[GRASS-SVN] r29940 - in grass/trunk/gui/wxpython: gui_modules vdigit
svn_grass at osgeo.org
Sun Feb 3 17:23:27 EST 2008
Author: martinl
Date: 2008-02-03 17:23:27 -0500 (Sun, 03 Feb 2008)
New Revision: 29940
grass/trunk/gui/wxpython/gui_modules/digit.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
grass/trunk/gui/wxpython/vdigit/cats.cpp
grass/trunk/gui/wxpython/vdigit/digit.h
grass/trunk/gui/wxpython/vdigit/driver.cpp
grass/trunk/gui/wxpython/vdigit/line.cpp
wxGUI/vdigit: Various improvements/fixes in vdigit/vedit interface.
Settings dialog improved.
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py 2008-02-03 20:22:15 UTC (rev 29939)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py 2008-02-03 22:23:27 UTC (rev 29940)
@@ -141,14 +141,15 @@
if USEVEDIT:
categoryCmd = gcmd.Command(cmd=["v.category", "-g", "--q",
"input=%s" % self.map,
- "option=report",
- "layer=%d" % self.settings["layer"]])
+ "option=report"])
if categoryCmd.returncode != 0:
return False
for line in categoryCmd.ReadStdOutput():
if "all" in line:
+ if self.settings['layer'] != int(line.split(' ')[0]):
+ continue
try:
maxCat = int(line.split(' ')[-1]) + 1
self.settings['category'] = maxCat
@@ -161,12 +162,9 @@
def SetCategory(self):
"""Return category number to use (according Settings)"""
if self.settings["categoryMode"] == "No category":
- self.settings["category"] = "None"
+ self.settings["category"] = 1
elif self.settings["categoryMode"] == "Next to use":
self.SetCategoryNextToUse()
- else:
- if self.settings["category"] == "None":
- self.SetCategoryNextToUse()
return self.settings["category"]
@@ -746,6 +744,21 @@
return ids
+ def GetLayers(self):
+ """Return list of layers"""
+ layerCommand = gcmd.Command(cmd=["v.db.connect",
+ "-g", "--q",
+ "map=%s" % self.map],
+ rerr=None, stderr=None)
+ if layerCommand.returncode == 0:
+ layers = []
+ for line in layerCommand.ReadStdOutput():
+ lineList = line.split(' ')
+ layers.append(int(lineList[0]))
+ return layers
+ return [1]
class VDigit(AbstractDigit):
Prototype of digitization class based on v.digit reimplementation
@@ -975,7 +988,11 @@
def GetLineCats(self):
"""Get layer/category pairs from given (selected) line"""
return self.digit.GetLineCats()
+ """Get list of layers"""
+ return self.digit.GetLayers()
def __getSnapThreshold(self):
"""Get snap mode and threshold value
@@ -1393,10 +1410,9 @@
self.lineWidthValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(50, -1),
initial=self.parent.digit.settings["lineWidth"][0],
min=1, max=1e6)
- self.lineWidthUnit = wx.ComboBox(parent=panel, id=wx.ID_ANY, size=(125, -1),
- style=wx.CB_SIMPLE | wx.CB_READONLY,
- choices=["screen pixels", "map units"])
- self.lineWidthUnit.SetValue(self.parent.digit.settings["lineWidth"][1])
+ self.lineWidthUnit = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
+ choices=["screen pixels", "map units"])
+ self.lineWidthUnit.SetStringSelection(self.parent.digit.settings["lineWidth"][1])
flexSizer.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
flexSizer.Add(self.lineWidthValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
flexSizer.Add(self.lineWidthUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
@@ -1419,11 +1435,10 @@
initial=self.parent.digit.settings["snapping"][0],
min=1, max=1e6)
self.snappingValue.Bind(wx.EVT_SPINCTRL, self.OnChangeSnappingValue)
- self.snappingUnit = wx.ComboBox(parent=panel, id=wx.ID_ANY, size=(125, -1),
- self.snappingUnit.SetValue(self.parent.digit.settings["snapping"][1])
- self.snappingUnit.Bind(wx.EVT_COMBOBOX, self.OnChangeSnappingUnits)
+ self.snappingUnit = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
+ self.snappingUnit.SetStringSelection(self.parent.digit.settings["snapping"][1])
+ self.snappingUnit.Bind(wx.EVT_CHOICE, self.OnChangeSnappingUnits)
flexSizer1.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
flexSizer1.Add(self.snappingValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
flexSizer1.Add(self.snappingUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
@@ -1444,7 +1459,7 @@
vertexSizer.Add(item=self.snapVertex, proportion=0, flag=wx.EXPAND)
self.mapUnits = self.parent.MapWindow.Map.ProjInfo()['units']
self.snappingInfo = wx.StaticText(parent=panel, id=wx.ID_ANY,
- label=_("Snapping threshold is currently %.1f %s") % \
+ label=_("Snapping threshold is %.1f %s") % \
(self.parent.digit.driver.GetThreshold(),
self.mapUnits))
vertexSizer.Add(item=self.snappingInfo, proportion=0,
@@ -1471,27 +1486,31 @@
settings = ((_("Layer"), 1), (_("Category"), 1), (_("Mode"), _("Next to use")))
# layer
text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Layer"))
- self.layer = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(125, -1),
- value=str(self.parent.digit.settings["layer"])) # TODO: validator
+ if self.parent.digit.map:
+ layers = map(str, self.parent.digit.GetLayers())
+ else:
+ layers = [str(self.parent.digit.settings["layer"])]
+ self.layer = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
+ choices=layers)
+ self.layer.SetStringSelection(str(self.parent.digit.settings["layer"]))
flexSizer.Add(item=text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
flexSizer.Add(item=self.layer, proportion=0,
flag=wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
# category number
text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Category number"))
- self.category = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(125, -1),
- value=str(self.parent.digit.settings["category"])) # TODO: validator
+ self.category = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(125, -1),
+ initial=self.parent.digit.settings["category"],
+ min=-1e9, max=1e9)
if self.parent.digit.settings["categoryMode"] != "Manual entry":
- self.category.SetEditable(False)
self.category.Enable(False)
flexSizer.Add(item=self.category, proportion=0,
# category mode
text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Category mode"))
- self.categoryMode = wx.ComboBox(parent=panel, id=wx.ID_ANY,
- style=wx.CB_SIMPLE | wx.CB_READONLY, size=(125, -1),
- choices=[_("Next to use"), _("Manual entry"), _("No category")])
- self.categoryMode.SetValue(self.parent.digit.settings["categoryMode"])
+ self.categoryMode = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
+ choices=[_("Next to use"), _("Manual entry"), _("No category")])
+ self.categoryMode.SetStringSelection(self.parent.digit.settings["categoryMode"])
flexSizer.Add(item=self.categoryMode, proportion=0,
@@ -1512,7 +1531,8 @@
# bindings
self.Bind(wx.EVT_CHECKBOX, self.OnChangeAddRecord, self.addRecord)
- self.Bind(wx.EVT_COMBOBOX, self.OnChangeCategoryMode, self.categoryMode)
+ self.Bind(wx.EVT_CHOICE, self.OnChangeCategoryMode, self.categoryMode)
+ self.Bind(wx.EVT_CHOICE, self.OnChangeLayer, self.layer)
panel.SetSizer(border)
@@ -1647,16 +1667,24 @@
self.parent.digit.settings["categoryMode"] = mode
if mode == "Manual entry": # enable
self.category.Enable(True)
- self.category.SetEditable(True)
elif self.category.IsEnabled(): # disable
if mode == "No category" and self.addRecord.IsChecked():
self.addRecord.SetValue(False)
self.parent.digit.SetCategory()
- self.category.SetValue(str(self.parent.digit.settings['category']))
+ self.category.SetValue(self.parent.digit.settings['category'])
+ def OnChangeLayer(self, event):
+ """Layer changed"""
+ layer = int(event.GetString())
+ if layer > 0:
+ self.parent.digit.settings['layer'] = layer
+ self.parent.digit.SetCategory()
+ event.Skip()
def OnChangeAddRecord(self, event):
"""Checkbox 'Add new record' status changed"""
self.category.SetValue(str(self.parent.digit.SetCategory()))
@@ -1664,17 +1692,21 @@
def OnChangeSnappingValue(self, event):
"""Change snapping value - update static text"""
value = self.snappingValue.GetValue()
- threshold = self.parent.digit.driver.GetThreshold(value)
- self.snappingInfo.SetLabel(_("Snapping threshold is currently %.1f %s") % \
- (threshold,
- self.mapUnits))
+ if self.snappingUnit.GetStringSelection() == "map units":
+ threshold = value
+ else:
+ threshold = self.parent.digit.driver.GetThreshold(value)
+ self.snappingInfo.SetLabel(_("Snapping threshold is %.1f %s") %
+ (threshold,
+ self.mapUnits))
event.Skip()
def OnChangeSnappingUnits(self, event):
"""Snapping units change -> update static text"""
- units = self.snappingUnit.GetValue()
+ units = self.snappingUnit.GetStringSelection()
threshold = self.parent.digit.driver.GetThreshold(value, units)
if units == "map units":
@@ -1735,21 +1767,21 @@
self.parent.digit.settings[key] = (None, color.GetColour())
# display
self.parent.digit.settings["lineWidth"] = (int(self.lineWidthValue.GetValue()),
- self.lineWidthUnit.GetValue())
+ self.lineWidthUnit.GetStringSelection())
# snapping
self.parent.digit.settings["snapping"] = (int(self.snappingValue.GetValue()), # value
- self.snappingUnit.GetValue()) # unit
+ self.snappingUnit.GetStringSelection()) # unit
self.parent.digit.settings["snapToVertex"] = self.snapVertex.IsChecked()
# digitize new feature
self.parent.digit.settings["addRecord"] = self.addRecord.IsChecked()
- self.parent.digit.settings["layer"] = int(self.layer.GetValue())
+ self.parent.digit.settings["layer"] = int(self.layer.GetStringSelection())
if self.parent.digit.settings["categoryMode"] == "No category":
self.parent.digit.settings["category"] = None
else:
self.parent.digit.settings["category"] = int(self.category.GetValue())
- self.parent.digit.settings["categoryMode"] = self.categoryMode.GetValue()
+ self.parent.digit.settings["categoryMode"] = self.categoryMode.GetStringSelection()
# delete existing feature
self.parent.digit.settings["delRecord"] = self.deleteRecord.IsChecked()
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2008-02-03 20:22:15 UTC (rev 29939)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2008-02-03 22:23:27 UTC (rev 29940)
@@ -364,7 +364,7 @@
self.type = "centroid"
self.parent.MapWindow.mouse['box'] = 'point'
- def OnExit (self, event):
+ def OnExit (self, event=None):
"""Quit digitization tool"""
# stop editing of the currently selected map layer
try:
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-02-03 20:22:15 UTC (rev 29939)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-02-03 22:23:27 UTC (rev 29940)
@@ -361,14 +361,7 @@
event.Skip()
return
- # mark layer as 'edited'
- self.mapdisplay.digittoolbar.StopEditing(maplayer)
- if self.mapdisplay.digittoolbar: # disable the tool
- self.mapdisplay.RemoveToolbar("digit")
- else: # tool already enabled
- pass
+ self.mapdisplay.digittoolbar.OnExit()
self.mapdisplay.imgVectorMap = None
def OnPopupProperties (self, event):
Modified: grass/trunk/gui/wxpython/vdigit/cats.cpp
--- grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-02-03 20:22:15 UTC (rev 29939)
+++ grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-02-03 22:23:27 UTC (rev 29940)
@@ -25,13 +25,11 @@
int Digit::InitCats()
- int nfields, field, index, ncats, max_cat;
+ int ndblinks, nfields, field, ncats, max_cat;
int cat, type, id;
- struct lcat lc;
+ struct field_info *fi;
- G_debug(2, "wxDigit.InitCats()");
if (!cats.empty()) {
cats.clear();
@@ -40,22 +38,39 @@
return -1;
+ /* initialization */
+ ndblinks = Vect_get_num_dblinks(display->mapInfo);
+ for (int i = 0; i < ndblinks; i++) {
+ fi = Vect_get_dblink(display->mapInfo, i);
+ if (fi) {
+ cats[fi->number] = PORT_INT_MIN;
+ /* find max category */
nfields = Vect_cidx_get_num_fields (display->mapInfo);
+ G_debug(2, "wxDigit.InitCats(): nfields=%d", nfields);
for (int i = 0; i < nfields; i++ ) {
field = Vect_cidx_get_field_number(display->mapInfo, i);
- ncats = Vect_cidx_get_num_cats_by_index(display->mapInfo, index);
+ ncats = Vect_cidx_get_num_cats_by_index(display->mapInfo, i);
for (int j = 0; j < ncats; j++) {
- Vect_cidx_get_cat_by_index (display->mapInfo, index, j, &cat, &type, &id);
- if (cat > max_cat)
- max_cat = cat;
+ Vect_cidx_get_cat_by_index (display->mapInfo, i, j, &cat, &type, &id);
+ if (cat > cats[field])
+ cats[field] = cat;
- lc.layer = Vect_cidx_get_field_number(display->mapInfo, i);
- lc.cat = max_cat;
+ G_debug(3, "wxDigit.InitCats(): layer=%d, cat=%d", field, cats[field]);
- cats.push_back(lc);
- G_debug(3, "wxDigit.InitCats(): layer=%d, cat=%d", lc.layer, lc.cat);
+ /* set default values */
+ for(std::map<int, int>::const_iterator b = cats.begin(), e = cats.end();
+ b != e; ++b ) {
+ if (b->second == PORT_INT_MIN) {
+ cats[b->first] = 0;
+ G_debug(3, "wxDigit.InitCats(): layer=%d, cat=%d", b->first, cats[b->first]);
return 0;
@@ -71,12 +86,9 @@
int Digit::GetCategory(int layer)
- for(std::vector<struct lcat>::const_iterator i = cats.begin(), e = cats.end();
- i != e; ++i) {
- if (layer == (*i).layer) {
- G_debug(3, "v.digit.GetCategory(): layer=%d, cat=%d", (*i).layer, (*i).cat);
- return (*i).cat;
+ if (cats.find(layer) != cats.end()) {
+ G_debug(3, "v.digit.GetCategory(): layer=%d, cat=%d", layer, cats[layer]);
+ return cats[layer];
return -1;
@@ -89,37 +101,43 @@
\param cats category number to be set
\return previosly set category
+ \return -1 if layer not available
int Digit::SetCategory(int layer, int cat)
int old_cat;
- for(std::vector<struct lcat>::iterator i = cats.begin(), e = cats.end();
- i != e; ++i) {
- old_cat = (*i).cat;
- (*i).cat = cat;
- G_debug(3, "wxDigit.SetCategory(): layer=%d, cat=%d", layer, cat);
+ old_cat = cats[layer];
+ else {
+ old_cat = -1;
+ cats[layer] = cat;
+ G_debug(3, "wxDigit.SetCategory(): layer=%d, cat=%d old_cat=%d",
+ layer, cat, old_cat);
return old_cat;
- \brief Copy categories from one vector feature to other
+ Get list of layers
- \param cats list of layer/category to be copied
- \param ids list of line ids where to copy categories
+ Requires InitCats() to be called.
- \return number of modified features
- \return -1 on error
+ \return list of layers
-int Digit::CopyCats(std::vector<std::vector<int> > cats, std::vector<int> ids)
+std::vector<int> Digit::GetLayers()
- /* TODO */
+ std::vector<int> layers;
- return 0;
+ b != e; ++b ) {
+ layers.push_back(b->first);
+ return layers;
@@ -170,3 +188,19 @@
return lc;
+ \brief Copy categories from one vector feature to other
+ \param cats list of layer/category to be copied
+ \param ids list of line ids where to copy categories
+ \return number of modified features
+ \return -1 on error
+int Digit::CopyCats(std::vector<std::vector<int> > cats, std::vector<int> ids)
+ /* TODO */
+ return 0;
Modified: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h 2008-02-03 20:22:15 UTC (rev 29939)
+++ grass/trunk/gui/wxpython/vdigit/digit.h 2008-02-03 22:23:27 UTC (rev 29940)
@@ -8,11 +8,8 @@
class Digit
private:
- struct lcat {
- int layer;
- int cat;
- std::vector<lcat> cats;
+ /* layer / max category */
+ std::map<int, int> cats;
DisplayDriver *display;
@@ -54,7 +51,7 @@
int CopyCats(std::vector<std::vector<int> >, std::vector<int>);
int GetCategory(int);
std::map<int, std::vector<int> > GetLineCats();
+ std::vector<int> GetLayers();
#endif /* __DIGIT_H__ */
Modified: grass/trunk/gui/wxpython/vdigit/driver.cpp
--- grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-02-03 20:22:15 UTC (rev 29939)
+++ grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-02-03 22:23:27 UTC (rev 29940)
@@ -44,7 +44,7 @@
drawSegments = false;
// avoid GUI crash when G_fatal_error() is called (opening the vector map)
- Vect_set_fatal_error(GV_FATAL_PRINT);
+ // Vect_set_fatal_error(GV_FATAL_PRINT);
// G_set_error_routine(print_error);
@@ -439,9 +439,11 @@
if (mapInfo) {
if (mapInfo->mode == GV_MODE_RW) {
/* rebuild topology */
+ Vect_build_partial(mapInfo, GV_BUILD_NONE, NULL);
Vect_build(mapInfo, NULL);
- ret = Vect_close(mapInfo);
+ /* close map and store topo/cidx */
+ ret = Vect_close(mapInfo);
G_free ((void *) mapInfo);
mapInfo = NULL;
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp 2008-02-03 20:22:15 UTC (rev 29939)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2008-02-03 22:23:27 UTC (rev 29940)
@@ -313,7 +313,7 @@
if (Cats_del->field[c] == fi->number) {
sprintf (buf, " %s = %d", fi->key, Cats_del->cat[c]);
db_append_string(&stmt, buf);
- if (n_cats > 0) {
+ if (n_cats > 0 && c < Cats_del->n_cats) {
sprintf (buf, " or");
