[GRASS-SVN] r34913 - grass/branches/develbranch_6/general/g.gisenv
svn_grass at osgeo.org
Tue Dec 16 09:33:27 EST 2008
Author: martinl
Date: 2008-12-16 09:33:27 -0500 (Tue, 16 Dec 2008)
New Revision: 34913
grass/branches/develbranch_6/general/g.gisenv/main.c
g.gisenv: -s/n flags added (merge from trunk)
Modified: grass/branches/develbranch_6/general/g.gisenv/main.c
--- grass/branches/develbranch_6/general/g.gisenv/main.c 2008-12-16 14:21:41 UTC (rev 34912)
+++ grass/branches/develbranch_6/general/g.gisenv/main.c 2008-12-16 14:33:27 UTC (rev 34913)
@@ -25,9 +25,10 @@
int main(int argc, char *argv[])
int n, store;
- int tty;
- char *name, *value, *ptr;
+ const char *name, *value;
+ char *ptr;
struct Option *get, *set, *store_opt;
+ struct Flag *flag_s, *flag_n;
struct GModule *module;
G_set_program_name(argv[0]);
@@ -60,15 +61,34 @@
store_opt->description = _("Where GRASS variable is stored");
store_opt->required = NO;
+ flag_s = G_define_flag();
+ flag_s->key = 's';
+ flag_s->description = _("Use shell syntax (for \"eval\")");
+ flag_n = G_define_flag();
+ flag_n->key = 'n';
+ flag_n->description = _("Don't use shell syntax");
if (argc > 1 && G_parser(argc, argv) < 0)
exit(EXIT_FAILURE);
+ if (flag_s->answer && flag_n->answer)
+ G_fatal_error(_("-s and -n are mutually exclusive"));
/* Print or optionally set environment variables */
if (!get->answer && !set->answer) {
- tty = isatty(1);
for (n = 0; (name = G__env_name(n)); n++) {
+ int quote;
+ if (flag_s->answer)
+ quote = 1;
+ else if (flag_n->answer)
+ quote = 0;
+ else
+ quote = !isatty(fileno(stdout));
if ((value = G__getenv(name))) {
- if (tty)
+ if (!quote)
fprintf(stdout, "%s=%s\n", name, value);
else
fprintf(stdout, "%s='%s';\n", name, value);
