[GRASS-SVN] r30340 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Feb 24 18:31:57 EST 2008
Author: martinl
Date: 2008-02-24 18:31:57 -0500 (Sun, 24 Feb 2008)
New Revision: 30340
grass/trunk/gui/wxpython/gui_modules/render.py
wxGUI: using gcmd.Command for g.pnmcomp doesn't not work for single map layers, back to os.system
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-02-24 22:54:42 UTC (rev 30339)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-02-24 23:31:57 UTC (rev 30340)
@@ -606,15 +606,23 @@
Debug.msg (3, "Map.Render() type=%s, layer=%s " % (layer.type, layer.name))
# compose command
- compcmd = ["g.pnmcomp",
- "in=%s" % ",".join(maps),
- "mask=%s" % ",".join(masks),
- "opacity=%s" % repr(",".join(opacities)),
- "background=255:255:255",
- "width=%s" % str(self.width),
- "height=%s" % str(self.height),
- "output=%s" % self.mapfile]
+ # compcmd = ["g.pnmcomp",
+ # "in='%s'" % ",".join(maps),
+ # "mask=%s" % ",".join(masks),
+ # "opacity=%s" % ",".join(opacities),
+ # "background=255:255:255",
+ # "width=%s" % str(self.width),
+ # "height=%s" % str(self.height),
+ # "output=%s" % self.mapfile]
+ compcmd = "g.pnmcomp in='" + ",".join(maps) + \
+ "' mask='" + ",".join(masks) + \
+ "' opacity=" + ",".join(opacities)+ \
+ " background=255:255:255" + \
+ " width=" + str(self.width) + \
+ " height=" + str(self.height) + \
+ " output='" + self.mapfile + "'"
# render overlays
os.unsetenv("GRASS_REGION")
@@ -624,7 +632,8 @@
# run g.composite to get composite image
try:
- gcmd.Command(compcmd)
+ # gcmd.Command(compcmd)
+ os.system(compcmd)
except gcmd.CmdError, e:
print e
return None
