[GRASS-SVN] r29674 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Fri Jan 11 17:58:05 EST 2008
Author: martinl
Date: 2008-01-11 17:58:05 -0500 (Fri, 11 Jan 2008)
New Revision: 29674
grass/trunk/vector/v.in.ogr/main.c
v.in.ogr: use more guisections, should fix #17 (gui function v.in.ogr form not consistent with other wx gui forms)
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2008-01-11 22:42:13 UTC (rev 29673)
+++ grass/trunk/vector/v.in.ogr/main.c 2008-01-11 22:58:05 UTC (rev 29674)
@@ -108,9 +108,11 @@
dsn_opt->description = _("Examples:\n"
"\t\tESRI Shapefile: directory containing shapefiles\n"
"\t\tMapInfo File: directory containing mapinfo files");
+ dsn_opt->guisection = _("Required");
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
out_opt->required = NO;
+ out_opt->guisection = _("Required");
layer_opt = G_define_option();
layer_opt->key = "layer";
@@ -121,6 +123,7 @@
layer_opt->description = _("Examples:\n"
"\t\tESRI Shapefile: shapefile name\n"
"\t\tMapInfo File: mapinfo file name");
+ layer_opt->guisection = _("Query");
spat_opt = G_define_option();
spat_opt->key = "spatial";
@@ -133,6 +136,7 @@
spat_opt->description = _("Format: xmin,ymin,xmax,ymax - usually W,S,E,N");
where_opt = G_define_standard_option(G_OPT_WHERE);
+ where_opt->guisection = _("Query");
min_area_opt = G_define_option();
min_area_opt->key = "min_area";
@@ -153,6 +157,7 @@
"line;import area boundaries as lines;"
"boundary;import lines as area boundaries;"
"centroid;import points as centroids");
+ type_opt->guisection = _("Query");
snap_opt = G_define_option();
snap_opt->key = "snap";
@@ -177,6 +182,7 @@
cnames_opt->description =
_("List of column names to be used instead of original names, "
"first is used for category column");
+ cnames_opt->guisection = _("Attributes");
list_flag = G_define_flag ();
list_flag->key = 'l';
@@ -198,6 +204,7 @@
notab_flag = G_define_flag ();
notab_flag->key = 't';
notab_flag->description = _("Do not create attribute table");
+ notab_flag->guisection = _("Attributes");
over_flag = G_define_flag();
over_flag->key = 'o';
@@ -215,6 +222,7 @@
tolower_flag = G_define_flag();
tolower_flag->key = 'w';
tolower_flag->description = _("Change column names to lowercase characters");
+ tolower_flag->guisection = _("Attributes");
/* The parser checks if the map already exists in current mapset, this is
* wrong if location options is used, so we switch out the check and do it
