[GRASS-SVN] r30228 - in grass/trunk/gui/wxpython: gui_modules vdigit
Mon Feb 18 07:04:58 EST 2008
Author: martinl
Date: 2008-02-18 07:04:57 -0500 (Mon, 18 Feb 2008)
New Revision: 30228
   grass/trunk/gui/wxpython/gui_modules/digit.py
   grass/trunk/gui/wxpython/vdigit/cats.cpp
wxGUI/vdigit: Copy objects from background vector map enabled also for vdigit component (already functional in vedit)
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py	2008-02-18 10:12:35 UTC (rev 30227)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py	2008-02-18 12:04:57 UTC (rev 30228)
@@ -232,6 +232,39 @@
         return type
+    def SelectLinesFromBackgroundMap(self, pos1, pos2):
+        """Select features from background map
+        @param pos1,pos2 bounding box defifinition
+        if self.settings['backgroundMap'] == '':
+            Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): []")
+            return []
+        x1, y1 = pos1
+        x2, y2 = pos2
+        vEditCmd = gcmd.Command(['v.edit',
+                                 '--q',
+                                 'map=%s' % self.settings['backgroundMap'],
+                                 'tool=select',
+                                 'bbox=%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1])])
+                                 #'polygon=%f,%f,%f,%f,%f,%f,%f,%f,%f,%f' % \
+                                 #    (x1, y1, x2, y1, x2, y2, x1, y2, x1, y1)])
+        try:
+            output = vEditCmd.ReadStdOutput()[0] # first line
+            ids = output.split(',')
+            ids = map(int, ids) # str -> int
+        except:
+            return []
+        Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): %s" % \
+                      ",".join(["%d" % v for v in ids]))
+        return ids
 class VEdit(AbstractDigit):
     Prototype of digitization class based on v.edit command
@@ -688,39 +721,6 @@
         return True
-    def SelectLinesFromBackgroundMap(self, pos1, pos2):
-        """Select features from background map
-        @param pos1,pos2 bounding box defifinition
-        if self.settings['backgroundMap'] == '':
-            Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): []")
-            return []
-        x1, y1 = pos1
-        x2, y2 = pos2
-        vEditCmd = gcmd.Command(['v.edit',
-                                 '--q',
-                                 'map=%s' % self.settings['backgroundMap'],
-                                 'tool=select',
-                                 'bbox=%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1])])
-                                 #'polygon=%f,%f,%f,%f,%f,%f,%f,%f,%f,%f' % \
-                                 #    (x1, y1, x2, y1, x2, y2, x1, y2, x1, y1)])
-        try:
-            output = vEditCmd.ReadStdOutput()[0] # first line
-            ids = output.split(',')
-            ids = map(int, ids) # str -> int
-        except:
-            return []
-        Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): %s" % \
-                      ",".join(["%d" % v for v in ids]))
-        return ids
     def SelectLinesByQuery(self, pos1, pos2):
         """Select features by query
@@ -770,9 +770,9 @@
     def GetLayers(self):
         """Return list of layers"""
         layerCommand = gcmd.Command(cmd=["v.db.connect",
-                                             "-g", "--q",
-                                             "map=%s" % self.map],
-                                        rerr=None, stderr=None)
+                                         "-g", "--q",
+                                         "map=%s" % self.map],
+                                    rerr=None, stderr=None)
         if layerCommand.returncode == 0:
             layers = []
             for line in layerCommand.ReadStdOutput():
@@ -780,7 +780,7 @@
                 layers.append(int(lineList[0]))
             return layers
-        return [1]
+        return [1,]
 class VDigit(AbstractDigit):
@@ -972,7 +972,7 @@
         @param ids list of line ids to be copied
-        return self.digit.CopyLines(ids, self.settings['backgroundMap'])
+        return self.digit.CopyLines(ids, str(self.settings['backgroundMap']))
     def CopyCats(self, cats, ids):
         """Copy given categories to objects with id listed in ids
Modified: grass/trunk/gui/wxpython/vdigit/cats.cpp
--- grass/trunk/gui/wxpython/vdigit/cats.cpp	2008-02-18 10:12:35 UTC (rev 30227)
+++ grass/trunk/gui/wxpython/vdigit/cats.cpp	2008-02-18 12:04:57 UTC (rev 30228)
@@ -54,6 +54,9 @@
     for (int i = 0; i < nfields; i++ ) {
 	field = Vect_cidx_get_field_number(display->mapInfo, i);
 	ncats = Vect_cidx_get_num_cats_by_index(display->mapInfo, i);
+	if (field <= 0) {
+	    continue;
 	for (int j = 0; j < ncats; j++) {
 	    Vect_cidx_get_cat_by_index (display->mapInfo, i, j, &cat, &type, &id);
 	    if (cat > cats[field])
