[GRASS-SVN] r29968 - grass-addons/i.landsat.toar
svn_grass at osgeo.org
Wed Feb 6 02:55:11 EST 2008
Author: neteler
Date: 2008-02-06 02:55:10 -0500 (Wed, 06 Feb 2008)
New Revision: 29968
grass-addons/i.landsat.toar/description.html
grass-addons/i.landsat.toar/landsat_met.c
grass-addons/i.landsat.toar/landsat_set.c
grass-addons/i.landsat.toar/main.c
E. Jorge Tizado: bugfix when reading met files of Landsat 5 TM
Modified: grass-addons/i.landsat.toar/description.html
--- grass-addons/i.landsat.toar/description.html 2008-02-06 05:29:06 UTC (rev 29967)
+++ grass-addons/i.landsat.toar/description.html 2008-02-06 07:55:10 UTC (rev 29968)
@@ -62,7 +62,7 @@
<em>TAUv</em> is the atmospheric transmittance along the path from the ground surface to the sensor.
</p>
-<p>For this calculus the values are from DOS2 method (Chavez, 1996): TAUz = sin(e) [for the bands with maximum wave length less than 1., i.e. bands 4/5/6 MSS, 1-4 TM, and 1-4 ETM+] otherwise TAUz = 1.07, TAUv = 1.0, and Esky = 0.</p>
+<p>For this calculus, the values are TAUv = 1.0, Esky = 0. and TAUz = 1.0. When the method is simplified TAUz = sin(e) for all bands with maximum wave length less than 1., i.e. bands 4-6 MSS, 1-4 TM, and 1-4 ETM+.</p>
<H2>NOTES</H2>
Modified: grass-addons/i.landsat.toar/landsat_met.c
--- grass-addons/i.landsat.toar/landsat_met.c 2008-02-06 05:29:06 UTC (rev 29967)
+++ grass-addons/i.landsat.toar/landsat_met.c 2008-02-06 07:55:10 UTC (rev 29968)
@@ -108,6 +108,7 @@
void get_value_met(const char mettext[], char *text, char value[])
char *ptr;
+ int i;
value[0] = 0;
ptr = strstr(mettext, text);
@@ -116,10 +117,10 @@
ptr = strstr(ptr, " VALUE ");
if (ptr == NULL) return;
+ i = 0;
while (*ptr++ != '\"') ;
- sscanf(ptr, "%s", value);
- ptr = value;
- do { if (*ptr == '\"') *ptr = '\0'; } while (*ptr++);
+ while( *ptr != '\"' && i < MAX_STR) value[i++]=*ptr++;
+ value[i] = '\0';
return;
@@ -164,11 +165,11 @@
break;
case '4':
get_value_met(mettext, "SENSORSHORTNAME", value);
- if (value[0] = 'M') set_MSS4(lsat); else set_TM4(lsat);
+ if (value[0] == 'M') set_MSS4(lsat); else set_TM4(lsat);
break;
case '5':
- if (value[0] = 'M') set_MSS5(lsat); else set_TM5(lsat);
+ if (value[0] == 'M') set_MSS5(lsat); else set_TM5(lsat);
break;
Modified: grass-addons/i.landsat.toar/landsat_set.c
--- grass-addons/i.landsat.toar/landsat_set.c 2008-02-06 05:29:06 UTC (rev 29967)
+++ grass-addons/i.landsat.toar/landsat_set.c 2008-02-06 07:55:10 UTC (rev 29968)
@@ -13,8 +13,8 @@
int i;
- int band[] = { 4, 5, 6, 7 };
- int code[] = { 1, 2, 3, 4 };
+ int band[] = { 1, 2, 3, 4 };
+ int code[] = { 4, 5, 6, 7 };
double wmax[] = { 0.6, 0.7, 0.8, 1.1 };
double wmin[] = { 0.5, 0.6, 0.7, 0.8 };
@@ -46,7 +46,7 @@
lsat->bands = 7;
for (i = 0; i < lsat->bands; i++) {
lsat->band[i].number = *(band + i);
- lsat->band[i].code = lsat->band[i].number;
+ lsat->band[i].code = *(band + i);
lsat->band[i].wavemax = *(wmax + i);
lsat->band[i].wavemin = *(wmin + i);
lsat->band[i].qcalmax = 255.;
@@ -337,9 +337,9 @@
/** Gyanesh Chander and Brian Markham.
IEEE Transactions On Geoscience And Remote Sensing, Vol. 41, No. 11, November 2003 */
/* Spectral radiances at detector */
- double Lmax[][7] = { { 152.10, 296.81, 204.30, 206.20, 27.19, 15.303, 14.38 }, /* before May 4, 2003 */
- { 193.00, 365.00, 264.00, 221.00, 30.20, 15.303, 16.50 }, /* on or after May 4, 2003 */
- { 169.00, 333.00, 264.00, 221.00, 30.20, 15.303, 16.50 } }; /* on or after April 2, 2007 */
+ double Lmax[][7] = { { 152.10, 296.81, 204.30, 206.20, 27.19, 15.303, 14.38 }, /* on or before May 4, 2003 */
+ { 193.00, 365.00, 264.00, 221.00, 30.20, 15.303, 16.50 }, /* after May 4, 2003 */
+ { 169.00, 333.00, 264.00, 221.00, 30.20, 15.303, 16.50 } }; /* after April 2, 2007 */
double Lmin[][7] = { { -1.52, -2.84, -1.17, -1.51, -0.37, 1.2378, -0.15 },
{ -1.52, -2.84, -1.17, -1.51, -0.37, 1.2378, -0.15 } };
Modified: grass-addons/i.landsat.toar/main.c
--- grass-addons/i.landsat.toar/main.c 2008-02-06 05:29:06 UTC (rev 29967)
+++ grass-addons/i.landsat.toar/main.c 2008-02-06 07:55:10 UTC (rev 29968)
@@ -11,8 +11,8 @@
* COPYRIGHT: (C) 2002, 2005 2008 by the GRASS Development Team
* This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
@@ -81,8 +81,8 @@
adate->key = _("date");
adate->type = TYPE_STRING;
adate->required = NO;
- adate->gisprompt = _("image acquisition adate");
- adate->description = _("Image acquisition adate (yyyy-mm-dd)");
+ adate->gisprompt = _("image acquisition date");
+ adate->description = _("Image acquisition date (yyyy-mm-dd)");
elev = G_define_option();
elev->key = _("solar");
@@ -102,8 +102,8 @@
pdate->key = _("product_date");
pdate->type = TYPE_STRING;
pdate->required = NO;
- pdate->gisprompt = _("image production adate");
- pdate->description = _("Image creation adate (yyyy-mm-dd)");
+ pdate->gisprompt = _("image production date");
+ pdate->description = _("Image creation date (yyyy-mm-dd)");
metho = G_define_option();
metho->key = _("method");
@@ -212,9 +212,9 @@
if (elev->answer != NULL)
lsat.sun_elev = atof(elev->answer); /* Overwrite sun elevation of met file */
- /* Data from adate and solar elevation */
+ /* Data from date and solar elevation */
else if (adate->answer == NULL || elev->answer == NULL) {
- G_fatal_error(_("Lacking adate and solar elevation for this satellite"));
+ G_fatal_error(_("Lacking date or solar elevation for this satellite"));
else {
if (sat7->answer) { /* Need gain */
@@ -256,20 +256,21 @@
- /* Now calculate band constants */
- for (i = 0; i < lsat.bands; i++) {
- switch(atcor[0])
- case 'c':
- method = CORRECTED;
- break;
- case 's':
- method = SIMPLIFIED;
- break;
- default:
- method = UNCORRECTED;
- break;
+ /* Set method and calculate band constants */
+ switch(atcor[0])
+ case 'c':
+ method = CORRECTED;
+ break;
+ case 's':
+ method = SIMPLIFIED;
+ break;
+ default:
+ method = UNCORRECTED;
+ break;
+ for (i = 0; i < lsat.bands; i++)
lsat_bandctes(&lsat, i, method, 0.0, percent);
@@ -281,6 +282,8 @@
fprintf(stdout, " ACQUISITION DATE %s [production date %s]\n", lsat.date, lsat.creation);
fprintf(stdout, " earth-sun distance = %.8lf\n", lsat.dist_es);
fprintf(stdout, " solar elevation angle = %.8lf\n", lsat.sun_elev);
+ fprintf(stdout, " Method for at sensor values = %s\n",
+ (atcor[0]=='c' ? "corrected" : (atcor[0]=='s' ? "simplified" : "uncorrected")));
if (atcor[0] == 's')
fprintf(stdout, " percent of solar irradiance in path radiance = %.4lf\n", percent);
