[GRASS-SVN] r34912 - grass/branches/develbranch_6/lib/python
svn_grass at osgeo.org
Tue Dec 16 09:21:41 EST 2008
Author: martinl
Date: 2008-12-16 09:21:41 -0500 (Tue, 16 Dec 2008)
New Revision: 34912
grass/branches/develbranch_6/lib/python/grass.py
synchronize grass.py with trunk
Modified: grass/branches/develbranch_6/lib/python/grass.py
--- grass/branches/develbranch_6/lib/python/grass.py 2008-12-16 14:02:21 UTC (rev 34911)
+++ grass/branches/develbranch_6/lib/python/grass.py 2008-12-16 14:21:41 UTC (rev 34912)
@@ -4,6 +4,7 @@
import subprocess
import re
import atexit
+import string
# subprocess wrapper that uses shell on Windows
@@ -230,33 +231,14 @@
result[k] = v
return result
-_kv_regex = None
-def parse_key_val2(s):
- """Parse a string into a dictionary, where entries are separated
- by newlines and the key and value are separated by `=', and the
- value is enclosed in single quotes.
- Suitable for parsing the output from g.findfile and g.gisenv.
- global _kv_regex
- if _kv_regex == None:
- _kv_regex = re.compile("([^=]+)='(.*)';?")
- result = []
- for line in s.splitlines():
- m = _kv_regex.match(line)
- if m != None:
- result.append(m.groups())
- else:
- result.append(line.split('=', 1))
- return dict(result)
# interface to g.gisenv
def gisenv():
"""Returns the output from running g.gisenv (with no arguments), as a
dictionary.
- return parse_key_val2(read_command("g.gisenv"))
+ s = read_command("g.gisenv", flags='n')
+ return parse_key_val(s)
# interface to g.region
@@ -287,8 +269,8 @@
def find_file(name, element = 'cell', mapset = None):
"""Returns the output from running g.findfile as a dictionary."""
- s = read_command("g.findfile", element = element, file = name, mapset = mapset)
- return parse_key_val2(s)
+ s = read_command("g.findfile", flags='n', element = element, file = name, mapset = mapset)
# interface to g.list
@@ -398,7 +380,7 @@
def verbosity():
"""Return the verbosity level selected by GRASS_VERBOSE"""
- vbstr = 'GRASS_VERBOSE'
+ vbstr = os.getenv('GRASS_VERBOSE')
if vbstr:
return int(vbstr)
else:
@@ -512,15 +494,16 @@
# run "v.info -c ..." and parse output
def vector_columns(map, layer = None, **args):
- """Return the list of columns for the database table connected to
+ """Return the directory of columns for the database table connected to
a vector map (interface to `v.info -c').
s = read_command('v.info', flags = 'c', map = map, layer = layer, quiet = True, **args)
- result = []
+ result = {}
f = line.split('|')
if len(f) == 2:
- result.append(f)
+ result[f[1]] = f[0]
return result
# add vector history
@@ -539,3 +522,20 @@
run_command('r.support', map = map, history = os.environ['CMDLINE'])
+# run "r.info -rgstmpud ..." and parse output
+def raster_info(map):
+ """Return information about a raster map (interface to `r.info')."""
+ s = read_command('r.info', flags = 'rgstmpud', map = map)
+ kv = parse_key_val(s)
+ for k in ['min', 'max', 'north', 'south', 'east', 'west', 'nsres', 'ewres']:
+ kv[k] = float(kv[k])
+ return kv
+# interface to r.mapcalc
+def mapcalc(exp, **kwargs):
+ t = string.Template(exp)
+ e = t.substitute(**kwargs)
+ if run_command('r.mapcalc', expression = e) != 0:
+ grass.fatal("An error occurred while running r.mapcalc")
