
+    int i, j, k;
+    double N_marg[2];		/* Marginal transition rate */
+    double N_sum;		/* total number of transitions counted */
+    for (k = 0; k < 2; k++) {
+	N_marg[k] = 0;
+	for (i = 0; i < 3; i++)
+	    for (j = 0; j < 2; j++) {
+		N_marg[k] += N[k][i][j];
+    N_sum = N_marg[0] + N_marg[1];
+    if (N_sum == 0)
+	return (0.0);
+    return (N_marg[1] / N_sum);
+		       /* prints out class transition statistics */
+		       double ***N)
+    int n0, n1, n2;
+    G_debug(2, "Class transition statistics");
+    for (n0 = 0; n0 < 2; n0++) {
+	for (n1 = 0; n1 < 3; n1++) {
+	    for (n2 = 0; n2 < 2; n2++)
+		G_debug(3, "   %f", N[n0][n1][n2]);
+			   /* prints out transition parameters. */
+			   double *alpha)
+    G_debug(1, "Transition probabilities: %f %f %f; %f",
+	    alpha[0], alpha[1], alpha[2],
+	    1.0 - alpha[0] - 2 * alpha[1] - alpha[2]);
+		      /* Estimates finer resolution segmentation from coarser resolution
+		         segmentation and texture statistics. */
+		      unsigned char **sf1,	/* finer resolution segmentation */
+		      struct Region *region,	/* image region */
+		      unsigned char **sf2,	/* coarser resolution segmentation */
+		      LIKELIHOOD *** ll,	/* Log likelihood ll[i][j][class] */
+		      double *alpha,	/* transition probability parameters; alpha[3] */
+		      int period,	/* sampling period of interpolation */
+		      double ***N,	/* transition probability statistics; N[2][3][2] */
+		      int statflag	/* compute transition statistics if == 1 */
+    int i, j;			/* pixel index */
+    int m;			/* class index */
+    int bflag;			/* boundary flag */
+    int nn0, nn1, nn2;		/* transition counts */
+    int *n0, *n1, *n2;		/* transition counts for each possible pixel class */
+    unsigned char *nbr[8];	/* pointers to neighbors at courser resolution */
+    double cost, mincost;	/* cost of class selection; minimum cost */
+    int best = 0;		/* class of minimum cost selection */
+    double Constant, tmp;
+    double *pdf;		/* propability density function of class selections */
+    double Z;			/* normalizing costant for pdf */
+    double alpha0, alpha1, alpha2;	/* transition probabilities */
+    double log_tbl[2][3][2];	/* log of transition probability */
+    /* allocate memory for pdf */
+    pdf = (double *)G_malloc(M * sizeof(double));
+    n0 = (int *)G_malloc(M * sizeof(int));
+    n1 = (int *)G_malloc(M * sizeof(int));
+    n2 = (int *)G_malloc(M * sizeof(int));
+    /* set constants */
+    alpha0 = alpha[0];
+    alpha1 = alpha[1];
+    alpha2 = alpha[2];
+    Constant = (1 - alpha0 - 2 * alpha1 - alpha2) / M;
+    if (Constant < 0)
+	G_fatal_error(_("Invalid parameter values"));
+    /* precompute logs and zero static vector */
+    for (nn0 = 0; nn0 < 2; nn0++)
+	for (nn1 = 0; nn1 < 3; nn1++)
+	    for (nn2 = 0; nn2 < 2; nn2++) {
+		tmp = (alpha0 * nn0 + alpha1 * nn1 + alpha2 * nn2) + Constant;
+		if (tmp == 0)
+		    log_tbl[nn0][nn1][nn2] = HUGE_VAL;
+		else
+		    log_tbl[nn0][nn1][nn2] = -log(tmp);
+		if (statflag)
+		    N[nn0][nn1][nn2] = 0;
+    /* classify points and compute expectation of N */
+    for (i = region->ymin; i < region->ymax; i += period)
+	for (j = region->xmin; j < region->xmax; j += period) {
+	    /* compute minimum cost class */
+	    mincost = HUGE_VAL;
+	    bflag = up_char(i, j, region, sf2, nbr);
+		nn0 = n0[m] = (m == (*nbr[0]));
+		nn1 = n1[m] = (m == (*nbr[1])) + (m == (*nbr[2]));
+		nn2 = n2[m] = (m == (*nbr[3]));
+		pdf[m] = cost = log_tbl[nn0][nn1][nn2] - ll[i][j][m];
+		if (cost < mincost) {
+		    mincost = cost;
+		    best = m;
+	    sf1[i][j] = best;
+	    /* if not on boundary, compute expectation of N */
+	    if ((!bflag) && (statflag)) {
+		Z = 0.0;
+		    if (pdf[m] == HUGE_VAL)
+			pdf[m] = 0;
+		    else
+			pdf[m] = exp(mincost - pdf[m]);
+		    Z += pdf[m];
+		    N[n0[m]][n1[m]][n2[m]] += pdf[m] / Z;
+    G_free((char *)pdf);
+    G_free((char *)n0);
+    G_free((char *)n1);
+    G_free((char *)n2);
+void MLE(			/* computes maximum likelihood classification */
+	    unsigned char **sf,	/* segmentation classes */
+	    LIKELIHOOD *** ll,	/* texture statistics */
+    int i, j, m, best;
+    double max;
+    for (i = region->ymin; i < region->ymax; i++)
+	for (j = region->xmin; j < region->xmax; j++) {
+	    max = ll[i][j][0];
+	    best = 0;
+	    for (m = 1; m < M; m++) {
+		if (max < ll[i][j][m]) {
+		    max = ll[i][j][m];
+		    best = m;
+	    sf[i][j] = best;
+		      /* Computes list of pointers to nieghbors at next coarser resolution. *
+		       * Returns flag when on boundary.                                     */
+		      int i, int j,	/* fine resolution pixel location */
+		      struct Region *region,	/* fine resolution image region */
+		      unsigned char **img,	/* course resolution image */
+		      unsigned char **pt	/* list of pointers */
+    static int xmax, ymax;
+    static int bflag;		/* =1 when on boundary */
+    static int i2, j2;		/* base indices at coarser level */
+    static int di, dj;		/* displacements at coarser level */
+    /* create new xmax and ymax */
+    xmax = region->xmax;
+    ymax = region->ymax;
+    /* check for images of odd length */
+    if (xmax & 1) {
+	xmax--;
+	if (j == xmax)
+	    j--;
+    if (ymax & 1) {
+	ymax--;
+	if (i == ymax)
+	    i--;
+    /* compute indices */
+    di = ((i & 1) << 1) - 1;
+    dj = ((j & 1) << 1) - 1;
+    i2 = i >> 1;
+    j2 = j >> 1;
+    /* enforce an absorptive boundary */
+    bflag = 0;
+    if ((i == region->ymin) && region->free.top) {
+	di = 0;
+	bflag = 1;
+    if ((i == ymax - 1) && region->free.bottom) {
+	di = 0;
+	bflag = 1;
+    /* mod shapiro */
+    /*  if((j==region->ymax)&&region->free.left)    { dj=0; bflag=1; } */
+    if ((j == region->xmin) && region->free.left) {
+	dj = 0;
+	bflag = 1;
+    /* end mod shapiro */
+    if ((j == xmax - 1) && region->free.right) {
+	dj = 0;
+	bflag = 1;
+    /* compute pointers */
+    pt[0] = img[i2] + j2;
+    pt[1] = img[i2] + j2 + dj;
+    pt[2] = img[i2 + di] + j2;
+    pt[3] = img[i2 + di] + j2 + dj;
+    return (bflag);
Property changes on: grass/trunk/imagery/i.smap/interp.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/invert.c (from rev 34868, grass/trunk/imagery/i.smap/bouman/invert.c)
--- grass/trunk/imagery/i.smap/invert.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/invert.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,38 @@
+#include <math.h>
+int invert(
+	      /* inverts a matrix of arbitrary size input as a 2D array. */
+	      double **a,	/* input/output matrix */
+	      int n		/* dimension */
+    int status;
+    int i, j, *indx;
+    double **y, *col, d;
+    indx = G_alloc_ivector(n);
+    y = G_alloc_matrix(n, n);
+    col = G_alloc_vector(n);
+    if ((status = G_ludcmp(a, n, indx, &d))) {
+	for (j = 0; j < n; j++) {
+		col[i] = 0.0;
+	    col[j] = 1.0;
+	    G_lubksb(a, n, indx, col);
+		y[i][j] = col[i];
+		a[i][j] = y[i][j];
+    G_free_ivector(indx);
+    G_free_matrix(y);
+    G_free_vector(col);
+    return (status);
Property changes on: grass/trunk/imagery/i.smap/invert.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/labels.c (from rev 34868, grass/trunk/imagery/i.smap/shapiro/labels.c)
--- grass/trunk/imagery/i.smap/labels.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/labels.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,16 @@
+int create_output_labels(struct SigSet *S, struct files *files)
+    int n;
+    struct ClassSig *C;
+    G_init_cats((CELL) 0, S->title, &files->output_labels);
+    for (n = 0; n < S->nclasses; n++) {
+	C = &S->ClassSig[n];
+	G_set_cat((CELL) C->classnum, C->title, &files->output_labels);
+    return 0;
Property changes on: grass/trunk/imagery/i.smap/labels.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/local_proto.h (from rev 34868, grass/trunk/imagery/i.smap/shapiro/local_proto.h)
--- grass/trunk/imagery/i.smap/local_proto.h	                        (rev 0)
+++ grass/trunk/imagery/i.smap/local_proto.h	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,6 @@
+/* history.c */
+void make_history(const char *, const char *, const char *, const char *);
+/* opencell.c */
+int open_cell_old(const char *, const char *);
+int open_cell_new(const char *);
Property changes on: grass/trunk/imagery/i.smap/local_proto.h
   + text/x-chdr
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/main.c (from rev 34870, grass/trunk/imagery/i.smap/shapiro/main.c)
--- grass/trunk/imagery/i.smap/main.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/main.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,55 @@
+ * MODULE:       i.smap
+ * AUTHOR(S):    Michael Shapiro (USACERL) (original contributor)
+ *               Markus Neteler <neteler itc.it>,
+ *               Roberto Flor <flor itc.it>,
+ *               Bernhard Reiter <bernhard intevation.de>,
+ *               Brad Douglas <rez touchofmadness.com>,
+ *               Glynn Clements <glynn gclements.plus.com>,
+ *               Jan-Oliver Wagner <jan intevation.de>
+ * PURPOSE:      segment multispectral images using a spectral class model
+ *               known as a Gaussian mixture distribution
+ * COPYRIGHT:    (C) 1999-2008 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+int main(int argc, char *argv[])
+    struct parms parms;		/* command line parms */
+    struct files files;		/* file descriptors, io, buffers */
+    struct SigSet S;
+    struct GModule *module;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = _("imagery, classification, supervised, SMAP");
+    module->description =
+	_("Performs contextual image classification "
+	  "using sequential maximum a posteriori (SMAP) estimation.");
+    parse(argc, argv, &parms);
+    openfiles(&parms, &files);
+    read_signatures(&parms, &S);
+    create_output_labels(&S, &files);
+    segment(&S, &parms, &files);
+    closefiles(&parms, &files);
+    G_done_msg(" ");
+    exit(EXIT_SUCCESS);
Property changes on: grass/trunk/imagery/i.smap/main.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/model.c (from rev 34870, grass/trunk/imagery/i.smap/bouman/model.c)
--- grass/trunk/imagery/i.smap/model.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/model.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,161 @@
+#define PI M_PI
+void extract_init(struct SigSet *S)
+    int m;
+    int i;
+    int b1, b2;
+    int nbands;
+    double *lambda;
+    struct SubSig *SubS;
+    nbands = S->nbands;
+    /* allocate scratch memory */
+    lambda = (double *)G_malloc(nbands * sizeof(double));
+    /* invert matrix and compute constant for each subclass */
+    /* for each class */
+    for (m = 0; m < S->nclasses; m++) {
+	C = &(S->ClassSig[m]);
+	/* for each subclass */
+	for (i = 0; i < C->nsubclasses; i++) {
+	    SubS = &(C->SubSig[i]);
+	    /* Test for symetric  matrix */
+	    for (b1 = 0; b1 < nbands; b1++)
+		for (b2 = 0; b2 < nbands; b2++) {
+		    if (SubS->R[b1][b2] != SubS->R[b2][b1])
+			G_warning(_("Nonsymetric covariance for class %d subclass %d"),
+				  m + 1, i + 1);
+		    SubS->Rinv[b1][b2] = SubS->R[b1][b2];
+	    /* Test for positive definite matrix */
+	    eigen(SubS->Rinv, lambda, nbands);
+	    for (b1 = 0; b1 < nbands; b1++) {
+		if (lambda[b1] <= 0.0)
+		    G_warning(_("Nonpositive eigenvalues for class %d subclass %d"),
+			      m + 1, i + 1);
+	    /* Precomputes the cnst */
+	    SubS->cnst = (-nbands / 2.0) * log(2 * PI);
+		SubS->cnst += -0.5 * log(lambda[b1]);
+	    /* Precomputes the inverse of tex->R */
+	    invert(SubS->Rinv, nbands);
+    G_free((char *)lambda);
+void extract(DCELL *** img,	/* multispectral image, img[band][i][j] */
+	     struct Region *region,	/* region to extract */
+	     LIKELIHOOD *** ll,	/* log likelihood, ll[i][j][class] */
+	     struct SigSet *S	/* class signatures */
+    int i, j;			/* column and row indexes */
+    int k;			/* subclass index */
+    int b1, b2;			/* spectral index */
+    int no_data;		/* no data flag */
+    int max_nsubclasses;	/* maximum number of subclasses */
+    int nbands;			/* number of spectral bands */
+    double *subll;		/* log likelihood of subclasses */
+    double *diff;
+    double maxlike = 0.0L;
+    double subsum;
+    /* determine the maximum number of subclasses */
+    max_nsubclasses = 0;
+	if (S->ClassSig[m].nsubclasses > max_nsubclasses)
+	    max_nsubclasses = S->ClassSig[m].nsubclasses;
+    diff = (double *)G_malloc(nbands * sizeof(double));
+    subll = (double *)G_malloc(max_nsubclasses * sizeof(double));
+    /* Compute log likelihood at each pixel and for every class. */
+    /* for each pixel */
+	    /* Check for no data condition */
+	    no_data = 1;
+	    for (b1 = 0; (b1 < nbands) && no_data; b1++)
+		no_data = no_data && (G_is_d_null_value(&img[b1][i][j]));
+	    if (no_data) {
+		    ll[i][j][m] = 0.0;
+	    else {
+		    /* compute log likelihood for each subclass */
+		    for (k = 0; k < C->nsubclasses; k++) {
+			SubS = &(C->SubSig[k]);
+			subll[k] = SubS->cnst;
+			    diff[b1] = img[b1][i][j] - SubS->means[b1];
+			    subll[k] -=
+				0.5 * diff[b1] * diff[b1] *
+				SubS->Rinv[b1][b1];
+			    for (b2 = b1 + 1; b2 < nbands; b2++)
+				subll[k] -=
+				    diff[b1] * diff[b2] * SubS->Rinv[b1][b2];
+		    /* shortcut for one subclass */
+		    if (C->nsubclasses == 1) {
+			ll[i][j][m] = subll[0];
+		    /* compute mixture likelihood */
+		    else {
+			/* find the most likely subclass */
+			    if (k == 0)
+				maxlike = subll[k];
+			    if (subll[k] > maxlike)
+			/* Sum weighted subclass likelihoods */
+			subsum = 0;
+			    subsum +=
+				exp(subll[k] - maxlike) * C->SubSig[k].pi;
+			ll[i][j][m] = log(subsum) + maxlike;
+    G_free((char *)diff);
+    G_free((char *)subll);
Property changes on: grass/trunk/imagery/i.smap/model.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/multialloc.c (from rev 34870, grass/trunk/imagery/i.smap/bouman/multialloc.c)
--- grass/trunk/imagery/i.smap/multialloc.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/multialloc.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,124 @@
+#include <stdio.h>
+#include <stdarg.h>
+/* modified from dynamem.c on 4/29/91 C. Bouman */
+ * multialloc( s, d,  dn, dn ....) allocates a d dimensional array, whose
+ * dimensions are stored in a list starting at d1. Each array element is
+ * of size s.
+char *multialloc(size_t s,	/* individual array element size */
+		 int d,		/* number of dimensions */
+    va_list ap;			/* varargs list traverser */
+    int max,			/* size of array to be declared */
+     *q;			/* pointer to dimension list */
+    char **r,			/* pointer to beginning of the array of the
+				 * pointers for a dimension */
+    **s1, *t, *tree;		/* base pointer to beginning of first array */
+    int i, j;			/* loop counters */
+    int *d1;			/* dimension list */
+    va_start(ap, d);
+    d1 = (int *)G_malloc(d * sizeof(int));
+    for (i = 0; i < d; i++)
+	d1[i] = va_arg(ap, int);
+    r = &tree;
+    q = d1;			/* first dimension */
+    max = 1;
+    for (i = 0; i < d - 1; i++, q++) {	/* for each of the dimensions
+					 * but the last */
+	max *= (*q);
+	r[0] = (char *)G_malloc(max * sizeof(char **));
+	r = (char **)r[0];	/* step through to beginning of next
+				 * dimension array */
+    max *= s * (*q);		/* grab actual array memory */
+    r[0] = (char *)G_malloc(max * sizeof(char));
+     * r is now set to point to the beginning of each array so that we can
+     * use it to scan down each array rather than having to go across and
+     * then down
+    r = (char **)tree;		/* back to the beginning of list of arrays */
+    q = d1;			/* back to the first dimension */
+    max = 1;
+    for (i = 0; i < d - 2; i++, q++) {	/* we deal with the last
+					 * array of pointers later on */
+	max *= (*q);		/* number of elements in this dimension */
+	for (j = 1, s1 = r + 1, t = r[0]; j < max; j++) {	/* scans down array for
+								 * first and subsequent
+								 * elements */
+	    /*  modify each of the pointers so that it points to
+	     * the correct position (sub-array) of the next
+	     * dimension array. s1 is the current position in the
+	     * current array. t is the current position in the
+	     * next array. t is incremented before s1 is, but it
+	     * starts off one behind. *(q+1) is the dimension of
+	     * the next array. */
+	    *s1 = (t += sizeof(char **) * *(q + 1));
+	    s1++;
+	r = (char **)r[0];	/* step through to begining of next
+    max *= (*q);		/* max is total number of elements in the
+				 * last pointer array */
+    /* same as previous loop, but different size factor */
+	*s1++ = (t += s * *(q + 1));
+    va_end(ap);
+    G_free((char *)d1);
+    return tree;		/* return base pointer */
+ * multifree releases all memory that we have already declared analogous to
+ * G_free () when using G_malloc ()
+void multifree(char *r, int d)
+    char **p;
+    char *next = NULL;
+    int i;
+    for (p = (char **)r, i = 0; i < d; p = (char **)next, i++) {
+	if (p != NULL) {
+	    next = *p;
+	    G_free((char *)p);
+unsigned char **get_img(int wd, int ht, size_t size)
+    char *pt;
+    if ((pt = multialloc(size, 2, ht, wd)) == NULL)
+	G_fatal_error(_("Out of memory"));
+    return ((unsigned char **)pt);
+void free_img(unsigned char **pt)
+    multifree((char *)pt, 2);
Property changes on: grass/trunk/imagery/i.smap/multialloc.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/opencell.c (from rev 34868, grass/trunk/imagery/i.smap/shapiro/opencell.c)
--- grass/trunk/imagery/i.smap/opencell.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/opencell.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,34 @@
+int open_cell_old(const char *name, const char *mapset)
+    int fd;
+    if (mapset == NULL)
+	mapset = G_find_cell2(name, "");
+    fd = G_open_cell_old(name, mapset);
+    if (fd >= 0)
+	return fd;
+    G_fatal_error(_("Unable to open raster map <%s>"), name);
+    /* should not get here */
+    return -1;
+int open_cell_new(const char *name)
+    int fd;
+    fd = G_open_cell_new(name);
+    if (fd >= 0)
+	return fd;
+    G_fatal_error(_("Unable to create raster map <%s>"), name);
+    return -1;
Property changes on: grass/trunk/imagery/i.smap/opencell.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/openfiles.c (from rev 34870, grass/trunk/imagery/i.smap/shapiro/openfiles.c)
--- grass/trunk/imagery/i.smap/openfiles.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/openfiles.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,39 @@
+int openfiles(struct parms *parms, struct files *files)
+    struct Ref Ref;		/* subgroup reference list */
+    int n;
+    if (!I_get_subgroup_ref(parms->group, parms->subgroup, &Ref))
+	G_fatal_error(_("Unable to read REF file for subgroup <%s> in group <%s>"),
+		      parms->subgroup, parms->group);
+    if (Ref.nfiles <= 0)
+	G_fatal_error(_("Subgroup <%s> in group <%s> contains no raster maps"),
+    /* allocate file descriptors, and io buffer */
+    files->cellbuf = G_allocate_d_raster_buf();
+    files->outbuf = G_allocate_c_raster_buf();
+    files->isdata = G_malloc(G_window_cols());
+    files->nbands = Ref.nfiles;
+    files->band_fd = (int *)G_calloc(Ref.nfiles, sizeof(int));
+    /* open all group maps for reading */
+    for (n = 0; n < Ref.nfiles; n++)
+	files->band_fd[n] =
+	    open_cell_old(Ref.file[n].name, Ref.file[n].mapset);
+    /* open output map */
+    files->output_fd = open_cell_new(parms->output_map);
+    return 0;
Property changes on: grass/trunk/imagery/i.smap/openfiles.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/parse.c (from rev 34870, grass/trunk/imagery/i.smap/shapiro/parse.c)
--- grass/trunk/imagery/i.smap/parse.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/parse.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,68 @@
+int parse(int argc, char *argv[], struct parms *parms)
+    struct Option *group, *subgroup, *sigfile, *output;
+    struct Option *blocksize;
+    struct Flag *quiet;
+    struct Flag *ml;
+    group = G_define_standard_option(G_OPT_I_GROUP);
+    subgroup = G_define_standard_option(G_OPT_I_SUBGROUP);
+    sigfile = G_define_option();
+    sigfile->key = "signaturefile";
+    sigfile->label = _("Name of file containing signatures");
+    sigfile->description = _("Generated by i.gensigset");
+    sigfile->key_desc = "name";
+    sigfile->required = YES;
+    sigfile->type = TYPE_STRING;
+    output = G_define_standard_option(G_OPT_R_OUTPUT);
+    blocksize = G_define_option();
+    blocksize->key = "blocksize";
+    blocksize->description = _("Size of submatrix to process at one time");
+    blocksize->required = NO;
+    blocksize->type = TYPE_INTEGER;
+    blocksize->answer = "128";
+    ml = G_define_flag();
+    ml->key = 'm';
+    ml->description =
+	_("Use maximum likelihood estimation (instead of smap)");
+    quiet = G_define_flag();
+    quiet->key = 'q';
+    quiet->description = _("Run quietly");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    parms->quiet = quiet->answer;
+    parms->ml = ml->answer;
+    parms->output_map = output->answer;
+    parms->group = group->answer;
+    parms->subgroup = subgroup->answer;
+    parms->sigfile = sigfile->answer;
+    /* check all the inputs */
+    if (!I_find_group(parms->group))
+	G_fatal_error(_("Group <%s> not found"), parms->group);
+    if (!I_find_subgroup(parms->group, parms->subgroup))
+	G_fatal_error(_("Subgroup <%s> not found"), parms->subgroup);
+    if (sscanf(blocksize->answer, "%d", &parms->blocksize) != 1
+	|| parms->blocksize <= 8)
+	parms->blocksize = 8;
+    return 0;
Property changes on: grass/trunk/imagery/i.smap/parse.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/read_block.c (from rev 34870, grass/trunk/imagery/i.smap/bouman/read_block.c)
--- grass/trunk/imagery/i.smap/read_block.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/read_block.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,24 @@
+int read_block(DCELL *** img,	/* img[band][row[col] */
+	       struct Region *region, struct files *files)
+    int band, row, col;
+    for (band = 0; band < files->nbands; band++) {
+	for (row = region->ymin; row < region->ymax; row++) {
+	    if (G_get_d_raster_row(files->band_fd[band], files->cellbuf, row)
+		< 0)
+		G_fatal_error(_("Unable to read raster map row %d"),
+			      row);
+	    for (col = region->xmin; col < region->xmax; col++)
+		img[band][row][col] = files->cellbuf[col];
+    return 0;
Property changes on: grass/trunk/imagery/i.smap/read_block.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/read_sig.c (from rev 34870, grass/trunk/imagery/i.smap/shapiro/read_sig.c)
--- grass/trunk/imagery/i.smap/read_sig.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/read_sig.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,32 @@
+int read_signatures(struct parms *parms, struct SigSet *S)
+    FILE *fd;
+    struct Ref Ref;
+    fd = I_fopen_sigset_file_old(parms->group, parms->subgroup,
+				 parms->sigfile);
+    if (fd == NULL)
+	G_fatal_error(_("Unable to read signature file <%s>"),
+		      parms->sigfile);
+    if (I_ReadSigSet(fd, S) < 0 || Ref.nfiles != S->nbands)
+	G_fatal_error(_("Signature file <%s> is invalid"), parms->sigfile);
+    fclose(fd);
+    return 0;
Property changes on: grass/trunk/imagery/i.smap/read_sig.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/reg_util.c (from rev 34868, grass/trunk/imagery/i.smap/bouman/reg_util.c)
--- grass/trunk/imagery/i.smap/reg_util.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/reg_util.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,52 @@
+int levels_reg(struct Region *region)
+    int D;
+    int wd, ht;
+    D = 0;
+	D++;
+	dec_reg(region);
+    return (D);
+void dec_reg(struct Region *region)
+    region->xmin = region->xmin / 2;
+    region->xmax = region->xmax / 2;
+    region->ymin = region->ymin / 2;
+    region->ymax = region->ymax / 2;
+void copy_reg(struct Region *region1, struct Region *region2)
+    region2->xmin = region1->xmin;
+    region2->xmax = region1->xmax;
+    region2->ymin = region1->ymin;
+    region2->ymax = region1->ymax;
+    region2->free.left = region1->free.left;
+    region2->free.right = region1->free.right;
+    region2->free.top = region1->free.top;
+    region2->free.bottom = region1->free.bottom;
+void reg_to_wdht(struct Region *region, int *wd, int *ht)
+    *wd = region->xmax - region->xmin;
+    *ht = region->ymax - region->ymin;
Property changes on: grass/trunk/imagery/i.smap/reg_util.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/region.h (from rev 34868, grass/trunk/imagery/i.smap/bouman/region.h)
--- grass/trunk/imagery/i.smap/region.h	                        (rev 0)
+++ grass/trunk/imagery/i.smap/region.h	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,41 @@
+struct Region
+    int xmin, xmax;
+    int ymin, ymax;
+    struct Free
+	int left;
+	int right;
+	int top;
+	int bottom;
+    } free;
+/* decimate.c */
+void make_pyramid(LIKELIHOOD ****, struct Region *, int, double *, int);
+char ***get_pyramid(int, int, size_t);
+void free_pyramid(char *, int, int);
+char ****get_cubic_pyramid(int, int, int, size_t);
+void free_cubic_pyramid(char *, int, int, int);
+int levels(int, int);
+/* interp.c */
+void seq_MAP(unsigned char ***, struct Region *, LIKELIHOOD ****, int,
+	     double *, int);
+/* reg_util.c */
+int levels_reg(struct Region *);
+void dec_reg(struct Region *);
+void copy_reg(struct Region *, struct Region *);
+void reg_to_wdht(struct Region *, int *, int *);
+/* read_block.c */
+int read_block(DCELL ***, struct Region *, struct files *);
+/* segment.c */
+/* model.c */
+void extract_init(struct SigSet *);
+void extract(DCELL ***, struct Region *, LIKELIHOOD ***, struct SigSet *);
+#endif
Property changes on: grass/trunk/imagery/i.smap/region.h
   + text/x-chdr
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/segment.c (from rev 34870, grass/trunk/imagery/i.smap/bouman/segment.c)
--- grass/trunk/imagery/i.smap/segment.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/segment.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,310 @@
+ * MODULE:       i.smap segmentation
+ * AUTHOR(S):    Charles Bouman,
+ *               School of Electrical Engineering, Purdue University
+ * PURPOSE:      image classification and segmentation
+ * COPYRIGHT:    (C) 1999-2007 by the GRASS Development Team
+ *               for details.
+static void init_reg(struct Region *, int, int, int);
+static int increment_reg(struct Region *, int, int, int);
+static int shift_img(DCELL ***, int, struct Region *, int);
+static int shift_ll(LIKELIHOOD ****, struct Region *, int);
+int segment(struct SigSet *S,	/* class parameters */
+	    struct parms *parms, struct files *files)
+    int block_size;		/* size of subregion blocks */
+    int ml;			/* max likelihood? */
+    int quiet;			/* be quiet when running? */
+    DCELL ***img;		/* multispectral image, img[band][i][j] */
+    int last_row;
+    int wd, ht;			/* image width and height */
+    struct Region region;	/* specifies image subregion */
+    int nbands;			/* number of bands */
+    int nclasses;		/* number of classes */
+    LIKELIHOOD ****ll_pym;	/* pyramid of log likelihoods */
+    unsigned char ***sf_pym;	/* pyramid of segmentations */
+    int D;			/* number of levels in pyramid */
+    double *alpha_dec;		/* class transition probabilities */
+    int vlevel;			/* level of verbose output */
+    int i;
+    quiet = parms->quiet;	/* run quietly? */
+    ml = parms->ml;		/* use maxl? */
+    block_size = parms->blocksize;
+    vlevel = quiet ? 0 : 1;
+    wd = G_window_cols();	/* get width from GRASS */
+    ht = G_window_rows();	/* get height from GRASS */
+    /* make blocksize a power of 2 */
+    if (block_size < 8)
+	block_size = 8;
+    for (i = 0; (block_size >> i) > 1; i++) {
+    block_size = 1 << i;
+/**** this code may stay the same ******/
+    nclasses = S->nclasses;
+    /* Check for too many classes */
+    if (nclasses > 256)
+	G_fatal_error(_("Number of classes must be < 256"));
+    /* allocate alpha_dec parameters */
+    D = levels(block_size, block_size);
+    alpha_dec = (double *)G_malloc(D * sizeof(double));
+    /* allocate image block */
+    img =
+	(DCELL ***) multialloc(sizeof(DCELL), 3, nbands, block_size,
+			       block_size);
+    /* allocate memory for log likelihood pyramid */
+    ll_pym =
+	(LIKELIHOOD ****) get_cubic_pyramid(block_size, block_size, nclasses,
+					    sizeof(LIKELIHOOD));
+    /* allocate memory for segmentation pyramid */
+    sf_pym = (unsigned char ***)get_pyramid(wd, ht, sizeof(char));
+    /* tiled segmentation */
+    init_reg(&region, wd, ht, block_size);
+    extract_init(S);
+    last_row = -1;
+    do {
+	if (vlevel >= 1 && last_row != region.ymin)
+	    G_message(_("Processing rows %d-%d (of %d)..."),
+		      region.ymin + 1, region.ymax, ht);
+	last_row = region.ymin;
+	shift_img(img, nbands, &region, block_size);
+	/* this reads grass images into the block defined in region */
+	read_block(img, &region, files);
+	shift_ll(ll_pym, &region, block_size);
+	extract(img, &region, ll_pym[0], S);
+	if (ml)
+	    MLE(sf_pym[0], ll_pym[0], &region, nclasses);
+	else {
+	    for (i = 0; i < D; i++)
+		alpha_dec[i] = 1.0;
+	    seq_MAP(sf_pym, &region, ll_pym, nclasses, alpha_dec, vlevel);
+    } while (increment_reg(&region, wd, ht, block_size));
+    write_img(sf_pym[0], wd, ht, S, parms, files);
+    return 0;
+static void init_reg(struct Region *region, int wd, int ht, int block_size)
+    region->xmin = 0;
+    region->ymin = 0;
+    region->xmax = block_size;
+    if (region->xmax > wd)
+	region->xmax = wd;
+    region->ymax = block_size;
+    if (region->ymax > ht)
+	region->ymax = ht;
+    region->free.left = 1;
+    region->free.top = 1;
+    region->free.right = 1;
+    region->free.bottom = 1;
+static int increment_reg(struct Region *region, int wd, int ht,
+			 int block_size)
+    /* shift one block to right */
+    if (region->xmax < wd) {
+	region->xmin = region->xmax;
+	region->xmax = region->xmin + block_size;
+    else {
+	/* shift one block down */
+	if (region->ymax < ht) {
+	    region->xmin = 0;
+	    region->ymin = region->ymax;
+	    region->ymax = region->ymax + block_size;
+	/* finished shifting */
+	else {
+	    return (0);
+    if (region->xmin == 0)
+    else
+	region->free.left = 0;
+    if (region->ymin == 0)
+    else
+	region->free.top = 0;
+    return (1);
+static int shift_img(DCELL *** img, int nbands,
+		     struct Region *region, int block_size)
+    static int xoffset = 0;
+    static int yoffset = 0;
+    int xdelta;
+    int ystart, ystop, ydelta;
+    int b, i;
+    xdelta = region->xmin - xoffset;
+    ydelta = region->ymin - yoffset;
+    xoffset = region->xmin;
+    yoffset = region->ymin;
+    ystart = region->ymin;
+    ystop = ystart + block_size;
+    for (b = 0; b < nbands; b++) {
+	img[b] -= ydelta;
+	for (i = ystart; i < ystop; i++)
+	    img[b][i] -= xdelta;
+    return 0;
+static int shift_ll(LIKELIHOOD **** ll_pym,
+    static int first = 1;
+    static int xoffset[20];
+    static int yoffset[20];
+    int xdelta;
+    int D;
+    int k, i;
+    int block_size_k;
+    /* if first time, set offsets to 0 */
+    if (first) {
+	for (k = 0; k <= D; k++)
+	    xoffset[k] = yoffset[k] = 0;
+	first = 0;
+    /* save region information */
+    /* subtract pointer offsets for each scale */
+    block_size_k = block_size;
+    for (k = 0; k <= D; k++) {
+	xdelta = region->xmin - xoffset[k];
+	ydelta = region->ymin - yoffset[k];
+	xoffset[k] = region->xmin;
+	yoffset[k] = region->ymin;
+	ystop = ystart + block_size_k;
+	ll_pym[k] -= ydelta;
+	    ll_pym[k][i] -= xdelta;
+	dec_reg(region);
+	block_size_k = block_size_k / 2;
+    /* replace region information */
+    return 0;
+#ifdef COMMENTED_OUT
+int read_block(DCELL *** img, int wd, int ht, int nbands,
+	       struct Region *region, char *infn)
+    static first = 1;
+    static unsigned char ***img_buf;
+    int b, i, j;
+    int xstop, ystop;
+    char *infn_num;
+    /* allocate image buffer first time called */
+    if (first) {
+	img_buf =
+	    (unsigned char ***)multialloc(sizeof(unsigned char), 3, nbands,
+					  ht, wd);
+	/* allocate memory for name extension */
+	infn_num = (char *)G_malloc((strlen(optarg) + 10) * sizeof(char));
+	/* read data */
+	if (nbands == 1) {
+	    read_img(img_buf[0], wd, ht, infn);
+	else {
+	    for (b = 1; b <= nbands; b++) {
+		sprintf(infn_num, "%s.%d", infn, b);
+		read_img(img_buf[b - 1], wd, ht, infn_num);
+	first = 0;
+    /* copy data from buffer */
+    xstop = region->xmax;
+    if (xstop > wd)
+	xstop = wd;
+    ystop = region->ymax;
+    if (ystop > ht)
+	ystop = ht;
+	for (i = region->ymin; i < ystop; i++)
+	    for (j = region->xmin; j < xstop; j++)
+		img[b][i][j] = img_buf[b][i][j];
+    return 0;
+#endif
Property changes on: grass/trunk/imagery/i.smap/segment.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/solve.c (from rev 34868, grass/trunk/imagery/i.smap/bouman/solve.c)
--- grass/trunk/imagery/i.smap/solve.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/solve.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,61 @@
+double solve(
+		/* Solves equation (*f)(x) = 0 on x in [a,b]. Uses half interval method. */
+		/* Requires that (*f)(a) and (*f)(b) have opposite signs.               */
+		/* Returns code=0 if signs are opposite.                                */
+		/* Returns code=1 if signs are both positive.                           */
+		/* Returns code=1 if signs are both negative.                           */
+		double (*f) (double),	/* pointer to function to be solved */
+		double a,	/* minimum value of solution */
+		double b,	/* maximum value of solution */
+		double err,	/* accuarcy of solution */
+		int *code	/* error code */
+    int signa, signb, signc;
+    double fa, fb, fc, c, signaling_nan();
+    double dist;
+    fa = (*f) (a);
+    signa = fa > 0;
+    fb = (*f) (b);
+    signb = fb > 0;
+    /* check starting conditions */
+    if (signa == signb) {
+	if (signa == 1)
+	    *code = 1;
+	else
+	    *code = -1;
+	return (0.0);
+    else
+	*code = 0;
+    /* half interval search */
+    if ((dist = b - a) < 0)
+	dist = -dist;
+    while (dist > err) {
+	c = (b + a) / 2;
+	fc = (*f) (c);
+	signc = fc > 0;
+	if (signa == signc) {
+	    a = c;
+	    fa = fc;
+	else {
+	    b = c;
+	    fb = fc;
+	    dist = -dist;
+    /* linear interpolation */
+    if ((fb - fa) == 0)
+	return (a);
+    else {
+	c = (a * fb - b * fa) / (fb - fa);
+	return (c);
Property changes on: grass/trunk/imagery/i.smap/solve.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/imagery/i.smap/write_img.c (from rev 34870, grass/trunk/imagery/i.smap/shapiro/write_img.c)
--- grass/trunk/imagery/i.smap/write_img.c	                        (rev 0)
+++ grass/trunk/imagery/i.smap/write_img.c	2008-12-14 14:29:09 UTC (rev 34871)
@@ -0,0 +1,27 @@
+int write_img(unsigned char **img, int ncols, int nrows, struct SigSet *S,	/* class parameters */
+	      struct parms *parms,	/* parms: command line parameters */
+	      struct files *files)
+{				/* files: contains file to output */
+    int row, col;
+    G_message(_("Writing raster map <%s>..."), parms->output_map);
+    for (row = 0; row < nrows; row++) {
+	G_percent(row, nrows, 2);
+	for (col = 0; col < ncols; col++) {
+	    int class = (int)img[row][col];
+	    G_debug(3, "class: [%d] row/col: [%d][%d]", class, row, col);
+	    files->outbuf[col] = (CELL) S->ClassSig[class].classnum;
+	G_put_raster_row(files->output_fd, files->outbuf, CELL_TYPE);
+    G_percent(nrows, nrows, 2);
+    return 0;
Property changes on: grass/trunk/imagery/i.smap/write_img.c
   + text/x-csrc
   + Author Date Id
   + native
