[GRASS-SVN] r29567 - grass/trunk/locale/po
svn_grass at osgeo.org
Sat Jan 5 05:59:25 EST 2008
Author: cdavilam
Date: 2008-01-05 05:59:24 -0500 (Sat, 05 Jan 2008)
New Revision: 29567
grass/trunk/locale/po/grasstcl_pt_br.po
Translations by Fernando Ferreira
Modified: grass/trunk/locale/po/grasstcl_pt_br.po
--- grass/trunk/locale/po/grasstcl_pt_br.po 2008-01-05 00:36:24 UTC (rev 29566)
+++ grass/trunk/locale/po/grasstcl_pt_br.po 2008-01-05 10:59:24 UTC (rev 29567)
@@ -10,8 +10,8 @@
msgstr ""
"Project-Id-Version: grasstcl_pt_br\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2008-01-02 18:35-0200\n"
-"PO-Revision-Date: 2008-01-02 19:52-0200\n"
+"POT-Creation-Date: 2008-01-04 20:33-0200\n"
+"PO-Revision-Date: 2008-01-05 00:59-0200\n"
"Last-Translator: Fernando Ferreira <fernando at vps.fmvz.usp.br>\n"
"Language-Team: Brazilian Portuguese <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
@@ -748,7 +748,9 @@
#: ../gui/tcltk/d.m/menu.tcl:178
msgid "XWD (Save display, selected with mouse, to map.xwd in home directory )"
-msgstr "XWD (Salvar tela, selecionada com o mouse, para mapa.xwd no diretório pessoal)"
+msgstr ""
+"XWD (Salvar tela, selecionada com o mouse, para mapa.xwd no diretório "
+"pessoal)"
#: ../gui/tcltk/d.m/menu.tcl:179
msgid "Save displays to multiple graphic file formats"
@@ -937,9 +939,8 @@
msgstr "Reprojetar raster de outra locação"
#: ../gui/tcltk/d.m/menu.tcl:238
-#:, fuzzy
msgid "Generate tiling for other projection"
-msgstr "Gerar mosaico para outras projeções"
+msgstr "Gerar 'tile' para outras projeções"
#: ../gui/tcltk/d.m/menu.tcl:240 ../gui/tcltk/gis.m/gmmenu.tcl:248
msgid "Manage map colors"
@@ -980,7 +981,7 @@
#: ../gui/tcltk/d.m/menu.tcl:252
msgid "Create raster MASK"
-msgstr "Criar MASK raster"
+msgstr "Criar Máscara raster"
#: ../gui/tcltk/d.m/menu.tcl:253
msgid "Locate closest points between areas in 2 raster maps"
@@ -997,7 +998,7 @@
#: ../gui/tcltk/d.m/menu.tcl:256
msgid "Moving window analysis of raster cells"
-msgstr "Análise de janela móvel de células raster"
+msgstr "Análise de janela móvel das células raster"
#: ../gui/tcltk/d.m/menu.tcl:257
msgid "Analyze vector points in neighborhood of raster cells"
@@ -1148,7 +1149,7 @@
#: ../gui/tcltk/d.m/menu.tcl:301 ../gui/tcltk/gis.m/gmmenu.tcl:317
msgid "Landscape structure modeling"
-msgstr "Modelagem da estrutura do relevo"
+msgstr "Modelagem da estrutura da paisagem"
#: ../gui/tcltk/d.m/menu.tcl:302 ../gui/tcltk/gis.m/gmmenu.tcl:329
msgid "Set up sampling and analysis framework"
@@ -1156,7 +1157,7 @@
#: ../gui/tcltk/d.m/menu.tcl:304
msgid "Analyze landscape characteristics"
-msgstr "Analisar características do relevo"
+msgstr "Analisar características da paisagem"
#: ../gui/tcltk/d.m/menu.tcl:305
msgid "Analyze landscape patch characteristics"
@@ -1168,7 +1169,7 @@
#: ../gui/tcltk/d.m/menu.tcl:308 ../gui/tcltk/gis.m/gmmenu.tcl:348
msgid "Wildfire modeling"
-msgstr "Modelagem de incõndios florestais"
+msgstr "Modelagem de incêndios florestais"
#: ../gui/tcltk/d.m/menu.tcl:309
msgid "Generate rate of spread (ROS) maps"
@@ -1210,11 +1211,11 @@
#: ../gui/tcltk/d.m/menu.tcl:323
msgid "Recode categories using rules file (create new map)"
-msgstr "Recodificar categorias usando arquivo de regras (crias novo mapa)"
+msgstr "Recodificar categorias usando arquivo de regras (criar novo mapa)"
#: ../gui/tcltk/d.m/menu.tcl:325
msgid "Rescale categories (create new map)"
-msgstr "Reescalonar categorias (crias novo mapa)"
+msgstr "Reescalonar categorias (criar novo mapa)"
#: ../gui/tcltk/d.m/menu.tcl:326
msgid "Rescale categories with equalized histogram (create new map)"
@@ -1290,13 +1291,11 @@
#: ../gui/tcltk/d.m/menu.tcl:349
msgid "Regularized spline tension interpolation from vector points or contours"
-msgstr "Interpolar pontos ou isolinhas por tensão regularizada da spline"
+msgstr "Interpolar pontos ou isolinhas com spline regularizado com tensão"
#: ../gui/tcltk/d.m/menu.tcl:351
msgid "Fill NULL cells by interpolation using regularized spline tension"
-msgstr ""
-"Preencher células nulas através de interpolação por tensão regularizada da "
-"spline"
+msgstr "Preencher células nulas através de interpolação por spline regularizado com tensão"
#: ../gui/tcltk/d.m/menu.tcl:354 ../gui/tcltk/d.m/menu.tcl:459
#: ../gui/tcltk/d.m/menu.tcl:515 ../gui/tcltk/gis.m/gmmenu.tcl:398
@@ -1335,7 +1334,7 @@
#: ../gui/tcltk/d.m/menu.tcl:363 ../gui/tcltk/gis.m/gmmenu.tcl:407
msgid "Total surface area corrected for topography"
-msgstr "Superfície total da área corrigida pela topografia"
+msgstr "Área de superfície total corrigida pela topografia"
#: ../gui/tcltk/d.m/menu.tcl:364 ../gui/tcltk/d.m/menu.tcl:463
#: ../gui/tcltk/gis.m/gmmenu.tcl:408
@@ -1352,7 +1351,7 @@
#: ../gui/tcltk/d.m/menu.tcl:368
msgid "Sample values along transects (use azimuth, distance)"
-msgstr "Amostrar valores nos perfis (usa azimute, distância)"
+msgstr "Amostrar valores nos perfis (usar azimute, distância)"
#: ../gui/tcltk/d.m/menu.tcl:370 ../gui/tcltk/gis.m/gmmenu.tcl:413
msgid "Covariance/correlation"
@@ -1424,7 +1423,7 @@
#: ../gui/tcltk/d.m/menu.tcl:396 ../gui/tcltk/gis.m/gmmenu.tcl:620
msgid "Vector<->database connections"
-msgstr "Conexões vetor <-> base de dados"
+msgstr "Vetor <-> conexões com base de dados"
#: ../gui/tcltk/d.m/menu.tcl:397
msgid "Create new vector as link to external OGR layer"
@@ -2958,9 +2957,8 @@
msgstr "Georretificar"
#: ../gui/tcltk/gis.m/gmmenu.tcl:189
-#, fuzzy
msgid "Animate raster maps"
-msgstr "Animar série de mapas raster"
+msgstr "Animar série de mapas raster "
#: ../gui/tcltk/gis.m/gmmenu.tcl:191
msgid "Bearing/distance to coordinates"
@@ -3164,7 +3162,7 @@
#: ../gui/tcltk/gis.m/gmmenu.tcl:305 ../gui/tcltk/gis.m/gmmenu.tcl:585
msgid "Groundwater flow model"
-msgstr ""
+msgstr "Modelo de drenagem de terreno"
#: ../gui/tcltk/gis.m/gmmenu.tcl:308
msgid "SIMWE sediment flux modeling"
@@ -3428,9 +3426,8 @@
msgstr "Criar vetor 3D sobre raster"
#: ../gui/tcltk/gis.m/gmmenu.tcl:437
-#, fuzzy
msgid "Extrude 3D vector"
-msgstr "Extrudar vetor 2D para vetor 3D"
+msgstr "Extrudar vetor 3D"
#: ../gui/tcltk/gis.m/gmmenu.tcl:439
msgid "Link to OGR"
@@ -3441,9 +3438,8 @@
msgstr "Criar etiquetas"
#: ../gui/tcltk/gis.m/gmmenu.tcl:443
-#, fuzzy
msgid "Reposition vector"
-msgstr "Sítios (GRASS 5.x) para vetor"
+msgstr "Reposicionar vetor"
#: ../gui/tcltk/gis.m/gmmenu.tcl:444
msgid "Reproject vector"
@@ -3462,9 +3458,8 @@
msgstr "Pesquisar por atributos "
#: ../gui/tcltk/gis.m/gmmenu.tcl:452
-#, fuzzy
msgid "Query with coordinate(s)"
-msgstr "Pesquisar por coordenada(s)"
+msgstr "Pesquisar por coordenada(s) "
#: ../gui/tcltk/gis.m/gmmenu.tcl:453
msgid "Query with another map"
@@ -3500,7 +3495,7 @@
#: ../gui/tcltk/gis.m/gmmenu.tcl:463
msgid "Create stationing"
-msgstr ""
+msgstr "Criar estações"
#: ../gui/tcltk/gis.m/gmmenu.tcl:464
msgid "Create points/segments"
@@ -3508,16 +3503,15 @@
#: ../gui/tcltk/gis.m/gmmenu.tcl:465
msgid "Find ID and offset"
-msgstr ""
+msgstr "Encontrar ID e afastamento"
#: ../gui/tcltk/gis.m/gmmenu.tcl:467
msgid "Nearest features"
msgstr "Objetos mais próximos"
#: ../gui/tcltk/gis.m/gmmenu.tcl:471
-#, fuzzy
msgid "Visibility network"
-msgstr "Visibilidade"
+msgstr "Rede de visibilidade"
#: ../gui/tcltk/gis.m/gmmenu.tcl:473
msgid "Display shortest route"
@@ -3536,9 +3530,8 @@
msgstr "Remendar (combinar)"
#: ../gui/tcltk/gis.m/gmmenu.tcl:488
-#, fuzzy
msgid "Manage or report categories"
-msgstr "Anexar, apagar ou relatar categorias"
+msgstr "Gerenciar ou relatar categorias"
#: ../gui/tcltk/gis.m/gmmenu.tcl:489
msgid "Reclassify objects interactively"
@@ -3591,7 +3584,7 @@
#: ../gui/tcltk/gis.m/gmmenu.tcl:511
#, fuzzy
msgid "Update point attributes from areas"
-msgstr "editar atributos (modo formulário)"
+msgstr "Atualizar atributos dos pontos das áreas"
#: ../gui/tcltk/gis.m/gmmenu.tcl:512
#, fuzzy
