[GRASS-SVN] r30019 - grass/trunk/scripts/v.db.renamecol
svn_grass at osgeo.org
Fri Feb 8 15:35:54 EST 2008
Author: neteler
Date: 2008-02-08 15:35:54 -0500 (Fri, 08 Feb 2008)
New Revision: 30019
grass/trunk/scripts/v.db.renamecol/v.db.renamecol
col length calc. polished
Modified: grass/trunk/scripts/v.db.renamecol/v.db.renamecol
--- grass/trunk/scripts/v.db.renamecol/v.db.renamecol 2008-02-08 17:57:10 UTC (rev 30018)
+++ grass/trunk/scripts/v.db.renamecol/v.db.renamecol 2008-02-08 20:35:54 UTC (rev 30019)
@@ -125,9 +125,8 @@
newcol="`echo $GIS_OPT_COLUMN | cut -d',' -f2`"
if [ "$driver" = "dbf" ] ; then
- # strangely "" counts as 1
- NAMELEN=`echo "$newcol" | wc -c | awk '{print $1}'`
- if [ "$NAMELEN" -gt 11 ] ; then
+ NAMELEN=`echo -n "$newcol" | wc -c | awk '{print $1}'`
+ if [ "$NAMELEN" -gt 10 ] ; then
g.message -e "Column name too long <$newcol>: the DBF driver only supports up to 10 characters as column name."
cleanup
exit 1
