[GRASS-SVN] r29934 - in grass/trunk/gui/wxpython: gui_modules vdigit
Sat Feb 2 16:21:26 EST 2008
Author: martinl
Date: 2008-02-02 16:21:26 -0500 (Sat, 02 Feb 2008)
New Revision: 29934
   grass/trunk/gui/wxpython/gui_modules/digit.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/vdigit/dig_types.i
   grass/trunk/gui/wxpython/vdigit/driver.cpp
   grass/trunk/gui/wxpython/vdigit/driver.h
wx/vdigit: Fix selecting features by point/box.
Selecting features can be filter out by type (point, line, centroid, boundary), see settings dialog (query tool tab).
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py	2008-02-02 18:49:03 UTC (rev 29933)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py	2008-02-02 21:21:26 UTC (rev 29934)
@@ -59,6 +59,8 @@
 USEVEDIT = True
+GV_LINES = vdigit.GV_LINES
 class AbstractDigit:
     Abstract digitization class
@@ -115,6 +117,12 @@
             self.settings["query"]       = ("length", True)   # name, select by box
             self.settings["queryLength"] = ("shorter than", 0) # gt or lt, threshold
             self.settings["queryDangle"] = ("shorter than", 0)
+            # select feature (point, line, centroid, boundary)
+            self.settings["selectFeature"] = {}
+            self.settings["selectFeature"]["point"] = {'id': None, 'val': True}
+            self.settings["selectFeature"]["line"] = {'id': None, 'val': True}
+            self.settings["selectFeature"]["centroid"] = {'id': None, 'val': True}
+            self.settings["selectFeature"]["boundary"] = {'id': None, 'val': True}
         else:
             self.settings = settings
@@ -199,6 +207,21 @@
         return thresh
+    def GetSelectType(self):
+        """Get type(s) to be selected
+        Used by SelectLinesByBox() and SelectLinesByPoint()"""
+        type = 0
+        for feature in (('point', vdigit.GV_POINT),
+                        ('line', vdigit.GV_LINE),
+                        ('centroid', vdigit.GV_CENTROID),
+                        ('boundary', vdigit.GV_BOUNDARY)):
+            if self.settings['selectFeature'][feature[0]]['val'] is True:
+                type |= feature[1]
+        return type
 class VEdit(AbstractDigit):
     Prototype of digitization class based on v.edit command
@@ -1107,7 +1130,7 @@
         return nlines
-    def SelectLinesByBox(self, begin, end, type=None):
+    def SelectLinesByBox(self, begin, end, type=0):
         """Select vector features by given bounding box.
         If type is given, only vector features of given type are selected.
@@ -1118,13 +1141,15 @@
         x1, y1 = begin
         x2, y2 = end
-        nselected = self.__display.SelectLinesByBox(x1, y1, x2, y2)
+        nselected = self.__display.SelectLinesByBox(x1, y1, -1.0 * vdigit.PORT_DOUBLE_MAX,
+                                                    x2, y2, vdigit.PORT_DOUBLE_MAX,
+                                                    type)
         Debug.msg(4, "CDisplayDriver.SelectLinesByBox(): selected=%d" % \
                       nselected)
         return nselected
-    def SelectLineByPoint(self, point, type=None):
+    def SelectLineByPoint(self, point, type=0):
         """Select vector feature by coordinates of click point (in given threshold).
@@ -1132,16 +1157,9 @@
         @param point click coordinates (bounding box given by threshold)
         @param type  select only objects of given type
-        ftype = -1 # all types
-        if type:
-            if type == "point":
-                ftype = 0
-            else:
-                ftype = 1 # line
-        pointOnLine = self.__display.SelectLineByPoint(point[0], point[1],
+        pointOnLine = self.__display.SelectLineByPoint(point[0], point[1], 0.0,
                                                        self.GetThreshold(),
-                                                       ftype);
+                                                       type, 0); # without_z
         if len(pointOnLine) > 0:
             Debug.msg(4, "CDisplayDriver.SelectLineByPoint(): pointOnLine=%f,%f" % \
@@ -1509,7 +1527,10 @@
         notebook.AddPage(page=panel, text=_("Query tool"))
         border = wx.BoxSizer(wx.VERTICAL)
+        # query tool box
         box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Choose query tool"))
         sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
@@ -1577,6 +1598,21 @@
         border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
+        # select box
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Select vector features"))
+        sizer = wx.StaticBoxSizer(box, wx.HORIZONTAL)
+        for feature in ('point', 'line',
+                        'centroid', 'boundary'):
+            chkbox = wx.CheckBox(parent=panel, label=feature)
+            settings['selectFeature'][feature]['id'] = chkbox.GetId()
+            chkbox.SetValue(settings['selectFeature'][feature]['val'])
+            sizer.Add(item=chkbox, proportion=0,
+                      flag=wx.EXPAND | wx.ALL, border=3)
+        border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
         panel.SetSizer(border)
         return panel
@@ -1734,6 +1770,12 @@
         self.parent.digit.settings["queryDangle"] = (self.queryDangleSL.GetStringSelection(),
                                                      int(self.queryDangleValue.GetValue()))
+        # select features
+            self.parent.digit.settings['selectFeature'][feature]['val'] = \
+                self.FindWindowById(self.parent.digit.settings["selectFeature"][feature]['id']).IsChecked()
         # update driver settings
         self.parent.digit.driver.UpdateSettings()
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-02-02 18:49:03 UTC (rev 29933)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-02-02 21:21:26 UTC (rev 29934)
@@ -67,6 +67,7 @@
 from digit import Digit               as Digit
 from digit import DigitCategoryDialog as DigitCategoryDialog
 from digit import DigitZBulkDialog    as DigitZBulkDialog
+from digit import GV_LINES            as Digit_Lines_Type
 from debug import Debug               as Debug
 from icon  import Icons               as Icons
@@ -1005,9 +1006,8 @@
        pos=posWindow,
        title=_("Update categories"))
                         else:
-                            if digitClass.driver.SelectLineByPoint(coords) is not None:
-                                print '#', digitClass.driver.GetSelected()[0], \
-                                    digitClass.GetLineCats()
+                            if digitClass.driver.SelectLineByPoint(coords,
+        digitClass.GetSelectType()) is not None:
                                 digitToolbar.categoryDialog = DigitCategoryDialog(parent=self,
        map=map,
        cats=digitClass.GetLineCats(),
@@ -1064,7 +1064,8 @@
                 if len(digitClass.driver.GetSelected()) > 1:
                     # if two line selected -> reset
                     digitClass.driver.SetSelected([])
-                digitClass.driver.SelectLineByPoint(self.Pixel2Cell(self.mouse['begin']))
+                digitClass.driver.SelectLineByPoint(self.Pixel2Cell(self.mouse['begin']),
         else:
             # get decoration id
@@ -1123,7 +1124,6 @@
                 pass
         elif self.mouse["use"] == "pointer" and self.gismanager.georectifying:
             self.SetCursor(self.parent.cursors["cross"])
-            print self.Pixel2Cell(self.mouse['end'])
             self.DrawCross(pdc=self.pdcTmp, coords=self.mouse['end'],
                                        size=5)
@@ -1148,7 +1148,7 @@
                 # -> delete line || move line || move vertex
                 if digitToolbar.action in ["moveVertex", "editLine"]:
                     if len(digitClass.driver.GetSelected()) == 0:
-                        nselected = digitClass.driver.SelectLineByPoint(pos1, type="line")
+                        nselected = digitClass.driver.SelectLineByPoint(pos1, type=Digit_Lines_Type)
                         if digitToolbar.action == "editLine":
                             self.UpdateMap(render=False)
                             selVertex = digitClass.driver.GetSelectedVertex(pos1)[0]
@@ -1171,7 +1171,7 @@
                 elif digitToolbar.action == "copyCats":
                     if not hasattr(self, "copyCatsIds"):
                         # collect categories
                         if nselected:
                             qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) / \
                                                 self.Map.width)
@@ -1190,7 +1190,8 @@
                         # collect ids
                         # return number of selected features
-                        nselected = digitClass.driver.SelectLinesByBox(pos1, pos2)
+                        nselected = digitClass.driver.SelectLinesByBox(pos1, pos2,
                         if nselected > 0:
                             self.copyCatsIds = digitClass.driver.GetSelected()
@@ -1202,18 +1203,19 @@
                 else:
                     # -> moveLine || deleteLine, etc. (select by point/box)
-                    if digitClass.driver.SelectLineByPoint(pos1) is not None:
-                        nselected = 1
-                    else:
+                    if nselected == 0:
+                        if digitClass.driver.SelectLineByPoint(pos1,
+                            nselected = 1
                 if nselected > 0:
                     if digitToolbar.action in ["moveLine", "moveVertex"]:
                         # get pseudoDC id of objects which should be redrawn
                         if digitToolbar.action == "moveLine":
                             # -> move line
                             self.moveIds = digitClass.driver.GetSelected(grassId=False)
-                            print self.moveIds, nselected
                         elif digitToolbar.action == "moveVertex":
                             # -> move vertex
@@ -1230,7 +1232,7 @@
             elif digitToolbar.action in ["splitLine", "addVertex", "removeVertex"]:
                 pointOnLine = digitClass.driver.SelectLineByPoint(pos1,
-        type="line")
+        type=Digit_Lines_Type)
                 if pointOnLine:
                     self.UpdateMap(render=False) # highlight object
                     if digitToolbar.action in ["splitLine", "addVertex"]:
@@ -1247,7 +1249,8 @@
             elif digitToolbar.action == "copyLine":
                 if digitClass.settings['backgroundMap'] == '':
                     # no background map -> copy from current vector map layer
                     if nselected > 0:
                         # highlight selected features
@@ -1281,7 +1284,8 @@
                 # select lines to be labeled
                 pos1 = self.polycoords[0]
                 pos2 = self.polycoords[1]
                 if nselected > 0:
Modified: grass/trunk/gui/wxpython/vdigit/dig_types.i
--- grass/trunk/gui/wxpython/vdigit/dig_types.i	2008-02-02 18:49:03 UTC (rev 29933)
+++ grass/trunk/gui/wxpython/vdigit/dig_types.i	2008-02-02 21:21:26 UTC (rev 29934)
@@ -12,6 +12,8 @@
 #define GV_POINTS (GV_POINT | GV_CENTROID )
 #define GV_LINES (GV_LINE | GV_BOUNDARY )
+#define PORT_DOUBLE_MAX 1.7976931348623157e+308
 /* extracted from vector/v.edit/lib/vedit.h */
 #define NO_SNAP    0 /* snapping disabled */
Modified: grass/trunk/gui/wxpython/vdigit/driver.cpp
--- grass/trunk/gui/wxpython/vdigit/driver.cpp	2008-02-02 18:49:03 UTC (rev 29933)
+++ grass/trunk/gui/wxpython/vdigit/driver.cpp	2008-02-02 21:21:26 UTC (rev 29934)
@@ -722,42 +722,40 @@
    If line id is already in the list of selected lines, then it will
    be excluded from this list.
-   \param[in] x1,y1,x2,y2 corners coordinates of bounding box
+   \param[in] x1,y1,z1,x2,y2,z3 bounding box definition
+   \param[in] type feature type
    \return number of selected features
    \return -1 on error
-int DisplayDriver::SelectLinesByBox(double x1, double y1, double x2, double y2)
+int DisplayDriver::SelectLinesByBox(double x1, double y1, double z1,
+				    double x2, double y2, double z2,
+				    int type)
     if (!mapInfo)
 	return -1;
-    int type, line;
-    double dx, dy;
+    int line;
     struct ilist *list;
     struct line_pnts *bbox;
     drawSegments = false;
-    type = -1; // all types
     list = Vect_new_list();
     bbox = Vect_new_line_struct();
-    dx = std::fabs(x2 - x1);
-    dy = std::fabs(y2 - y1);
+    Vect_append_point(bbox, x1, y1, z1);
+    Vect_append_point(bbox, x2, y1, z2);
+    Vect_append_point(bbox, x2, y2, z1);
+    Vect_append_point(bbox, x1, y2, z2);
-    Vect_append_point(bbox, x1, y1, -PORT_DOUBLE_MAX);
-    Vect_append_point(bbox, x2, y1,  PORT_DOUBLE_MAX);
-    Vect_append_point(bbox, x2, y2, -PORT_DOUBLE_MAX);
-    Vect_append_point(bbox, x1, y2,  PORT_DOUBLE_MAX);
     Vect_select_lines_by_polygon(mapInfo, bbox,
-				 0, NULL,
+				 0, NULL, /* isles */
 				 type, list);
     for (int i = 0; i < list->n_values; i++) {
 	line = list->value[i];
 	if (!IsSelected(line)) {
@@ -778,7 +776,8 @@
     Vect_destroy_list(list);
     // return selected.size();
-    return selected->n_values;
+    // return selected->n_values;
+    return list->n_values;
@@ -790,12 +789,12 @@
    \param[in] x,y point of searching
    \param[in] thresh threshold value where to search
-   \param[in] onlyType select vector object of given type
+   \param[in] type select vector object of given type
    \return point on line if line found
-std::vector<double> DisplayDriver::SelectLineByPoint(double x, double y, double thresh,
-						     int type)
+std::vector<double> DisplayDriver::SelectLineByPoint(double x, double y, double z,
+						     double thresh, int type, int with_z)
     long int line;
     int ftype;
@@ -803,28 +802,28 @@
     std::vector<double> p;
-    if (type == -1) {
-	ftype = GV_POINTS | GV_LINES;
-    else if (type == 0) {
-	ftype = GV_POINTS;
-    else if (type == 1) {
-	ftype = GV_LINES;
+    line = Vect_find_line(mapInfo, x, y, z,
+			  type, thresh, with_z, 0);
-    line = Vect_find_line(mapInfo, x, y, 0.0,
-			  ftype, thresh, 0, 0);
     if (line > 0) {
-	// selected.push_back(line);
-	Vect_list_append(selected, line);
+	if (!IsSelected(line)) {
+	    // selected.push_back(line);
+	    Vect_list_append(selected, line);
+	else {
+	    // selected.erase(GetSelectedIter(line));
+	    Vect_list_delete(selected, line);
 	type = Vect_read_line (mapInfo, points, cats, line);
-	Vect_line_distance (points, x, y, 0.0, WITHOUT_Z,
+	Vect_line_distance (points, x, y, z, with_z,
 			    &px, &py, &pz,
 			    NULL, NULL, NULL);
 	p.push_back(px);
 	p.push_back(py);
+	if (with_z) {
+	    p.push_back(pz);
     drawSegments = true;
Modified: grass/trunk/gui/wxpython/vdigit/driver.h
--- grass/trunk/gui/wxpython/vdigit/driver.h	2008-02-02 18:49:03 UTC (rev 29933)
+++ grass/trunk/gui/wxpython/vdigit/driver.h	2008-02-02 21:21:26 UTC (rev 29934)
@@ -158,9 +158,9 @@
     int DrawMap(bool);
     /* select */
-    int SelectLinesByBox(double, double, double, double);
+    int SelectLinesByBox(double, double, double, double, double, double, int);
     std::vector<double> SelectLineByPoint(double, double, double,
-					  int);
+					  double, int, int);
     std::vector<int> GetSelected(bool);
     int SetSelected(std::vector<int>);
