[GRASS-SVN] r29568 - grass/trunk/vector/v.distance
Sat Jan 5 06:22:14 EST 2008
Author: martinl
Date: 2008-01-05 06:22:13 -0500 (Sat, 05 Jan 2008)
New Revision: 29568
   grass/trunk/vector/v.distance/description.html
   grass/trunk/vector/v.distance/main.c
Fix bug GForge/378: v.distance: bogus distances for Lat/Lon locations (v.distance in a lat/lon location gives distances in degrees, which is useless in most cases as lat and lon are not equally scaled). For LL locations is used Vect_line_geodesic_length()
Modified: grass/trunk/vector/v.distance/description.html
--- grass/trunk/vector/v.distance/description.html	2008-01-05 10:59:24 UTC (rev 29567)
+++ grass/trunk/vector/v.distance/description.html	2008-01-05 11:22:13 UTC (rev 29568)
@@ -123,6 +123,9 @@
 null.
 <p>
 The upload <B>column</B>(s) must already exist. Create one with <em>v.db.addcol</em>.
+<p>
+In lat-long location <em>v.distance</em> gives distances (<b>dist</b>
+and <b>to_along</b>) in meters not in degrees.
 <H2>SEE ALSO</H2>
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c	2008-01-05 10:59:24 UTC (rev 29567)
+++ grass/trunk/vector/v.distance/main.c	2008-01-05 11:22:13 UTC (rev 29568)
@@ -68,7 +68,7 @@
 int main (int argc, char *argv[])
-    int    i, j;
+    int    i, j, k;
     int    print_as_matrix; /* only for all */
     int    all;             /* calculate from each to each within the threshold */
     char   *mapset;
@@ -471,6 +471,13 @@
     count = 0; /* count of distances in 'all' mode */
     /* Find nearest lines */
     if ( to_type & (GV_POINTS | GV_LINES) ) {
+	struct line_pnts *LLPoints;
+	if (G_projection() == PROJECTION_LL) {
+	    LLPoints = Vect_new_line_struct();
+	else {
+	    LLPoints = NULL;
 	for ( fline = 1; fline <= nfrom ; fline++ ) {
 	    int tmp_tcat;
 	    double tmp_tangle, tangle;
@@ -503,7 +510,20 @@
 		/* TODO: more cats of the same field */
 		Vect_cat_get(TCats, to_field, &tmp_tcat);
-	        G_debug (4, "  tmp_dist = %f tmp_tcat = %d", tmp_dist, tmp_tcat);
+		    /* calculate distances in meters not degrees (only 2D) */
+		    Vect_reset_line(LLPoints);
+		    Vect_append_point(LLPoints, FPoints->x[0], FPoints->y[0], FPoints->z[0]);
+		    Vect_append_point(LLPoints, tmp_tx, tmp_ty, tmp_tz);
+		    tmp_dist = Vect_line_geodesic_length(LLPoints);
+		    for (k = 0; k < tseg; k++)
+			Vect_append_point(LLPoints, TPoints->x[k], TPoints->y[k], TPoints->z[k]);
+		    tmp_talong = Vect_line_geodesic_length(LLPoints);
+		G_debug (4, "  tmp_dist = %f tmp_tcat = %d", tmp_dist, tmp_tcat);
 		if ( all ) {
 		    if ( anear <= count ) {
@@ -562,6 +582,9 @@
 		near->count++;
+	if (LLPoints) {
+	    Vect_destroy_line_struct(LLPoints);
     /* Find nearest areas */
