[GRASS-SVN] r29944 - in grass/trunk: display/d.grid include
lib/display
svn_grass at osgeo.org
Mon Feb 4 03:19:17 EST 2008
Author: hamish
Date: 2008-02-04 03:19:15 -0500 (Mon, 04 Feb 2008)
New Revision: 29944
grass/trunk/display/d.grid/fiducial.c
grass/trunk/include/display.h
grass/trunk/lib/display/tran_colr.c
add D_color_number_to_RGB(), enable color change for d.grid -f,-c
Modified: grass/trunk/display/d.grid/fiducial.c
--- grass/trunk/display/d.grid/fiducial.c 2008-02-04 06:45:47 UTC (rev 29943)
+++ grass/trunk/display/d.grid/fiducial.c 2008-02-04 08:19:15 UTC (rev 29944)
@@ -33,8 +33,10 @@
line_color = G_malloc(sizeof(RGBA_Color));
fill_color = G_malloc(sizeof(RGBA_Color));
- /* TODO: color->RGB values, for now just use DEFAULT_FG_COLOR */
- G_str_to_color(DEFAULT_FG_COLOR, &R, &G, &B);
+ if( D_color_number_to_RGB(color, &R, &G, &B) == 0 )
+ /* fall back to black on failure */
+ G_str_to_color(DEFAULT_FG_COLOR, &R, &G, &B);
line_color->r = (unsigned char) R;
line_color->g = (unsigned char) G;
line_color->b = (unsigned char) B;
Modified: grass/trunk/include/display.h
--- grass/trunk/include/display.h 2008-02-04 06:45:47 UTC (rev 29943)
+++ grass/trunk/include/display.h 2008-02-04 08:19:15 UTC (rev 29944)
@@ -125,6 +125,7 @@
int D_allocate_color(void);
int D_parse_color(const char *, int);
int D_raster_use_color(int);
+int D_color_number_to_RGB(int, int *, int *, int *);
/* window.c */
int D_new_window(char *, int, int, int, int);
Modified: grass/trunk/lib/display/tran_colr.c
--- grass/trunk/lib/display/tran_colr.c 2008-02-04 06:45:47 UTC (rev 29943)
+++ grass/trunk/lib/display/tran_colr.c 2008-02-04 08:19:15 UTC (rev 29944)
@@ -166,3 +166,47 @@
return 0;
+ * \brief get RGB values from color number
+ * Translates the color number provided by D_parse_color
+ * into 0-255 RGB values.
+ * Returns 1 if color can be used to draw (is good and
+ * isn't 'none'), 0 otherwise.
+ * \param color_number
+ * \param red
+ * \param green
+ * \param blue
+ * \return int
+int D_color_number_to_RGB(int color, int *r, int *g, int *b)
+ const struct color_rgb *c;
+ if (color <= 0)
+ return 0;
+ if (color < G_num_standard_colors()) {
+ struct color_rgb col = G_standard_color_rgb(color);
+ if(r) *r = col.r;
+ if(g) *g = col.g;
+ if(b) *b = col.b;
+ return 1;
+ if (color >= ncolors)
+ return 0;
+ c = &colors[color];
+ if(r) *r = c->r;
+ if(g) *g = c->g;
+ if(b) *b = c->b;
+ return 1;
