[GRASS-SVN] r34925 - grass/branches/develbranch_6/vector/v.out.ascii
Wed Dec 17 16:29:55 EST 2008
Author: martinl
Date: 2008-12-17 16:29:54 -0500 (Wed, 17 Dec 2008)
New Revision: 34925
   grass/branches/develbranch_6/vector/v.out.ascii/description.html
fix typo in manual page
Modified: grass/branches/develbranch_6/vector/v.out.ascii/description.html
--- grass/branches/develbranch_6/vector/v.out.ascii/description.html	2008-12-17 21:29:16 UTC (rev 34924)
+++ grass/branches/develbranch_6/vector/v.out.ascii/description.html	2008-12-17 21:29:54 UTC (rev 34925)
@@ -18,7 +18,7 @@
 maps between GRASS and other software, and for transferring data
 between machines.
-<o>
+<p>
 If the <b>format</b> parameter is set to <b>standard</b>, a GRASS
 ASCII vector map will be exported, which may contain a mix of
 primitives including points, lines, boundaries, centroids, areas,
