[GRASS-SVN] r29572 - in grass/trunk/raster: r.in.gdal r.out.gdal
svn_grass at osgeo.org
Sat Jan 5 09:20:15 EST 2008
Author: martinl
Date: 2008-01-05 09:20:15 -0500 (Sat, 05 Jan 2008)
New Revision: 29572
grass/trunk/raster/r.in.gdal/main.c
grass/trunk/raster/r.out.gdal/main.c
GUI section renamed from 'Main' to 'Required' to be less confusing
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c 2008-01-05 14:05:33 UTC (rev 29571)
+++ grass/trunk/raster/r.in.gdal/main.c 2008-01-05 14:20:15 UTC (rev 29572)
@@ -86,11 +86,11 @@
parm.input->description = _("Raster file to be imported");
parm.input->gisprompt = "old_file,file,input";
parm.input->required = NO; /* not required because of -f flag */
- parm.input->guisection = _("Main");
+ parm.input->guisection = _("Required");
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
parm.output->required = NO; /* not required because of -f flag */
- parm.output->guisection = _("Main");
+ parm.output->guisection = _("Required");
parm.band = G_define_option();
parm.band->key = "band";
Modified: grass/trunk/raster/r.out.gdal/main.c
--- grass/trunk/raster/r.out.gdal/main.c 2008-01-05 14:05:33 UTC (rev 29571)
+++ grass/trunk/raster/r.out.gdal/main.c 2008-01-05 14:20:15 UTC (rev 29572)
@@ -382,7 +382,7 @@
input = G_define_standard_option(G_OPT_R_INPUT);
input->description = _("Name of raster map (or group) to export");
- input->guisection = _("Main");
+ input->guisection = _("Required");
format = G_define_option();
format->key = "format";
@@ -418,7 +418,7 @@
output->gisprompt = "new_file,file,output";
output->description = _("Name for output raster file");
- output->guisection = _("Main");
+ output->guisection = _("Required");
createopt = G_define_option();
createopt->key = "createopt";
