[GRASS-SVN] r30341 - grass/trunk/general/manage/cmd
svn_grass at osgeo.org
Mon Feb 25 01:20:39 EST 2008
Author: glynn
Date: 2008-02-25 01:20:38 -0500 (Mon, 25 Feb 2008)
New Revision: 30341
grass/trunk/general/manage/cmd/remove.c
Only perform reclass check for rasters.
Modified: grass/trunk/general/manage/cmd/remove.c
--- grass/trunk/general/manage/cmd/remove.c 2008-02-24 23:31:57 UTC (rev 30340)
+++ grass/trunk/general/manage/cmd/remove.c 2008-02-25 06:20:38 UTC (rev 30341)
@@ -24,6 +24,74 @@
#include "list.h"
#include "local_proto.h"
+static int
+check_reclass(const char *name, const char *mapset, int force)
+ char rname[GNAME_MAX], rmapset[GMAPSET_MAX];
+ char **rmaps;
+ int nrmaps;
+ if (G_is_reclassed_to(name, mapset, &nrmaps, &rmaps) > 0)
+ for ( ; *rmaps; rmaps++)
+ /* force remove */
+ if (force)
+ G_warning(
+ _("[%s@%s] is a base map for [%s]. Remove forced."),
+ name, mapset, *rmaps);
+ else
+ G_warning(
+ _("[%s@%s] is a base map. Remove reclassed map first: %s"),
+ if (!force)
+ return 1;
+ if (G_is_reclass(name, mapset, rname, rmapset) > 0 &&
+ G_is_reclassed_to(rname, rmapset, &nrmaps, &rmaps) > 0)
+ char path[GPATH_MAX];
+ char *p = strchr(rname, '@');
+ char *qname = G_fully_qualified_name(name, mapset);
+ if (p)
+ *p = '\0';
+ G__file_name_misc(path, "cell_misc", "reclassed_to", rname, rmapset);
+ if(nrmaps == 1 && !G_strcasecmp(rmaps[0], qname))
+ if (remove(path) < 0)
+ G_warning(
+ _("Removing information about reclassed map from [%s@%s] failed"),
+ rname, rmapset);
+ else
+ FILE *fp = fopen(path, "w");
+ if (fp)
+ if (G_strcasecmp(*rmaps, qname))
+ fprintf(fp, "%s\n", *rmaps);
+ fclose(fp);
+ else
+ G_warning(
+ rname, rmapset);
+ return 0;
int
main (int argc, char *argv[])
@@ -32,10 +100,7 @@
struct Option **parm, *p;
struct Flag *force_flag;
char *name, *mapset;
- char rname[256], rmapset[256];
- int nrmaps;
- char **rmaps, *location_path;
- FILE *fp;
+ char *location_path;
int result = EXIT_SUCCESS;
int force = 0;
@@ -80,62 +145,10 @@
if (parm[n]->answers)
for (i = 0; (name = parm[n]->answers[i]); i++)
- if(G_is_reclassed_to(name, mapset, &nrmaps, &rmaps) > 0)
- for(; *rmaps; rmaps++) {
- /* force remove */
- if ( force ) {
- G_warning(
- _("[%s@%s] is a base map for [%s]. Remove forced."),
- name, mapset, *rmaps);
- else {
- G_warning(
- _("[%s@%s] is a base map. Remove reclassed map first: %s"),
- if ( !force )
- continue;
- if(G_is_reclass(name, mapset, rname, rmapset) > 0 &&
- G_is_reclassed_to(rname, rmapset, &nrmaps, &rmaps) > 0)
- char path[GPATH_MAX];
- char *p = strchr(rname, '@');
- char *qname = G_fully_qualified_name(name, mapset);
- if (p)
- *p = '\0';
- G__file_name_misc(path, "cell_misc", "reclassed_to", rname, rmapset);
+ if (G_strcasecmp(list[n].alias, "rast") == 0 &&
+ check_reclass(name, mapset, force))
+ continue;
- if(nrmaps == 1 && !G_strcasecmp(rmaps[0], qname))
- if ( remove(path) < 0 ) {
- G_warning(
- _("Removing information about reclassed map from [%s@%s] failed"),
- rname, rmapset);
- else
- if ( (fp = fopen(path, "w")) ) {
- if(G_strcasecmp(*rmaps, qname))
- fprintf(fp, "%s\n", *rmaps);
- fclose(fp);
- else {
- G_warning(
- rname, rmapset);
if ( do_remove (n, name) == 1 )
result = EXIT_FAILURE;
