[GRASS-SVN] r29967 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Feb 6 00:29:06 EST 2008
Author: cmbarton
Date: 2008-02-06 00:29:06 -0500 (Wed, 06 Feb 2008)
New Revision: 29967
grass/trunk/gui/wxpython/gui_modules/georect.py
GCP map and georef coord map now work properly, GCPs and georef coords automatically entered into proper place in GCP manager. Map displays update correctly. Other small fixes. Pretty much have all the infrastructure done at last.
Modified: grass/trunk/gui/wxpython/gui_modules/georect.py
--- grass/trunk/gui/wxpython/gui_modules/georect.py 2008-02-06 05:27:37 UTC (rev 29966)
+++ grass/trunk/gui/wxpython/gui_modules/georect.py 2008-02-06 05:29:06 UTC (rev 29967)
@@ -63,6 +63,7 @@
import disp_print
import gcmd
import utils
+import menuform
from debug import Debug as Debug
from icon import Icons as Icons
@@ -207,7 +208,7 @@
self.xy_mapdisp.Update()
# start GCP form
- self.gcpmgr = GCP(self.parent)
+ self.gcpmgr = GCP(self.parent, grwiz=self)
self.gcpmgr.Show()
self.gcpmgr.Refresh()
self.gcpmgr.Update()
@@ -233,7 +234,6 @@
def SwitchEnv(self, grc):
"""Switches between original working location/mapset and
location/mapset that is source of file(s) to georectify"""
- print 'switch = ',grc
if grc == 'original':
os.environ["GISRC"] = str(self.orig_gisrc)
elif grc == 'new':
@@ -262,8 +262,11 @@
# return to current location and mapset
self.SwitchEnv('original')
self.parent.georectifying = False
- self.xy_mapdisp.Destroy()
- self.wizard.Destroy()
+ try:
+ self.xy_mapdisp.Destroy()
+ self.wizard.Destroy()
+ except:
+ pass
class LocationPage(TitledPage):
@@ -406,6 +409,7 @@
self.sizer.Add(box, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
self.Bind(wx.EVT_COMBOBOX, self.OnGroup, self.cb_group)
+ self.Bind(wx.EVT_BUTTON, self.OnMkGroup, self.btn_mkgroup)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.onPageChanging)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnPageChanged)
self.Bind(wx.EVT_CLOSE, self.parent.Cleanup)
@@ -414,6 +418,11 @@
global xy_group
xy_group = event.GetString()
+ def OnMkGroup(self, event):
+ self.parent.SwitchEnv('new')
+ cmdlist = ['i.group']
+ menuform.GUI().ParseCommand(cmdlist, parentframe=self.parent.parent)
def onPageChanging(self,event=None):
global xy_group
@@ -499,10 +508,13 @@
Calls i.rectify or v.transform to georectify map.
- def __init__(self,parent,id=-1,title="Create & manage ground control points"):
+ def __init__(self,parent,id=-1,title="Create & manage ground control points",
+ size=wx.DefaultSize, grwiz=None):
wx.Frame.__init__(self, parent, id , title, size=(500,400))
toolbar = self.__createToolBar()
+ self.grwiz = grwiz
self.selected = 0 #gcp list item selected
self.mapcoordlist = [(0000000.00,0000000.00,'')] #list map coords and ID of map display they came from
@@ -535,6 +547,8 @@
self.list.SetStringItem(index, 3, i[3])
self.list.SetStringItem(index, 4, i[4])
self.list.SetStringItem(index, 5, i[5])
+ self.list.CheckItem(0, True)
p.SetSizer(self.sizer)
@@ -580,7 +594,10 @@
def AddGCP(self, event):
self.list.Append(['0000000.00','0000000.00','0000000.00','0000000.00','0000.00','0000.00'])
+ index = self.list.GetItemCount() - 1
self.mapcoordlist.append((0000000.00,0000000.00,''))
+ self.list.CheckItem(index, True)
+ self.list.SetItemState(index, wx.LIST_STATE_SELECTED, wx.LIST_STATE_SELECTED)
def SetGCPData(self, coordtype, coord, mapdisp):
index = self.selected
@@ -593,7 +610,7 @@
if coordtype == 'mapcoord':
self.list.SetStringItem(index, 2, coord0)
self.list.SetStringItem(index, 3, coord1)
- self.mapcoordlist[index] = [(coord[0], coord[1], mapdisp)]
+ self.mapcoordlist[index] = (coord[0], coord[1], mapdisp)
if coordtype == 'rms':
self.list.SetStringItem(index, 4, coord0)
self.list.SetStringItem(index, 5, coord1)
@@ -602,7 +619,7 @@
for i in range(6):
self.list.SetStringItem(index, i, '0000000.00')
- self.mapcoordlist[index] = [(0000000.00,0000000.00,'')]
+ self.mapcoordlist[index] = (0000000.00,0000000.00,'')
def OnRMS(self, event):
pass
@@ -619,22 +636,41 @@
def OnItemSelected(self, event):
self.selected = event.GetIndex()
- print 'item = ',self.selected
def RefreshGCPMarks(self, event):
+ Update GCP and map coord maps and redraw
+ active GCP markers on both
+ self.grwiz.SwitchEnv("new")
+ self.grwiz.mapwin.UpdateMap()
+ self.grwiz.SwitchEnv("original")
+ mapid = ''
+ for map in self.mapcoordlist:
+ if map[2] != mapid and map[2] != '':
+ map[2].UpdateMap()
+ mapid = map[2]
for index in range(self.list.GetItemCount()):
- if self.list.IsChecked(index):
+ if self.list.IsChecked(index) and (
+ (self.list.GetItem(index, 0).GetText() != '0000000.00' and
+ self.list.GetItem(index, 1).GetText() != '0000000.00') or
+ (self.list.GetItem(index, 2).GetText() != '0000000.00' and
+ self.list.GetItem(index, 3).GetText() != '0000000.00')
+ print 'checked? ',index,self.list.IsChecked(index)
coord0 = float(self.list.GetItem(index, 0).GetText())
coord1 = float(self.list.GetItem(index, 1).GetText())
coord2 = float(self.list.GetItem(index, 2).GetText())
coord3 = float(self.list.GetItem(index, 3).GetText())
- print coord0,coord1,coord2,coord3,coord4
- self.mapcoordlist[2].MapWindow.DrawCross(pdc=self.pdcTmp, coords=(coord2,coord3),
- size=5)
- self.mapcoordlist[2].MapWindow.UpdateMap()
- self.parent.mapwin.DrawCross(pdc=self.pdcTmp, coords=(coord0,coord1),
- size=5)
- self.parent.mapwin.UpdateMap()
+ pxcoord1 = self.grwiz.mapwin.Cell2Pixel((coord0, coord1))
+ self.grwiz.mapwin.DrawCross(pdc=self.grwiz.mapwin.pdcTmp,
+ coords=pxcoord1, size=5)
+ pxcoord2 = self.mapcoordlist[index][2].Cell2Pixel((coord2, coord3))
+ self.mapcoordlist[index][2].DrawCross(pdc=self.mapcoordlist[index][2].pdcTmp,
+ coords=pxcoord2, size=5)
class CheckListCtrl(wx.ListCtrl, CheckListCtrlMixin, ListCtrlAutoWidthMixin):
def __init__(self, parent):
@@ -652,97 +688,4 @@
def OnCheckItem(self, index, flag):
pass
-# These 2 grid classes are ones I tried to use instead of a list. Might want
-# to rethink this later
-class GCPGrid(gridlib.Grid):
- def __init__(self, parent):
- gridlib.Grid.__init__(self, parent, -1)
- table = GCPDateTable()
- # The second parameter means that the grid is to take ownership of the
- # table and will destroy it when done. Otherwise you would need to keep
- # a reference to it and call it's Destroy method later.
- self.SetTable(table, True)
- self.SetRowLabelSize(10)
- self.SetMargins(0,0)
- self.AutoSizeColumns(True)
- gridlib.EVT_GRID_CELL_LEFT_DCLICK(self, self.OnLeftDClick)
- # I do this because I don't like the default behaviour of not starting the
- # cell editor on double clicks, but only a second click.
- def OnLeftDClick(self, evt):
- if self.CanEnableCellControl():
- self.EnableCellEditControl()
-class GCPDateTable(gridlib.PyGridTableBase):
- def __init__(self):
- gridlib.PyGridTableBase.__init__(self)
- self.colLabels = ['Use', 'X Coord', 'Y Coord', 'East', 'North',
- 'Forward Error', 'Backward Error']
- self.dataTypes = [gridlib.GRID_VALUE_BOOL,
- gridlib.GRID_VALUE_FLOAT + ':7,2',
- self.data = [
- [1, '0000000.00', '0000000.00', '0000000.00', '0000000.00', '0000000.00', '0000000.00'],
- # required methods for the wxPyGridTableBase interface
- def GetNumberRows(self):
- return len(self.data) + 1
- def GetNumberCols(self):
- return len(self.data[0])
- def IsEmptyCell(self, row, col):
- try:
- return not self.data[row][col]
- except IndexError:
- return True
- # Get/Set values in the table. The Python version of these
- # methods can handle any data-type, (as long as the Editor and
- # Renderer understands the type too,) not just strings as in the
- # C++ version.
- def GetValue(self, row, col):
- try:
- return self.data[row][col]
- return ''
- def SetValue(self, row, col, value):
- try:
- self.data[row][col] = value
- # add a new row
- self.data.append([''] * self.GetNumberCols())
- self.SetValue(row, col, value)
- # tell the grid we've added a row
- msg = gridlib.GridTableMessage(self, # The table
- gridlib.GRIDTABLE_NOTIFY_ROWS_APPENDED, # what we did to it
- 1 # how many
- self.GetView().ProcessTableMessage(msg)
- # Some optional methods
- # Called when the grid needs to display labels
- def GetColLabelValue(self, col):
- return self.colLabels[col]
- # Called to determine the kind of editor/renderer to use by
- # default, doesn't necessarily have to be the same type used
- # natively by the editor/renderer if they know how to convert.
- def GetTypeName(self, row, col):
- return self.dataTypes[col]
- # Called to determine how the data can be fetched and stored by the
- # editor and renderer. This allows you to enforce some type-safety
- # in the grid.
- def CanGetValueAs(self, row, col, typeName):
- colType = self.dataTypes[col].split(':')[0]
- if typeName == colType:
- return True
- else:
- return False
- def CanSetValueAs(self, row, col, typeName):
- return self.CanGetValueAs(row, col, typeName)
