[GRASS-SVN] r30229 - grass/trunk/raster/r.in.gdal
svn_grass at osgeo.org
Mon Feb 18 07:30:32 EST 2008
Author: neteler
Date: 2008-02-18 07:30:31 -0500 (Mon, 18 Feb 2008)
New Revision: 30229
grass/trunk/raster/r.in.gdal/description.html
better use 'location' parm
Modified: grass/trunk/raster/r.in.gdal/description.html
--- grass/trunk/raster/r.in.gdal/description.html 2008-02-18 12:04:57 UTC (rev 30228)
+++ grass/trunk/raster/r.in.gdal/description.html 2008-02-18 12:30:31 UTC (rev 30229)
@@ -228,10 +228,8 @@
<i>"ERROR: Projection of dataset does not appear to match the current location."</i><br>
You need to create a location whose projection matches the data you
-wish to import. Try using <em>g.proj</em> with the <em>-c</em> flag and the
-<em>location=</em> and <em>georef=</em> options to create a new location based
-upon the projection information in the file. You should then be able to import the
-file into that location with <em>r.in.gdal</em>. If desired, you can then re-project
+wish to import. Try using <em>location</em> parameter to create a new location based
+upon the projection information in the file. If desired, you can then re-project
it to another location with <em>r.proj</em>.
<H2>SEE ALSO</H2>
@@ -247,11 +245,6 @@
GDAL Pages: <a href="http://www.gdal.org">http://www.gdal.org/</a><br>
-<em>
-<a href="g.proj.html">g.proj</a>
-<em>
<H2>AUTHOR</H2>
<a href="http://home.gdal.org/warmerda/">Frank Warmerdam</a> (<a href="mailto:warmerdam AT pobox dot com">email</a>).
