[GRASS-SVN] r29601 - in grass/trunk/gui/wxpython: . gui_modules
vdigit
svn_grass at osgeo.org
Tue Jan 8 06:48:03 EST 2008
Author: martinl
Date: 2008-01-08 06:48:03 -0500 (Tue, 08 Jan 2008)
New Revision: 29601
Added:
grass/trunk/gui/wxpython/vdigit/
grass/trunk/gui/wxpython/vdigit/Makefile.in
grass/trunk/gui/wxpython/vdigit/cats.cpp
grass/trunk/gui/wxpython/vdigit/digit.cpp
grass/trunk/gui/wxpython/vdigit/digit.h
grass/trunk/gui/wxpython/vdigit/digit.i
grass/trunk/gui/wxpython/vdigit/driver.cpp
grass/trunk/gui/wxpython/vdigit/driver.h
grass/trunk/gui/wxpython/vdigit/driver.i
grass/trunk/gui/wxpython/vdigit/line.cpp
Removed:
grass/trunk/gui/wxpython/display_driver/
grass/trunk/gui/wxpython/README
grass/trunk/gui/wxpython/gui_modules/digit.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
wxGUI/vdigit: display_driver renamed to vdigit. Experimental interface for digitization initialized (currently v.edit is used on background which is slow for larger vector maps).
Modified: grass/trunk/gui/wxpython/README
--- grass/trunk/gui/wxpython/README 2008-01-08 11:30:08 UTC (rev 29600)
+++ grass/trunk/gui/wxpython/README 2008-01-08 11:48:03 UTC (rev 29601)
@@ -31,17 +31,10 @@
http://www.activestate.com/store/download.aspx?prdGUID=b08b04e0-6872-4d9d-a722-7a0c2dea2758
E.g. On Debian GNU/Linux install these packages:
- * libwxbase2.8-0
- * libwxbase2.8-dbg
- * libwxbase2.8-dev
- * libwxgtk2.8-0
- * libwxgtk2.8-dbg
- * libwxgtk2.8-dev
- * python-wxgtk2.8
- * wx2.8-doc
- * wx2.8-examples
- * wx2.8-headers
- * wx2.8-i18n
+ apt-get install libwxbase2.8-0 libwxbase2.8-dbg libwxbase2.8-dev \
+ libwxgtk2.8-0 libwxgtk2.8-dbg libwxgtk2.8-dev \
+ python-wxgtk2.8 wx2.8-doc wx2.8-examples \
+ wx2.8-headers wx2.8-i18n
1 - INSTALLATION
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py 2008-01-08 11:30:08 UTC (rev 29600)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py 2008-01-08 11:48:03 UTC (rev 29601)
@@ -2,6 +2,7 @@
MODULE: digit
CLASSES:
+ * DigitError
* AbstractDigit
* VEdit
* VDigit
@@ -25,7 +26,7 @@
AUTHORS: The GRASS Development Team
Martin Landa <landa.martin gmail.com>
-COPYRIGHT: (C) 2007 by the GRASS Development Team
+COPYRIGHT: (C) 2007-2008 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@@ -45,21 +46,35 @@
from debug import Debug as Debug
import gselect
try:
- driverPath = os.path.join(os.getenv("GISBASE"), "etc","wx", "display_driver")
- sys.path.append(driverPath)
- from grass6_wxdriver import DisplayDriver
+ digitPath = os.path.join(os.getenv("GISBASE"), "etc","wx", "vdigit")
+ sys.path.append(digitPath)
+ from grass6_wxvdigit import DisplayDriver
except ImportError, err:
print >> sys.stderr, "%sWARNING: Digitization tool is disabled (%s).%s" \
"Detailed information in README file." % \
(os.linesep, err, os.linesep)
USEVEDIT = True
+class DigitError(Exception):
+ def __init__(self, message):
+ self.message = message
+ def __str__(self):
+ wx.MessageBox(parent=None,
+ message=self.message,
+ style=wx.ICON_ERROR)
class AbstractDigit:
Abstract digitization class
def __init__(self, mapwindow, settings=None):
+ """Initialization
+ @param mapwindow reference to mapwindow (MapFrame) instance
+ @param settings initial settings of digitization tool
self.map = None
Debug.msg (3, "AbstractDigit.__init__(): map=%s" % \
@@ -112,28 +127,31 @@
"""Find maximum category number in the map layer
and update Digit.settings['category']
- Returns 'True' on success, 'False' on failure
+ @return 'True' on success, 'False' on failure
# vector map layer without categories, reset to '1'
self.settings['category'] = 1
if self.map:
- categoryCmd = gcmd.Command(cmd=["v.category", "-g", "--q",
- "input=%s" % self.map,
- "option=report",
- "layer=%d" % self.settings["layer"]])
+ if USEVEDIT:
+ categoryCmd = gcmd.Command(cmd=["v.category", "-g", "--q",
+ "input=%s" % self.map,
+ "option=report",
+ "layer=%d" % self.settings["layer"]])
- if categoryCmd.returncode != 0:
- return False
+ if categoryCmd.returncode != 0:
+ return False
- for line in categoryCmd.ReadStdOutput():
- if "all" in line:
- try:
- maxCat = int(line.split(' ')[-1]) + 1
- self.settings['category'] = maxCat
- except:
- return False
- return True
+ for line in categoryCmd.ReadStdOutput():
+ if "all" in line:
+ try:
+ maxCat = int(line.split(' ')[-1]) + 1
+ self.settings['category'] = maxCat
+ except:
+ return False
+ return True
+ else:
+ self.settings['category'] = self.digit.GetCategory(self.settings['layer']) + 1
def SetCategory(self):
"""Return category number to use (according Settings)"""
@@ -148,11 +166,16 @@
return self.settings["category"]
def SetMapName(self, map):
- """Set map name"""
+ """Set map name
+ @param map map name to be set up or None (will close currently edited map)
Debug.msg (3, "AbstractDigit.SetMapName map=%s" % map)
self.map = map
self.driver.Reset(self.map)
+ if not USEVEDIT:
+ self.digit.InitCats()
class VEdit(AbstractDigit):
@@ -161,16 +184,24 @@
Note: This should be replaced by VDigit class.
+ """Initialization
AbstractDigit.__init__(self, mapwindow, settings)
- def AddPoint (self, map, type, x, y, z=None):
+ def AddPoint (self, map, point, x, y, z=None):
+ """Add point/centroid to the vector map layer
+ @param point feature type (True for point, otherwise centroid)
+ @param x,y,z coordinates
- Add point/centroid to the vector map layer
- if type == "centroid":
+ if point:
+ key = "P"
+ else:
key = "C"
- else:
- key = "P"
layer = self.settings["layer"]
cat = self.SetCategory()
@@ -194,22 +225,25 @@
self.__AddFeature (map=map, input=addstring)
- def AddLine (self, map, type, coords):
+ def AddLine (self, map, line, coords):
+ """Add line/boundary to the vector map layer
+ @param line feature type (True for line, otherwise boundary)
+ @param list of coordinates
- Add line/boundary to the vector map layer
if len(coords) < 2:
return
- if type == "boundary":
+ if line:
+ key = "L"
+ flags = []
+ else:
key = "B"
flags = ['-c'] # close boundaries
- else:
- key = "L"
- flags = []
if layer > 0 and cat != "None":
addstring = "%s %d 1\n" % (key, len(coords))
@@ -233,10 +267,12 @@
self.__AddFeature (map=map, input=addstring, flags=flags)
def __AddFeature (self, map, input, flags=[]):
+ """General method for adding feature to the vector map layer
+ @param input feature definition in GRASS ASCII format
+ @param flags additional flags
- General method which adds feature to the vector map
if self.settings['snapping'][0] <= 0:
snap = "no"
else:
@@ -267,7 +303,6 @@
def DeleteSelectedLines(self):
"""Delete selected vector features from the vector map"""
selected = self.driver.GetSelected() # grassId
if len(selected) <= 0:
@@ -292,16 +327,27 @@
return True
def MoveSelectedLines(self, move):
- """Move selected vector features"""
+ """Move selected vector features
+ @param move X,Y direction
return self.__MoveFeature("move", None, move)
def MoveSelectedVertex(self, coords, move):
- """Move selected vertex of the line"""
+ """Move selected vertex of the line
+ @param coords click coordinates
return self.__MoveFeature("vertexmove", coords, move)
def __MoveFeature(self, tool, coords, move):
- """Move selected vector feature or vertex"""
+ """Move selected vector feature or vertex
+ @param tool tool for v.edit
@@ -342,8 +388,10 @@
return True
def SplitLine(self, coords):
- """Split selected line on position 'coords'"""
+ """Split selected line on position 'coords'
+ @param coords coordinates to split line
try:
line = self.driver.GetSelected()[0]
except:
@@ -365,15 +413,25 @@
return True
def AddVertex(self, coords):
- """Add new vertex to the selected line on position 'coords'"""
+ """Add new vertex to the selected line on position 'coords'
+ @param coords coordinates to add vertex
return self.__ModifyVertex(coords, "vertexadd")
def RemoveVertex(self, coords):
- """Remove vertex from the selected line on position 'coords'"""
+ """Remove vertex from the selected line on position 'coords'
+ @param coords coordinates to remove vertex
return self.__ModifyVertex(coords, "vertexdel")
def __ModifyVertex(self, coords, action):
+ """Generic method for vertex manipulation
+ @param action operation to perform
try:
except:
@@ -395,7 +453,11 @@
return True
def CopyCats(self, cats, ids):
- """Copy given categories to objects with id listed in ids"""
+ """Copy given categories to objects with id listed in ids
+ @param cats list of cats to be copied
+ @param ids ids of lines to be modified
if len(cats) == 0 or len(ids) == 0:
return False
@@ -413,7 +475,11 @@
return True
def EditLine(self, line, coords):
- """Edit existing line"""
+ """Edit existing line
+ @param line id of line to be modified
+ @param coords list of coordinates of modified line
# remove line
vEditDelete = gcmd.Command(['v.edit',
'--q',
@@ -429,8 +495,10 @@
self.driver.ReloadMap()
def __ModifyLines(self, tool):
- """General method to modify selected lines"""
+ """Generic method to modify selected lines
+ @param tool operation to be performed by v.edit
ids = self.driver.GetSelected()
if len(ids) <= 0:
@@ -454,32 +522,29 @@
def FlipLine(self):
"""Flip selected lines"""
return self.__ModifyLines('flip')
def MergeLine(self):
"""Merge selected lines"""
return self.__ModifyLines('merge')
def BreakLine(self):
"""Break selected lines"""
return self.__ModifyLines('break')
def SnapLine(self):
"""Snap selected lines"""
return self.__ModifyLines('snap')
def ConnectLine(self):
"""Connect selected lines"""
return self.__ModifyLines('connect')
def CopyLine(self, ids=None):
- """Copy features from (background) vector map"""
+ """Copy features from (background) vector map
+ @param ids list of line ids to be copied
if not ids:
@@ -505,7 +570,7 @@
def SelectLinesFromBackgroundMap(self, pos1, pos2):
"""Select features from background map
- pos1, pos2: bounding box defifinition
+ @param pos1,pos2 bounding box defifinition
if self.settings['backgroundMap'] == '':
@@ -536,7 +601,10 @@
return ids
def SelectLinesByQuery(self, pos1, pos2):
- """Select features by query"""
+ """Select features by query
+ @param pos1, pos2 bounding box definition
if self.settings['query'][0] == "length":
thresh = self.settings['queryLength'][1]
if self.settings["queryLength"][0] == "shorter than":
@@ -591,8 +659,12 @@
def ZBulkLine(self, pos1, pos2, value, step):
"""Provide z bulk-labeling (automated assigment of z coordinate
- to 3d lines"""
+ to 3d lines
+ @param pos1,pos2 bounding box definition for selecting lines to be labeled
+ @param value starting value
+ @param step step value
'--q',
'map=%s' % self.map,
@@ -607,31 +679,87 @@
Under development (wxWidgets C/C++ background)
+ """Initialization
try:
- from grass6_wxdriver import DigitClass
- self.digit = DigitClass()
- except:
+ from grass6_wxvdigit import Digit as DigitClass
+ self.digit = DigitClass(self.driver.GetDevice())
+ except ImportError, err:
+ print >> sys.stderr, "%sWARNING: Digitization tool is disabled (%s).%s" \
+ "Detailed information in README file." % \
+ (os.linesep, err, os.linesep)
self.digit = None
- def DeleteSelectedLines(self):
- """Delete selected vector features from the vector map"""
- selected = self.driver.GetSelected() # grassId
+ @param map map name (unused)
+ @param point feature type (if True -> point otherwise centroid)
+ layer = self.settings["layer"]
+ cat = self.SetCategory()
+ if point:
+ type = 0x01 # point
+ else:
+ type = 0x08 # centroid
- if len(selected) <= 0:
- return False
+ if z:
+ ret = self.digit.AddLine(type, [x, y, z], True, layer, cat)
+ else:
+ ret = self.digit.AddLine(type, [x, y], False, layer, cat)
- ids = ",".join(["%d" % v for v in selected])
+ if ret == -1:
+ raise DigitError, _("Adding new feature to vector map <%s> failed") % map
- Debug.msg(4, "Digit.DeleteSelectedLines(): ids=%s" % \
- ids)
+ if len(coords) < 2:
+ return
- self.digit.DeleteSelectedLines()
+ if line:
+ type = 0x02
+ else:
+ type = 0x04
+ listCoords = []
+ for c in coords:
+ for x in c:
+ listCoords.append(x)
+ if len(coords[0]) == 3: # with_z
+ ret = self.digit.AddLine(type, listCoords, True, layer, cat)
+ else:
+ ret = self.digit.AddLine(type, listCoords, False, layer, cat)
+ if ret == -1:
+ def DeleteSelectedLines(self):
+ """Delete selected vector features from the vector map
+ @return number of deleted lines
+ nlines = self.digit.DeleteSelectedLines()
#self.driver.DrawUpdatedLines()
- return True
+ return nlines
if USEVEDIT:
class Digit(VEdit):
@@ -647,6 +775,11 @@
class AbstractDisplayDriver:
"""Abstract classs for display driver"""
def __init__(self, parent, mapwindow):
+ """Initialization
+ @param parent
+ @param mapwindow reference to mapwindow (MFrame)
self.parent = parent
self.mapwindow = mapwindow
@@ -654,7 +787,11 @@
self.selected = [] # list of selected objects (grassId!)
def GetThreshold(self, value=None, units=None):
- """Return threshold in map units"""
+ """Return threshold in map units
+ @param value threshold to be set up
+ @param units units (map, screen)
if not value:
value = self.parent.settings["snapping"][0]
@@ -682,6 +819,11 @@
Display driver using grass6_wxdriver module
+ """Initialization
+ @param parent
AbstractDisplayDriver.__init__(self, parent, mapwindow)
self.mapWindow = mapwindow
@@ -695,15 +837,28 @@
settings = self.parent.settings
self.UpdateSettings()
+ def GetDevice(self):
+ """Get device"""
+ return self.__display
def SetDevice(self, pdc):
- """Set device for driver"""
+ """Set device for driver
+ @param pdc wx.PseudoDC instance
self.__display.SetDevice(pdc)
def Reset(self, map):
- """Close map and open new one"""
+ """Close map and open new one
+ map map name to be set up
if map:
name, mapset = map.split('@')
- self.__display.OpenMap(str(name), str(mapset))
+ if USEVEDIT:
+ ret = self.__display.OpenMap(str(name), str(mapset), False)
+ else:
+ ret = self.__display.OpenMap(str(name), str(mapset), True)
else:
self.__display.CloseMap()
@@ -718,7 +873,7 @@
def DrawMap(self):
"""Draw vector map layer content
- Return wx.Image
+ @return wx.Image instance
import time
start = time.clock()
@@ -733,8 +888,10 @@
"""Select vector features by given bounding box.
If type is given, only vector features of given type are selected.
+ @param begin,end bounding box definition
+ @param type select only objects of given type
x1, y1 = begin
x2, y2 = end
@@ -748,8 +905,10 @@
"""Select vector feature by coordinates of click point (in given threshold).
+ @param point click coordinates (bounding box given by threshold)
ftype = -1 # all types
if type:
if type == "point":
@@ -772,9 +931,8 @@
def GetSelected(self, grassId=True):
"""Return ids of selected vector features
- If grassId is True returns GRASS ids, otherwise
+ @param grassId if grassId is True returns GRASS ids, otherwise
internal ids of objects drawn in PseudoDC"""
if grassId:
selected = self.__display.GetSelected(True)
else:
@@ -787,8 +945,10 @@
def GetSelectedVertex(self, coords):
"""Get PseudoDC id(s) of vertex (of selected line)
- on position 'coords'"""
+ on position 'coords'
+ @param coords click position
x, y = coords
id = self.__display.GetSelectedVertex(x, y, self.GetThreshold())
@@ -799,8 +959,10 @@
return id
def SetSelected(self, id):
- """Set selected vector features"""
+ """Set selected vector features
+ @param id line id to be selected
Debug.msg(4, "CDisplayDriver.SetSelected(): id=%s" % id)
self.__display.SetSelected(id)
@@ -831,66 +993,67 @@
if not self.__display:
return
- self.__display.SetSettings (wx.Color(settings['symbolHighlight'][1][0],
- settings['symbolHighlight'][1][1],
- settings['symbolHighlight'][1][2],
+ self.__display.UpdateSettings (wx.Color(settings['symbolHighlight'][1][0],
+ settings['symbolHighlight'][1][1],
+ settings['symbolHighlight'][1][2],
+ 255).GetRGB(),
+ settings['symbolPoint'][0],
+ wx.Color(settings['symbolPoint'][1][0],
+ settings['symbolPoint'][1][1],
+ settings['symbolPoint'][1][2],
+ 255).GetRGB(),
+ settings['symbolLine'][0],
+ wx.Color(settings['symbolLine'][1][0],
+ settings['symbolLine'][1][1],
+ settings['symbolLine'][1][2],
255).GetRGB(),
- settings['symbolPoint'][0],
- wx.Color(settings['symbolPoint'][1][0],
- settings['symbolPoint'][1][1],
- settings['symbolPoint'][1][2],
- 255).GetRGB(),
- settings['symbolLine'][0],
- wx.Color(settings['symbolLine'][1][0],
- settings['symbolLine'][1][1],
- settings['symbolLine'][1][2],
- 255).GetRGB(),
- settings['symbolBoundaryNo'][0],
- wx.Color(settings['symbolBoundaryNo'][1][0],
- settings['symbolBoundaryNo'][1][1],
- settings['symbolBoundaryNo'][1][2],
- 255).GetRGB(),
- settings['symbolBoundaryOne'][0],
- wx.Color(settings['symbolBoundaryOne'][1][0],
- settings['symbolBoundaryOne'][1][1],
- settings['symbolBoundaryOne'][1][2],
- 255).GetRGB(),
- settings['symbolBoundaryTwo'][0],
- wx.Color(settings['symbolBoundaryTwo'][1][0],
- settings['symbolBoundaryTwo'][1][1],
- settings['symbolBoundaryTwo'][1][2],
- 255).GetRGB(),
- settings['symbolCentroidIn'][0],
- wx.Color(settings['symbolCentroidIn'][1][0],
- settings['symbolCentroidIn'][1][1],
- settings['symbolCentroidIn'][1][2],
- 255).GetRGB(),
- settings['symbolCentroidOut'][0],
- wx.Color(settings['symbolCentroidOut'][1][0],
- settings['symbolCentroidOut'][1][1],
- settings['symbolCentroidOut'][1][2],
- 255).GetRGB(),
- settings['symbolCentroidDup'][0],
- wx.Color(settings['symbolCentroidDup'][1][0],
- settings['symbolCentroidDup'][1][1],
- settings['symbolCentroidDup'][1][2],
- 255).GetRGB(),
- settings['symbolNodeOne'][0],
- wx.Color(settings['symbolNodeOne'][1][0],
- settings['symbolNodeOne'][1][1],
- settings['symbolNodeOne'][1][2],
- 255).GetRGB(),
- settings['symbolNodeTwo'][0],
- wx.Color(settings['symbolNodeTwo'][1][0],
- settings['symbolNodeTwo'][1][1],
- settings['symbolNodeTwo'][1][2],
- 255).GetRGB(),
- settings['symbolVertex'][0],
- wx.Color(settings['symbolVertex'][1][0],
- settings['symbolVertex'][1][1],
- settings['symbolVertex'][1][2],
- 255).GetRGB(),
- settings['lineWidth'][0])
+ settings['symbolBoundaryNo'][0],
+ wx.Color(settings['symbolBoundaryNo'][1][0],
+ settings['symbolBoundaryNo'][1][1],
+ settings['symbolBoundaryNo'][1][2],
+ 255).GetRGB(),
+ settings['symbolBoundaryOne'][0],
+ wx.Color(settings['symbolBoundaryOne'][1][0],
+ settings['symbolBoundaryOne'][1][1],
+ settings['symbolBoundaryOne'][1][2],
+ 255).GetRGB(),
+ settings['symbolBoundaryTwo'][0],
+ wx.Color(settings['symbolBoundaryTwo'][1][0],
+ settings['symbolBoundaryTwo'][1][1],
+ settings['symbolBoundaryTwo'][1][2],
+ 255).GetRGB(),
+ settings['symbolCentroidIn'][0],
+ wx.Color(settings['symbolCentroidIn'][1][0],
+ settings['symbolCentroidIn'][1][1],
+ settings['symbolCentroidIn'][1][2],
+ 255).GetRGB(),
+ settings['symbolCentroidOut'][0],
+ wx.Color(settings['symbolCentroidOut'][1][0],
+ settings['symbolCentroidOut'][1][1],
+ settings['symbolCentroidOut'][1][2],
+ 255).GetRGB(),
+ settings['symbolCentroidDup'][0],
+ wx.Color(settings['symbolCentroidDup'][1][0],
+ settings['symbolCentroidDup'][1][1],
+ settings['symbolCentroidDup'][1][2],
+ 255).GetRGB(),
+ settings['symbolNodeOne'][0],
+ wx.Color(settings['symbolNodeOne'][1][0],
+ settings['symbolNodeOne'][1][1],
+ settings['symbolNodeOne'][1][2],
+ 255).GetRGB(),
+ settings['symbolNodeTwo'][0],
+ wx.Color(settings['symbolNodeTwo'][1][0],
+ settings['symbolNodeTwo'][1][1],
+ settings['symbolNodeTwo'][1][2],
+ 255).GetRGB(),
+ settings['symbolVertex'][0],
+ wx.Color(settings['symbolVertex'][1][0],
+ settings['symbolVertex'][1][1],
+ settings['symbolVertex'][1][2],
+ 255).GetRGB(),
+ settings['lineWidth'][0],
+ self.GetThreshold())
class DigitSettingsDialog(wx.Dialog):
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-01-08 11:30:08 UTC (rev 29600)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-01-08 11:48:03 UTC (rev 29601)
@@ -906,9 +906,11 @@
if digitToolbar.action == "addLine":
if digitToolbar.type in ["point", "centroid"]:
# add new point
- digitClass.AddPoint(map=map,
- type=digitToolbar.type,
- x=east, y=north)
+ if digitToolbar.type == 'point':
+ point = True
+ else:
+ point = False
+ digitClass.AddPoint(map, point, east, north)
self.UpdateMap(render=False) # redraw map
@@ -1357,11 +1359,12 @@
# xy -> EN
# for coord in self.polycoords:
# mapcoords.append(self.Pixel2Cell(coord))
+ if digitToolbar.type == 'line':
+ line = True
+ else:
+ line = False
+ digitClass.AddLine(map, line, self.polycoords)
- digitClass.AddLine(map=map,
- coords=self.polycoords)
position = self.Cell2Pixel(self.polycoords[-1])
self.polycoords = []
Copied: grass/trunk/gui/wxpython/vdigit (from rev 29593, grass/trunk/gui/wxpython/display_driver)
Deleted: grass/trunk/gui/wxpython/vdigit/Makefile.in
--- grass/trunk/gui/wxpython/display_driver/Makefile.in 2008-01-07 12:38:19 UTC (rev 29593)
+++ grass/trunk/gui/wxpython/vdigit/Makefile.in 2008-01-08 11:48:03 UTC (rev 29601)
@@ -1,38 +0,0 @@
-### DEFINITIONS
-PYTHONVERSION=@PYVERSION@
-### END DEFINITIONS
-MODULE_TOPDIR = ../../..
-include $(MODULE_TOPDIR)/include/Make/Lib.make
-include $(MODULE_TOPDIR)/include/Make/Doxygen.make
-SWIG=swig
-CFLAGS=-c -fpic -I/usr/include/python$(PYTHONVERSION) -I./ -I$(ARCH_DISTDIR)/include `wx-config --cxxflags` `gdal-config --cflags`
-LDFLAGS=-shared -fpic -L$(ARCH_LIBDIR) -lgrass_vect -lgrass_gis `wx-config --libs` -L./ -lgdi
-default: grass6_wxdriver.so
-clean:
- -rm -f *.o _grass6_wxdriver.so grass6_wxdriver_wrap.cxx grass6_wxdriver.py grass6_wxdriver.i grass6_wxdriver.pyc
-grass6_wxdriver.i:
- cat ./driver.i > grass6_wxdriver.i
- echo "/* auto-generate swig typedef file (with some GRASS functions removed) */" >> grass6_wxdriver.i
- cat ./driver.h >> grass6_wxdriver.i
-grass6_wxdriver_wrap.cxx: grass6_wxdriver.i
- $(SWIG) -c++ -python -shadow $<
-grass6_wxdriver_wrap.o: grass6_wxdriver_wrap.cxx
- $(CXX) $(CFLAGS) $(INCLUDE_DIRS) $<
-driver.o: driver.cpp driver.h
-grass6_wxdriver.so: grass6_wxdriver_wrap.o driver.o
- $(CXX) $(LDFLAGS) grass6_wxdriver_wrap.o driver.o -o _grass6_wxdriver.so
Copied: grass/trunk/gui/wxpython/vdigit/Makefile.in (from rev 29600, grass/trunk/gui/wxpython/display_driver/Makefile.in)
--- grass/trunk/gui/wxpython/vdigit/Makefile.in (rev 0)
@@ -0,0 +1,38 @@
+### DEFINITIONS
+PYTHONVERSION=@PYVERSION@
+### END DEFINITIONS
+MODULE_TOPDIR = ../../..
+include $(MODULE_TOPDIR)/include/Make/Lib.make
+include $(MODULE_TOPDIR)/include/Make/Doxygen.make
+SWIG=swig
+CFLAGS=-c -fpic -I/usr/include/python$(PYTHONVERSION) -I./ -I$(ARCH_DISTDIR)/include `wx-config --cxxflags` `gdal-config --cflags`
+LDFLAGS=-shared -fpic -L$(ARCH_LIBDIR) -lgrass_vect -lgrass_gis `wx-config --libs` -L./ -lgdi
+default: grass6_wxdriver.so
+clean:
+ -rm -f *.o _grass6_wxdriver.so grass6_wxdriver_wrap.cxx grass6_wxdriver.py grass6_wxdriver.i grass6_wxdriver.pyc
+grass6_wxdriver.i:
+ cat ./driver.i > grass6_wxdriver.i
+ echo "/* auto-generate swig typedef file (with some GRASS functions removed) */" >> grass6_wxdriver.i
+ cat ./driver.h >> grass6_wxdriver.i
+grass6_wxdriver_wrap.cxx: grass6_wxdriver.i
+ $(SWIG) -c++ -python -shadow $<
+grass6_wxdriver_wrap.o: grass6_wxdriver_wrap.cxx
+ $(CXX) $(CFLAGS) $(INCLUDE_DIRS) $<
+driver.o: driver.cpp driver.h
+grass6_wxdriver.so: grass6_wxdriver_wrap.o driver.o
+ $(CXX) $(LDFLAGS) grass6_wxdriver_wrap.o driver.o -o _grass6_wxdriver.so
Added: grass/trunk/gui/wxpython/vdigit/cats.cpp
--- grass/trunk/gui/wxpython/vdigit/cats.cpp (rev 0)
+++ grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-01-08 11:48:03 UTC (rev 29601)
@@ -0,0 +1,107 @@
+ \file cats.cpp
+ \brief Category management
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ \author (C) by The GRASS development team
+ Martin Landa <landa.martin gmail.com>
+ \date 2008
+#include "driver.h"
+#include "digit.h"
+ \brief Initialize cats structure.
+ \return 0 on success
+ \return -1 on error
+int Digit::InitCats()
+ int nfields, field, index, ncats, max_cat;
+ int cat, type, id;
+ struct lcat lc;
+ G_debug(2, "vdigit.InitCats()");
+ if (!cats.empty()) {
+ cats.clear();
+ if (!display->mapInfo) {
+ return -1;
+ nfields = Vect_cidx_get_num_fields (display->mapInfo);
+ for (int i = 0; i < nfields; i++ ) {
+ field = Vect_cidx_get_field_number(display->mapInfo, i);
+ ncats = Vect_cidx_get_num_cats_by_index(display->mapInfo, index);
+ for (int j = 0; j < ncats; j++) {
+ Vect_cidx_get_cat_by_index (display->mapInfo, index, j, &cat, &type, &id);
+ if (cat > max_cat)
+ max_cat = cat;
+ lc.layer = Vect_cidx_get_field_number(display->mapInfo, i);
+ lc.cat = max_cat;
+ cats.push_back(lc);
+ G_debug(3, "vdigit.InitCats(): layer=%d, cat=%d", lc.layer, lc.cat);
+ return 0;
+ \brief Get max category number for layer
+ \param layer layer number
+ \return category number (1 if no category found)
+int Digit::GetCategory(int layer)
+ for(std::vector<struct lcat>::const_iterator i = cats.begin(), e = cats.end();
+ i != e; ++i) {
+ if (layer == (*i).layer) {
+ G_debug(3, "v.digit.GetCategory(): layer=%d, cat=%d", (*i).layer, (*i).cat);
+ return (*i).cat;
+ return -1;
+ \brief Set max category number for layer
+ \param cats category number to be set
+ \return previosly set category
+int Digit::SetCategory(int layer, int cat)
+ int old_cat;
+ for(std::vector<struct lcat>::iterator i = cats.begin(), e = cats.end();
+ i != e; ++i) {
+ old_cat = (*i).cat;
+ (*i).cat = cat;
+ G_debug(3, "vdigit.SetCategory(): layer=%d, cat=%d", layer, cat);
+ return old_cat;
Added: grass/trunk/gui/wxpython/vdigit/digit.cpp
--- grass/trunk/gui/wxpython/vdigit/digit.cpp (rev 0)
+++ grass/trunk/gui/wxpython/vdigit/digit.cpp 2008-01-08 11:48:03 UTC (rev 29601)
@@ -0,0 +1,32 @@
+ \file digit.cpp
+ \brief Experimental C++ interace for vector digitization used
+ by wxPython GUI.
+ for details.
+ \author (C) by the GRASS Development Team
+ \date 2008
+#include "digit.h"
+ \brief Initialize digit interface used by SWIG
+ \param driver display driver instance
+Digit::Digit(DisplayDriver *ddriver)
+ display = ddriver;
+ if (display->mapInfo) {
+ InitCats();
Added: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h (rev 0)
+++ grass/trunk/gui/wxpython/vdigit/digit.h 2008-01-08 11:48:03 UTC (rev 29601)
@@ -0,0 +1,30 @@
+#ifndef __DIGIT_H__
+#define __DIGIT_H__
+class Digit
+private:
+ struct lcat {
+ int layer;
+ int cat;
+ std::vector<lcat> cats;
+ DisplayDriver *display;
+ int SetCategory(int, int);
+public:
+ Digit(DisplayDriver *);
+ int InitCats();
+ int AddLine(int, std::vector<double>, bool, int, int);
+ int DeleteSelectedLines();
+ int GetCategory(int);
+#endif /* __DIGIT_H__ */
Added: grass/trunk/gui/wxpython/vdigit/digit.i
--- grass/trunk/gui/wxpython/vdigit/digit.i (rev 0)
+++ grass/trunk/gui/wxpython/vdigit/digit.i 2008-01-08 11:48:03 UTC (rev 29601)
@@ -0,0 +1,17 @@
+/* File: digit.i */
+%module grass6_wxvdigit
+#include <grass/gis.h>
+#include <grass/gisdefs.h>
+#include <grass/Vect.h>
+#include <grass/vect/dig_structs.h>
+#include "digit.h"
+%include "std_vector.i"
+namespace std {
+ %template(IntVector) vector<int>;
+ %template(DoubleVector) vector<double>;
Deleted: grass/trunk/gui/wxpython/vdigit/driver.cpp
--- grass/trunk/gui/wxpython/display_driver/driver.cpp 2008-01-07 12:38:19 UTC (rev 29593)
+++ grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-01-08 11:48:03 UTC (rev 29601)
@@ -1,1066 +0,0 @@
- \file driver.cpp
- \brief Experimental C++ wxWidgets display driver
- This driver is designed for wxPython GRASS GUI (digitization tool).
- Draw vector map layer to PseudoDC.
- \author Martin Landa <landa.martin gmail.com>
- (C) 2007 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
-#include "driver.h"
- \brief Initialize driver
- Allocate given structures.
- \param[in,out] PseudoDC device where to draw vector objects
- \return
-DisplayDriver::DisplayDriver(void *device)
- G_gisinit(""); /* GRASS functions */
- mapInfo = NULL;
- dc = (wxPseudoDC *) device;
- points = Vect_new_line_struct();
- pointsScreen = new wxList();
- cats = Vect_new_cats_struct();
- drawSegments = false;
- \brief Destroy driver
- Close the map, deallocate given structures.
- \param
- \return
-DisplayDriver::~DisplayDriver()
- if (mapInfo)
- CloseMap();
- Vect_destroy_line_struct(points);
- delete pointsScreen;
- Vect_destroy_cats_struct(cats);
- \brief Set device for drawing
- \return
-void DisplayDriver::SetDevice(void *device)
- return;
- \brief Draw content of the vector map to device
- \return number of lines which were drawn
- \return -1 on error
-int DisplayDriver::DrawMap(bool force)
- if (!mapInfo || !dc)
- return -1;
- int nlines;
- BOUND_BOX mapBox;
- struct ilist *listLines;
- // ids.clear();
- listLines = Vect_new_list();
- ResetTopology();
- /* nlines = Vect_get_num_lines(mapInfo); */
- //Vect_build_partial(mapInfo, GV_BUILD_NONE, stderr);
- //Vect_build(mapInfo, stderr);
- Vect_get_map_box(mapInfo, &mapBox);
- // draw lines inside of current display region
- nlines = Vect_select_lines_by_box(mapInfo, &(region.box),
- GV_POINTS | GV_LINES, // fixme
- listLines);
- nlines = Vect_select_lines_by_box(mapInfo, &mapBox,
- listLines);
- for (int i = 0; i < listLines->n_values; i++) {
- DrawLine(listLines->value[i]);
-#ifdef DEBUG
- std::cerr.flags(std::ios_base::fixed);
- std::cerr << "region: W=" << region.box.W
- << "; E=" << region.box.E
- << "; S=" << region.box.S
- << "; N=" << region.box.N << std::endl;
- std::cerr << "-> nlines=" << nlines << std::endl;
-#endif
- bool inBox;
- dc->BeginDrawing();
- dc->EndDrawing();
-#ifdef DEBUG
- PrintIds();
-#endif
- Vect_destroy_list(listLines);
- return listLines->n_values;
- \brief Draw selected vector objects to the device
- \param[in] line id
- \return 1 on success
- \return -1 on failure (vector object is dead, etc.)
-int DisplayDriver::DrawLine(int line)
- if (!dc || !Vect_line_alive (mapInfo, line))
- return -1;
- int dcId; // 0 | 1 | segment id
- int type; // line type
- double x, y, z; // screen coordinates
- bool draw; // draw object ?
- wxPen *pen;
- // read line
- type = Vect_read_line (mapInfo, points, cats, line);
- // add ids
- // -> node1, line1, vertex1, line2, ..., node2
- // struct lineDesc desc = {points->n_points, dcId};
- // ids[line] = desc;
- // update id for next line
- // dcId += points->n_points * 2 - 1;
- if (IsSelected(line)) { // line selected ?
- pen = new wxPen(settings.highlight, settings.lineWidth, wxSOLID);
- draw = true;
- dcId = 1;
- topology.highlight++;
- else {
- dcId = 0;
- if (type & GV_LINES) {
- switch (type) {
- case GV_LINE:
- pen = new wxPen(settings.line.color, settings.lineWidth, wxSOLID);
- topology.line++;
- draw = settings.line.enabled;
- break;
- case GV_BOUNDARY:
- int left, right;
- Vect_get_line_areas(mapInfo, line,
- &left, &right);
- if (left == 0 && right == 0) {
- pen = new wxPen(settings.boundaryNo.color, settings.lineWidth, wxSOLID);
- topology.boundaryNo++;
- draw = settings.boundaryNo.enabled;
- else if (left > 0 && right > 0) {
- pen = new wxPen(settings.boundaryTwo.color, settings.lineWidth, wxSOLID);
- topology.boundaryTwo++;
- draw = settings.boundaryTwo.enabled;
- else {
- pen = new wxPen(settings.boundaryOne.color, settings.lineWidth, wxSOLID);
- topology.boundaryOne++;
- draw = settings.boundaryOne.enabled;
- break;
- default:
- draw = false;
- break;
- else if (type & GV_POINTS) {
- if (type == GV_POINT && settings.point.enabled) {
- pen = new wxPen(settings.point.color, settings.lineWidth, wxSOLID);
- topology.point++;
- draw = settings.point.enabled;
- else if (type == GV_CENTROID) {
- int cret = Vect_get_centroid_area(mapInfo, line);
- if (cret > 0) { // -> area
- draw = settings.centroidIn.enabled;
- pen = new wxPen(settings.centroidIn.color, settings.lineWidth, wxSOLID);
- topology.centroidIn++;
- else if (cret == 0) {
- draw = settings.centroidOut.enabled;
- pen = new wxPen(settings.centroidOut.color, settings.lineWidth, wxSOLID);
- topology.centroidOut++;
- else {
- draw = settings.centroidDup.enabled;
- pen = new wxPen(settings.centroidDup.color, settings.lineWidth, wxSOLID);
- topology.centroidDup++;
- // clear screen points & convert EN -> xy
- pointsScreen->Clear();
- for (int i = 0; i < points->n_points; i++) {
- Cell2Pixel(points->x[i], points->y[i], points->z[i],
- &x, &y, &z);
- pointsScreen->Append((wxObject*) new wxPoint((int) x, (int) y)); /* TODO: 3D */
- dc->SetId(dcId); /* 0 | 1 (selected) */
- dc->SetPen(*pen);
- if (draw) {
- if (type & GV_POINTS) {
- DrawCross(line, (const wxPoint *) pointsScreen->GetFirst()->GetData());
- else {
- // long int startId = ids[line].startId + 1;
- if (dcId > 0 && drawSegments) {
- dcId = 2; // first segment
- for (int i = 0; i < pointsScreen->GetCount() - 1; dcId += 2) {
- wxPoint *point_beg = (wxPoint *) pointsScreen->Item(i)->GetData();
- wxPoint *point_end = (wxPoint *) pointsScreen->Item(++i)->GetData();
- // set bounds for line
- // wxRect rect (*point_beg, *point_end);
- // dc->SetIdBounds(startId, rect);
- dc->SetId(dcId); // set unique id & set bbox for each segment
- dc->SetPen(*pen);
- wxRect rect (*point_beg, *point_end);
- dc->SetIdBounds(dcId, rect);
- dc->DrawLine(point_beg->x, point_beg->y,
- point_end->x, point_end->y);
- else {
- wxPoint points[pointsScreen->GetCount()];
- for (int i = 0; i < pointsScreen->GetCount(); i++) {
- points[i] = *point_beg;
- dc->DrawLines(pointsScreen->GetCount(), points);
- DrawLineVerteces(line); // draw vertices
- DrawLineNodes(line); // draw nodes
- delete pen;
- return 1;
- \brief Draw line verteces to the device
- Except of first and last vertex, see DrawLineNodes().
- \param line id
- \return number of verteces which were drawn
- \return -1 if drawing vertices is disabled
-int DisplayDriver::DrawLineVerteces(int line)
- int dcId;
- wxPoint *point;
- wxPen *pen;
- if (!IsSelected(line) && !settings.vertex.enabled)
- return -1;
- // determine color
- if (!IsSelected(line)) {
- pen = new wxPen(settings.vertex.color, settings.lineWidth, wxSOLID);
- dcId = 0;
- else {
- if (drawSegments) {
- dcId = 3; // first vertex
- else {
- dcId = 1;
- dc->SetPen(*pen);
- for (int i = 1; i < pointsScreen->GetCount() - 1; i++, dcId += 2) {
- point = (wxPoint*) pointsScreen->Item(i)->GetData();
- if (IsSelected(line) && drawSegments) {
- dc->SetId(dcId);
- dc->SetPen(*pen);
- wxRect rect (*point, *point);
- if (settings.vertex.enabled) {
- DrawCross(line, (const wxPoint*) pointsScreen->Item(i)->GetData());
- topology.vertex++;
- delete pen;
- return pointsScreen->GetCount() - 2;
- \brief Draw line nodes to the device
- \param line id
- \return 1
- \return -1 if no nodes were drawn
-int DisplayDriver::DrawLineNodes(int line)
- int dcId;
- int node;
- double east, north, depth;
- double x, y, z;
- int nodes [2];
- bool draw;
- wxPen *pen;
- // draw nodes??
- if (!settings.nodeOne.enabled && !settings.nodeTwo.enabled)
- return -1;
- // get nodes
- Vect_get_line_nodes(mapInfo, line, &(nodes[0]), &(nodes[1]));
- for (int i = 0; i < sizeof(nodes) / sizeof(int); i++) {
- node = nodes[i];
- // get coordinates
- Vect_get_node_coor(mapInfo, node,
- &east, &north, &depth);
- // convert EN->xy
- Cell2Pixel(east, north, depth,
- &x, &y, &z);
- draw = true;
- if (!drawSegments) {
- dcId = 1;
- else {
- // node1, line1, vertex1, line2, vertex2, ..., node2
- if (i == 0) // first node
- dcId = 1;
- else // last node
- dcId = 2 * points->n_points - 1;
- else {
- dcId = 0;
- if (Vect_get_node_n_lines(mapInfo, node) == 1) {
- pen = new wxPen(settings.nodeOne.color, settings.lineWidth, wxSOLID);
- topology.nodeOne++;
- draw = settings.nodeOne.enabled;
- else {
- pen = new wxPen(settings.nodeTwo.color, settings.lineWidth, wxSOLID);
- topology.nodeTwo++;
- draw = settings.nodeTwo.enabled;
- wxPoint point((int) x, (int) y);
- wxRect rect (point, point);
- // draw node if needed
- if (draw) {
- dc->SetId(dcId);
- dc->SetPen(*pen);
- DrawCross(line, &point);
- delete pen;
- return 1;
- \brief Close vector map layer
- \param
- \return
-void DisplayDriver::CloseMap()
- if (mapInfo) {
- Vect_close(mapInfo);
- G_free ((void *) mapInfo);
- mapInfo = NULL;
- return;
- \brief Open vector map layer
- \param[in] mapname name of vector map
- \param[in] mapset name of mapset where the vector map layer is stored
- \return
-void DisplayDriver::OpenMap(const char* mapname, const char *mapset)
- if (!mapInfo)
- mapInfo = (struct Map_info *) G_malloc (sizeof (struct Map_info));
- // define open level (level 2: topology)
- Vect_set_open_level(2);
- // open existing map
- Vect_open_old(mapInfo, (char*) mapname, (char *) mapset);
- return;
- \brief Reload vector map layer
- Close and open again. Needed for modification using v.edit.
- TODO: Get rid of that...
- \param
- \return
-void DisplayDriver::ReloadMap()
- // char* name = G_store(Vect_get_map_name(mapInfo)); ???
- char* name = G_store(mapInfo->name);
- char* mapset = G_store(Vect_get_mapset(mapInfo));
- mapInfo = NULL;
- OpenMap(name, mapset);
- return;
- \brief Conversion from geographic coordinates (east, north)
- to screen (x, y)
- TODO: 3D stuff...
- \param[in] east,north,depth geographical coordinates
- \param[out] x, y, z screen coordinates
- \return
-void DisplayDriver::Cell2Pixel(double east, double north, double depth,
- double *x, double *y, double *z)
- double n, w;
- *x = int((east - region.map_west) / region.map_res);
- *y = int((region.map_north - north) / region.map_res);
- w = region.center_easting - (region.map_width / 2) * region.map_res;
- n = region.center_northing + (region.map_height / 2) * region.map_res;
- *x = int((east - w) / region.map_res);
- *y = int((n - north) / region.map_res);
- *x = (east - w) / region.map_res;
- *y = (n - north) / region.map_res;
- *z = 0;
- return;
- \brief Set geographical region
- Region must be upgraded because of Cell2Pixel().
- \param[in] north,south,east,west,ns_res,ew_res region settings
- \return
-void DisplayDriver::SetRegion(double north, double south, double east, double west,
- double ns_res, double ew_res,
- double center_easting, double center_northing,
- double map_width, double map_height)
- region.box.N = north;
- region.box.S = south;
- region.box.E = east;
- region.box.W = west;
- region.box.T = PORT_DOUBLE_MAX;
- region.box.B = -PORT_DOUBLE_MAX;
- region.ns_res = ns_res;
- region.ew_res = ew_res;
- region.center_easting = center_easting;
- region.center_northing = center_northing;
- region.map_width = map_width;
- region.map_height = map_height;
-#ifdef DEBUG
- std::cerr << "region: n=" << north
- << "; s=" << south
- << "; e=" << east
- << "; w=" << west
- << "; ns_res=" << ns_res
- << "; ew_res=" << ew_res
- << "; center_easting=" << center_easting
- << "; center_northing=" << center_northing
- << "; map_width=" << map_width
- << "; map_height=" << map_height
- << std::endl;
-#endif
- // calculate real region
- region.map_res = (region.ew_res > region.ns_res) ? region.ew_res : region.ns_res;
- region.map_west = region.center_easting - (region.map_width / 2.) * region.map_res;
- region.map_north = region.center_northing + (region.map_height / 2.) * region.map_res;
- return;
- \brief Draw cross symbol of given size to device content
- Used for points, nodes, vertices
- \param[in] point coordinates of center
- \param[in] size size of the cross symbol
-int DisplayDriver::DrawCross(int line, const wxPoint* point, int size)
- if (!dc || !point)
- return -1;
- dc->DrawLine(point->x - size, point->y, point->x + size, point->y);
- dc->DrawLine(point->x, point->y - size, point->x, point->y + size);
- return 1;
- \brief Set settings for displaying vector feature
- E.g. line width, color, ...
- \param[in] lineWidth,... settgings
- \return
-void DisplayDriver::SetSettings(unsigned long highlight,
- bool ePoint, unsigned long cPoint, /* enabled, color */
- bool eLine, unsigned long cLine,
- bool eBoundaryNo, unsigned long cBoundaryNo,
- bool eBoundaryOne, unsigned long cBoundaryOne,
- bool eBoundaryTwo, unsigned long cBoundaryTwo,
- bool eCentroidIn, unsigned long cCentroidIn,
- bool eCentroidOut, unsigned long cCentroidOut,
- bool eCentroidDup, unsigned long cCentroidDup,
- bool eNodeOne, unsigned long cNodeOne,
- bool eNodeTwo, unsigned long cNodeTwo,
- bool eVertex, unsigned long cVertex,
- int lineWidth)
- settings.highlight.Set(highlight);
- settings.point.enabled = ePoint;
- settings.point.color.Set(cPoint);
- settings.line.enabled = eLine;
- settings.line.color.Set(cLine);
- settings.boundaryNo.enabled = eBoundaryNo;
- settings.boundaryNo.color.Set(cBoundaryNo);
- settings.boundaryOne.enabled = eBoundaryOne;
- settings.boundaryOne.color.Set(cBoundaryOne);
- settings.boundaryTwo.enabled = eBoundaryTwo;
- settings.boundaryTwo.color.Set(cBoundaryTwo);
- settings.centroidIn.enabled = eCentroidIn;
- settings.centroidIn.color.Set(cCentroidIn);
- settings.centroidOut.enabled = eCentroidOut;
- settings.centroidOut.color.Set(cCentroidOut);
- settings.centroidDup.enabled = eCentroidDup;
- settings.centroidDup.color.Set(cCentroidDup);
- settings.nodeOne.enabled = eNodeOne;
- settings.nodeOne.color.Set(cNodeOne);
- settings.nodeTwo.enabled = eNodeTwo;
- settings.nodeTwo.color.Set(cNodeTwo);
- settings.vertex.enabled = eVertex;
- settings.vertex.color.Set(cVertex);
- settings.lineWidth = lineWidth;
- \brief Prints gId: dcIds
- Useful for debugging purposes.
- \param
- \return
-void DisplayDriver::PrintIds()
- for (ids_map::const_iterator i = ids.begin(), e = ids.end();
- i != e; ++i) {
- std::cerr << "line=" << i->first << ": "
- << "npoints=" << i->second.npoints
- << " startId=" << i->second.startId
- << std::endl;
- std::cerr << "topology.highlight: " << topology.highlight << std::endl;
- std::cerr << "topology.point: " << topology.point << std::endl;
- std::cerr << "topology.line: " << topology.line << std::endl;
- std::cerr << "topology.boundaryNo: " << topology.boundaryNo << std::endl;
- std::cerr << "topology.boundaryOne: " << topology.boundaryOne << std::endl;
- std::cerr << "topology.boundaryTwo: " << topology.boundaryTwo << std::endl;
- std::cerr << "topology.centroidIn: " << topology.centroidIn << std::endl;
- std::cerr << "topology.centroidOut: " << topology.centroidOut << std::endl;
- std::cerr << "topology.centroidDup: " << topology.centroidDup << std::endl;
- std::cerr << "topology.nodeOne: " << topology.nodeOne << std::endl;
- std::cerr << "topology.nodeTwo: " << topology.nodeTwo << std::endl;
- std::cerr << "topology.vertex: " << topology.vertex << std::endl;
- std::cerr << std::endl << "nobjects: "
- << topology.point * 2 + // cross
- topology.line +
- topology.boundaryNo +
- topology.boundaryOne +
- topology.boundaryTwo +
- topology.centroidIn * 2 +
- topology.centroidOut * 2 +
- topology.centroidDup * 2 +
- topology.nodeOne * 2 +
- topology.nodeTwo * 2 +
- topology.vertex * 2 << std::endl;
- std::cerr << "selected: ";
- for (std::vector<int>::const_iterator i = selected.begin(), e = selected.end();
- i != e; ++i)
- std::cerr << *i << " ";
- std::cerr << std::endl;
- return;
- \brief Select vector objects by given bounding box
- If line id is already in the list of selected lines, then it will
- be excluded from this list.
- \param[in] x1,y1,x2,y2 corners coordinates of bounding box
- \return number of selected features
-int DisplayDriver::SelectLinesByBox(double x1, double y1, double x2, double y2)
- if (!mapInfo)
- return -1;
- int type, line;
- double dx, dy;
- struct ilist *list;
- struct line_pnts *bbox;
- type = -1; // all types
- list = Vect_new_list();
- bbox = Vect_new_line_struct();
- dx = std::fabs(x2 - x1);
- dy = std::fabs(y2 - y1);
- Vect_append_point(bbox, x1, y1, -PORT_DOUBLE_MAX);
- Vect_append_point(bbox, x2, y1, PORT_DOUBLE_MAX);
- Vect_append_point(bbox, x2, y2, -PORT_DOUBLE_MAX);
- Vect_append_point(bbox, x1, y2, PORT_DOUBLE_MAX);
- Vect_select_lines_by_polygon(mapInfo, bbox,
- 0, NULL,
- type, list);
- for (int i = 0; i < list->n_values; i++) {
- line = list->value[i];
- selected.push_back(line);
- else {
- selected.erase(GetSelectedIter(line));
- // remove all duplicate ids
- sort(selected.begin(), selected.end());
- selected.erase(unique(selected.begin(), selected.end()), selected.end());
- Vect_destroy_line_struct(bbox);
- Vect_destroy_list(list);
- return selected.size();
- \brief Select vector feature by given point in given
- threshold
- Only one vector object can be selected. Bounding boxes of
- all segments are stores.
- \param[in] x,y point of searching
- \param[in] thresh threshold value where to search
- \param[in] onlyType select vector object of given type
- \return point on line if line found
-std::vector<double> DisplayDriver::SelectLineByPoint(double x, double y, double thresh,
- int type)
- long int line;
- int ftype;
- double px, py, pz;
- std::vector<double> p;
- if (type == -1) {
- ftype = GV_POINTS | GV_LINES;
- else if (type == 0) {
- ftype = GV_POINTS;
- else if (type == 1) {
- ftype = GV_LINES;
- line = Vect_find_line(mapInfo, x, y, 0.0,
- ftype, thresh, 0, 0);
- if (line > 0) {
- Vect_line_distance (points, x, y, 0.0, WITHOUT_Z,
- &px, &py, &pz,
- NULL, NULL, NULL);
- p.push_back(px);
- p.push_back(py);
- drawSegments = true;
- return p;
- \brief Is vector object selected?
- \return true if vector object is selected
- \return false if vector object is not selected
-bool DisplayDriver::IsSelected(int line)
- if (GetSelectedIter(line) != selected.end())
- return true;
- return false;
- \return item iterator
- \return selected.end() if object is not selected
-std::vector<int>::iterator DisplayDriver::GetSelectedIter(int line)
- for(std::vector<int>::iterator i = selected.begin(), e = selected.end();
- i != e; ++i) {
- if (line == *i)
- return i;
- return selected.end();
- \brief Get ids of selected objects
- \param[in] grassId if true return GRASS line ids
- if false return PseudoDC ids
- \return list of ids of selected vector objects
-std::vector<int> DisplayDriver::GetSelected(bool grassId)
- if (grassId)
- return selected;
- std::vector<int> dc_ids;
- long int line;
- dc_ids.push_back(1);
- else {
- int npoints;
- Vect_read_line(mapInfo, points, NULL, selected[0]);
- npoints = points->n_points;
- for (int i = 1; i < 2 * npoints; i++) {
- dc_ids.push_back(i);
- for(std::vector<int>::const_iterator i = selected.begin(), e = selected.end();
- i != e; ++i) {
- line = *i;
- ids_map::const_iterator ii = ids.find(line);
- if (ii != ids.end()) { // line found
- long int endId = ii->second.npoints * 2 - 1 + ii->second.startId;
- int type, i;
- int vx, vy, vz;
- i = 0;
- for (long int id = ii->second.startId; id < endId; id++) {
- dc_ids.push_back(id);
- // set bounding boxes for all selected objects (only nodes)
- if (id % 2) {
- &vx, &vy, &vz);
- wxRect rect (wxPoint (vx, vy), wxPoint (vx, vy));
- dc->SetIdBounds(id, rect);
- i++;
- return dc_ids;
- \brief Set selected vector objects
- \param[in] list of GRASS ids to be set
- \return 1
-int DisplayDriver::SetSelected(std::vector<int> id)
- selected = id;
- if (selected.size() <= 0)
- return 1;
- \brief Get PseudoDC vertex id of selected line
- Set bounding box for vertices of line.
- \param[in] x,y coordinates of click
- \return id of center, left and right vertex
- \return 0 no line found
-std::vector<int> DisplayDriver::GetSelectedVertex(double x, double y, double thresh)
- int startId;
- int line, type;
- int Gid, DCid;
- double vx, vy, vz; // vertex screen coordinates
- double dist, minDist;
- std::vector<int> returnId;
- // only one object can be selected
- if (selected.size() != 1 || !drawSegments)
- return returnId;
- startId = 1;
- line = selected[0];
- // find the closest vertex (x, y)
- DCid = 1;
- for(int idx = 0; idx < points->n_points; idx++) {
- dist = Vect_points_distance(x, y, 0.0,
- points->x[idx], points->y[idx], points->z[idx], 0);
- if (idx == 0) {
- minDist = dist;
- Gid = idx;
- else {
- if (minDist > dist) {
- minDist = dist;
- Gid = idx;
- Cell2Pixel(points->x[idx], points->y[idx], points->z[idx],
- &vx, &vy, &vz);
- wxRect rect (wxPoint ((int) vx, (int) vy), wxPoint ((int) vx, (int) vy));
- dc->SetIdBounds(DCid, rect);
- DCid+=2;
- if (minDist > thresh)
- return returnId;
- // desc = &(ids[line]);
- // translate id
- DCid = Gid * 2 + 1;
- // add selected vertex
- returnId.push_back(DCid);
- // left vertex
- if (DCid == startId) {
- returnId.push_back(-1);
- else {
- returnId.push_back(DCid - 2);
- // right vertex
- if (DCid == (points->n_points - 1) * 2 + startId) {
- else {
- returnId.push_back(DCid + 2);
- return returnId;
- \brief Reset topology structure.
- \return
-void DisplayDriver::ResetTopology()
- topology.highlight = 0;
- topology.point = 0;
- topology.line = 0;
- topology.boundaryNo = 0;
- topology.boundaryOne = 0;
- topology.boundaryTwo = 0;
- topology.centroidIn = 0;
- topology.centroidOut = 0;
- topology.centroidDup = 0;
- topology.nodeOne = 0;
- topology.nodeTwo = 0;
- topology.vertex = 0;
- return;
Copied: grass/trunk/gui/wxpython/vdigit/driver.cpp (from rev 29600, grass/trunk/gui/wxpython/display_driver/driver.cpp)
--- grass/trunk/gui/wxpython/vdigit/driver.cpp (rev 0)
@@ -0,0 +1,1078 @@
+ \file driver.cpp
+ \brief Experimental C++ wxWidgets display driver
+ This driver is designed for wxPython GRASS GUI (digitization tool).
+ Draw vector map layer to PseudoDC.
+ for details.
+ \date 2007-2008
+ \brief Initialize driver
+ Allocate given structures.
+ \param[in,out] PseudoDC device where to draw vector objects
+ \return
+DisplayDriver::DisplayDriver(void *device)
+ G_gisinit(""); /* GRASS functions */
+ mapInfo = NULL;
+ dc = (wxPseudoDC *) device;
+ points = Vect_new_line_struct();
+ pointsScreen = new wxList();
+ cats = Vect_new_cats_struct();
+ drawSegments = false;
+ \brief Destroy driver
+ Close the map, deallocate given structures.
+ \param
+ \return
+DisplayDriver::~DisplayDriver()
+ if (mapInfo)
+ CloseMap();
+ Vect_destroy_line_struct(points);
+ delete pointsScreen;
+ Vect_destroy_cats_struct(cats);
+ \brief Set device for drawing
+ \return
+void DisplayDriver::SetDevice(void *device)
+ return;
+ \brief Draw content of the vector map to device
+ \return number of lines which were drawn
+int DisplayDriver::DrawMap(bool force)
+ if (!mapInfo || !dc)
+ return -1;
+ int nlines;
+ BOUND_BOX mapBox;
+ struct ilist *listLines;
+ // ids.clear();
+ listLines = Vect_new_list();
+ ResetTopology();
+ /* nlines = Vect_get_num_lines(mapInfo); */
+ //Vect_build_partial(mapInfo, GV_BUILD_NONE, stderr);
+ //Vect_build(mapInfo, stderr);
+ Vect_get_map_box(mapInfo, &mapBox);
+ // draw lines inside of current display region
+ nlines = Vect_select_lines_by_box(mapInfo, &(region.box),
+ GV_POINTS | GV_LINES, // fixme
+ listLines);
+ nlines = Vect_select_lines_by_box(mapInfo, &mapBox,
+ listLines);
+ for (int i = 0; i < listLines->n_values; i++) {
+ DrawLine(listLines->value[i]);
+#ifdef DEBUG
+ std::cerr.flags(std::ios_base::fixed);
+ std::cerr << "region: W=" << region.box.W
+ << "; E=" << region.box.E
+ << "; S=" << region.box.S
+ << "; N=" << region.box.N << std::endl;
+ std::cerr << "-> nlines=" << nlines << std::endl;
+#endif
+ bool inBox;
+ dc->BeginDrawing();
+ dc->EndDrawing();
+#ifdef DEBUG
+ PrintIds();
+#endif
+ Vect_destroy_list(listLines);
+ return listLines->n_values;
+ \brief Draw selected vector objects to the device
+ \param[in] line id
+ \return 1 on success
+ \return -1 on failure (vector object is dead, etc.)
+int DisplayDriver::DrawLine(int line)
+ if (!dc || !Vect_line_alive (mapInfo, line))
+ return -1;
+ int dcId; // 0 | 1 | segment id
+ int type; // line type
+ double x, y, z; // screen coordinates
+ bool draw; // draw object ?
+ wxPen *pen;
+ // read line
+ type = Vect_read_line (mapInfo, points, cats, line);
+ // add ids
+ // -> node1, line1, vertex1, line2, ..., node2
+ // struct lineDesc desc = {points->n_points, dcId};
+ // ids[line] = desc;
+ // update id for next line
+ // dcId += points->n_points * 2 - 1;
+ if (IsSelected(line)) { // line selected ?
+ pen = new wxPen(settings.highlight, settings.lineWidth, wxSOLID);
+ draw = true;
+ dcId = 1;
+ topology.highlight++;
+ else {
+ dcId = 0;
+ if (type & GV_LINES) {
+ switch (type) {
+ case GV_LINE:
+ pen = new wxPen(settings.line.color, settings.lineWidth, wxSOLID);
+ topology.line++;
+ draw = settings.line.enabled;
+ break;
+ case GV_BOUNDARY:
+ int left, right;
+ Vect_get_line_areas(mapInfo, line,
+ &left, &right);
+ if (left == 0 && right == 0) {
+ pen = new wxPen(settings.boundaryNo.color, settings.lineWidth, wxSOLID);
+ topology.boundaryNo++;
+ draw = settings.boundaryNo.enabled;
+ else if (left > 0 && right > 0) {
+ pen = new wxPen(settings.boundaryTwo.color, settings.lineWidth, wxSOLID);
+ topology.boundaryTwo++;
+ draw = settings.boundaryTwo.enabled;
+ else {
+ pen = new wxPen(settings.boundaryOne.color, settings.lineWidth, wxSOLID);
+ topology.boundaryOne++;
+ draw = settings.boundaryOne.enabled;
+ break;
+ default:
+ draw = false;
+ break;
+ else if (type & GV_POINTS) {
+ if (type == GV_POINT && settings.point.enabled) {
+ pen = new wxPen(settings.point.color, settings.lineWidth, wxSOLID);
+ topology.point++;
+ draw = settings.point.enabled;
+ else if (type == GV_CENTROID) {
+ int cret = Vect_get_centroid_area(mapInfo, line);
+ if (cret > 0) { // -> area
+ draw = settings.centroidIn.enabled;
+ pen = new wxPen(settings.centroidIn.color, settings.lineWidth, wxSOLID);
+ topology.centroidIn++;
+ else if (cret == 0) {
+ draw = settings.centroidOut.enabled;
+ pen = new wxPen(settings.centroidOut.color, settings.lineWidth, wxSOLID);
+ topology.centroidOut++;
+ else {
+ draw = settings.centroidDup.enabled;
+ pen = new wxPen(settings.centroidDup.color, settings.lineWidth, wxSOLID);
+ topology.centroidDup++;
+ // clear screen points & convert EN -> xy
+ pointsScreen->Clear();
+ for (int i = 0; i < points->n_points; i++) {
+ Cell2Pixel(points->x[i], points->y[i], points->z[i],
+ &x, &y, &z);
+ pointsScreen->Append((wxObject*) new wxPoint((int) x, (int) y)); /* TODO: 3D */
+ dc->SetId(dcId); /* 0 | 1 (selected) */
+ dc->SetPen(*pen);
+ if (draw) {
+ if (type & GV_POINTS) {
+ DrawCross(line, (const wxPoint *) pointsScreen->GetFirst()->GetData());
+ else {
+ // long int startId = ids[line].startId + 1;
+ if (dcId > 0 && drawSegments) {
+ dcId = 2; // first segment
+ for (int i = 0; i < pointsScreen->GetCount() - 1; dcId += 2) {
+ wxPoint *point_beg = (wxPoint *) pointsScreen->Item(i)->GetData();
+ wxPoint *point_end = (wxPoint *) pointsScreen->Item(++i)->GetData();
+ // set bounds for line
+ // wxRect rect (*point_beg, *point_end);
+ // dc->SetIdBounds(startId, rect);
+ dc->SetId(dcId); // set unique id & set bbox for each segment
+ dc->SetPen(*pen);
+ wxRect rect (*point_beg, *point_end);
+ dc->SetIdBounds(dcId, rect);
+ dc->DrawLine(point_beg->x, point_beg->y,
+ point_end->x, point_end->y);
+ else {
+ wxPoint points[pointsScreen->GetCount()];
+ for (int i = 0; i < pointsScreen->GetCount(); i++) {
+ points[i] = *point_beg;
+ dc->DrawLines(pointsScreen->GetCount(), points);
+ DrawLineVerteces(line); // draw vertices
+ DrawLineNodes(line); // draw nodes
+ delete pen;
+ return 1;
+ \brief Draw line verteces to the device
+ Except of first and last vertex, see DrawLineNodes().
+ \param line id
+ \return number of verteces which were drawn
+ \return -1 if drawing vertices is disabled
+int DisplayDriver::DrawLineVerteces(int line)
+ int dcId;
+ wxPoint *point;
+ wxPen *pen;
+ if (!IsSelected(line) && !settings.vertex.enabled)
+ return -1;
+ // determine color
+ if (!IsSelected(line)) {
+ pen = new wxPen(settings.vertex.color, settings.lineWidth, wxSOLID);
+ dcId = 0;
+ else {
+ if (drawSegments) {
+ dcId = 3; // first vertex
+ else {
+ dcId = 1;
+ dc->SetPen(*pen);
+ for (int i = 1; i < pointsScreen->GetCount() - 1; i++, dcId += 2) {
+ point = (wxPoint*) pointsScreen->Item(i)->GetData();
+ if (IsSelected(line) && drawSegments) {
+ dc->SetId(dcId);
+ dc->SetPen(*pen);
+ wxRect rect (*point, *point);
+ if (settings.vertex.enabled) {
+ DrawCross(line, (const wxPoint*) pointsScreen->Item(i)->GetData());
+ topology.vertex++;
+ delete pen;
+ return pointsScreen->GetCount() - 2;
+ \brief Draw line nodes to the device
+ \param line id
+ \return 1
+ \return -1 if no nodes were drawn
+int DisplayDriver::DrawLineNodes(int line)
+ int dcId;
+ int node;
+ double east, north, depth;
+ double x, y, z;
+ int nodes [2];
+ bool draw;
+ wxPen *pen;
+ // draw nodes??
+ if (!settings.nodeOne.enabled && !settings.nodeTwo.enabled)
+ return -1;
+ // get nodes
+ Vect_get_line_nodes(mapInfo, line, &(nodes[0]), &(nodes[1]));
+ for (int i = 0; i < sizeof(nodes) / sizeof(int); i++) {
+ node = nodes[i];
+ // get coordinates
+ Vect_get_node_coor(mapInfo, node,
+ &east, &north, &depth);
+ // convert EN->xy
+ Cell2Pixel(east, north, depth,
+ &x, &y, &z);
+ draw = true;
+ if (!drawSegments) {
+ dcId = 1;
+ else {
+ // node1, line1, vertex1, line2, vertex2, ..., node2
+ if (i == 0) // first node
+ dcId = 1;
+ else // last node
+ dcId = 2 * points->n_points - 1;
+ else {
+ dcId = 0;
+ if (Vect_get_node_n_lines(mapInfo, node) == 1) {
+ pen = new wxPen(settings.nodeOne.color, settings.lineWidth, wxSOLID);
+ topology.nodeOne++;
+ draw = settings.nodeOne.enabled;
+ else {
+ pen = new wxPen(settings.nodeTwo.color, settings.lineWidth, wxSOLID);
+ topology.nodeTwo++;
+ draw = settings.nodeTwo.enabled;
+ wxPoint point((int) x, (int) y);
+ wxRect rect (point, point);
+ // draw node if needed
+ if (draw) {
+ dc->SetId(dcId);
+ dc->SetPen(*pen);
+ DrawCross(line, &point);
+ delete pen;
+ return 1;
+ \brief Close vector map layer
+ \param
+ \return
+void DisplayDriver::CloseMap()
+ if (mapInfo) {
+ if (mapInfo->mode == GV_MODE_RW) {
+ Vect_build(mapInfo, NULL);
+ Vect_close(mapInfo);
+ G_free ((void *) mapInfo);
+ mapInfo = NULL;
+ return;
+ \brief Open vector map layer
+ \param[in] mapname name of vector map
+ \param[in] mapset name of mapset where the vector map layer is stored
+ \return topo level
+int DisplayDriver::OpenMap(const char* mapname, const char *mapset, bool update)
+ int ret;
+ if (!mapInfo)
+ mapInfo = (struct Map_info *) G_malloc (sizeof (struct Map_info));
+ // define open level (level 2: topology)
+ Vect_set_open_level(2);
+ // open existing map
+ if (!update) {
+ ret = Vect_open_old(mapInfo, (char*) mapname, (char *) mapset);
+ else {
+ ret = Vect_open_update(mapInfo, (char*) mapname, (char *) mapset);
+ return ret;
+ \brief Reload vector map layer
+ Close and open again. Needed for modification using v.edit.
+ TODO: Get rid of that...
+ \param
+ \return
+void DisplayDriver::ReloadMap()
+ // char* name = G_store(Vect_get_map_name(mapInfo)); ???
+ char* name = G_store(mapInfo->name);
+ char* mapset = G_store(Vect_get_mapset(mapInfo));
+ mapInfo = NULL;
+ OpenMap(name, mapset, false); // used only for v.edit
+ return;
+ \brief Conversion from geographic coordinates (east, north)
+ to screen (x, y)
+ TODO: 3D stuff...
+ \param[in] east,north,depth geographical coordinates
+ \param[out] x, y, z screen coordinates
+ \return
+void DisplayDriver::Cell2Pixel(double east, double north, double depth,
+ double *x, double *y, double *z)
+ double n, w;
+ *x = int((east - region.map_west) / region.map_res);
+ *y = int((region.map_north - north) / region.map_res);
+ w = region.center_easting - (region.map_width / 2) * region.map_res;
+ n = region.center_northing + (region.map_height / 2) * region.map_res;
+ *x = int((east - w) / region.map_res);
+ *y = int((n - north) / region.map_res);
+ *x = (east - w) / region.map_res;
+ *y = (n - north) / region.map_res;
+ *z = 0;
+ return;
+ \brief Set geographical region
+ Region must be upgraded because of Cell2Pixel().
+ \param[in] north,south,east,west,ns_res,ew_res region settings
+ \return
+void DisplayDriver::SetRegion(double north, double south, double east, double west,
+ double ns_res, double ew_res,
+ double center_easting, double center_northing,
+ double map_width, double map_height)
+ region.box.N = north;
+ region.box.S = south;
+ region.box.E = east;
+ region.box.W = west;
+ region.box.T = PORT_DOUBLE_MAX;
+ region.box.B = -PORT_DOUBLE_MAX;
+ region.ns_res = ns_res;
+ region.ew_res = ew_res;
+ region.center_easting = center_easting;
+ region.center_northing = center_northing;
+ region.map_width = map_width;
+ region.map_height = map_height;
+#ifdef DEBUG
+ std::cerr << "region: n=" << north
+ << "; s=" << south
+ << "; e=" << east
+ << "; w=" << west
+ << "; ns_res=" << ns_res
+ << "; ew_res=" << ew_res
+ << "; center_easting=" << center_easting
+ << "; center_northing=" << center_northing
+ << "; map_width=" << map_width
+ << "; map_height=" << map_height
+ << std::endl;
+#endif
+ // calculate real region
+ region.map_res = (region.ew_res > region.ns_res) ? region.ew_res : region.ns_res;
+ region.map_west = region.center_easting - (region.map_width / 2.) * region.map_res;
+ region.map_north = region.center_northing + (region.map_height / 2.) * region.map_res;
+ return;
+ \brief Draw cross symbol of given size to device content
+ Used for points, nodes, vertices
+ \param[in] point coordinates of center
+ \param[in] size size of the cross symbol
+int DisplayDriver::DrawCross(int line, const wxPoint* point, int size)
+ if (!dc || !point)
+ return -1;
+ dc->DrawLine(point->x - size, point->y, point->x + size, point->y);
+ dc->DrawLine(point->x, point->y - size, point->x, point->y + size);
+ return 1;
+ \brief Set settings for displaying vector feature
+ E.g. line width, color, ...
+ \param[in] lineWidth,... settgings
+ \return
+void DisplayDriver::UpdateSettings(unsigned long highlight,
+ bool ePoint, unsigned long cPoint, /* enabled, color */
+ bool eLine, unsigned long cLine,
+ bool eBoundaryNo, unsigned long cBoundaryNo,
+ bool eBoundaryOne, unsigned long cBoundaryOne,
+ bool eBoundaryTwo, unsigned long cBoundaryTwo,
+ bool eCentroidIn, unsigned long cCentroidIn,
+ bool eCentroidOut, unsigned long cCentroidOut,
+ bool eCentroidDup, unsigned long cCentroidDup,
+ bool eNodeOne, unsigned long cNodeOne,
+ bool eNodeTwo, unsigned long cNodeTwo,
+ bool eVertex, unsigned long cVertex,
+ int lineWidth,
+ double threshold)
+ settings.highlight.Set(highlight);
+ settings.point.enabled = ePoint;
+ settings.point.color.Set(cPoint);
+ settings.line.enabled = eLine;
+ settings.line.color.Set(cLine);
+ settings.boundaryNo.enabled = eBoundaryNo;
+ settings.boundaryNo.color.Set(cBoundaryNo);
+ settings.boundaryOne.enabled = eBoundaryOne;
+ settings.boundaryOne.color.Set(cBoundaryOne);
+ settings.boundaryTwo.enabled = eBoundaryTwo;
+ settings.boundaryTwo.color.Set(cBoundaryTwo);
+ settings.centroidIn.enabled = eCentroidIn;
+ settings.centroidIn.color.Set(cCentroidIn);
+ settings.centroidOut.enabled = eCentroidOut;
+ settings.centroidOut.color.Set(cCentroidOut);
+ settings.centroidDup.enabled = eCentroidDup;
+ settings.centroidDup.color.Set(cCentroidDup);
+ settings.nodeOne.enabled = eNodeOne;
+ settings.nodeOne.color.Set(cNodeOne);
+ settings.nodeTwo.enabled = eNodeTwo;
+ settings.nodeTwo.color.Set(cNodeTwo);
+ settings.vertex.enabled = eVertex;
+ settings.vertex.color.Set(cVertex);
+ settings.lineWidth = lineWidth;
+ settings.threshold = threshold;
+ \brief Prints gId: dcIds
+ Useful for debugging purposes.
+ \param
+ \return
+void DisplayDriver::PrintIds()
+ for (ids_map::const_iterator i = ids.begin(), e = ids.end();
+ i != e; ++i) {
+ std::cerr << "line=" << i->first << ": "
+ << "npoints=" << i->second.npoints
+ << " startId=" << i->second.startId
+ << std::endl;
+ std::cerr << "topology.highlight: " << topology.highlight << std::endl;
+ std::cerr << "topology.point: " << topology.point << std::endl;
+ std::cerr << "topology.line: " << topology.line << std::endl;
+ std::cerr << "topology.boundaryNo: " << topology.boundaryNo << std::endl;
+ std::cerr << "topology.boundaryOne: " << topology.boundaryOne << std::endl;
+ std::cerr << "topology.boundaryTwo: " << topology.boundaryTwo << std::endl;
+ std::cerr << "topology.centroidIn: " << topology.centroidIn << std::endl;
+ std::cerr << "topology.centroidOut: " << topology.centroidOut << std::endl;
+ std::cerr << "topology.centroidDup: " << topology.centroidDup << std::endl;
+ std::cerr << "topology.nodeOne: " << topology.nodeOne << std::endl;
+ std::cerr << "topology.nodeTwo: " << topology.nodeTwo << std::endl;
+ std::cerr << "topology.vertex: " << topology.vertex << std::endl;
+ std::cerr << std::endl << "nobjects: "
+ << topology.point * 2 + // cross
+ topology.line +
+ topology.boundaryNo +
+ topology.boundaryOne +
+ topology.boundaryTwo +
+ topology.centroidIn * 2 +
+ topology.centroidOut * 2 +
+ topology.centroidDup * 2 +
+ topology.nodeOne * 2 +
+ topology.nodeTwo * 2 +
+ topology.vertex * 2 << std::endl;
+ std::cerr << "selected: ";
+ for (std::vector<int>::const_iterator i = selected.begin(), e = selected.end();
+ i != e; ++i)
+ std::cerr << *i << " ";
+ std::cerr << std::endl;
+ return;
+ \brief Select vector objects by given bounding box
+ If line id is already in the list of selected lines, then it will
+ be excluded from this list.
+ \param[in] x1,y1,x2,y2 corners coordinates of bounding box
+ \return number of selected features
+int DisplayDriver::SelectLinesByBox(double x1, double y1, double x2, double y2)
+ if (!mapInfo)
+ return -1;
+ int type, line;
+ double dx, dy;
+ struct ilist *list;
+ struct line_pnts *bbox;
+ type = -1; // all types
+ list = Vect_new_list();
+ bbox = Vect_new_line_struct();
+ dx = std::fabs(x2 - x1);
+ dy = std::fabs(y2 - y1);
+ Vect_append_point(bbox, x1, y1, -PORT_DOUBLE_MAX);
+ Vect_append_point(bbox, x2, y1, PORT_DOUBLE_MAX);
+ Vect_append_point(bbox, x2, y2, -PORT_DOUBLE_MAX);
+ Vect_append_point(bbox, x1, y2, PORT_DOUBLE_MAX);
+ Vect_select_lines_by_polygon(mapInfo, bbox,
+ 0, NULL,
+ type, list);
+ for (int i = 0; i < list->n_values; i++) {
+ line = list->value[i];
+ selected.push_back(line);
+ else {
+ selected.erase(GetSelectedIter(line));
+ // remove all duplicate ids
+ sort(selected.begin(), selected.end());
+ selected.erase(unique(selected.begin(), selected.end()), selected.end());
+ Vect_destroy_line_struct(bbox);
+ Vect_destroy_list(list);
+ return selected.size();
+ \brief Select vector feature by given point in given
+ threshold
+ Only one vector object can be selected. Bounding boxes of
+ all segments are stores.
+ \param[in] x,y point of searching
+ \param[in] thresh threshold value where to search
+ \param[in] onlyType select vector object of given type
+ \return point on line if line found
+std::vector<double> DisplayDriver::SelectLineByPoint(double x, double y, double thresh,
+ int type)
+ long int line;
+ int ftype;
+ double px, py, pz;
+ std::vector<double> p;
+ if (type == -1) {
+ ftype = GV_POINTS | GV_LINES;
+ else if (type == 0) {
+ ftype = GV_POINTS;
+ else if (type == 1) {
+ ftype = GV_LINES;
+ line = Vect_find_line(mapInfo, x, y, 0.0,
+ ftype, thresh, 0, 0);
+ if (line > 0) {
+ Vect_line_distance (points, x, y, 0.0, WITHOUT_Z,
+ &px, &py, &pz,
+ NULL, NULL, NULL);
+ p.push_back(px);
+ p.push_back(py);
+ drawSegments = true;
+ return p;
+ \brief Is vector object selected?
+ \return true if vector object is selected
+ \return false if vector object is not selected
+bool DisplayDriver::IsSelected(int line)
+ if (GetSelectedIter(line) != selected.end())
+ return true;
+ return false;
+ \return item iterator
+ \return selected.end() if object is not selected
+std::vector<int>::iterator DisplayDriver::GetSelectedIter(int line)
+ for(std::vector<int>::iterator i = selected.begin(), e = selected.end();
+ i != e; ++i) {
+ if (line == *i)
+ return i;
+ return selected.end();
+ \brief Get ids of selected objects
+ \param[in] grassId if true return GRASS line ids
+ if false return PseudoDC ids
+ \return list of ids of selected vector objects
+std::vector<int> DisplayDriver::GetSelected(bool grassId)
+ if (grassId)
+ return selected;
+ std::vector<int> dc_ids;
+ long int line;
+ dc_ids.push_back(1);
+ else {
+ int npoints;
+ Vect_read_line(mapInfo, points, NULL, selected[0]);
+ npoints = points->n_points;
+ for (int i = 1; i < 2 * npoints; i++) {
+ dc_ids.push_back(i);
+ for(std::vector<int>::const_iterator i = selected.begin(), e = selected.end();
+ i != e; ++i) {
+ line = *i;
+ ids_map::const_iterator ii = ids.find(line);
+ if (ii != ids.end()) { // line found
+ long int endId = ii->second.npoints * 2 - 1 + ii->second.startId;
+ int type, i;
+ int vx, vy, vz;
+ i = 0;
+ for (long int id = ii->second.startId; id < endId; id++) {
+ dc_ids.push_back(id);
+ // set bounding boxes for all selected objects (only nodes)
+ if (id % 2) {
+ &vx, &vy, &vz);
+ wxRect rect (wxPoint (vx, vy), wxPoint (vx, vy));
+ dc->SetIdBounds(id, rect);
+ i++;
+ return dc_ids;
+ \brief Set selected vector objects
+ \param[in] list of GRASS ids to be set
+ \return 1
+int DisplayDriver::SetSelected(std::vector<int> id)
+ selected = id;
+ if (selected.size() <= 0)
+ return 1;
+ \brief Get PseudoDC vertex id of selected line
+ Set bounding box for vertices of line.
+ \param[in] x,y coordinates of click
+ \return id of center, left and right vertex
+ \return 0 no line found
+std::vector<int> DisplayDriver::GetSelectedVertex(double x, double y, double thresh)
+ int startId;
+ int line, type;
+ int Gid, DCid;
+ double vx, vy, vz; // vertex screen coordinates
+ double dist, minDist;
+ std::vector<int> returnId;
+ // only one object can be selected
+ if (selected.size() != 1 || !drawSegments)
+ return returnId;
+ startId = 1;
+ line = selected[0];
+ // find the closest vertex (x, y)
+ DCid = 1;
+ for(int idx = 0; idx < points->n_points; idx++) {
+ dist = Vect_points_distance(x, y, 0.0,
+ points->x[idx], points->y[idx], points->z[idx], 0);
+ if (idx == 0) {
+ minDist = dist;
+ Gid = idx;
+ else {
+ if (minDist > dist) {
+ minDist = dist;
+ Gid = idx;
+ Cell2Pixel(points->x[idx], points->y[idx], points->z[idx],
+ &vx, &vy, &vz);
+ wxRect rect (wxPoint ((int) vx, (int) vy), wxPoint ((int) vx, (int) vy));
+ dc->SetIdBounds(DCid, rect);
+ DCid+=2;
+ if (minDist > thresh)
+ return returnId;
+ // desc = &(ids[line]);
+ // translate id
+ DCid = Gid * 2 + 1;
+ // add selected vertex
+ returnId.push_back(DCid);
+ // left vertex
+ if (DCid == startId) {
+ returnId.push_back(-1);
+ else {
+ returnId.push_back(DCid - 2);
+ // right vertex
+ if (DCid == (points->n_points - 1) * 2 + startId) {
+ else {
+ returnId.push_back(DCid + 2);
+ return returnId;
+ \brief Reset topology structure.
+ \return
+void DisplayDriver::ResetTopology()
+ topology.highlight = 0;
+ topology.point = 0;
+ topology.line = 0;
+ topology.boundaryNo = 0;
+ topology.boundaryOne = 0;
+ topology.boundaryTwo = 0;
+ topology.centroidIn = 0;
+ topology.centroidOut = 0;
+ topology.centroidDup = 0;
+ topology.nodeOne = 0;
+ topology.nodeTwo = 0;
+ topology.vertex = 0;
+ return;
Deleted: grass/trunk/gui/wxpython/vdigit/driver.h
--- grass/trunk/gui/wxpython/display_driver/driver.h 2008-01-07 12:38:19 UTC (rev 29593)
+++ grass/trunk/gui/wxpython/vdigit/driver.h 2008-01-08 11:48:03 UTC (rev 29601)
@@ -1,190 +0,0 @@
-#include <iostream> // debug
-#include <vector>
-//#include <map>
-#include <cmath>
-// For compilers that support precompilation, includes "wx.h".
-#include <wx/wxprec.h>
-#ifdef __BORLANDC__
-#pragma hdrstop
-#endif
-#ifndef WX_PRECOMP
-// Include your minimal set of headers here, or wx.h
-#include <wx/wx.h>
-#endif
-#include <wx/dc.h>
-#include <wx/list.h>
-#include <Python.h>
-#include <wx/wxPython/pseudodc.h>
-//#include "pseudodc.h"
-extern "C" {
-#include <grass/gis.h>
-#include <grass/Vect.h>
-// #define DEBUG
-class DisplayDriver
- private:
- wxPseudoDC *dc; // device content
- /* disabled due to expensive calling dc->SetId()
- * currently all objects are drawn without id
- * only selected lines with id '1'
- * segments with unique id (starting with '1')
- * are drawn only when line was selected using SelectLineByPoint()
- struct lineDesc {
- int npoints;
- long int startId;
- typedef std::map<int, lineDesc> ids_map;
- ids_map ids; // gId : {dcIds, ...}
- std::vector<int> selected; // list of selected features (gId)
- bool drawSegments; // draw segments of selected line
- struct Map_info *mapInfo;
- struct line_pnts *points; // east, north, depth
- wxList *pointsScreen; // x, y, z
- struct line_cats *cats;
- struct _region {
- // GRASS region section
- BOUND_BOX box; // W,E,N,S,T,B
- double ns_res;
- double ew_res;
- double center_easting;
- double center_northing;
- // map window section
- double map_width; // px
- double map_height;
- double map_west;
- double map_north;
- double map_res;
- } region;
- struct symbol {
- bool enabled;
- wxColor color;
- struct _settings {
- wxColor highlight;
- symbol point;
- symbol line;
- symbol boundaryNo;
- symbol boundaryOne;
- symbol boundaryTwo;
- symbol centroidIn;
- symbol centroidOut;
- symbol centroidDup;
- symbol nodeOne;
- symbol nodeTwo;
- symbol vertex;
- int lineWidth; // screen units
- } settings;
- struct _topology {
- long int highlight;
- long int point;
- long int line;
- long int boundaryNo;
- long int boundaryOne;
- long int boundaryTwo;
- long int centroidIn;
- long int centroidOut;
- long int centroidDup;
- long int nodeOne;
- long int nodeTwo;
- long int vertex;
- } topology;
- void Cell2Pixel (double east, double north, double depth,
- double *x, double *y, double *z);
- int DrawCross(int line, const wxPoint *point, int size=5);
- int DrawLine(int line);
- int DrawLineVerteces(int line);
- int DrawLineNodes(int line);
- /* debug */
- void PrintIds();
- /* select feature */
- bool IsSelected(int line);
- std::vector<int>::iterator GetSelectedIter(int line);
- void ResetTopology();
- public:
- /* constructor */
- DisplayDriver(void *device);
- /* destructor */
- ~DisplayDriver();
- /* display */
- int DrawMap(bool force);
- /* select */
- int SelectLinesByBox(double x1, double y1, double x2, double y2);
- std::vector<double> SelectLineByPoint(double x, double y, double thresh,
- int type);
- std::vector<int> GetSelected(bool grassId);
- int SetSelected(std::vector<int> id);
- std::vector<int> GetSelectedVertex(double x, double y, double thresh);
- /* general */
- void CloseMap();
- void OpenMap(const char *mapname, const char *mapset);
- void ReloadMap();
- void SetDevice(void *device);
- /* set */
- void SetRegion(double north, double south, double east, double west,
- double map_width, double map_height);
- void SetSettings(unsigned long highlight,
- int lineWidth);
Copied: grass/trunk/gui/wxpython/vdigit/driver.h (from rev 29600, grass/trunk/gui/wxpython/display_driver/driver.h)
--- grass/trunk/gui/wxpython/vdigit/driver.h (rev 0)
@@ -0,0 +1,196 @@
+#ifndef __DRIVER_H__
+#define __DRIVER_H__
+#include <iostream> // debug
+#include <vector>
+#include <cmath>
+// For compilers that support precompilation, includes "wx.h".
+#include <wx/wxprec.h>
+#ifdef __BORLANDC__
+#pragma hdrstop
+#endif
+#ifndef WX_PRECOMP
+// Include your minimal set of headers here, or wx.h
+#include <wx/wx.h>
+#endif
+#include <wx/dc.h>
+#include <wx/list.h>
+#include <Python.h>
+#include <wx/wxPython/pseudodc.h>
+extern "C" {
+// #define DEBUG
+class DisplayDriver
+private:
+ friend class Digit;
+ wxPseudoDC *dc; // device content
+ /* disabled due to expensive calling dc->SetId()
+ * currently all objects are drawn without id
+ * only selected lines with id '1'
+ * segments with unique id (starting with '1')
+ * are drawn only when line was selected using SelectLineByPoint()
+ struct lineDesc {
+ int npoints;
+ long int startId;
+ typedef std::map<int, lineDesc> ids_map;
+ ids_map ids; // gId : {dcIds, ...}
+ std::vector<int> selected; // list of selected features (gId)
+ bool drawSegments; // draw segments of selected line
+ struct Map_info *mapInfo;
+ struct line_pnts *points; // east, north, depth
+ wxList *pointsScreen; // x, y, z
+ struct line_cats *cats;
+ struct _region {
+ // GRASS region section
+ BOUND_BOX box; // W,E,N,S,T,B
+ double ns_res;
+ double ew_res;
+ double center_easting;
+ double center_northing;
+ // map window section
+ double map_width; // px
+ double map_height;
+ double map_west;
+ double map_north;
+ double map_res;
+ } region;
+ struct symbol {
+ bool enabled;
+ wxColor color;
+ struct _settings {
+ wxColor highlight;
+ symbol point;
+ symbol line;
+ symbol boundaryNo;
+ symbol boundaryOne;
+ symbol boundaryTwo;
+ symbol centroidIn;
+ symbol centroidOut;
+ symbol centroidDup;
+ symbol nodeOne;
+ symbol nodeTwo;
+ symbol vertex;
+ int lineWidth; // screen units
+ double threshold; // threshold value (map units)
+ } settings;
+ struct _topology {
+ long int highlight;
+ long int point;
+ long int line;
+ long int boundaryNo;
+ long int boundaryOne;
+ long int boundaryTwo;
+ long int centroidIn;
+ long int centroidOut;
+ long int centroidDup;
+ long int nodeOne;
+ long int nodeTwo;
+ long int vertex;
+ } topology;
+ void Cell2Pixel (double east, double north, double depth,
+ double *x, double *y, double *z);
+ int DrawCross(int line, const wxPoint *point, int size=5);
+ int DrawLine(int line);
+ int DrawLineVerteces(int line);
+ int DrawLineNodes(int line);
+ /* debug */
+ void PrintIds();
+ /* select feature */
+ bool IsSelected(int line);
+ std::vector<int>::iterator GetSelectedIter(int line);
+ void ResetTopology();
+public:
+ /* constructor */
+ DisplayDriver(void *);
+ /* destructor */
+ ~DisplayDriver();
+ /* display */
+ int DrawMap(bool);
+ /* select */
+ int SelectLinesByBox(double, double, double, double);
+ std::vector<double> SelectLineByPoint(double, double, double,
+ int);
+ std::vector<int> GetSelected(bool);
+ int SetSelected(std::vector<int>);
+ std::vector<int> GetSelectedVertex(double, double, double);
+ /* general */
+ void CloseMap();
+ int OpenMap(const char *, const char *, bool);
+ void ReloadMap();
+ void SetDevice(void *);
+ /* set */
+ void SetRegion(double, double, double, double,
+ double, double,
+ double, double,
+ double, double);
+ void UpdateSettings(unsigned long,
+ bool, unsigned long, /* enabled, color */
+ int,
+ double);
+#endif /* __DRIVER_H__ */
Deleted: grass/trunk/gui/wxpython/vdigit/driver.i
--- grass/trunk/gui/wxpython/display_driver/driver.i 2008-01-07 12:38:19 UTC (rev 29593)
+++ grass/trunk/gui/wxpython/vdigit/driver.i 2008-01-08 11:48:03 UTC (rev 29601)
@@ -1,16 +0,0 @@
-/* File: driver.i */
-%module grass6_wxdriver
-#include <grass/gisdefs.h>
-#include <grass/vect/dig_structs.h>
-%include "std_vector.i"
-namespace std {
- %template(IntVector) vector<int>;
- %template(DoubleVector) vector<double>;
Copied: grass/trunk/gui/wxpython/vdigit/driver.i (from rev 29600, grass/trunk/gui/wxpython/display_driver/driver.i)
--- grass/trunk/gui/wxpython/vdigit/driver.i (rev 0)
@@ -0,0 +1,16 @@
+/* File: driver.i */
+%module grass6_wxdriver
+namespace std {
Added: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp (rev 0)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2008-01-08 11:48:03 UTC (rev 29601)
@@ -0,0 +1,126 @@
+ \file line.cpp
+ \brief Line manipulation
+ for details.
+ \date 2008
+#include "digit.h"
+ \brief Delete selected lines
+ \return number of deleted lines
+int Digit::DeleteSelectedLines()
+ int nlines = 0;
+ return -1;
+ for(std::vector<int>::iterator i = display->selected.begin(), e = display->selected.end();
+ i != e; ++i) {
+ Vect_delete_line(display->mapInfo, *i);
+ return nlines;
+ \brief Add new line
+ For feature type see include/vect/dig_defines.h
+ #define GV_POINT 0x01
+ #define GV_LINE 0x02
+ #define GV_BOUNDARY 0x04
+ #define GV_CENTROID 0x08
+ (unsupported)
+ #define GV_FACE 0x10
+1 #define GV_KERNEL 0x20
+ #define GV_AREA 0x40
+ #define GV_VOLUME 0x80
+ \param type feature type
+ \param coords pairs of coordinates list
+ \param with_z 3D?
+int Digit::AddLine(int type, std::vector<double> coords, bool with_z, int layer, int cat)
+ int i, npoints;
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ return -1;
+ npoints = coords.size() / (with_z ? 3 : 2);
+ if (coords.size() != npoints * (with_z ? 3 : 2)) {
+ return -1;
+ /* TODO: 3D */
+ if (!(type & GV_POINTS) && !(type & GV_LINES)) {
+ return -1;
+ if (layer < -1) {
+ return -1;
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ Vect_cat_set(Cats, layer, cat);
+ if (cat > GetCategory(layer)) {
+ SetCategory(layer, cat); /* set up max category for layer */
+ i = 0;
+ while (i < coords.size()) {
+ if (with_z) {
+ Vect_append_point(Points, coords[i], coords[i+1], coords[i+2]);
+ i += 3;
+ else {
+ Vect_append_point(Points, coords[i], coords[i+1], 0.0);
+ i += 2;
+ if (type & GV_BOUNDARY) { /* close boundary */
+ int last = Points->n_points-1;
+ if (Vect_points_distance(Points->x[0], Points->x[0], Points->z[0],
+ Points->x[last], Points->x[last], Points->z[last],
+ with_z) <= display->settings.threshold) {
+ Points->x[last] = Points->x[0];
+ Points->y[last] = Points->y[0];
+ Points->z[last] = Points->z[0];
+ Vect_write_line(display->mapInfo, type, Points, Cats);
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_cats_struct(Cats);
+ return 1;
