[GRASS-SVN] r29933 - in grass/trunk/gui/wxpython: . gui_modules
vdigit
svn_grass at osgeo.org
Sat Feb 2 13:49:03 EST 2008
Author: martinl
Date: 2008-02-02 13:49:03 -0500 (Sat, 02 Feb 2008)
New Revision: 29933
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/digit.py
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/utils.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
grass/trunk/gui/wxpython/vdigit/cats.cpp
grass/trunk/gui/wxpython/vdigit/digit.h
grass/trunk/gui/wxpython/vdigit/driver.cpp
grass/trunk/gui/wxpython/vdigit/line.cpp
grass/trunk/gui/wxpython/vdigit/vertex.cpp
grass/trunk/gui/wxpython/wxgui.py
wxGUI: Various improvements in vdigit and v.edit interface.
Drop also attribute record when deleting vector objects (optional).
Select vector objects by click/box.
Fix moving vector objects, #29.
Various minor improvements.
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-02-02 18:33:34 UTC (rev 29932)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-02-02 18:49:03 UTC (rev 29933)
@@ -2909,7 +2909,7 @@
# use scrolled panel instead (and fix initial max height of the window to 480px)
### panel = wx.Panel(parent=self.notebook, id=wx.ID_ANY)
panel = scrolled.ScrolledPanel(parent=self.notebook, id=wx.ID_ANY,
- size=(-1, 300))
+ size=(-1, 150))
panel.SetupScrolling(scroll_x=False)
self.notebook.AddPage(page=panel, text=_(" %s %d ") % (_("Layer"), layer))
@@ -3001,7 +3001,7 @@
"""Check DB connection"""
layerCommand = gcmd.Command(cmd=["v.db.connect",
"-g", "--q",
- "map=%s" % self.map,],
+ "map=%s" % self.map],
rerr=None, stderr=None)
if layerCommand.returncode != 0:
return False
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py 2008-02-02 18:33:34 UTC (rev 29932)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py 2008-02-02 18:49:03 UTC (rev 29933)
@@ -107,6 +107,9 @@
self.settings["layer"] = 1
self.settings["category"] = 1
self.settings["categoryMode"] = "Next to use"
+ # delete existing feature(s)
+ self.settings["delRecord"] = True
# query tool
self.settings["query"] = ("length", True) # name, select by box
@@ -292,7 +295,7 @@
@param input feature definition in GRASS ASCII format
@param flags additional flags
- if self.settings['snapping'][0] <= 0:
+ if self.settings['snapping'][0] <= 0.0:
snap = "no"
else:
if self.settings['snapToVertex']:
@@ -315,7 +318,7 @@
# run the command
Debug.msg(4, "VEdit.AddFeature(): input=%s" % input)
- vedit = gcmd.Command(cmd=command, stdin=input)
+ vedit = gcmd.Command(cmd=command, stdin=input, stderr=None)
# reload map (needed for v.edit)
self.driver.ReloadMap()
@@ -332,13 +335,49 @@
Debug.msg(4, "Digit.DeleteSelectedLines(): ids=%s" % \
ids)
+ # delete also attributes if requested
+ if self.settings['delRecord'] is True:
+ layerCommand = gcmd.Command(cmd=["v.db.connect",
+ "-g", "--q",
+ rerr=None, stderr=None)
+ if layerCommand.returncode == 0:
+ layers = {}
+ for line in layerCommand.ReadStdOutput():
+ lineList = line.split(' ')
+ layers[int(lineList[0])] = { "table" : lineList[1],
+ "key" : lineList[2],
+ "database" : lineList[3],
+ "driver" : lineList[4] }
+ for layer in layers.keys():
+ printCats = gcmd.Command(['v.category',
+ '--q',
+ 'input=%s' % self.map,
+ 'layer=%d' % layer,
+ 'option=print',
+ 'id=%s' % ids])
+ sql = 'DELETE FROM %s WHERE' % layers[layer]['table']
+ n_cats = 0
+ for cat in printCats.ReadStdOutput():
+ for c in cat.split('/'):
+ sql += ' cat = %d or' % int(c)
+ n_cats += 1
+ sql = sql.rstrip(' or')
+ if n_cats > 0:
+ gcmd.Command(['db.execute',
+ '--q',
+ 'driver=%s' % layers[layer]['driver'],
+ 'database=%s' % layers[layer]['database']],
+ stdin=sql,
command = [ "v.edit",
"tool=delete",
"ids=%s" % ids]
# run the command
- vedit = gcmd.Command(cmd=command)
+ vedit = gcmd.Command(cmd=command, stderr=None)
@@ -401,7 +440,7 @@
command.append("-1") # modify only first selected
# run the command
@@ -441,7 +480,7 @@
"thresh=%f" % self.driver.GetThreshold()]
# run the command
@@ -466,7 +505,7 @@
# run the command
# redraw map
@@ -484,7 +523,7 @@
'--q',
'map=%s' % self.map,
'tool=delete',
- 'ids=%s' % line])
+ 'ids=%s' % line], stderr=None)
# add line
if len(coords) > 0:
@@ -767,7 +806,7 @@
@return number of deleted lines
- nlines = self.digit.DeleteLines()
+ nlines = self.digit.DeleteLines(self.settings['delRecord'])
return nlines
@@ -909,7 +948,11 @@
",".join(["%d" % v for v in ids]))
return ids
+ def GetLineCats(self):
+ """Get layer/category pairs from given (selected) line"""
+ return self.digit.GetLineCats()
def __getSnapThreshold(self):
"""Get snap mode and threshold value
@@ -932,11 +975,13 @@
"""Default digit class"""
def __init__(self, mapwindow):
VEdit.__init__(self, mapwindow)
+ self.type = 'vedit'
else:
class Digit(VDigit):
VDigit.__init__(self, mapwindow)
+ self.type = 'vdigit'
class AbstractDisplayDriver:
"""Abstract classs for display driver"""
@@ -1390,7 +1435,7 @@
sizer.Add(item=flexSizer1, proportion=1, flag=wx.TOP | wx.LEFT | wx.EXPAND, border=1)
sizer.Add(item=flexSizer2, proportion=1, flag=wx.TOP | wx.LEFT | wx.EXPAND, border=1)
sizer.Add(item=vertexSizer, proportion=1, flag=wx.BOTTOM | wx.LEFT | wx.EXPAND, border=1)
- border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
+ border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
# attributes
@@ -1436,11 +1481,21 @@
sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=1)
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Delete existing feature(s)"))
+ sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ # checkbox
+ self.deleteRecord = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+ label=_("Delete record from table"))
+ self.deleteRecord.SetValue(self.parent.digit.settings["delRecord"])
+ sizer.Add(item=self.deleteRecord, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
# bindings
self.Bind(wx.EVT_CHECKBOX, self.OnChangeAddRecord, self.addRecord)
self.Bind(wx.EVT_COMBOBOX, self.OnChangeCategoryMode, self.categoryMode)
panel.SetSizer(border)
return panel
@@ -1660,6 +1715,9 @@
self.parent.digit.settings["category"] = int(self.category.GetValue())
self.parent.digit.settings["categoryMode"] = self.categoryMode.GetValue()
+ self.parent.digit.settings["delRecord"] = self.deleteRecord.IsChecked()
# threshold
try:
self.parent.digit.threshold = self.parent.digit.driver.GetThreshold()
@@ -1686,9 +1744,17 @@
class DigitCategoryDialog(wx.Dialog, listmix.ColumnSorterMixin):
Dialog used to display/modify categories of vector objects
+ @param parent
+ @param title dialog title
+ @param query {coordinates, qdist} - v.edit/v.what
+ @param cats directory of categories - vdigit
+ @param line line id - vdigit
+ @param pos
+ @param style
def __init__(self, parent, title,
- map, queryCoords, qdist,
+ map, query=None, cats=None, line=None,
pos=wx.DefaultPosition,
style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
@@ -1705,9 +1771,13 @@
self.cats = {}
# do not display dialog if no line is found (-> self.cats)
- if self.__GetCategories(queryCoords, qdist) == 0 or not self.line:
- Debug.msg(3, "DigitCategoryDialog(): nothing found!")
- return
+ if cats is None:
+ if self.__GetCategories(query[0], query[1]) == 0 or not self.line:
+ Debug.msg(3, "DigitCategoryDialog(): nothing found!")
+ return
+ else:
+ self.cats = cats
+ self.line = line
# make copy of cats (used for 'reload')
self.cats_orig = copy.deepcopy(self.cats)
@@ -2038,9 +2108,11 @@
"""Get id of selected line of 'None' if no line is selected"""
return self.line
- def UpdateDialog(self, queryCoords, qdist):
+ def UpdateDialog(self, query=None, cats=None, line=None):
"""Update dialog
+ @param query {coordinates, distance} - v.edit/v.what
+ @param cats directory layer/cats - vdigit
Return True if updated otherwise False
@@ -2051,7 +2123,13 @@
self.cats = {}
+ if cats is None:
+ ret = self.__GetCategories(query[0], query[1])
+ else:
+ self.cats = cats
+ ret = 1
+ self.line = line
+ if ret == 0 or not self.line:
return False
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2008-02-02 18:33:34 UTC (rev 29932)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2008-02-02 18:49:03 UTC (rev 29933)
@@ -115,7 +115,7 @@
self.SetAutoLayout(True)
self.SetSizer(tmpsizer)
- tmpsizer.Fit(self)
+ # tmpsizer.Fit(self)
self.Layout()
class DatabasePage(TitledPage):
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-02-02 18:33:34 UTC (rev 29932)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-02-02 18:49:03 UTC (rev 29933)
@@ -951,9 +951,12 @@
elif digitToolbar.action in ["moveLine", "moveVertex", "editLine"] and \
not hasattr(self, "moveBegin"):
- self.moveBegin = [0, 0]
- self.moveCoords = self.Pixel2Cell(self.mouse['begin'])
- self.moveIds = []
+ # incremental value
+ self.moveBegin = [0, 0]
+ # geographic coordinates of initial position (self.mouse['end'])
+ self.moveCoords = []
+ # list of ids to modify
+ self.moveIds = []
if digitToolbar.action in ["moveVertex", "editLine"]:
# set pen
self.pen = self.polypen = wx.Pen(colour=digitClass.settings["symbolHighlight"][1],
@@ -992,18 +995,32 @@
digitToolbar.attributesDialog.Hide()
else: # displayCats
+ coords = (east, north)
if digitToolbar.categoryDialog is None:
# open new dialog
- digitToolbar.categoryDialog = DigitCategoryDialog(parent=self,
- map=map,
- queryCoords=(east, north),
- qdist=qdist,
- pos=posWindow,
- title=_("Update categories"))
+ if digitClass.type == 'vedit':
+ digitToolbar.categoryDialog = DigitCategoryDialog(parent=self,
+ map=map,
+ query=(coords, qdist),
+ pos=posWindow,
+ title=_("Update categories"))
+ else:
+ if digitClass.driver.SelectLineByPoint(coords) is not None:
+ print '#', digitClass.driver.GetSelected()[0], \
+ digitClass.GetLineCats()
+ map=map,
+ cats=digitClass.GetLineCats(),
+ line=digitClass.driver.GetSelected()[0],
+ pos=posWindow,
else:
# update currently open dialog
- digitToolbar.categoryDialog.UpdateDialog(queryCoords=(east, north),
- qdist=qdist)
+ digitToolbar.categoryDialog.UpdateDialog(query=(coords, qdist))
+ else:
+ digitToolbar.categoryDialog.UpdateDialog(cats=digitClass.GetLineCats())
line = digitToolbar.categoryDialog.GetLine()
redraw = False
@@ -1118,6 +1135,11 @@
pos1 = self.Pixel2Cell(self.mouse['begin'])
pos2 = self.Pixel2Cell(self.mouse['end'])
+ if hasattr(self, "moveBegin"):
+ self.moveCoords = pos2
+ # eliminate initial mouse moving efect
+ self.mouse['begin'] = self.mouse['end']
if digitToolbar.action in ["deleteLine", "moveLine", "moveVertex",
"copyCats", "editLine", "flipLine",
"mergeLine", "snapLine",
@@ -1179,15 +1201,19 @@
digitClass.driver.SetSelected(selected)
else:
- # -> moveLine || deleteLine, etc. (select by box)
- nselected = digitClass.driver.SelectLinesByBox(pos1, pos2)
+ # -> moveLine || deleteLine, etc. (select by point/box)
+ if digitClass.driver.SelectLineByPoint(pos1) is not None:
+ nselected = 1
+ else:
+ nselected = digitClass.driver.SelectLinesByBox(pos1, pos2)
if nselected > 0:
if digitToolbar.action in ["moveLine", "moveVertex"]:
# get pseudoDC id of objects which should be redrawn
if digitToolbar.action == "moveLine":
# -> move line
self.moveIds = digitClass.driver.GetSelected(grassId=False)
+ print self.moveIds, nselected
elif digitToolbar.action == "moveVertex":
# -> move vertex
@@ -1201,7 +1227,6 @@
else: # no vector object found
self.UpdateMap(render=False, renderVector=False)
- pass
elif digitToolbar.action in ["splitLine", "addVertex", "removeVertex"]:
pointOnLine = digitClass.driver.SelectLineByPoint(pos1,
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py 2008-02-02 18:33:34 UTC (rev 29932)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py 2008-02-02 18:49:03 UTC (rev 29933)
@@ -57,6 +57,8 @@
for item in dcmd:
if 'map=' in item:
mapname = item.split('=')[1]
+ elif 'input=' in item:
+ mapname = item.split('=')[1]
elif 'red=' in item:
elif 'h_map=' in item:
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-02-02 18:33:34 UTC (rev 29932)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-02-02 18:49:03 UTC (rev 29933)
@@ -1291,7 +1291,7 @@
if len(line) == 0:
continue
- if 'GRASS_INFO_PERCENT:' in line:
+ if 'GRASS_INFO_PERCENT' in line:
# 'GRASS_INFO_PERCENT: 10' -> value=10
value = int(line.split(':')[1].strip())
if value < 100:
Modified: grass/trunk/gui/wxpython/vdigit/cats.cpp
--- grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-02-02 18:33:34 UTC (rev 29932)
+++ grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-02-02 18:49:03 UTC (rev 29933)
@@ -121,3 +121,52 @@
return 0;
+ \brief Get list of layer/category(ies) for selected line.
+ \return list of layer/cats
+std::map<int, std::vector<int> > Digit::GetLineCats()
+ std::map<int, std::vector<int> > lc;
+ int line, n_dblinks;
+ struct line_cats *Cats;
+ struct field_info *fi;
+ if (!display->mapInfo || display->selected->n_values < 1) {
+ return lc;
+ line = display->selected->value[0];
+ if (!Vect_line_alive(display->mapInfo, line)) {
+ return lc;
+ Cats = Vect_new_cats_struct();
+ if (Vect_read_line(display->mapInfo, NULL, Cats, line) < 0) {
+ Vect_destroy_cats_struct(Cats);
+ return lc;
+ n_dblinks = Vect_get_num_dblinks(display->mapInfo);
+ for (int dblink = 0; dblink < n_dblinks; dblink++) {
+ fi = Vect_get_dblink(display->mapInfo, dblink);
+ if (fi == NULL) {
+ continue;
+ std::vector<int> cats;
+ lc[fi->number] = cats;
+ for (int i = 0; i < Cats->n_cats; i++) {
+ lc[Cats->field[i]].push_back(Cats->cat[i]);
+ return lc;
Modified: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h 2008-02-02 18:33:34 UTC (rev 29932)
+++ grass/trunk/gui/wxpython/vdigit/digit.h 2008-02-02 18:49:03 UTC (rev 29933)
@@ -1,6 +1,10 @@
#ifndef __DIGIT_H__
#define __DIGIT_H__
+#define GSQL_MAX 4000
+#include <map>
class Digit
private:
@@ -25,7 +29,7 @@
int SplitLine(double, double, double,
double);
- int DeleteLines();
+ int DeleteLines(bool);
int MoveLines(double, double, double,
int, double);
int FlipLines();
@@ -48,8 +52,8 @@
int, int, double);
int CopyCats(std::vector<std::vector<int> >, std::vector<int>);
int GetCategory(int);
+ std::map<int, std::vector<int> > GetLineCats();
Modified: grass/trunk/gui/wxpython/vdigit/driver.cpp
--- grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-02-02 18:33:34 UTC (rev 29932)
+++ grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-02-02 18:49:03 UTC (rev 29933)
@@ -738,6 +738,8 @@
struct ilist *list;
struct line_pnts *bbox;
+ drawSegments = false;
type = -1; // all types
list = Vect_new_list();
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp 2008-02-02 18:33:34 UTC (rev 29932)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2008-02-02 18:49:03 UTC (rev 29933)
@@ -16,6 +16,7 @@
extern "C" {
#include <grass/vedit.h>
+#include <grass/dbmi.h>
#include "driver.h"
#include "digit.h"
@@ -244,19 +245,98 @@
\brief Delete selected vector features
+ \param delete_records delete also attribute records
\return number of deleted lines
\return -1 on error
-int Digit::DeleteLines()
+int Digit::DeleteLines(bool delete_records)
int ret;
+ int n_dblinks;
+ struct line_cats *Cats, *Cats_del;
if (!display->mapInfo) {
return -1;
+ Cats_del = NULL;
+ /* collect categories if needed */
+ if (delete_records) {
+ Cats_del = Vect_new_cats_struct();
+ for (int i = 0; i < display->selected->n_values; i++) {
+ if (Vect_read_line(display->mapInfo, NULL, Cats, display->selected->value[i]) < 0) {
+ Vect_destroy_cats_struct(Cats_del);
+ return -1;
+ for (int j = 0; j < Cats->n_cats; j++) {
+ Vect_cat_set(Cats_del, Cats->field[j], Cats->cat[j]);
ret = Vedit_delete_lines(display->mapInfo, display->selected);
+ if (ret > 0 && delete_records) {
+ char buf[GSQL_MAX];
+ dbDriver *driver;
+ dbHandle handle;
+ dbString stmt;
+ if (fi == NULL) {
+ return -1;
+ driver = db_start_driver(fi->driver);
+ if (driver == NULL) {
+ return -1;
+ db_init_handle (&handle);
+ db_set_handle (&handle, fi->database, NULL);
+ if (db_open_database(driver, &handle) != DB_OK) {
+ return -1;
+ db_init_string (&stmt);
+ sprintf (buf, "DELETE FROM %s WHERE", fi->table);
+ db_set_string(&stmt, buf);
+ int n_cats = 0;
+ for (int c = 0; c < Cats_del->n_cats; c++) {
+ if (Cats_del->field[c] == fi->number) {
+ sprintf (buf, " %s = %d", fi->key, Cats_del->cat[c]);
+ db_append_string(&stmt, buf);
+ if (n_cats > 0) {
+ sprintf (buf, " or");
+ n_cats++;
+ Vect_cat_del(Cats_del, fi->number);
+ if (n_cats &&
+ db_execute_immediate (driver, &stmt) != DB_OK ) {
+ return -1;
+ db_close_database(driver);
+ db_shutdown_driver(driver);
+ if (Cats_del) {
return ret;
Modified: grass/trunk/gui/wxpython/vdigit/vertex.cpp
--- grass/trunk/gui/wxpython/vdigit/vertex.cpp 2008-02-02 18:33:34 UTC (rev 29932)
+++ grass/trunk/gui/wxpython/vdigit/vertex.cpp 2008-02-02 18:49:03 UTC (rev 29933)
@@ -50,7 +50,7 @@
display->selected,
point, thresh,
move_x, move_y, move_z,
- 1, (snap == SNAPVERTEX) ? 1 : 0);
+ 1, snap);
Vect_destroy_line_struct(point);
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-02-02 18:33:34 UTC (rev 29932)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-02-02 18:49:03 UTC (rev 29933)
@@ -398,7 +398,6 @@
def GetMenuCmd(self, event):
"""Get GRASS command from menu item
Return command as a list"""
cmd = self.menucmd[event.GetId()]
try:
@@ -406,6 +405,13 @@
except: # already list?
cmdlist = cmd
+ layer = self.curr_page.maptree.layer_selected
+ name = self.curr_page.maptree.GetPyData(layer)[0]['maplayer'].name
+ type = self.curr_page.maptree.GetPyData(layer)[0]['type']
+ if type == 'raster' and cmdlist[0][0] == 'r' and cmdlist[0][1] != '3':
+ cmdlist.append(name) # TODO map/input=
+ elif type == 'vector' and cmdlist[0][0] == 'v':
return cmdlist
def RunMenuCmd(self, event):
