[GRASS-SVN] r29571 - grass/trunk/lib/gis
svn_grass at osgeo.org
Sat Jan 5 09:05:33 EST 2008
Author: martinl
Date: 2008-01-05 09:05:33 -0500 (Sat, 05 Jan 2008)
New Revision: 29571
grass/trunk/lib/gis/parser.c
GRASS_GUI can be defined as environment variable or internal GRASS variable.
Cosmetics in doxygen docs.
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c 2008-01-05 13:21:38 UTC (rev 29570)
+++ grass/trunk/lib/gis/parser.c 2008-01-05 14:05:33 UTC (rev 29571)
@@ -3,12 +3,12 @@
* \brief GIS library - Argument parsing functions.
+ * \author Radim Blazek
+ * \date 2003-2008 (C) The GRASS development team
* This program is free software under the GNU General Public License
* (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author Radim Blazek
- * \date 2003-2006
@@ -781,8 +781,8 @@
j++;
if ( !found ) {
- G_warning ( "BUG in descriptions, option %s in %s does not exist",
- tokens[i], opt->key );
+ G_warning (_("BUG in descriptions, option %s in %s does not exist"),
+ tokens[i], opt->key );
} else {
opt->descs[j] = G_store ( tokens[i+1] );
@@ -1261,6 +1261,9 @@
#undef do_escape
+ \brief Print module usage description in XML format.
static void G_usage_xml (void)
struct Option *opt ;
@@ -1477,6 +1480,9 @@
fprintf(stdout, "</task>\n");
+ \brief Print module usage description in HTML format.
static void G_usage_html (void)
@@ -1704,6 +1710,9 @@
fprintf(stdout, "</body>\n</html>\n");
+ \brief Print module usage description used in shell scripts.
static void G_script(void)
FILE *fp = stdout;
@@ -1817,6 +1826,11 @@
+ \brief Generates tcltk dialog.
+ \param[out] fp File to store tcltk code
static void generate_tcl(FILE *fp)
int new_prompt = uses_new_gisprompt();
@@ -1914,7 +1928,9 @@
fprintf(fp, "end_dialog %d\n", optn - 1);
-/* Build Tcl/Tk gui */
+ \brief Build Tcl/Tk GUI dialog
static void G_gui_tcltk (void)
FILE *fp;
@@ -1937,7 +1953,7 @@
#endif
if (!fp)
- G_fatal_error("unable to spawn wish");
+ G_fatal_error(_("Unable to spawn wish"));
fprintf(fp, "source $env(GISBASE)/etc/gui.tcl\n");
@@ -1946,32 +1962,48 @@
G_pclose(fp);
-/* Build wxPython gui */
+ \brief Build wxPython GUI dialog
static void G_gui_wx (void)
char script[GPATH_MAX];
if (!pgm_name)
- pgm_name = G_program_name ();
+ pgm_name = G_program_name ();
if (!pgm_name)
- G_fatal_error("unable to determine program name");
+ G_fatal_error(_("Unable to determine program name"));
sprintf(script, "%s/etc/wx/gui_modules/menuform.py", getenv("GISBASE"));
G_spawn("python", "menuform.py", script, pgm_name, NULL);
-/* Invoke gui */
+ \brief Invoke GUI dialog
+ Use G_gui_wx() or G_gui_tcltk() to generate GUI dialog.
+ G_gui_tcltk() is called by default (if GRASS_GUI is not defined)
static void G_gui (void)
- char *gui = getenv("GRASS_GUI");
+ /* read environment variables first then internal GRASS variable */
+ char *gui = getenv("GRASS_GUI");
+ if (!gui) {
+ gui = G_getenv("GRASS_GUI");
- if (gui && strcmp(gui, "wx") == 0)
- G_gui_wx();
- else
- G_gui_tcltk();
+ if (gui && strcmp(gui, "wx") == 0)
+ G_gui_wx();
+ else
+ G_gui_tcltk();
+ return;
-/* Send Tcl/Tk code to tcltkgrass */
+ \brief Send Tcl/Tk code to tcltkgrass
static void G_tcltk (void)
if (!pgm_name)
@@ -2538,7 +2570,7 @@
if ( G_find_file (element, opt->answer, G_mapset()) ) /* found */
if ( !overwrite && !over ) {
- fprintf(stderr,_("ERROR: option <%s>: <%s> exists.\n"),
+ fprintf(stderr, _("ERROR: option <%s>: <%s> exists.\n"),
opt->key, opt->answer );
error = 1;
@@ -2763,7 +2795,6 @@
return 0;
* \fn char *G_recreate_command (void)
@@ -2774,7 +2805,6 @@
* \retval char * Pointer to a char string
static char *buff;
@@ -2878,4 +2908,3 @@
return(buff) ;
