[GRASS-SVN] r30378 - in grass/trunk: include lib/vector/Vlib
svn_grass at osgeo.org
Wed Feb 27 14:34:16 EST 2008
Author: martinl
Date: 2008-02-27 14:34:16 -0500 (Wed, 27 Feb 2008)
New Revision: 30378
grass/trunk/include/Vect.h
grass/trunk/lib/vector/Vlib/dangles.c
vectlib: Vect_select_dangle() added, used by v.edit query=dangle/wxGUI
Modified: grass/trunk/include/Vect.h
--- grass/trunk/include/Vect.h 2008-02-27 18:58:20 UTC (rev 30377)
+++ grass/trunk/include/Vect.h 2008-02-27 19:34:16 UTC (rev 30378)
@@ -277,6 +277,7 @@
void Vect_snap_lines_list (struct Map_info *, struct ilist *, double, struct Map_info *, FILE *);
void Vect_remove_dangles ( struct Map_info *, int, double, struct Map_info *, FILE * );
void Vect_chtype_dangles ( struct Map_info *, double, struct Map_info *, FILE * );
+void Vect_select_dangles (struct Map_info *, int, double, FILE *, struct ilist *);
void Vect_remove_bridges ( struct Map_info *, struct Map_info *, FILE * );
void Vect_chtype_bridges ( struct Map_info *, struct Map_info *, FILE * );
int Vect_remove_small_areas ( struct Map_info *, double, struct Map_info *, FILE *, double * );
Modified: grass/trunk/lib/vector/Vlib/dangles.c
--- grass/trunk/lib/vector/Vlib/dangles.c 2008-02-27 18:58:20 UTC (rev 30377)
+++ grass/trunk/lib/vector/Vlib/dangles.c 2008-02-27 19:34:16 UTC (rev 30378)
@@ -22,21 +22,29 @@
#include <grass/Vect.h>
#include <grass/glocale.h>
-static void remove_dangles ( struct Map_info *Map, int type, int chtype, double maxlength,
- struct Map_info *Err, FILE *msgout );
+#define REMOVE_DANGLE 0
+#define CHTYPE_DANGLE 1
+#define SELECT_DANGLE 2
+static void dangles ( struct Map_info *, int, int, double,
+ struct Map_info *, FILE *, struct ilist *);
\brief Remove dangles from vector map.
- Remove dangles of given type shorter than maxlength from vector map.
- Line is considered to be a dangle if on at least one end node is no other line of given type(s).
- If a dangle is formed by more lines, such string of lines is taken as one dangle and
- either deleted are all parts or nothing.
+ Remove dangles of given type shorter than maxlength from vector map.
+ Line is considered to be a dangle if on at least one end node is no
+ other line of given type(s). If a dangle is formed by more lines,
+ such string of lines is taken as one dangle and either deleted are
+ all parts or nothing.
Optionaly deleted dangles are written to error map.
Input map must be opened on level 2 for update.
\param Map input map where have to be deleted
- \param type type of dangles
+ \param type type of dangles (GV_LINES, GV_LINE or GV_BOUNDARY)
\param maxlength maxlength of dangles or -1 for all dangles
\param Err vector map where deleted dangles are written or NULL
\param msgout file pointer where messages will be written or NULL
@@ -46,21 +54,23 @@
void
Vect_remove_dangles ( struct Map_info *Map, int type, double maxlength, struct Map_info *Err, FILE *msgout )
- remove_dangles ( Map, type, 0, maxlength, Err, msgout );
+ dangles ( Map, type, REMOVE_DANGLE, maxlength, Err, msgout, NULL);
\brief Change boundary dangles to lines.
- Boundary is considered to be a dangle if on at least one end node is no other boundary.
- If a dangle is formed by more boundaries, such string of boundaries is taken as one dangle and
+ Boundary is considered to be a dangle if on at least one end node is
+ no other boundary. If a dangle is formed by more boundaries, such
+ string of boundaries is taken as one dangle.
Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
@@ -70,29 +80,55 @@
void
Vect_chtype_dangles ( struct Map_info *Map, double maxlength, struct Map_info *Err, FILE *msgout )
- remove_dangles ( Map, 0, 1, maxlength, Err, msgout );
+ dangles ( Map, 0, CHTYPE_DANGLE, maxlength, Err, msgout, NULL);
+ \brief Select dangles from vector map.
+ such string of lines is taken as one dangle.
+ Input map must be opened on level 2 for update.
+ \param Map input map where have to be deleted
+ \param maxlength maxlength of dangles or -1 for all dangles
+ \param msgout file pointer where messages will be written or NULL
+ \return
+void
+Vect_select_dangles (struct Map_info *Map, int type, double maxlength, FILE *msgout,
+ struct ilist *List)
+ dangles ( Map, type, SELECT_DANGLE, maxlength, NULL, msgout, List);
- Optionaly, if chtype is set to 1, only GV_BOUNDARY are checked for dangles, and if dangle is found
- lines are not deleted but rewritten with type GVLINE.
- Optionaly deleted dangles are written to error map.
- Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
+ all parts or nothing. Optionaly, if chtype is set to 1, only
+ GV_BOUNDARY are checked for dangles, and if dangle is found lines
+ are not deleted but rewritten with type GVLINE. Optionaly deleted
+ dangles are written to error map. Input map must be opened on level
+ 2 for update at least on GV_BUILD_BASE.
Parameters:
- chtype change boundaries to lines
+ option dangle option (REMOVE_DANGLE, CHTYPE_DANGLE, SELECT_DANGLE)
+ List_dangle list of feature (selected dangles) ids
-static void
-remove_dangles ( struct Map_info *Map, int type, int chtype, double maxlength, struct Map_info *Err, FILE *msgout )
+static void dangles ( struct Map_info *Map, int type, int option, double maxlength,
+ struct Map_info *Err, FILE *msgout, struct ilist *List_dangle)
struct line_pnts *Points;
struct line_cats *Cats;
@@ -100,31 +136,42 @@
int nnodes, node, node1, node2, next_node;
int lcount, tmp_next_line=0;
double length;
- int dangles_removed = 0; /* number of removed dangles */
- int lines_removed = 0; /* number of lines removed */
- struct ilist *List; /* List of lines in chain */
+ int dangles_removed; /* number of removed dangles */
+ int lines_removed; /* number of lines removed */
+ struct ilist *List; /* List of lines in chain */
char *lmsg;
+ next_line = tmp_next_line = 0;
+ dangles_removed = 0;
+ lines_removed = 0;
type &= GV_LINES; /* to work only with lines and boundaries */
- if ( chtype ) {
+ if ( option == CHTYPE_DANGLE ) {
type = GV_BOUNDARY; /* process boundaries only */
lmsg = "changed lines";
- } else {
+ } else if ( option == REMOVE_DANGLE ) {
lmsg = "removed lines";
+ else {
+ lmsg = "selected lines";
+ if (List_dangle)
+ Vect_reset_list(List_dangle);
Points = Vect_new_line_struct ();
Cats = Vect_new_cats_struct ();
List = Vect_new_list ();
- if ( msgout ) fprintf (msgout, "%s: %5d %s: %5d",
- _("Removed dangles"), dangles_removed, lmsg, lines_removed );
+ if ( msgout )
+ fprintf (msgout, "%s %5d %s: %5d",
+ _("Removed dangles:"), dangles_removed, lmsg, lines_removed);
nnodes = Vect_get_num_nodes (Map);
G_debug (2, "nnodes = %d", nnodes );
- for ( node = 1; node <= nnodes; node++ ){
+ for ( node = 1; node <= nnodes; node++ ) {
G_debug (3, "node = %d", node);
if ( !Vect_node_alive (Map, node) ) continue;
@@ -186,7 +233,7 @@
if ( maxlength < 0 || length < maxlength ) { /* delete the chain */
- G_debug (3, " delete the chain" );
+ G_debug (3, " delete the chain (length=%g)", length);
for ( i = 0; i < List->n_values; i++) {
ltype = Vect_read_line (Map, Points, Cats, List->value[i]);
@@ -196,28 +243,35 @@
Vect_write_line ( Err, ltype, Points, Cats );
- if ( !chtype ) {
+ if ( option == REMOVE_DANGLE ) {
Vect_delete_line (Map, List->value[i]);
- } else {
+ } else if (option == CHTYPE_DANGLE) {
G_debug (3, " rewrite line %d", List->value[i] );
Vect_rewrite_line ( Map, List->value[i], GV_LINE, Points, Cats);
+ else {
+ if (List_dangle) {
+ Vect_list_append(List_dangle, List->value[i]);
lines_removed++;
+ } /* delete the chain */
if ( msgout ) {
- if ( msgout ) fprintf (msgout, "\r%s: %5d %s: %5d",
+ if ( msgout ) fprintf (msgout, "\r%s %5d %s: %5d",
+ _("Removed dangles:"), dangles_removed, lmsg, lines_removed );
fflush ( msgout );
dangles_removed++;
+ } /* lcount == 1 */
+ } /* node <= nnodes */
if ( msgout ) {
+ if ( msgout )
+ fprintf (msgout, "\r%s %5d %s: %5d",
fprintf (msgout, "\n" );
