[GRASS-SVN] r34906 - grass/branches/develbranch_6/vector/v.to.db
svn_grass at osgeo.org
Tue Dec 16 08:30:29 EST 2008
Author: martinl
Date: 2008-12-16 08:30:29 -0500 (Tue, 16 Dec 2008)
New Revision: 34906
grass/branches/develbranch_6/vector/v.to.db/update.c
v.to.db: fix qlayer
Modified: grass/branches/develbranch_6/vector/v.to.db/update.c
--- grass/branches/develbranch_6/vector/v.to.db/update.c 2008-12-16 12:14:51 UTC (rev 34905)
+++ grass/branches/develbranch_6/vector/v.to.db/update.c 2008-12-16 13:30:29 UTC (rev 34906)
@@ -42,10 +42,10 @@
db_begin_transaction(driver);
- /* select existing categories to array (array is sorted) */
- vstat.select = db_select_int(driver, qFi->table, qFi->key, NULL, &catexst);
+ /* select existing categories (layer) to array (array is sorted) */
+ vstat.select = db_select_int(driver, Fi->table, Fi->key, NULL, &catexst);
G_debug(3, "Existing categories: %d", vstat.select);
/* create beginning of stmt */
switch (options.option) {
case O_CAT:
@@ -73,7 +73,9 @@
/* update */
G_message(_("Updating database..."));
for (i = 0; i < vstat.rcat; i++) {
- fcat = Values[i].cat;
+ G_percent(i, vstat.rcat, 2);
+ fcat = Values[i].cat;
if (fcat < 0)
continue;
@@ -184,8 +186,8 @@
break;
- G_percent(i + 1, vstat.rcat, 2);
+ G_percent(1, 1, 1);
G_debug(3, "SQL: %s", buf2);
db_set_string(&stmt, buf2);
