[GRASS-SVN] r29939 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sun Feb 3 15:22:15 EST 2008
Author: martinl
Date: 2008-02-03 15:22:15 -0500 (Sun, 03 Feb 2008)
New Revision: 29939
grass/trunk/lib/vector/Vlib/break_lines.c
Simplify calling Vect_break_lines_list().
I18n support added.
Modified: grass/trunk/lib/vector/Vlib/break_lines.c
--- grass/trunk/lib/vector/Vlib/break_lines.c 2008-02-03 10:13:34 UTC (rev 29938)
+++ grass/trunk/lib/vector/Vlib/break_lines.c 2008-02-03 20:22:15 UTC (rev 29939)
@@ -3,71 +3,61 @@
* \brief Vector library - Clean vector map (break lines)
- * \author Radim Blazek
+ * (C) 2001-2008 by the GRASS Development Team
- * (C) 2001 by the GRASS Development Team
* This program is free software under the
* GNU General Public License (>=v2).
* Read the file COPYING that comes with GRASS
* for details.
+ * \author Radim Blazek
+ * \date 2001
#include <stdlib.h>
#include <grass/gis.h>
#include <grass/Vect.h>
+#include <grass/glocale.h>
- \brief Break lines in vector map at each intersection.
+ \brief Break lines in vector map at each intersection.
- For details see Vect_break_lines_list().
+ For details see Vect_break_lines_list().
- \param[in] Map input vector map where lines will be broken
- \param[in] type type of line to be broken
- \param[out] Err vector map where points at intersections will be written or NULL
- \param[out] msgout file pointer where messages will be written or NULL
+ \param Map input vector map
+ \param type feature type
+ \param[out] Err vector map where points at intersections will be written or NULL
+ \param[out] msgout file pointer where messages will be written or NULL
- \return
+ \return
void
Vect_break_lines ( struct Map_info *Map, int type, struct Map_info *Err, FILE *msgout )
- int line, nlines;
- struct ilist *List;
- List = Vect_new_list();
+ Vect_break_lines_list (Map, NULL, type, Err, msgout);
- nlines = Vect_get_num_lines(Map);
- for (line = 1; line <= nlines; line++) {
- Vect_list_append (List, line);
- Vect_break_lines_list (Map, List, type, Err, msgout);
- Vect_destroy_list(List);
return;
- \brief Break selected lines in vector map at each intersection.
+ \brief Break selected lines in vector map at each intersection.
+ Breaks selected lines specified by type in vector map. Points at
+ intersections may be optionaly written to error map. Input vector map
+ must be opened on level 2 for update at least on GV_BUILD_BASE.
- Breaks selected lines specified by type in vector map. Points at
- intersections may be optionaly written to error map. Input vector map
- must be opened on level 2 for update at least on GV_BUILD_BASE.
+ The function also breaks lines forming collapsed loop, for example
+ 0,0;1,0;0,0 is broken at 1,0.
+ \param List_break list of lines to be broken or NULL
- The function also breaks lines forming collapsed loop, for example
- 0,0;1,0;0,0 is broken at 1,0.
- \param[in] List_break list of lines
- \return
+ \return number of intersections
int
@@ -77,7 +67,7 @@
struct line_pnts *APoints, *BPoints, *Points;
struct line_pnts **AXLines, **BXLines;
struct line_cats *ACats, *BCats, *Cats;
- int j, k, l, ret, atype, btype, aline, bline, found, iline;
+ int j, k, l, ret, atype, btype, aline, bline, found, iline, nlines;
int naxlines, nbxlines, nx;
double *xx=NULL, *yx=NULL, *zx=NULL;
BOUND_BOX ABox, BBox;
@@ -100,7 +90,14 @@
is3d = Vect_is_3d ( Map );
- G_debug (3, "nlines = %d", List_break->n_values );
+ if (List_break) {
+ nlines = List_break->n_values;
+ else {
+ nlines = Vect_get_num_lines(Map);
+ G_debug (3, "nlines = %d", nlines );
/* To find intersection of two lines (Vect_line_intersection) is quite slow.
* Fortunately usual lines/boundaries in GIS often forms a network where lines
* are connected by end points, and touch by MBR. This function checks and occasionaly
@@ -116,10 +113,15 @@
printed = 0;
if (msgout)
- fprintf (msgout, "Intersections: %5d", nbreaks );
+ fprintf (msgout, _("%s %5d"), _("Intersections:"), nbreaks );
- for ( iline = 0; iline < List_break->n_values; iline++ ){
- aline = List_break->value[iline];
+ for ( iline = 0; iline < nlines; iline++ ) {
+ if (List_break) {
+ aline = List_break->value[iline];
+ else {
+ aline = iline + 1;
G_debug (3, "aline = %d", aline);
if ( !Vect_line_alive ( Map, aline ) )
continue;
@@ -155,6 +157,9 @@
for ( j = 0; j < List->n_values; j++ ){
bline = List->value[j];
+ if (List_break && !Vect_val_in_list(List_break, bline)) {
+ continue;
G_debug (3, " j = %d bline = %d", j, bline);
/* Check if thouch by end node only */
@@ -238,7 +243,9 @@
if ( (atype & GV_POINTS) || AXLines[k]->n_points > 1 ) {
ret = Vect_write_line ( Map, atype, AXLines[k], ACats );
G_debug (3, "Line %d written, npoints = %d", ret, AXLines[k]->n_points);
- Vect_list_append(List_break, ret);
+ if (List_break) {
+ Vect_list_append(List_break, ret);
/* Write intersection points */
@@ -266,7 +273,9 @@
if ( (btype & GV_POINTS) || BXLines[k]->n_points > 1 ) {
ret = Vect_write_line ( Map, btype, BXLines[k], BCats );
G_debug (5, "Line %d written", ret);
+ if (List_break) {
@@ -311,17 +320,25 @@
if (msgout && printed > 1000) {
- fprintf (msgout, "\rIntersections: %5d (line %d)", nbreaks, aline );
+ fprintf (msgout, "\r%s %5d (line %d)", _("Intersections:"), nbreaks, aline );
fflush ( msgout );
printed = 0;
printed++;
if ( naxlines > 0 ) break; /* first line was broken and deleted -> take the next one */
- G_debug (3, "nlines = %d\n", List_break->n_values);
+ if (List_break) {
+ else {
+ G_debug (3, "nlines = %d", nlines);
+ } /* for each line */
if (msgout)
- fprintf (msgout, "\rIntersections: %5d \n", nbreaks );
+ fprintf (msgout, "\r%s %5d \n", _("Intersections:"), nbreaks );
Vect_destroy_list ( List );
