[GRASS-SVN] r30379 - grass/trunk/lib/vector/vedit
svn_grass at osgeo.org
Wed Feb 27 14:38:06 EST 2008
Author: martinl
Date: 2008-02-27 14:38:06 -0500 (Wed, 27 Feb 2008)
New Revision: 30379
grass/trunk/lib/vector/vedit/select.c
veditlib: use Vect_select_dangles() for selecting dangles
Modified: grass/trunk/lib/vector/vedit/select.c
--- grass/trunk/lib/vector/vedit/select.c 2008-02-27 19:34:16 UTC (rev 30378)
+++ grass/trunk/lib/vector/vedit/select.c 2008-02-27 19:38:06 UTC (rev 30379)
@@ -14,22 +14,16 @@
#include <grass/vedit.h>
-static int select_by_query(struct Map_info *, int, int, int,
- int, double,
- struct line_pnts *, struct line_cats *);
+static int select_by_query(struct Map_info *, int, int, double,
+ int, struct line_pnts *, struct line_cats *);
- \brief Select features by query (based on geometry)
+ \brief Select features by query (based on geometry properties)
Currently supported:
- - QUERY_LENGTH, select all lines longer then threshold (or shorter if threshold is negative)
- - QUERY_DANGLE, select all dangles then threshold (or shorter if threshold is negative)
+ - QUERY_LENGTH, select all features longer then threshold (or shorter if threshold is negative)
+ - QUERY_DANGLE, select all dangles longer then threshold (or shorter if threshold is negative)
- If <em>List</em> is not empty query only those feature, otherwise query all
- vector features stored in the vector map.
- \todo Rewrite dangle part to use Vector library functionality
\param[in] Map vector map
\param[in] type feature type
\param[in] layer layer number
@@ -44,6 +38,7 @@
struct ilist* List)
int num, line, i;
+ double thresh_tmp;
struct line_pnts *Points;
struct line_cats *Cats;
struct ilist *List_query;
@@ -53,34 +48,35 @@
List_query = Vect_new_list();
- if (List->n_values > 0) { /* query only selected */
- for (i = 0; i < List->n_values; i++) {
- line = List->value[i];
- if (select_by_query(Map, line, type, layer,
- query, thresh,
- Points, Cats) == 1) {
- if (!Vect_val_in_list(List, line)) {
- Vect_list_append(List, line);
- else {
- if (Vect_val_in_list(List, line)) {
- Vect_list_delete(List, line);
- i--;
- else { /* global query */
+ switch (query) {
+ case QUERY_LENGTH: {
num = Vect_get_num_lines (Map);
for (line = 1; line <= num; line++) {
- query, thresh,
+ if (select_by_query(Map, line, type, thresh,
+ query, Points, Cats))
+ break;
+ case QUERY_DANGLE: {
+ thresh_tmp = fabs(thresh);
+ Vect_select_dangles (Map, type, thresh_tmp, stderr,
+ List_query);
+ if (thresh <= 0.0) { /* shorter than */
+ for(i = 0; i < List_query->n_values; i++) {
+ Vect_list_append(List, List_query->value[i]);
+ else { /* longer than */
+ for(i = 1; i <= Vect_get_num_lines(Map); i++) {
+ if (!Vect_val_in_list(List_query, i))
+ Vect_list_append(List, i);
+ break;
+ default: break;
G_debug (3, "Vedit_select_by_query(): %d lines selected (by query %d)", List -> n_values, query);
@@ -92,24 +88,22 @@
- \brief Query given line
+ \brief Query given feature
\return 1 line test positive
\return 0 line test negative
\return -1 on error (line is dead)
-static int select_by_query(struct Map_info *Map, int line, int type, int layer,
- int query, double thresh,
- struct line_pnts* Points, struct line_cats* Cats)
+static int select_by_query(struct Map_info *Map, int line, int type, double thresh,
+ int query, struct line_pnts *Points, struct line_cats *Cats)
- int ltype, cat;
+ int ltype;
double length;
if (!Vect_line_alive(Map, line))
return -1;
ltype = Vect_read_line(Map, Points, Cats, line);
- Vect_cat_get(Cats, layer, &cat); /* get first category from layer */
if (!(ltype & type))
return -1;
@@ -126,6 +120,13 @@
else if (query == QUERY_DANGLE) {
+ this code is currently replaced by Vect_select_dangle()
+ not used by v.edit
+ int layer, cat;
+ layer = 1;
+ Vect_cat_get(Cats, layer, &cat); /* get first category from layer */
if (!(type & GV_LINES))
return -1;
/* check if line is dangle */
