[GRASS-SVN] r30066 - grass/branches/releasebranch_6_3/lib/init
svn_grass at osgeo.org
Sun Feb 10 14:30:14 EST 2008
Author: neteler
Date: 2008-02-10 14:30:14 -0500 (Sun, 10 Feb 2008)
New Revision: 30066
grass/branches/releasebranch_6_3/lib/init/grass-xterm-wrapper
Revert bogus Terminal.app changes; Add missing quotes around variable substitutions (merge form HEAD)
Modified: grass/branches/releasebranch_6_3/lib/init/grass-xterm-wrapper
--- grass/branches/releasebranch_6_3/lib/init/grass-xterm-wrapper 2008-02-10 19:21:39 UTC (rev 30065)
+++ grass/branches/releasebranch_6_3/lib/init/grass-xterm-wrapper 2008-02-10 19:30:14 UTC (rev 30066)
@@ -1,90 +1,9 @@
#!/bin/sh
-# script to wrap xterm
-# handles OSX Terminal as a special emulated case
+# script to wrap xterm
-SYSTEM=`uname -s`
-case $SYSTEM in
-Darwin*)
- MACOSX=1
-esac
if [ -z "$GRASS_XTERM" ] ; then
- if [ "$MACOSX" ] ; then
- GRASS_XTERM=Terminal.app
- else
- GRASS_XTERM=xterm
- fi
+ GRASS_XTERM=xterm
fi
-case $GRASS_XTERM in
-*xterm)
- # the basic way or on other platform than OSX - run command
- exec $GRASS_XTERM "$@"
-*Terminal.app)
- # manually transfer the necessary env vars
- TMPSCRIPT="/tmp/grassxterm_$$"
- touch "$TMPSCRIPT.sh"
- chmod +x "$TMPSCRIPT.sh"
- echo "#!/bin/sh" > "$TMPSCRIPT.sh"
- echo "DISPLAY=$DISPLAY" >> "$TMPSCRIPT.sh"
- echo "PATH=\"$PATH\"" >> "$TMPSCRIPT.sh"
- echo "GIS_LOCK=\"$GIS_LOCK\"" >> "$TMPSCRIPT.sh"
- echo "GISRC=\"$GISRC\"" >> "$TMPSCRIPT.sh"
- echo "GISBASE=\"$GISBASE\"" >> "$TMPSCRIPT.sh"
- echo "GRASS_VERSION=\"$GRASS_VERSION\"" >> "$TMPSCRIPT.sh"
- echo "GRASS_PAGER=$GRASS_PAGER" >> "$TMPSCRIPT.sh"
- echo "DYLD_LIBRARY_PATH=\"$DYLD_LIBRARY_PATH\"" >> "$TMPSCRIPT.sh"
- echo "GRASS_LD_LIBRARY_PATH=\"$GRASS_LD_LIBRARY_PATH\"" >> "$TMPSCRIPT.sh"
- echo "GRASS_WISH=\"$GRASS_WISH\"" >> "$TMPSCRIPT.sh"
- echo "GRASS_TCLSH=\"$GRASS_TCLSH\"" >> "$TMPSCRIPT.sh"
- echo "GRASS_HTML_BROWSER=\"$GRASS_HTML_BROWSER\"" >> "$TMPSCRIPT.sh"
- echo "GRASS_HTML_BROWSER_MACOSX=\"$GRASS_HTML_BROWSER_MACOSX\"" >> "$TMPSCRIPT.sh"
- echo "export DISPLAY PATH GIS_LOCK GISRC GISBASE GRASS_VERSION GRASS_PAGER DYLD_LIBRARY_PATH GRASS_LD_LIBRARY_PATH GRASS_WISH GRASS_TCLSH GRASS_HTML_BROWSER GRASS_HTML_BROWSER_MACOSX" >> "$TMPSCRIPT.sh"
- if [ "$GRASS_ADDON_PATH" ] ; then
- echo "GRASS_ADDON_PATH=\"$GRASS_ADDON_PATH\"" >> "$TMPSCRIPT.sh"
- echo "export GRASS_ADDON_PATH" >> "$TMPSCRIPT.sh"
- fi
- if [ "$TCL_LIBRARY" ] ; then
- echo "TCL_LIBRARY=\"$TCL_LIBRARY\"" >> "$TMPSCRIPT.sh"
- echo "export TCL_LIBRARY" >> "$TMPSCRIPT.sh"
- fi
- if [ "$TK_LIBRARY" ] ; then
- echo "TK_LIBRARY=\"$TK_LIBRARY\"" >> "$TMPSCRIPT.sh"
- echo "export TK_LIBRARY" >> "$TMPSCRIPT.sh"
- fi
- # get command, ignore all other xterm flags
- while true ; do
- if [ "$1" = "-e" ] ; then break ; fi
- shift
- done
- shift
- # and add it to end of script
- echo "$@" >> "$TMPSCRIPT.sh"
- # execute
- # save current active app/window, return to it when script finishes.
- osascript - <<EOF
---tell application "System Events"
--- set save_app to item 1 of (get name of processes whose frontmost is true)
---end tell
-tell application "Terminal"
- activate
- -- start new window with env/cmd script
- do script "$TMPSCRIPT.sh; exit"
- tell window 1
- -- wait for it to finish
- repeat while (processes is not equal to {})
- delay 1
- end repeat
- close
- end tell
-end tell
---tell application save_app to activate
-EOF
- rm -f "$TMPSCRIPT.sh"
-esac
+# run command
+exec "$GRASS_XTERM" "$@"
