[GRASS-SVN] r29692 - grass/trunk/vector/v.to.db
Sun Jan 13 07:05:46 EST 2008
Author: wolf
Date: 2008-01-13 07:05:46 -0500 (Sun, 13 Jan 2008)
New Revision: 29692
   grass/trunk/vector/v.to.db/areas.c
   grass/trunk/vector/v.to.db/global.h
   grass/trunk/vector/v.to.db/lines.c
   grass/trunk/vector/v.to.db/parse.c
   grass/trunk/vector/v.to.db/report.c
   grass/trunk/vector/v.to.db/update.c
Added option=sinuous
Modified: grass/trunk/vector/v.to.db/areas.c
--- grass/trunk/vector/v.to.db/areas.c	2008-01-13 07:57:27 UTC (rev 29691)
+++ grass/trunk/vector/v.to.db/areas.c	2008-01-13 12:05:46 UTC (rev 29692)
@@ -51,7 +51,7 @@
 		    case O_COMPACT:
 			Values[idx].d1 = perimeter / (2.0 * sqrt(M_PI * area));
 			break;
-			case O_FD:
+		    case O_FD:
 			Values[idx].d1 = 2.0 * log(perimeter) / log(area) ;
 			break;
Modified: grass/trunk/vector/v.to.db/global.h
--- grass/trunk/vector/v.to.db/global.h	2008-01-13 07:57:27 UTC (rev 29691)
+++ grass/trunk/vector/v.to.db/global.h	2008-01-13 12:05:46 UTC (rev 29692)
@@ -70,6 +70,8 @@
 #define O_FD		13 /* fractal dimension */
+#define O_SINUOUS       14 /* sinuousity of a line (length / <distance between end points>) */
 #define U_ACRES		1
 #define U_HECTARES	2
 #define U_KILOMETERS	3
Modified: grass/trunk/vector/v.to.db/lines.c
--- grass/trunk/vector/v.to.db/lines.c	2008-01-13 07:57:27 UTC (rev 29691)
+++ grass/trunk/vector/v.to.db/lines.c	2008-01-13 12:05:46 UTC (rev 29692)
@@ -47,7 +47,7 @@
  * Read: - points/centroids : cat,count,coor
- *       - lines/boundaries : cat,count,length,slope
+ *       - lines/boundaries : cat,count,length,slope,sinuous
 int
@@ -55,12 +55,13 @@
     int    i, idx, nlines, type, found;
     register int line_num;
-    struct line_pnts *Points;
+    struct line_pnts *Points,*EndPoints;
     struct line_cats *Cats, *LCats, *RCats;
-    double len,slope;
+    double len,slope,dist;
     /* Initialize the Point struct */
     Points = Vect_new_line_struct();
+    EndPoints = Vect_new_line_struct();
     Cats = Vect_new_cats_struct ();
     LCats = Vect_new_cats_struct ();
     RCats = Vect_new_cats_struct ();
@@ -151,6 +152,21 @@
                     slope = (Points->z[Points->n_points-1] - Points->z[0])/len;
 		    Values[idx].d1 += slope;
+		} else if ( options.option == O_SINUOUS && (type & GV_LINES) ) {
+		    /* Calculate line length / distance between end points */
+		    Vect_append_point(EndPoints, Points->x[0], Points->y[0], Points->z[0]);
+		    Vect_append_point(EndPoints, Points->x[Points->n_points-1], Points->y[Points->n_points-1], Points->z[Points->n_points-1]);
+		    if (!Vect_is_3d(Map)) {
+			len = length (Points->n_points, Points->x, Points->y);
+			dist = length (EndPoints->n_points, EndPoints->x, EndPoints->y);
+		    else {
+			len = Vect_line_length(Points);
+			dist = Vect_line_length(EndPoints);
+		    Vect_destroy_line_struct(EndPoints);
+		    Values[idx].d1 = len / dist;
 		found = 1;
@@ -197,8 +213,22 @@
+		else {
Modified: grass/trunk/vector/v.to.db/parse.c
--- grass/trunk/vector/v.to.db/parse.c	2008-01-13 07:57:27 UTC (rev 29691)
+++ grass/trunk/vector/v.to.db/parse.c	2008-01-13 12:05:46 UTC (rev 29692)
@@ -47,12 +47,12 @@
     parms.option->type         = TYPE_STRING;
     parms.option->required     = YES;
     parms.option->multiple     = NO;
-    parms.option->options      = "cat,area,compact,fd,perimeter,length,count,coor,start,end,sides,query,slope";
+    parms.option->options      = "cat,area,compact,fd,perimeter,length,count,coor,start,end,sides,query,slope,sinuous";
     parms.option->description  = _("Value to upload");
     parms.option->descriptions  =
 		 "cat;insert new row for each category if doesn't exist yet;"
 		 "area;area size;"
-    	 "compact;compactness of an area, calculated as \n"
+		 "compact;compactness of an area, calculated as \n"
 		 "              compactness = perimeter / (2 * sqrt(PI * area));"
 		 "fd;fractal dimension of boundary defining a polygon, calculated as \n"
 		 "              fd = 2 * (log(perimeter) / log(area));"
@@ -66,7 +66,8 @@
 		       "'qlayer' is used for area category;"
 		 "query;result of a database query for all records of the geometry"
 		       "(or geometries) from table specified by 'qlayer' option;"
-		 "slope;slope steepness of vector line or boundary";
+		 "slope;slope steepness of vector line or boundary;"
+		 "sinuous;Line Sinuousity. Calculated as line length / distance between end points;";
     parms.units = G_define_option();
     parms.units->key   = "units";
@@ -138,7 +139,7 @@
     if (!options.print) {
 	if ( options.option == O_AREA || options.option == O_LENGTH || options.option == O_COUNT
 	     || options.option == O_QUERY || options.option == O_COMPACT || options.option == O_FD
-	     || options.option == O_PERIMETER || options.option == O_SLOPE ) /* one column required */
+	     || options.option == O_PERIMETER || options.option == O_SLOPE || options.option == O_SINUOUS ) /* one column required */
 	    if ( ncols != 1) {
 		G_fatal_error ( _("This option requires one column") );
@@ -162,6 +163,10 @@
     if ( options.option == O_SIDES && !(options.type | GV_BOUNDARY) )
 	G_fatal_error ( _("The 'sides' option makes sense only for boundaries"));
+    if ( options.option == O_SINUOUS && !(options.type | GV_LINES) )
+	G_fatal_error ( _("The 'sinuous' option makes sense only for lines"));
     return 0;
@@ -196,6 +201,7 @@
     else if (strcmp (s, "fd") == 0) x = O_FD;
     else if (strcmp (s, "perimeter") == 0) x = O_PERIMETER;
     else if (strcmp (s, "slope") == 0) x = O_SLOPE;
+    else if (strcmp (s, "sinuous") == 0) x = O_SINUOUS;
     return x;
Modified: grass/trunk/vector/v.to.db/report.c
--- grass/trunk/vector/v.to.db/report.c	2008-01-13 07:57:27 UTC (rev 29691)
+++ grass/trunk/vector/v.to.db/report.c	2008-01-13 12:05:46 UTC (rev 29692)
@@ -82,7 +82,12 @@
             break;
+        case O_SINUOUS:
+	    if (G_verbose() > G_verbose_min())
+		fprintf (stdout,"cat|sinuous\n");
+	    for ( i = 0; i < vstat.rcat; i++ )
+		fprintf (stdout, "%d|%.15g\n", Values[i].cat, Values[i].d1);
+            break;
         case O_COOR:
         case O_START:
         case O_END:
Modified: grass/trunk/vector/v.to.db/update.c
--- grass/trunk/vector/v.to.db/update.c	2008-01-13 07:57:27 UTC (rev 29691)
+++ grass/trunk/vector/v.to.db/update.c	2008-01-13 12:05:46 UTC (rev 29692)
@@ -50,6 +50,7 @@
 	case O_FD:
 	case O_PERIMETER:
         case O_SLOPE:
+        case O_SINUOUS:
 	    sprintf (buf1, "update %s set %s =", Fi->table, options.col[0]);
             break;
         case O_COOR:
@@ -82,6 +83,7 @@
 	    case O_FD:
 	    case O_PERIMETER:
 	    case O_SLOPE:
+	    case O_SINUOUS:
     		sprintf (buf2, "%s %f where %s = %d", buf1, Values[i].d1, Fi->key,  Values[i].cat);
         	break;
