[GRASS-SVN] r34924 - grass/trunk/vector/v.out.ascii
svn_grass at osgeo.org
Wed Dec 17 16:29:16 EST 2008
Author: martinl
Date: 2008-12-17 16:29:16 -0500 (Wed, 17 Dec 2008)
New Revision: 34924
grass/trunk/vector/v.out.ascii/v.out.ascii.html
fix typo in manual page
Modified: grass/trunk/vector/v.out.ascii/v.out.ascii.html
--- grass/trunk/vector/v.out.ascii/v.out.ascii.html 2008-12-17 21:04:58 UTC (rev 34923)
+++ grass/trunk/vector/v.out.ascii/v.out.ascii.html 2008-12-17 21:29:16 UTC (rev 34924)
@@ -18,7 +18,7 @@
maps between GRASS and other software, and for transferring data
between machines.
-<o>
+<p>
If the <b>format</b> parameter is set to <b>standard</b>, a GRASS
ASCII vector map will be exported, which may contain a mix of
primitives including points, lines, boundaries, centroids, areas,
