[GRASS-SVN] r30020 - in grass/trunk/vector/v.edit: cmd lib
svn_grass at osgeo.org
Fri Feb 8 16:04:05 EST 2008
Author: martinl
Date: 2008-02-08 16:04:05 -0500 (Fri, 08 Feb 2008)
New Revision: 30020
grass/trunk/vector/v.edit/cmd/args.c
grass/trunk/vector/v.edit/cmd/description.html
grass/trunk/vector/v.edit/cmd/global.h
grass/trunk/vector/v.edit/cmd/main.c
grass/trunk/vector/v.edit/cmd/proto.h
grass/trunk/vector/v.edit/cmd/select.c
grass/trunk/vector/v.edit/lib/break.c
grass/trunk/vector/v.edit/lib/cats.c
grass/trunk/vector/v.edit/lib/copy.c
grass/trunk/vector/v.edit/lib/delete.c
grass/trunk/vector/v.edit/lib/distance.c
grass/trunk/vector/v.edit/lib/flip.c
grass/trunk/vector/v.edit/lib/merge.c
grass/trunk/vector/v.edit/lib/move.c
grass/trunk/vector/v.edit/lib/snap.c
grass/trunk/vector/v.edit/lib/vedit.h
grass/trunk/vector/v.edit/lib/vertex.c
grass/trunk/vector/v.edit/lib/zbulk.c
v.edit: Tool for changing feature type added (points<->centroids, lines<->boundaries).
Doxygen fixes in lib.
Selecting features by id fixed (type is not ignored).
Modified: grass/trunk/vector/v.edit/cmd/args.c
--- grass/trunk/vector/v.edit/cmd/args.c 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/cmd/args.c 2008-02-08 21:04:05 UTC (rev 30020)
@@ -86,9 +86,11 @@
"Connect two lines;"
"zbulk;"
"Z bulk-labeling (automated assignment of z coordinate to "
- "vector lines)");
+ "vector lines);"
+ "chtype;"
+ "Change feature type (point<->centroid, line<->boundary)");
params -> tool->options = "create,add,delete,copy,move,flip,catadd,catdel,"
- "merge,break,snap,connect,"
+ "merge,break,snap,connect,chtype,"
"vertexadd,vertexdel,vertexmove,zbulk,select";
params -> in = G_define_standard_option (G_OPT_F_INPUT);
@@ -275,33 +277,29 @@
*action_mode = MODE_VERTEX_MOVE;
else if(G_strcasecmp (params -> tool -> answer, "select") == 0) {
- /* del requires a cats or or bbox or coords */
*action_mode = MODE_SELECT;
else if(G_strcasecmp (params -> tool -> answer, "catadd") == 0) {
- /* cat requires a cats or or bbox or coords */
*action_mode = MODE_CATADD;
else if(G_strcasecmp (params -> tool -> answer, "catdel") == 0) {
*action_mode = MODE_CATDEL;
else if(G_strcasecmp(params -> tool -> answer, "copy") == 0) {
*action_mode = MODE_COPY;
else if(G_strcasecmp (params -> tool -> answer, "snap") == 0) {
*action_mode = MODE_SNAP;
else if(G_strcasecmp (params -> tool -> answer, "flip") == 0) {
*action_mode = MODE_FLIP;
else if(G_strcasecmp (params -> tool -> answer, "zbulk") == 0) {
*action_mode = MODE_ZBULK;
+ else if(G_strcasecmp (params -> tool -> answer, "chtype") == 0) {
+ *action_mode = MODE_CHTYPE;
else
G_fatal_error (_("Operation '%s' not implemented"),
Modified: grass/trunk/vector/v.edit/cmd/description.html
--- grass/trunk/vector/v.edit/cmd/description.html 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/cmd/description.html 2008-02-08 21:04:05 UTC (rev 30020)
@@ -122,6 +122,10 @@
is broken if necessary. The lines are connected regarding
threshold distance <b>thresh</b>.</li>
+ <li><b>chtype</b> - Change feature type of selected geometry
+ objects. Points are converted to centroids, centroids to points,
+ lines to boundaries and boundaries to lines.
<li><b>vertexadd</b> - Add vertex(ces) to the given vector lines
or boundaries. Location of the new vertex is given by <b>coord</b>
option. If <b>-1</b> is given only first found line or boundary in bounding
Modified: grass/trunk/vector/v.edit/cmd/global.h
--- grass/trunk/vector/v.edit/cmd/global.h 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/cmd/global.h 2008-02-08 21:04:05 UTC (rev 30020)
@@ -34,6 +34,8 @@
MODE_NONE,
/* z bulk-labeling */
MODE_ZBULK,
+ /* change feature type (point<->centroid, line<->boundary) */
+ MODE_CHTYPE,
struct GParams {
Modified: grass/trunk/vector/v.edit/cmd/main.c
--- grass/trunk/vector/v.edit/cmd/main.c 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/cmd/main.c 2008-02-08 21:04:05 UTC (rev 30020)
@@ -346,6 +346,35 @@
G_message(_("%d lines labeled"), ret);
break;
+ case MODE_CHTYPE: {
+ int npoints, nlines, ncentroids, nboundaries;
+ ret = Vedit_chtype_lines(&Map, List,
+ &npoints, &ncentroids,
+ &nlines, &nboundaries);
+ if (ret > 0) {
+ if (npoints > 0) {
+ G_message(_("%d points converted to centroids"),
+ npoints);
+ if (ncentroids > 0) {
+ G_message(_("%d centroids converted to points"),
+ ncentroids);
+ if (nlines > 0) {
+ G_message(_("%d lines converted to boundaries"),
+ nlines);
+ if (nboundaries > 0) {
+ G_message(_("%d boundaries converted to lines"),
+ nboundaries);
+ else {
+ G_message(_("No feature modified"));
+ break;
default:
G_warning(_("Operation not implemented"));
ret = -1;
Modified: grass/trunk/vector/v.edit/cmd/proto.h
--- grass/trunk/vector/v.edit/cmd/proto.h 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/cmd/proto.h 2008-02-08 21:04:05 UTC (rev 30020)
@@ -27,7 +27,7 @@
int, struct line_pnts *,
struct ilist *);
int sel_by_id(struct Map_info *,
- char *,
+ int, char *,
struct ilist *);
int sel_by_where(struct Map_info *,
int, int, char *,
Modified: grass/trunk/vector/v.edit/cmd/select.c
--- grass/trunk/vector/v.edit/cmd/select.c 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/cmd/select.c 2008-02-08 21:04:05 UTC (rev 30020)
@@ -47,7 +47,7 @@
/* select by id's */
if (params -> id -> answer != NULL) {
sel_by_id(Map,
- params -> id -> answer,
+ type, params -> id -> answer,
List);
@@ -429,16 +429,17 @@
\brief Select features by id
\param[in] Map vector map
+ \param[in] type feature type
\param[in] ids ids list
\param[in,out] List list of selected features
\return number of selected lines
int sel_by_id(struct Map_info *Map,
- char *ids,
+ int type, char *ids,
struct ilist* List)
- int i, j;
+ int i;
int num, id;
struct cat_list *il; /* NOTE: this is not cat list, but list of id's */
struct ilist *List_tmp;
@@ -457,13 +458,14 @@
num = Vect_get_num_lines (Map);
for(i = 0; i < il -> n_ranges; i++) {
- for(id = il -> min[i]; id <= il -> max[i]; id++) {
- for (j = 1; j <= num; j++) {
- if (id == j) {
- Vect_list_append (List_tmp, id);
+ for (id = 1; id <= num; id++) {
+ if (!(Vect_read_line(Map, NULL, NULL, id) & type)) {
+ continue;
+ if (id >= il -> min[i] && id <= il -> max[i]) {
+ Vect_list_append (List_tmp, id);
G_debug (1, " %d lines selected (by id)", List_tmp -> n_values);
Modified: grass/trunk/vector/v.edit/lib/break.c
--- grass/trunk/vector/v.edit/lib/break.c 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/lib/break.c 2008-02-08 21:04:05 UTC (rev 30020)
@@ -1,4 +1,6 @@
+ \file break.c
\brief Vedit library - split/break lines
This program is free software under the
Modified: grass/trunk/vector/v.edit/lib/cats.c
--- grass/trunk/vector/v.edit/lib/cats.c 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/lib/cats.c 2008-02-08 21:04:05 UTC (rev 30020)
@@ -1,4 +1,6 @@
+ \file cats.c
\brief Vedit library - category manipulation
Modified: grass/trunk/vector/v.edit/lib/copy.c
--- grass/trunk/vector/v.edit/lib/copy.c 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/lib/copy.c 2008-02-08 21:04:05 UTC (rev 30020)
@@ -1,4 +1,6 @@
+ \file copy.c
\brief Vedit library - copy features
Modified: grass/trunk/vector/v.edit/lib/delete.c
--- grass/trunk/vector/v.edit/lib/delete.c 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/lib/delete.c 2008-02-08 21:04:05 UTC (rev 30020)
@@ -1,4 +1,6 @@
+ \file delete.c
\brief Vedit library - delete features
Modified: grass/trunk/vector/v.edit/lib/distance.c
--- grass/trunk/vector/v.edit/lib/distance.c 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/lib/distance.c 2008-02-08 21:04:05 UTC (rev 30020)
@@ -1,4 +1,6 @@
+ \file distance.c
\brief Vedit library - distance calculation
Modified: grass/trunk/vector/v.edit/lib/flip.c
--- grass/trunk/vector/v.edit/lib/flip.c 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/lib/flip.c 2008-02-08 21:04:05 UTC (rev 30020)
@@ -1,4 +1,6 @@
+ \file flip.c
\brief Vedit library - lines flipping
Modified: grass/trunk/vector/v.edit/lib/merge.c
--- grass/trunk/vector/v.edit/lib/merge.c 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/lib/merge.c 2008-02-08 21:04:05 UTC (rev 30020)
@@ -1,4 +1,6 @@
+ \file merge.c
\brief Vedit library - merge lines
Modified: grass/trunk/vector/v.edit/lib/move.c
--- grass/trunk/vector/v.edit/lib/move.c 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/lib/move.c 2008-02-08 21:04:05 UTC (rev 30020)
@@ -1,4 +1,6 @@
+ \file move.c
\brief Vedit library - snapping
Modified: grass/trunk/vector/v.edit/lib/snap.c
--- grass/trunk/vector/v.edit/lib/snap.c 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/lib/snap.c 2008-02-08 21:04:05 UTC (rev 30020)
@@ -1,4 +1,6 @@
+ \file snap.c
Modified: grass/trunk/vector/v.edit/lib/vedit.h
--- grass/trunk/vector/v.edit/lib/vedit.h 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/lib/vedit.h 2008-02-08 21:04:05 UTC (rev 30020)
@@ -28,6 +28,10 @@
int Vedit_copy_lines (struct Map_info *, struct Map_info *,
struct ilist *);
+/* chtype.c */
+int Vedit_chtype_lines(struct Map_info *, struct ilist *,
+ int *, int *, int *, int *);
/* delete.c */
int Vedit_delete_lines(struct Map_info *, struct ilist *);
Modified: grass/trunk/vector/v.edit/lib/vertex.c
--- grass/trunk/vector/v.edit/lib/vertex.c 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/lib/vertex.c 2008-02-08 21:04:05 UTC (rev 30020)
@@ -1,4 +1,6 @@
+ \file vertex.c
\brief Vedit library - vertex manipulation
Modified: grass/trunk/vector/v.edit/lib/zbulk.c
--- grass/trunk/vector/v.edit/lib/zbulk.c 2008-02-08 20:35:54 UTC (rev 30019)
+++ grass/trunk/vector/v.edit/lib/zbulk.c 2008-02-08 21:04:05 UTC (rev 30020)
@@ -1,4 +1,6 @@
+ \file zbulk.c
\brief Vedit library - Bulk labeling (automated labeling of vector features)
