[GRASS-SVN] r29945 - in grass/trunk/gui/wxpython: gui_modules vdigit
svn_grass at osgeo.org
Mon Feb 4 15:56:26 EST 2008
Author: martinl
Date: 2008-02-04 15:56:20 -0500 (Mon, 04 Feb 2008)
New Revision: 29945
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/digit.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/vdigit/cats.cpp
grass/trunk/gui/wxpython/vdigit/digit.h
grass/trunk/gui/wxpython/vdigit/digit.i
wxGUI/vdigit: C++ vdigit interface upgraded (display cats, attributes).
Some fixes in vedit interface.
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-02-04 08:19:15 UTC (rev 29944)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-02-04 20:56:20 UTC (rev 29945)
@@ -22,7 +22,7 @@
- ModifyTableRecord
- NewVectorDialog
-(C) 2007 by the GRASS Development Team
+(C) 2007-2008 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
@@ -2638,21 +2638,26 @@
to the vector map.
Attribute data can be selected based on layer and category number
- or coordinates"""
+ or coordinates.
+ @param parent
+ @param map vector map
+ @param query query coordinates and distance (used for v.edit)
+ @param cats {layer: cats}
+ @param line feature id (requested for cats)
+ @param style
+ @param pos
+ @param action (add, update, display)
def __init__(self, parent, map,
- layer=-1, cat=-1, # select by layer/cat
- queryCoords=None, qdist=-1, # select by point
+ query=None, cats=None, line=None,
style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
pos=wx.DefaultPosition,
action="add"):
- self.parent = parent # mapdisplay.BufferedWindow
- self.map = map
- self.layer = layer
- self.action = action
- self.cat = cat
- self.queryCoords = queryCoords
- self.qdist = qdist
+ self.parent = parent # mapdisplay.BufferedWindow
+ self.map = map
+ self.action = action
# id of selected line
self.line = None
@@ -2663,14 +2668,9 @@
layers = self.mapDBInfo.layers.keys() # get available layers
# check if db connection / layer exists
- if (self.layer == -1 and len(layers) <= 0) or \
- (self.layer > 0 and self.layer not in layers):
- if self.layer == -1:
- label = _("Database connection "
- "is not defined in DB file.")
- else:
- label = _("Database connection for layer %d "
- "is not defined in DB file.") % self.layer
+ if len(layers) <= 0:
+ label = _("Database connection "
+ "is not defined in DB file.")
wx.MessageBox(parent=self.parent,
message=_("No attribute table linked to "
@@ -2689,10 +2689,6 @@
# dialog body
mainSizer = wx.BoxSizer(wx.VERTICAL)
- if self.queryCoords: # select by position
- self.line, nselected = self.mapDBInfo.SelectByPoint(self.queryCoords,
- self.qdist)
# notebook
self.notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
@@ -2700,7 +2696,7 @@
label=_("Close dialog on submit"))
self.closeDialog.SetValue(True)
- self.UpdateDialog(cat, queryCoords, qdist)
+ self.UpdateDialog(query, cats, line)
# set title
if self.action == "update":
@@ -2860,15 +2856,12 @@
"""Get id of selected line or 'None' if no line is selected"""
return self.line
- def UpdateDialog(self, cat=-1, queryCoords=None, qdist=-1):
+ def UpdateDialog(self, query=None, cats=None, line=None):
"""Update dialog
Return True if updated otherwise False
- self.cat = cat
+ self.line = line
if not self.mapDBInfo:
return False
@@ -2877,30 +2870,31 @@
- self.line, nselected = self.mapDBInfo.SelectByPoint(queryCoords,
- qdist)
+ if query: # select by position
+ self.line, nselected = self.mapDBInfo.SelectByPoint(query[0],
+ query[1])
# reset notebook
self.notebook.DeleteAllPages()
for layer in layers: # for each layer
- if self.layer > 0 and \
- self.layer != layer:
- continue
+ if not query: # select by layer/cat
+ if cats.has_key(layer):
+ for cat in cats[layer]:
+ nselected = self.mapDBInfo.SelectFromTable(layer, where="cat=%d" % cat)
+ else:
+ nselected = 0
- if not self.queryCoords: # select using layer/cat
- nselected = self.mapDBInfo.SelectFromTable(layer, where="cat=%d" % self.cat)
+ # if nselected <= 0 and self.action != "add":
+ # continue # nothing selected ...
- if nselected <= 0 and self.action != "add":
- continue # nothing selected ...
if self.action == "add":
- if nselected <= 0:
+ if nselected <= 0 and cats.has_key(layer):
table = self.mapDBInfo.layers[layer]["table"]
columns = self.mapDBInfo.tables[table]
for name in columns.keys():
if name == "cat":
- self.mapDBInfo.tables[table][name]['values'].append(self.cat)
+ self.mapDBInfo.tables[table][name]['values'].append(cat)
else:
self.mapDBInfo.tables[table][name]['values'].append('')
else: # change status 'add' -> 'update'
@@ -2924,7 +2918,7 @@
if len(columns["cat"]['values']) == 0: # no cats
sizer = wx.BoxSizer(wx.VERTICAL)
txt = wx.StaticText(parent=panel, id=wx.ID_ANY,
- label=_("No categories available."))
+ label=_("No database record available."))
sizer.Add(txt, proportion=1,
flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER | wx.EXPAND)
border.Add(item=sizer, proportion=1,
@@ -3079,7 +3073,7 @@
'map=%s' % self.map,
'east_north=%f,%f' % \
(float(queryCoords[0]), float(queryCoords[1])),
- 'distance=%f' % qdist])
+ 'distance=%f' % qdist], stderr=None)
if cmdWhat.returncode == 0:
read = False
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py 2008-02-04 08:19:15 UTC (rev 29944)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py 2008-02-04 20:56:20 UTC (rev 29945)
@@ -60,7 +60,15 @@
# Use v.edit on background or experimental C++ interface (not yet completed)
USEVEDIT = True
+if USEVEDIT is True:
+ print >> sys.stderr, "%sWARNING: Digitization tool uses v.edit interface by default. " \
+ "This can significantly slow down some operations especially for " \
+ "middle-large vector maps. "\
+ "You can enable experimental vdigit interface by setting " \
+ "USEVEDIT to False in digit.py file." % \
+ os.linesep
class AbstractDigit:
Abstract digitization class
@@ -985,10 +993,23 @@
return ids
- def GetLineCats(self):
- """Get layer/category pairs from given (selected) line"""
- return self.digit.GetLineCats()
+ def GetLineCats(self, line=-1):
+ """Get layer/category pairs from given (selected) line
+ @param line feature id (-1 for first selected line)
+ return self.digit.GetLineCats(line)
+ def SetLineCats(self, line, layer, cats, add=True):
+ """Set categories for given line and layer
+ @param layer layer number (-1 for first selected line)
+ @param cats list of categories
+ @param add if True to add, otherwise do delete categories
+ return self.digit.SetLineCats(line, layer, cats, add)
def GetLayers(self):
"""Get list of layers"""
return self.digit.GetLayers()
@@ -1850,9 +1871,11 @@
Debug.msg(3, "DigitCategoryDialog(): nothing found!")
return
else:
- self.cats = cats
+ # self.cats = dict(cats)
+ for layer in cats.keys():
+ self.cats[layer] = list(cats[layer]) # TODO: tuple to list
self.line = line
# make copy of cats (used for 'reload')
self.cats_orig = copy.deepcopy(self.cats)
@@ -2118,25 +2141,35 @@
# add/delete new category
for action, cats in check.iteritems():
for layer in cats[0].keys():
- catList = ""
+ catList = []
for cat in cats[0][layer]:
if layer not in cats[1].keys() or \
cat not in cats[1][layer]:
- catList += "%s," % cat
- if catList != "":
- catList = catList[:-1] # remove last comma
- vEditCmd = ['v.edit', '--q',
- 'map=%s' % self.map,
- 'layer=%d' % layer,
- 'tool=%s' % action,
- 'cats=%s' % catList,
- 'id=%d' % self.line]
+ catList.append(cat)
+ if catList != []:
+ if USEVEDIT is True:
+ vEditCmd = ['v.edit', '--q',
+ 'map=%s' % self.map,
+ 'layer=%d' % layer,
+ 'tool=%s' % action,
+ 'cats=%s' % ",".join(["%d" % v for v in catList]),
+ 'id=%d' % self.line]
- gcmd.Command(vEditCmd)
+ gcmd.Command(vEditCmd)
+ else:
+ if action == 'catadd':
+ add = True
+ else:
+ add = False
+ self.line = self.parent.parent.digit.SetLineCats(-1, layer,
+ catList, add)
+ if self.line < 0:
+ wx.MessageBox(parent=self, message=_("Unable to update vector map."),
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
+ # reload map (needed for v.edit)
+ self.parent.parent.digit.driver.ReloadMap()
- # reload map (needed for v.edit)
- self.parent.parent.digit.driver.ReloadMap()
event.Skip()
@@ -2200,9 +2233,11 @@
if cats is None:
ret = self.__GetCategories(query[0], query[1])
else:
- self.cats = cats
+ self.line = line
ret = 1
- self.line = line
if ret == 0 or not self.line:
return False
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-02-04 08:19:15 UTC (rev 29944)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-02-04 20:56:20 UTC (rev 29945)
@@ -923,9 +923,10 @@
# add new record into atribute table
if digitClass.settings["addRecord"]:
# select attributes based on layer and category
+ cats = {}
+ cats[digitClass.settings["layer"]] = (digitClass.settings["category"],)
addRecordDlg = dbm.DisplayAttributesDialog(parent=self, map=map,
- layer=digitClass.settings["layer"],
- cat=digitClass.settings["category"],
+ cats=cats,
pos=posWindow,
action="add")
if addRecordDlg.mapDBInfo and \
@@ -970,20 +971,39 @@
elif digitToolbar.action in ["displayAttrs", "displayCats"]:
qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) / self.Map.width)
- redraw = False
+ coords = (east, north)
if digitToolbar.action == "displayAttrs":
# select attributes based on coordinates (all layers)
if digitToolbar.attributesDialog is None:
- digitToolbar.attributesDialog = dbm.DisplayAttributesDialog(parent=self, map=map,
- queryCoords=(east,
- north),
- qdist=qdist,
- pos=posWindow,
- action="update")
+ if digitClass.type == 'vedit':
+ digitToolbar.attributesDialog = dbm.DisplayAttributesDialog(parent=self, map=map,
+ query=(coords, qdist),
+ pos=posWindow,
+ action="update")
+ else:
+ if digitClass.driver.SelectLineByPoint(coords,
+ digitClass.GetSelectType()) is not None:
+ cats=digitClass.GetLineCats(),
+ line=digitClass.driver.GetSelected()[0],
+ action="update")
else:
# update currently open dialog
- digitToolbar.attributesDialog.UpdateDialog(queryCoords=(east, north),
- qdist=qdist)
+ digitToolbar.attributesDialog.UpdateDialog(query=(coords, qdist))
+ else:
+ # unselect
+ digitClass.driver.SetSelected([])
+ # select new feature
+ digitClass.GetSelectType()) is None:
+ line = None
+ else:
+ line = digitClass.driver.GetSelected()[0]
+ # upgrade dialog
+ digitToolbar.attributesDialog.UpdateDialog(cats=digitClass.GetLineCats(),
+ line=line)
line = digitToolbar.attributesDialog.GetLine()
if digitToolbar.attributesDialog.mapDBInfo and line:
@@ -997,7 +1017,6 @@
digitToolbar.attributesDialog.Hide()
else: # displayCats
- coords = (east, north)
if digitToolbar.categoryDialog is None:
# open new dialog
@@ -1021,10 +1040,19 @@
digitToolbar.categoryDialog.UpdateDialog(query=(coords, qdist))
else:
- digitToolbar.categoryDialog.UpdateDialog(cats=digitClass.GetLineCats())
+ # unselect
+ line = None
+ else:
+ # upgrade dialog
+ digitToolbar.categoryDialog.UpdateDialog(cats=digitClass.GetLineCats(),
+ line=line)
line = digitToolbar.categoryDialog.GetLine()
- redraw = False
if line:
# highlight feature & re-draw map
digitClass.driver.SetSelected([line])
@@ -1196,9 +1224,14 @@
else:
# collect ids
- # return number of selected features
+ # return number of selected features (by box/point)
nselected = digitClass.driver.SelectLinesByBox(pos1, pos2,
+ if nselected == 0:
+ if digitClass.driver.SelectLineByPoint(pos1,
+ nselected = 1
if nselected > 0:
self.copyCatsIds = digitClass.driver.GetSelected()
@@ -1433,9 +1466,10 @@
position[1] + offset))
+ cats = {}
+ cats=cats,
pos=posWindow,
action="add")
Modified: grass/trunk/gui/wxpython/vdigit/cats.cpp
--- grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-02-04 08:19:15 UTC (rev 29944)
+++ grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-02-04 20:56:20 UTC (rev 29945)
@@ -141,23 +141,31 @@
- \brief Get list of layer/category(ies) for selected line.
+ \brief Get list of layer/category(ies) for selected feature.
+ \param line feature id (-1 for first selected feature)
\return list of layer/cats
-std::map<int, std::vector<int> > Digit::GetLineCats()
+std::map<int, std::vector<int> > Digit::GetLineCats(int line_id)
std::map<int, std::vector<int> > lc;
int line, n_dblinks;
struct line_cats *Cats;
struct field_info *fi;
- if (!display->mapInfo || display->selected->n_values < 1) {
+ if (!display->mapInfo) {
return lc;
- line = display->selected->value[0];
+ if (line_id == -1 && display->selected->n_values < 1) {
+ return lc;
+ if (line_id == -1) {
+ line = display->selected->value[0];
if (!Vect_line_alive(display->mapInfo, line)) {
return lc;
@@ -190,6 +198,73 @@
+ \brief Set categories for given feature/layer
+ \param layer layer number
+ \param cats list of cats
+ \param add True for add, False for delete
+ \return new feature id (feature need to be rewritten)
+ \return -1 on error
+int Digit::SetLineCats(int line_id, int layer, std::vector<int> cats, bool add)
+ int line, ret, type;
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ return -1;
+ return -1;
+ if (!Vect_line_alive(display->mapInfo, line)) {
+ return -1;
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ type = Vect_read_line(display->mapInfo, Points, Cats, line);
+ if (type < 0) {
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_cats_struct(Cats);
+ return -1;
+ for (std::vector<int>::const_iterator c = cats.begin(), e = cats.end();
+ c != e; ++c) {
+ if (add) {
+ Vect_cat_set(Cats, layer, *c);
+ else {
+ Vect_field_cat_del(Cats, layer, *c);
+ G_debug(3, "Digit.SetLineCats(): layer=%d, cat=%d, add=%d",
+ layer, *c, add);
+ ret = Vect_rewrite_line(display->mapInfo, line, type,
+ Points, Cats);
+ /* update line id since the line was rewritten */
+ display->selected->value[0] = ret;
+ return ret;
\brief Copy categories from one vector feature to other
\param cats list of layer/category to be copied
Modified: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h 2008-02-04 08:19:15 UTC (rev 29944)
+++ grass/trunk/gui/wxpython/vdigit/digit.h 2008-02-04 20:56:20 UTC (rev 29945)
@@ -50,7 +50,8 @@
int CopyCats(std::vector<std::vector<int> >, std::vector<int>);
int GetCategory(int);
- std::map<int, std::vector<int> > GetLineCats();
+ std::map<int, std::vector<int> > GetLineCats(int);
+ int SetLineCats(int, int, std::vector<int>, bool);
std::vector<int> GetLayers();
Modified: grass/trunk/gui/wxpython/vdigit/digit.i
--- grass/trunk/gui/wxpython/vdigit/digit.i 2008-02-04 08:19:15 UTC (rev 29944)
+++ grass/trunk/gui/wxpython/vdigit/digit.i 2008-02-04 20:56:20 UTC (rev 29945)
@@ -10,8 +10,12 @@
#include "digit.h"
-%include "std_vector.i"
+%include "std_vector.i"
namespace std {
%template(IntVector) vector<int>;
%template(DoubleVector) vector<double>;
+%include "std_map.i"
+namespace std {
+ %template(IntVecIntMap) map<int, vector<int> >;
