[GRASS-SVN] r29673 - grass/trunk/raster/r.in.xyz
svn_grass at osgeo.org
Fri Jan 11 17:42:13 EST 2008
Author: martinl
Date: 2008-01-11 17:42:13 -0500 (Fri, 11 Jan 2008)
New Revision: 29673
grass/trunk/raster/r.in.xyz/main.c
r.in.xyz: use guisections, should fix #16
Modified: grass/trunk/raster/r.in.xyz/main.c
--- grass/trunk/raster/r.in.xyz/main.c 2008-01-11 22:16:50 UTC (rev 29672)
+++ grass/trunk/raster/r.in.xyz/main.c 2008-01-11 22:42:13 UTC (rev 29673)
@@ -164,6 +164,7 @@
method_opt->description = _("Statistic to use for raster values");
method_opt->options = "n,min,max,range,sum,mean,stddev,variance,coeff_var,median,percentile,skewness,trimmean";
method_opt->answer = "mean";
+ method_opt->guisection = _("Output");
type_opt = G_define_option();
type_opt->key = "type";
@@ -172,8 +173,10 @@
type_opt->options = "CELL,FCELL,DCELL";
type_opt->answer = "FCELL";
type_opt->description = _("Storage type for resultant raster map");
+ type_opt->guisection = _("Output");
delim_opt = G_define_standard_option(G_OPT_F_SEP);
+ delim_opt->guisection = _("Input");
xcol_opt = G_define_option();
xcol_opt->key = "x";
@@ -182,6 +185,7 @@
xcol_opt->answer = "1";
xcol_opt->description =
_("Column number of x coordinates in input file (first column is 1)");
+ xcol_opt->guisection = _("Input");
ycol_opt = G_define_option();
ycol_opt->key = "y";
@@ -190,6 +194,7 @@
ycol_opt->answer = "2";
ycol_opt->description =
_("Column number of y coordinates in input file");
+ ycol_opt->guisection = _("Input");
zcol_opt = G_define_option();
zcol_opt->key = "z";
@@ -198,6 +203,7 @@
zcol_opt->answer = "3";
zcol_opt->description =
_("Column number of data values in input file");
+ zcol_opt->guisection = _("Input");
zrange_opt = G_define_option();
zrange_opt->key = "zrange";
@@ -205,6 +211,7 @@
zrange_opt->required = NO;
zrange_opt->key_desc = "min,max";
zrange_opt->description = _("Filter range for z data (min,max)");
+ zrange_opt->guisection = _("Input");
percent_opt = G_define_option();
percent_opt->key = "percent";
