[GRASS-SVN] r34905 - in grass/branches/develbranch_6:
gui/wxpython/gui_modules scripts/d.vect.thematic
scripts/v.db.update vector/v.net vector/v.net.iso vector/v.reclass
svn_grass at osgeo.org
Tue Dec 16 07:14:52 EST 2008
Author: martinl
Date: 2008-12-16 07:14:51 -0500 (Tue, 16 Dec 2008)
New Revision: 34905
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic
grass/branches/develbranch_6/scripts/v.db.update/v.db.update
grass/branches/develbranch_6/vector/v.net.iso/main.c
grass/branches/develbranch_6/vector/v.net/main.c
grass/branches/develbranch_6/vector/v.reclass/main.c
message standardization, missing gisprompts added
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2008-12-15 23:17:11 UTC (rev 34904)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2008-12-16 12:14:51 UTC (rev 34905)
@@ -420,7 +420,7 @@
def __init__(self, parent,
id=wx.ID_ANY, pos=wx.DefaultPosition,
size=globalvar.DIALOG_LAYER_SIZE,
- vector=None, choices=[], all=False):
+ vector=None, choices=[], all=False, default=None):
super(LayerSelect, self).__init__(parent, id, pos=pos, size=size,
choices=choices)
@@ -429,6 +429,9 @@
self.SetName("LayerSelect")
+ # default value
+ self.default = default
if len(choices) > 1:
return
@@ -453,7 +456,10 @@
else:
self.SetItems(['1'])
self.SetStringSelection('1')
+ if self.default:
+ self.SetStringSelection(str(self.default))
class DriverSelect(wx.ComboBox):
Creates combo box for selecting database driver.
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2008-12-15 23:17:11 UTC (rev 34904)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2008-12-16 12:14:51 UTC (rev 34905)
@@ -1201,13 +1201,14 @@
all = False
if p.get('age', 'old_layer') == 'old_layer':
win = gselect.LayerSelect(parent=which_panel,
- all=all)
+ all=all,
+ default=p['default'])
p['wxGetValue'] = win.GetStringSelection
win.Bind(wx.EVT_CHOICE, self.OnUpdateSelection)
win.Bind(wx.EVT_CHOICE, self.OnSetValue)
else:
win = wx.SpinCtrl(parent=which_panel, id=wx.ID_ANY,
- min=1, max=100, initial=1)
+ min=1, max=100, initial=int(p['default']))
win.Bind(wx.EVT_SPINCTRL, self.OnSetValue)
elif p.get('prompt', '') == 'dbdriver':
Modified: grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic
--- grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic 2008-12-15 23:17:11 UTC (rev 34904)
+++ grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic 2008-12-16 12:14:51 UTC (rev 34905)
@@ -18,34 +18,35 @@
#%Module
#% description: Displays thematic vector map
-#% keywords: display, legend
+#% keywords: display, vector, thematic, legend
#%End
#%option
#% guisection: Files
#% key: map
#% type: string
#% gisprompt: old,vector,vector
-#% description: Vector map to display thematically
+#% description: Name of vector map
#% required : yes
#%end
#%option
-#% guisection: Theme_prefs
+#% guisection: Theme
#% key: type
#% type: string
-#% description: Vector map type
+#% description: Feature type
#% options: area,point,centroid,line,boundary
#% answer: area
#% required : yes
#%end
#%option
#% key: column
+#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
#% type: string
-#% description: Attribute column to use for thematic display (must be numeric)
+#% description: Name of attribute column to use for thematic display (must be numeric)
#% required : yes
#%end
#%option
#% key: themetype
#% type: string
#% options: graduated_colors,graduated_points,graduated_lines
@@ -54,7 +55,7 @@
#% required : yes
#%end
#%option
#% key: themecalc
#% type: string
#% options: interval,std_deviation,quartiles,custom_breaks
@@ -63,17 +64,19 @@
#% required : yes
#%end
#%option
#% key: breakpoints
#% type: string
-#% description: Break points for custom breaks option. Separate values by spaces. (0 10 20 30 ...)
+#% label: Break points for custom breaks option
+#% description: Separate values by spaces (0 10 20 30 ...)
#% required : no
#%end
#%option
#% key: layer
#% type: integer
-#% description: Layer to use for thematic display
+#% gisprompt: old_layer,layer,layer
+#% description: Layer number
#% answer: 1
#% required : no
#%end
@@ -90,7 +93,8 @@
#% guisection: Points
#% key: size
#% type: double
-#% description: Icon size for point data (minimum icon size/line width for graduated points/lines)
+#% label: Icon size for point data
+#% description: Minimum icon size/line width for graduated points/lines)
#% answer: 5
#% required : no
#%end
@@ -103,7 +107,7 @@
#% required : no
#%end
#%option
#% key: nint
#% type: integer
#% description: Number of classes for interval theme (integer)
@@ -114,7 +118,8 @@
#% guisection: Color
#% key: colorscheme
#% type: string
-#% description: Color scheme for graduated color mapping (select 'single_color' for graduated point/line display)
+#% label: Color scheme for graduated color mapping
+#% description: Select 'single_color' for graduated point/line display
#% options: blue-red,red-blue,green-red,red-green,blue-green,green-blue,cyan-yellow,yellow-cyan,custom_gradient,single_color
#% answer: blue-red
#% required : yes
@@ -123,7 +128,8 @@
#% key: pointcolor
#% type: string
-#% description: Color for graduated points map (grass named color or R:G:B triplet). Set color scheme to single color.
+#% label: Color for graduated points map
+#% description: GRASS named color or R:G:B triplet. Set color scheme to single color
#% answer: 255:0:0
#% required : no
#%end
@@ -131,7 +137,8 @@
#% key: linecolor
#% type: string
-#% description: Color for graduated lines or point/area outlines (grass named color or R:G:B triplet). Set color scheme to single color.
+#% label: Color for graduated lines or point/area outlines
+#% description: GRASS named color or R:G:B triplet. Set color scheme to single color.
#% answer: 0:0:0
#% required : no
#%end
@@ -139,7 +146,8 @@
#% key: startcolor
#% type: string
-#% description: Beginning color for custom color gradient. Must be expressed as R:G:B triplet.
+#% label: Beginning color for custom color gradient
+#% description: Must be expressed as R:G:B triplet
#% answer: 255:0:0
#% required : no
#%end
@@ -147,7 +155,8 @@
#% key: endcolor
#% type: string
-#% description: Ending color for custom color gradient. Must be expressed as R:G:B triplet
+#% label: Ending color for custom color gradient
#% answer: 0:0:255
#% required : no
#%end
@@ -166,7 +175,7 @@
#%description: Save thematic map commands to group file for GIS Manager
#%end
#%option
#% key: where
#% type: string
#% description: WHERE conditions of SQL statement without 'where' keyword
@@ -176,7 +185,8 @@
#% key: psmap
#% type: string
-#% description: Root for the name of psmap instruction files to be in current directory (if not set, no psmap instruction files will be created)
+#% label: Root for the name of psmap instruction files to be in current directory
+#% description: If not set, no psmap instruction files will be created)
#% required : no
#%end
#%option
@@ -188,7 +198,7 @@
#% required : no
#%end
#%flag
#%key: l
#%description: Create graphic legend in x11 display monitor
#%end
Modified: grass/branches/develbranch_6/scripts/v.db.update/v.db.update
--- grass/branches/develbranch_6/scripts/v.db.update/v.db.update 2008-12-15 23:17:11 UTC (rev 34904)
+++ grass/branches/develbranch_6/scripts/v.db.update/v.db.update 2008-12-16 12:14:51 UTC (rev 34905)
@@ -28,6 +28,7 @@
#%option
#% key: layer
#% type: integer
#% description: Layer to which the table to be changed is connected
#% answer: 1
#% required : no
@@ -35,6 +36,7 @@
#%option
#% key: column
#% type: string
#% description: Column to update
#% required : yes
#%end
@@ -46,6 +48,7 @@
#%end
#%option
#% key: qcolumn
#% type: string
#% description: Column to query
#% required : no
Modified: grass/branches/develbranch_6/vector/v.net/main.c
--- grass/branches/develbranch_6/vector/v.net/main.c 2008-12-15 23:17:11 UTC (rev 34904)
+++ grass/branches/develbranch_6/vector/v.net/main.c 2008-12-16 12:14:51 UTC (rev 34905)
@@ -9,7 +9,7 @@
* PURPOSE: Network maintenance
- * COPYRIGHT: (C) 2001 by the GRASS Development Team
+ * COPYRIGHT: (C) 2001-2008 by the GRASS Development Team
* This program is free software under the
* GNU General Public License (>=v2).
@@ -45,7 +45,7 @@
module = G_define_module();
module->keywords = _("vector, networking");
- module->description = _("Network maintenance.");
+ module->description = _("Performs network maintenance.");
/* Define the options */
input = G_define_standard_option(G_OPT_V_INPUT);
@@ -78,12 +78,14 @@
afield_opt = G_define_standard_option(G_OPT_V_FIELD);
afield_opt->key = "alayer";
- afield_opt->label = _("Arc layer (network)");
+ afield_opt->gisprompt = "new_layer,layer,layer";
+ afield_opt->label = _("Arc layer");
nfield_opt = G_define_standard_option(G_OPT_V_FIELD);
nfield_opt->key = "nlayer";
nfield_opt->answer = "2";
- nfield_opt->label = _("Node layer (points)");
+ nfield_opt->gisprompt = "new_layer,layer,layer";
+ nfield_opt->label = _("Node layer");
thresh_opt = G_define_option();
thresh_opt->key = "thresh";
@@ -185,7 +187,7 @@
narcs = connect_arcs(&In, &Points, &Out, nfield, thresh);
- G_message(_("%d arcs added to network (nlayer: [%d])"), narcs,
+ G_message(_("%d arcs added to network (nlayer %d)"), narcs,
nfield);
Vect_close(&Points);
Modified: grass/branches/develbranch_6/vector/v.net.iso/main.c
--- grass/branches/develbranch_6/vector/v.net.iso/main.c 2008-12-15 23:17:11 UTC (rev 34904)
+++ grass/branches/develbranch_6/vector/v.net.iso/main.c 2008-12-16 12:14:51 UTC (rev 34905)
@@ -7,7 +7,7 @@
* PURPOSE: Split net to bands between isolines.
@@ -69,7 +69,7 @@
G_gisinit(argv[0]);
- module->label = _("Split net by cost isolines");
+ module->label = _("Splits net by cost isolines.");
_("Splits net to bands between cost isolines (direction from centre). "
@@ -86,30 +86,24 @@
- afield_opt->description = _("Arc layer");
- nfield_opt->description = _("Node layer");
- afcol = G_define_option();
+ afcol = G_define_standard_option(G_OPT_COLUMN);
afcol->key = "afcolumn";
- afcol->type = TYPE_STRING;
- afcol->required = NO;
afcol->description =
_("Arc forward/both direction(s) cost column (number)");
- abcol = G_define_option();
+ abcol = G_define_standard_option(G_OPT_COLUMN);
abcol->key = "abcolumn";
- abcol->type = TYPE_STRING;
- abcol->required = NO;
abcol->description = _("Arc backward direction cost column (number)");
- ncol = G_define_option();
+ ncol = G_define_standard_option(G_OPT_COLUMN);
ncol->key = "ncolumn";
- ncol->type = TYPE_STRING;
- ncol->required = NO;
ncol->description = _("Node cost column (number)");
term_opt = G_define_standard_option(G_OPT_V_CATS);
@@ -167,7 +161,7 @@
if (iso[niso] <= iso[niso - 1])
G_fatal_error(_("Iso cost: %f less than previous"), iso[niso]);
- G_message(_("Iso cost [%d] : [%f]"), niso, iso[niso]);
+ G_verbose_message(_("Iso cost %d: %f"), niso, iso[niso]);
niso++;
i++;
@@ -227,7 +221,7 @@
- G_message(_("Number of centres: [%d] (nlayer: [%d])"), ncentres, nfield);
+ G_message(_("Number of centres: %d (nlayer %d)"), ncentres, nfield);
if (ncentres == 0)
G_warning(_("Not enough centres for selected nlayer. Nothing will be allocated."));
@@ -245,14 +239,14 @@
pnts2 = (ISOPOINT *) G_malloc(apnts2 * sizeof(ISOPOINT));
/* Fill Nodes by neares centre and costs from that centre */
- G_message(_("Calculating costs from centres..."));
for (centre = 0; centre < ncentres; centre++) {
- G_percent(centre, ncentres, 1);
node1 = Centers[centre].node;
Vect_net_get_node_cost(&Map, node1, &n1cost);
G_debug(2, "centre = %d node = %d cat = %d", centre, node1,
Centers[centre].cat);
+ G_message(_("Calculating costs from centre %d..."), centre + 1);
for (node2 = 1; node2 <= nnodes; node2++) {
+ G_percent(node2, nnodes, 1);
G_debug(5, " node1 = %d node2 = %d", node1, node2);
Vect_net_get_node_cost(&Map, node2, &n2cost);
if (n2cost == -1) {
@@ -278,14 +272,16 @@
- G_percent(1, 1, 1);
/* Write arcs to new map */
Vect_open_new(&Out, output->answer, Vect_is_3d(&Map));
Vect_hist_command(&Out);
+ G_message("Generating isolines...");
nlines = Vect_get_num_lines(&Map);
for (line = 1; line <= nlines; line++) {
+ G_percent(line, nlines, 2);
ltype = Vect_read_line(&Map, Points, NULL, line);
if (!(ltype & type)) {
continue;
Modified: grass/branches/develbranch_6/vector/v.reclass/main.c
--- grass/branches/develbranch_6/vector/v.reclass/main.c 2008-12-15 23:17:11 UTC (rev 34904)
+++ grass/branches/develbranch_6/vector/v.reclass/main.c 2008-12-16 12:14:51 UTC (rev 34905)
@@ -60,7 +60,7 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, attribute table");
+ module->keywords = _("vector, reclass, attributes");
_("Changes vector category values for an existing vector map "
"according to results of SQL queries or a value in attribute table column.");
@@ -69,23 +69,24 @@
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
- rules_opt = G_define_standard_option(G_OPT_F_INPUT);
- rules_opt->key = "rules";
- rules_opt->required = NO;
- rules_opt->description = _("Full path to the reclass rule file");
+ type_opt = G_define_standard_option(G_OPT_V_TYPE);
+ type_opt->options = "point,line,boundary,centroid";
+ type_opt->answer = "point,line,boundary,centroid";
+ type_opt->guisection = _("Selection");
+ field_opt = G_define_standard_option(G_OPT_V_FIELD);
+ field_opt->guisection = _("Selection");
col_opt = G_define_standard_option(G_OPT_COLUMN);
col_opt->label =
_("The name of the column whose values are to be used as new categories");
col_opt->description = _("The source for the new key column must be type integer or string");
- type_opt = G_define_standard_option(G_OPT_V_TYPE);
- type_opt->description = _("Select type");
- type_opt->options = "point,line,boundary,centroid";
- type_opt->answer = "point,line,boundary,centroid";
+ rules_opt = G_define_standard_option(G_OPT_F_INPUT);
+ rules_opt->key = "rules";
+ rules_opt->required = NO;
+ rules_opt->description = _("Full path to the reclass rule file");
- field_opt = G_define_standard_option(G_OPT_V_FIELD);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -117,7 +118,8 @@
Fi = Vect_get_field(&In, field);
if (Fi == NULL)
- G_fatal_error(_("Unable to get layer info for vector map"));
+ G_fatal_error(_("Database connection not defined for layer %d"),
+ field);
Driver = db_start_driver_open_database(Fi->driver, Fi->database);
if (Driver == NULL)
@@ -132,7 +134,8 @@
ctype = db_column_Ctype(Driver, Fi->table, col_opt->answer);
if (ctype == -1) {
- G_fatal_error(_("Column <%s> not found"), col_opt->answer);
+ G_fatal_error(_("Column <%s> not found in table <%s>"),
+ col_opt->answer, Fi->table);
else if (ctype == DB_C_TYPE_INT) {
nrec =
@@ -173,13 +176,15 @@
if (db_open_select_cursor(Driver, &stmt, &cursor, DB_SEQUENTIAL)
!= DB_OK)
- G_fatal_error("Cannot open select cursor: %s",
+ G_fatal_error("Unable to open select cursor: '%s'",
db_get_string(&stmt));
nrows = db_get_num_rows(&cursor);
G_debug(3, " %d rows selected", nrows);
if (nrows < 0)
- G_fatal_error(_("Cannot select records from database"));
+ G_fatal_error(_("No records selected from table <%s>"),
+ Fi->table);
db_CatValArray_alloc(&cvarr, nrows);
@@ -210,17 +215,17 @@
Vect_close(&Out);
db_close_database_shutdown_driver(Driver);
db_close_database_shutdown_driver(Driver2);
- G_fatal_error("Cannot create table: %s",
+ G_fatal_error("Unable to create table: '%s'",
db_get_string(&stmt2));
- if (db_create_index2(Driver2, NewFi->table, "cat") != DB_OK)
- G_warning(_("Cannot create index"));
+ if (db_create_index2(Driver2, NewFi->table, NewFi->key) != DB_OK)
+ G_warning(_("Unable to create index for table <%s>, key <%s>"),
+ NewFi->table, NewFi->key);
- if (db_grant_on_table
- (Driver2, NewFi->table, DB_PRIV_SELECT,
- DB_GROUP | DB_PUBLIC) != DB_OK) {
- G_fatal_error(_("Cannot grant privileges on table <%s>"),
+ if (db_grant_on_table(Driver2, NewFi->table, DB_PRIV_SELECT,
+ DB_GROUP | DB_PUBLIC) != DB_OK) {
+ G_fatal_error(_("Unable to grant privileges on table <%s>"),
NewFi->table);
@@ -229,7 +234,8 @@
/* fetch the data */
for (i = 0; i < nrows; i++) {
if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
- G_fatal_error(_("Cannot fetch data"));
+ G_fatal_error(_("Unable to fetch data from table <%s>"),
+ Fi->table);
column = db_get_table_column(table, 1);
@@ -419,7 +425,7 @@
Vect_build(&Out);
Vect_close(&Out);
- G_message(_("%d features reclassed"), rclelem);
+ G_done_msg(_("%d features reclassed."), rclelem);
exit(EXIT_SUCCESS);
