[GRASS-SVN] r29693 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sun Jan 13 07:41:21 EST 2008
Author: martinl
Date: 2008-01-13 07:41:21 -0500 (Sun, 13 Jan 2008)
New Revision: 29693
grass/trunk/lib/vector/Vlib/area.c
grass/trunk/lib/vector/Vlib/array.c
grass/trunk/lib/vector/Vlib/box.c
grass/trunk/lib/vector/Vlib/break_polygons.c
grass/trunk/lib/vector/Vlib/bridges.c
grass/trunk/lib/vector/Vlib/buffer.c
grass/trunk/lib/vector/Vlib/build.c
grass/trunk/lib/vector/Vlib/build_nat.c
grass/trunk/lib/vector/Vlib/build_ogr.c
grass/trunk/lib/vector/Vlib/cats.c
grass/trunk/lib/vector/Vlib/clean_nodes.c
grass/trunk/lib/vector/Vlib/close.c
grass/trunk/lib/vector/Vlib/constraint.c
grass/trunk/lib/vector/Vlib/dangles.c
grass/trunk/lib/vector/Vlib/dbcolumns.c
grass/trunk/lib/vector/Vlib/error.c
grass/trunk/lib/vector/Vlib/field.c
grass/trunk/lib/vector/Vlib/graph.c
grass/trunk/lib/vector/Vlib/header.c
grass/trunk/lib/vector/Vlib/hist.c
grass/trunk/lib/vector/Vlib/init_head.c
grass/trunk/lib/vector/Vlib/intersect.c
grass/trunk/lib/vector/Vlib/legal_vname.c
grass/trunk/lib/vector/Vlib/level.c
grass/trunk/lib/vector/Vlib/level_two.c
grass/trunk/lib/vector/Vlib/line.c
grass/trunk/lib/vector/Vlib/list.c
grass/trunk/lib/vector/Vlib/map.c
grass/trunk/lib/vector/Vlib/net.c
grass/trunk/lib/vector/Vlib/open.c
grass/trunk/lib/vector/Vlib/overlay.c
grass/trunk/lib/vector/Vlib/poly.c
grass/trunk/lib/vector/Vlib/read.c
grass/trunk/lib/vector/Vlib/read_nat.c
grass/trunk/lib/vector/Vlib/read_ogr.c
grass/trunk/lib/vector/Vlib/remove_areas.c
grass/trunk/lib/vector/Vlib/remove_duplicates.c
grass/trunk/lib/vector/Vlib/rewind.c
grass/trunk/lib/vector/Vlib/select.c
grass/trunk/lib/vector/Vlib/sindex.c
grass/trunk/lib/vector/Vlib/snap.c
grass/trunk/lib/vector/Vlib/tin.c
grass/trunk/lib/vector/Vlib/type.c
grass/trunk/lib/vector/Vlib/write.c
Do not use structural commands (like \fn) in doxygen docs. I18n updated.
Modified: grass/trunk/lib/vector/Vlib/area.c
--- grass/trunk/lib/vector/Vlib/area.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/area.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,32 +1,37 @@
-* MODULE: Vector library
-* AUTHOR(S): Original author CERL, probably Dave Gerdes or Mike Higgins.
-* Update to GRASS 5.7 Radim Blazek and David D. Gray.
-* PURPOSE: Higher level functions for reading/writing/manipulating vectors.
-* COPYRIGHT: (C) 2001 by the GRASS Development Team
-* This program is free software under the GNU General Public
-* License (>=v2). Read the file COPYING that comes with GRASS
-* for details.
+ \file area.c
+ \brief Vector library - area feature related fns
+ Higher level functions for reading/writing/manipulating vectors.
+ (C) 2001-2008 by the GRASS Development Team
+ This program is free software under the
+ GNU General Public License (>=v2).
+ Read the file COPYING that comes with GRASS
+ for details.
+ \author Original author CERL, probably Dave Gerdes or Mike Higgins.
+ Update to GRASS 5.7 Radim Blazek and David D. Gray.
+ \date 2001-2008
#include <stdlib.h>
#include <grass/gis.h>
#include <grass/Vect.h>
+#include <grass/glocale.h>
- \fn int Vect_get_area_points (
- struct Map_info *Map,
- int area,
- struct line_pnts *BPoints)
- \brief returns the polygon array of points in BPoints
- \return number of points or -1 on error
- \param Map_info structure, area number, line_pnts structure
+ \brief Returns the polygon array of points in BPoints
+ \param Map vector map
+ \param area area id
+ \param[out] BPoints points array
+ \return number of points
+ \return -1 on error
int
@@ -47,7 +52,7 @@
Area = Plus->Area[area];
if ( Area == NULL ) { /* dead area */
- G_warning ("Attempt to read points of nonexisting area" );
+ G_warning (_("Attempt to read points of nonexisting area"));
return -1; /* error , because we should not read dead areas */
@@ -84,13 +89,13 @@
- \fn int Vect_get_isle_points (
- int isle,
- \param Map_info structure, island number, line_pnts structure
+ \param isle island id
+ \return number of points or -1 on error
int
@@ -123,7 +128,7 @@
G_debug ( 3, " append line(%d) = %d", i, line );
if (0 > Vect_read_line (Map, Points, NULL, aline)) {
- G_fatal_error ( "Cannot read line %d", aline );
+ G_fatal_error (_("Unable to read line %d"), aline );
G_debug ( 3, " line n_points = %d", Points->n_points );
@@ -143,12 +148,13 @@
- \fn int Vect_get_area_centroid (
- int area )
- \brief returns centroid number of area
- \return centroid number of area or 0
+ \brief Returns centroid number of area
+ \return centroid number of area
+ \return 0 if no centroid found
int
@@ -163,19 +169,20 @@
Plus = &(Map->plus);
- if ( Area == NULL ) G_fatal_error ( "Attempt to read topo for dead area (%d)", area);
+ if ( Area == NULL )
+ G_fatal_error (_("Attempt to read topo for dead area (%d)"), area);
return ( Area->centroid );
- \fn int Vect_get_area_boundaries (
- int area,
- struct ilist *List )
- \brief creates list of boundaries for area
- \return number of boundaries
- \param Map_info structure, area number, List pointer to list
+ \brief Creates list of boundaries for area
+ \param List pointer to list of boundaries
+ \return number of boundaries
int
@@ -194,7 +201,8 @@
for (i = 0; i < Area->n_lines; i++) {
line = Area->lines[i];
@@ -205,15 +213,13 @@
- \fn int Vect_get_isle_boundaries (
- int isle,
- \brief creates list of boundaries for isle
- \param Map vector map
- \param isle island number
- \param List pointer to list where boundaries are stored
+ \brief Creates list of boundaries for isle
+ \param isle island number
+ \param List pointer to list where boundaries are stored
int
@@ -243,12 +249,13 @@
- \fn int Vect_get_area_num_isles (
- int area )
- \brief returns number of isles for area
- \return number of isles for area or 0
+ \brief Returns number of isles for area
+ \return number of isles for area
+ \return 0 if area not found
int
@@ -263,7 +270,8 @@
G_debug ( 3, " n_isles = %d", Area->n_isles );
@@ -272,13 +280,14 @@
- \fn int Vect_get_area_isle (
- int area,
- int isle)
- \brief returns isle for area
- \return isles for area or 0
- \param Map_info structure, area number, island number
+ \brief Returns isle for area
+ \param isle isle id
+ \return isles for area
+ \return 0 if no isle found
int
@@ -294,7 +303,8 @@
G_debug ( 3, " -> isle = %d", Area->isles[isle] );
@@ -302,11 +312,13 @@
- \fn int Vect_get_isle_area ( struct Map_info *Map, int isle)
- \brief returns area for isle
- \return area or 0
- \param Map vector
- \isle island number
+ \brief Returns area for isle
+ \param Map vector
+ \return area id
+ \return 0 area not found
int
@@ -319,7 +331,8 @@
Isle = Plus->Isle[isle];
- if ( Isle == NULL ) G_fatal_error ( "Attempt to read topo for dead isle (%d)", isle);
+ if ( Isle == NULL )
+ G_fatal_error (_("Attempt to read topo for dead isle (%d)"), isle);
G_debug ( 3, " -> area = %d", Isle->area );
@@ -328,11 +341,11 @@
- * \fn double Vect_area_perimeter ( struct line_pnts *Points )
- * \brief calculate area perimeter
- * \return area perimeter
- * \param line_pnts * structure
+ \brief Calculate area perimeter
+ \param Points list of points defining area boundary
+ \return area perimeter
double
@@ -342,13 +355,14 @@
- \fn int Vect_point_in_area (
- int area,
- double x, double y)
- \brief returns 1 if point is in area
- \return 1 if point is in area 0 if not
- \param Map_info structure, area number, xy coordinate of point
+ \brief Returns 1 if point is in area
+ \param x,y point coordinates
+ \return 1 if point is in area
+ \return 0 if not
int
@@ -379,13 +393,12 @@
- \fn double Vect_get_area_area (
- int area)
- \brief returns area of area without areas of isles
- \return area of area without areas of isles
- \param area number
+ \brief Returns area of area without areas of isles
+ \return area of area without areas of isles
double
@@ -427,11 +440,14 @@
-\brief Get area categories
-\param vmap: Map input
-\param varea: area number
-\return 0 OK centroid found (but may be without categories)
-\return 1 no centroid found
+ \brief Get area categories
+ \param[out] Cats list of categories
+ \return 0 OK centroid found (but may be without categories)
+ \return 1 no centroid found
int
Vect_get_area_cats ( struct Map_info *Map, int area, struct line_cats *Cats )
@@ -452,11 +468,14 @@
-\brief Find FIRST category of given field and area
-\return first found category of given field
-\return -1 no centroid or no category found
+ \brief Find FIRST category of given field and area
+ \param field layer number
+ \return first found category of given field
+ \return -1 no centroid or no category found
int
Vect_get_area_cat ( struct Map_info *Map, int area, int field )
@@ -481,4 +500,3 @@
return -1;
Modified: grass/trunk/lib/vector/Vlib/array.c
--- grass/trunk/lib/vector/Vlib/array.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/array.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,18 +1,22 @@
-* AUTHOR(S): Radim Blazek
-* for details.
+ \file array.c
+ \brief Vector library - array structure
+ for details.
+ \author Radim Blazek
+ \date 2001-2008
#include <stdlib.h>
#include <grass/dbmi.h>
@@ -26,12 +30,15 @@
- \fn VARRAY *Vect_new_varray (int size)
\brief Create new VARRAY and allocate space for given number of items.
Space allocated is 'size + 1' so that lines are accessed by line id.
Array values are set to 0.
- Returns : pointer to new VARRAY
- NULL if failed
+ \param size size of array
+ \return pointer to new VARRAY
+ \return NULL if failed
VARRAY *
@@ -55,17 +62,23 @@
- \fn int Vect_set_varray_from_cat_string ( struct Map_info *Map, int field, char *cstring,
- int type, int value, VARRAY *varray )
- \brief Set values in 'varray' to 'value' if category of object of given type is in
- 'cstring' (string representing category list like: '1,3,5-7').
- 'type' may be either: GV_AREA
- or: GV_POINT | GV_LINE | GV_BOUNDARY | GV_CENTROID
+ \brief Set values in 'varray' to 'value'.
+ If category of object of given type is in 'cstring' (string
+ representing category list like: '1,3,5-7'). 'type' may be either:
+ GV_AREA or: GV_POINT | GV_LINE | GV_BOUNDARY | GV_CENTROID
Array is not reset to zero before, but old values (if any > 0) are overwritten.
- Return: number of items set
- -1 on error
+ \param cstring pointer to string with categories
+ \param type feature type
+ \param value value to set up
+ \param[in,out] varray varray structure to modify
+ \return number of items set
int
@@ -93,17 +106,23 @@
- \fn int Vect_set_varray_from_cat_list ( struct Map_info *Map, int field, struct cat_list *clist,
- \brief
- Set values in 'varray' to 'value' if category of object of given type is in 'clist' (category list).
+ If category of object of given type is in 'clist' (category list).
+ 'type' may be either: GV_AREA or: GV_POINT | GV_LINE | GV_BOUNDARY |
+ GV_CENTROID
- -1 on error
+ \param clist list of categories
int
@@ -118,7 +137,7 @@
/* Check type */
if ( (type & GV_AREA) && (type & (GV_POINTS | GV_LINES)) ) {
- G_warning(_("Mixed area and other type requested for vector array."));
+ G_warning(_("Mixed area and other type requested for vector array"));
return 0;
@@ -128,7 +147,7 @@
n = Vect_get_num_areas (Map);
if ( n > varray->size ) { /* not enough space */
- G_warning(_("Not enough space in vector array."));
+ G_warning(_("Not enough space in vector array"));
return 0;
@@ -148,7 +167,7 @@
n = Vect_get_num_lines (Map);
return 0;
@@ -196,24 +215,31 @@
- \fn int Vect_set_varray_from_db ( struct Map_info *Map, int field, char *where,
- categories selected from DB based on where statement (given without where).
- Array is not reset to zero before, but old values (if any > 0) are overwritten.
+ if category of object of given type is in categories selected from
+ DB based on where statement (given without where). 'type' may be
+ either: GV_AREA or: GV_POINT | GV_LINE | GV_BOUNDARY | GV_CENTROID
- -1 on error
+ Array is not reset to zero before, but old values (if any > 0) are
+ overwritten.
+ \param where where statement
int
int i, n, c, centr, cat, *cats;
- size_t ncats;
+ int ncats;
int ni = 0; /* number of items set */
int ltype; /* line type */
struct line_cats *Cats;
@@ -226,7 +252,7 @@
/* Check type */
return 0;
@@ -235,13 +261,14 @@
/* Select categories from DB to array */
Fi = Vect_get_field ( Map, field);
if ( Fi == NULL ) {
- G_warning(_("Cannot get field info"));
+ G_warning(_("Database connection not defined for layer %d"), field);
return -1;
driver = db_start_driver_open_database ( Fi->driver, Fi->database );
if ( driver == NULL ) {
- G_warning(_("Cannot open database"));
+ G_warning(_("Unable to open database <%s> by driver <%s>"),
+ Fi->database, Fi->driver);
return -1;
@@ -250,7 +277,8 @@
db_close_database_shutdown_driver ( driver );
if(ncats == -1) {
- G_warning(_("Could not select from table/column"));
+ G_warning(_("Unable to select record from table <%s> (key %s, where %s)"),
+ Fi->table, Fi->key, where);
return -1;
@@ -258,7 +286,7 @@
return 0;
@@ -288,7 +316,7 @@
return 0;
@@ -321,4 +349,3 @@
return ni;
Modified: grass/trunk/lib/vector/Vlib/box.c
--- grass/trunk/lib/vector/Vlib/box.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/box.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,28 +1,34 @@
-* for details.
+ \file array.c
+ \brief Vector library - bounding box related fns
+ for details.
+ \date 2001-2008
#include <stdlib.h>
- \fn int Vect_point_in_box (double x, double y, double z, BOUND_BOX *Box)
- \brief tests for point in box
- \return 1 point is in box, 0 point is not in box
- \param xyz coordinates, boundary box
+ \brief Tests for point in box
+ \param x,y,z coordinates
+ \param Box boundary box
+ \return 1 point is in box
+ \return 0 point is not in box
int
@@ -39,10 +45,13 @@
- \fn int Vect_box_overlap (BOUND_BOX *A, BOUND_BOX *B)
- \brief tests for overlap of two boxes
- \return 1 boxes overlap, 0 boxes do not overlap
- \param boundary box A, boundary box B
+ \brief Tests for overlap of two boxes
+ \param A boundary box A
+ \param B boundary box B
+ \return 1 boxes overlap
+ \return 0 boxes do not overlap
int
@@ -59,10 +68,12 @@
- \fn int Vect_box_copy (BOUND_BOX *A, BOUND_BOX *B)
- \brief copy box B to box A
- \return 1
- \param boundary box1, boundary box2
+ \brief Copy box B to box A
+ \param A boundary A
+ \param B boundary B
+ \return 1
int
@@ -79,10 +90,12 @@
- \fn int Vect_box_extend (BOUND_BOX *A, BOUND_BOX *B)
- \brief extend box A by box B
- \return 1
+ \brief Extend box A by box B
+ \return 1
int
@@ -100,8 +113,7 @@
- * \fn int Vect_box_clip (double *x, double *y, double *c_x, double *c_y, BOUND_BOX *Box)
- * \brief clip coordinates to box, if necessary, lines extending outside of a box.
+ * \brief Clip coordinates to box, if necessary, lines extending outside of a box.
* A line represented by the coordinates <b>x, y</b> and <b>c_x, c_y</b> is clipped to
* the window defined by <b>s</b> (south), <b>n</b> (north), <b>w</b>
@@ -116,12 +128,12 @@
* <b>e.</b> The <b>y</b> and <b>c_y</b> values returned lie between
* <b>s</b> and <b>n.</b>
- * \param x
- * \param y
- * \param c_x
- * \param c_y
- * \param boundary box
- * \return 1 if any clipping occured, 0 otherwise
+ * \param x, y coordinates (w, e)
+ * \param c_x,c_y coordinates (s, n)
+ * \param Box boundary box
+ * \return 1 if any clipping occured
+ * \return 0 otherwise
int
@@ -194,10 +206,14 @@
- \fn int Vect_get_line_box (struct Map_info *Map, int line, BOUND_BOX *Box )
- \brief get line number in boundary box ??
- \return 1 on success, 0 line is dead
- \param Map_info structure, line number, boundary box
+ \brief Get boundary box of line
+ \param line line id
+ \param[out] Box bounding box
+ \return 1 on success
+ \return 0 line is dead
int
@@ -229,10 +245,14 @@
- \fn int Vect_get_area_box (struct Map_info *Map, int area, BOUND_BOX *Box )
- \brief get area number in boundary box ?
- \return 1 on success, 0 area is dead
- \param Map_info structure, area number, boundary box
+ \brief Get boundary box of area
+ \return 0 area is dead
int
@@ -264,10 +284,14 @@
- \fn int Vect_get_isle_box (struct Map_info *Map, int isle, BOUND_BOX *Box )
- \brief get isle number in boundary box ?
- \return 1 on success, 0 isle is dead
- \param Map_info structure, isle number, boundary box
+ \brief Get boundary box of isle
+ \return 0 isle is dead
int
@@ -299,10 +323,12 @@
- \fn int Vect_get_map_box (struct Map_info *Map, BOUND_BOX *Box )
- \brief falls map into boundary box ???
- \return 1 on success, 0 on error
- \param Map_info structure, boundary box
+ \brief Get boundary box of map
+ \param[out] Box bouding box
+ \return 1 on success, 0 on error
int
@@ -323,10 +349,12 @@
- \fn int Vect_region_box (struct Cell_head *Window, BOUND_BOX *Box )
- \brief copy region Window to Box
- \param region structure, boundary box
+ \brief Copy region Window to Box
+ \param Window region structure (raster-based)
+ \param[out] Box boundary box (vector-based)
int
Vect_region_box ( struct Cell_head *Window, BOUND_BOX *Box )
Modified: grass/trunk/lib/vector/Vlib/break_polygons.c
--- grass/trunk/lib/vector/Vlib/break_polygons.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/break_polygons.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,23 +1,27 @@
- * MODULE: vector library
- * AUTHOR(S): Radim Blazek
- * PURPOSE: Clean lines
- * COPYRIGHT: (C) 2001 by the GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
+ \file break_polygons.c
+ \brief Vector library - clean geometry (break polygons)
+ for details.
+ \date 2001-2008
#include <stdlib.h>
#include <math.h>
typedef struct {
double x, y;
@@ -36,22 +40,22 @@
- \fn void Vect_break_polygons ( struct Map_info *Map, int type, struct Map_info *Err, FILE *msgout)
- \brief Break polygons in vector map.
+ \brief Break polygons in vector map.
+ Breaks lines specified by type in vector map. Points at intersections may be optionaly
+ written to error map. Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
+ Function is optimized for closed polygons rigs (e.g. imported from OGR) but with clean geometry -
+ adjacent polygons mostly have identical boundary. Function creates database of ALL points
+ in the map, and then is looking for those where polygons should be broken.
+ Lines may be broken only at points existing in input map!
+ \param Map input map where polygons will be broken
+ \param type type of line to be broken
+ \param Err vector map where points at intersections will be written or NULL
+ \param msgout file pointer where messages will be written or NULL
- Breaks lines specified by type in vector map. Points at intersections may be optionaly
- written to error map. Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
- Function is optimized for closed polygons rigs (e.g. imported from OGR) but with clean geometry -
- adjacent polygons mostly have identical boundary. Function creates database of ALL points
- in the map, and then is looking for those where polygons should be broken.
- Lines may be broken only at points existing in input map!
- \param Map input map where polygons will be broken
- \param type type of line to be broken
- \param Err vector map where points at intersections will be written or NULL
- \param msgout file pointer where messages will be written or NULL
- \return
+ \return
void
Vect_break_polygons ( struct Map_info *Map, int type, struct Map_info *Err, FILE *msgout )
@@ -184,24 +188,24 @@
if ( msgout && printed > 5000 ) {
- fprintf (msgout, "\rRegistering points ... %d", npoints - 1);
+ fprintf (msgout, "\r%s %d", _("Registering points"), npoints - 1);
fflush ( msgout );
printed = 0;
printed++;
if ( msgout ) {
- fprintf (msgout, "\rRegistering points ... %d", npoints - 1 );
- fprintf ( msgout, "\n" );
- fprintf ( msgout, "All points (vertices): %5d\n", nallpoints );
- fprintf ( msgout, "Registered points (unique coordinates): %5d\n", npoints - 1 );
- fprintf ( msgout, "Points marked for break: %5d\n", nmarks );
+ fprintf (msgout, "\r%s %d", _("Registering points"), npoints - 1 );
+ fprintf (msgout, "\n" );
+ fprintf (msgout, "%s: %5d\n", _("All points (vertices)"), nallpoints );
+ fprintf (msgout, "%s: %5d\n", _("Registered points (unique coordinates)"), npoints - 1 );
+ fprintf (msgout, "%s: %5d\n", _("Points marked for break"), nmarks );
/* G_sleep (10); */
nbreaks = 0;
- if ( msgout ) fprintf (msgout, "Breaks: %5d", nbreaks );
+ if ( msgout ) fprintf (msgout, "%s: %5d", _("Breaks"), nbreaks );
printed = 0;
/* Second loop through lines (existing when loop is started, no need to process lines written again)
@@ -265,7 +269,7 @@
if ( msgout && printed > 1000 ) {
- fprintf ( msgout, "\rBreaks: %5d", nbreaks );
+ fprintf ( msgout, "\r%s: %5d", _("Breaks"), nbreaks );
fflush ( msgout );
printed = 0;
@@ -285,7 +289,7 @@
if ( msgout )
/* Write points on breaks */
if ( Err ) {
@@ -304,4 +308,3 @@
G_free ( XPnts );
RTreeDestroyNode ( RTree);
Modified: grass/trunk/lib/vector/Vlib/bridges.c
--- grass/trunk/lib/vector/Vlib/bridges.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/bridges.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,29 +1,32 @@
- * for details.
+ \file bridges.c
+ \brief Vector library - clean geometry (bridges)
+ for details.
+ \date 2001-2008
#include <stdlib.h>
-void
+static void
remove_bridges ( struct Map_info *Map, int chtype, struct Map_info *Err, FILE *msgout );
- \fn void Vect_remove_bridges ( struct Map_info *Map, struct Map_info *Err, FILE *msgout)
- \brief Remove bridges from vector map.
+ \brief Remove bridges from vector map.
Remove bridges (type boundary) connecting areas to islands or 2 islands.
Islands and areas must be already clean, i.e. without dangles.
@@ -31,9 +34,11 @@
Optionaly deleted bridges are written to error map.
Input map must be opened on level 2 for update at least on level GV_BUILD_BASE
- \param Map input map where bridges are deleted
- \param Err vector map where deleted bridges are written or NULL
+ \param Map input map where bridges are deleted
+ \param Err vector map where deleted bridges are written or NULL
+ \return
void
@@ -43,8 +48,7 @@
- \brief Change type of bridges in vector map.
+ \brief Change type of bridges in vector map.
Change the type of bridges (type boundary) connecting areas to islands or 2 islands.
@@ -52,9 +56,11 @@
Optionaly changed bridges are written to error map.
Input map must be opened on level 2 for update at least on level GV_BUILD_BASE.
- \param Map input map where bridges are changed
- \param Err vector map where changed bridges are written or NULL
+ \param Map input map where bridges are changed
+ \param Err vector map where changed bridges are written or NULL
+ \return
void
@@ -75,7 +81,6 @@
traversed from other side it is a bridge.
List of all lines in chain is created during the cycle.
void
@@ -109,8 +114,8 @@
G_debug (1, "nlines = %d", nlines );
- if ( msgout ) fprintf (msgout, "Removed bridges: %5d %s: %5d",
- bridges_removed, lmsg, lines_removed );
+ if ( msgout ) fprintf (msgout, "%s: %5d %s: %5d",
+ _("Removed bridges"), bridges_removed, lmsg, lines_removed );
for ( line = 1; line <= nlines; line++ ){
if ( !Vect_line_alive ( Map, line ) ) continue;
@@ -182,16 +187,14 @@
if ( msgout ) {
- fprintf (msgout, "\rRemoved bridges: %5d %s: %5d",
+ fprintf (msgout, "\r%s: %5d %s: %5d",
fflush ( msgout );
if ( msgout ) {
Modified: grass/trunk/lib/vector/Vlib/buffer.c
--- grass/trunk/lib/vector/Vlib/buffer.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/buffer.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,9 +1,22 @@
-/* Functions: nearest, adjust_line, parallel_line
-** Author: Radim Blazek Feb 2000
+ \file buffer.c
+ \brief Vector library - nearest, adjust_line, parallel_line
+ for details.
+ \date 2001-2008
#include <stdlib.h>
#include <math.h>
@@ -35,7 +48,7 @@
** -1 found overlap
** 0 not found
-int find_cross ( struct line_pnts *Points, int s1, int s2, int s3, int s4, int *s5, int *s6 )
+static int find_cross ( struct line_pnts *Points, int s1, int s2, int s3, int s4, int *s5, int *s6 )
int i, j, np, ret;
double *x, *y;
@@ -79,7 +92,7 @@
** returns: 1 in buffer
** 0 not in buffer
-int point_in_buf ( struct line_pnts *Points, double px, double py, double d )
+static int point_in_buf ( struct line_pnts *Points, double px, double py, double d )
int i, np;
double sd;
@@ -114,7 +127,7 @@
** than I am should write paralle_line + clean_parallel
** better; RB March 2000
-void clean_parallel ( struct line_pnts *Points, struct line_pnts *origPoints, double d , int rm_end )
+static void clean_parallel ( struct line_pnts *Points, struct line_pnts *origPoints, double d , int rm_end )
int i, j, np, npn, sa, sb;
int sa_max = 0;
@@ -238,7 +251,7 @@
* New line is written to existing nPoints structure.
-void parallel_line (struct line_pnts *Points, double d, double tol, struct line_pnts *nPoints)
+static void parallel_line (struct line_pnts *Points, double d, double tol, struct line_pnts *nPoints)
int i, j, np, na, side;
double *x, *y, nx, ny, tx, ty, vx, vy, ux, uy, wx, wy;
@@ -311,14 +324,15 @@
- \fn void Vect_line_parallel ( struct line_pnts *InPoints, double distance, double tolerance, int rm_end,
- struct line_pnts *OutPoints )
\brief Create parrallel line
\param InPoints input line
- \param distance
+ \param distance create parrallel line in distance
\param tolerance maximum distance between theoretical arc and polygon segments
\param rm_end remove end points falling into distance
- \param OutPoints output line
+ \param[out] OutPoints output line
+ \return
void
@@ -330,22 +344,24 @@
parallel_line ( InPoints, distance, tolerance, OutPoints);
clean_parallel ( OutPoints, InPoints, distance, rm_end );
+ return;
- \fn void Vect_line_buffer ( struct line_pnts *InPoints, double distance, double tolerance,
\brief Create buffer around the line line.
- Buffer is closed counter clockwise polygon.
- Warning: output line may contain loops!
+ Buffer is closed counter clockwise polygon.
+ Warning: output line may contain loops!
- \param distance
+ \param distance create buffer in distance
void
+ struct line_pnts *OutPoints )
double dangle;
int side, npoints;
@@ -439,6 +455,8 @@
Vect_append_point ( OutPoints, OutPoints->x[0], OutPoints->y[0], 0 );
Vect_line_prune ( OutPoints );
+ return;
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/build.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,20 +1,22 @@
-* for details.
+ \file build.c
+ \brief Vector library - Building topology
+ for details.
+ \date 2001-2008
#include <stdlib.h>
#include <stdio.h>
#include <stdarg.h>
@@ -56,11 +58,13 @@
- \fn int Vect_build ( struct Map_info *Map, FILE *msgout )
- \brief build topology for vector map
- \param msgout file for message output (stdout/stderr for example) or NULL
+ \brief Build topology for vector map
+ \param msgout file for message output (stdout/stderr for example) or NULL
+ \return 0 on error
int
@@ -70,10 +74,11 @@
- \fn int Vect_get_built ( struct Map_info *Map )
- \brief return current highest built level (part)
- \return current highest built level
+ \brief Return current highest built level (part)
+ \return current highest built level
int
@@ -82,38 +87,41 @@
- \fn int Vect_build_partial ( struct Map_info *Map, int top, FILE *msgout )
- \brief build partial topology for vector map. Should only be used in special cases
- of vector processing.
+ \brief Build partial topology for vector map.
- This functions optionaly builds only some parts of topology. Highest level is specified by build
- parameter which may be:
- GV_BUILD_NONE - nothing is build;
- GV_BUILD_BASE - basic topology, nodes, spatial index;
- GV_BUILD_AREAS - build areas and islands, but islands are not attached to areas;
- GV_BUILD_ATTACH_ISLES - attach islands to areas;
- GV_BUILD_CENTROIDS - assign centroids to areas;
- GV_BUILD_ALL - top level, the same as GV_BUILD_CENTROIDS.
+ Should only be used in special cases of vector processing.
- If functions is called with build lower than current value of the Map, the level is downgraded to
- requested value.
+ This functions optionaly builds only some parts of topology. Highest level is specified by build
+ parameter which may be:
+ - GV_BUILD_NONE - nothing is build;
+ - GV_BUILD_BASE - basic topology, nodes, spatial index;
+ - GV_BUILD_AREAS - build areas and islands, but islands are not attached to areas;
+ - GV_BUILD_ATTACH_ISLES - attach islands to areas;
+ - GV_BUILD_CENTROIDS - assign centroids to areas;
+ - GV_BUILD_ALL - top level, the same as GV_BUILD_CENTROIDS.
- All calls to Vect_write_line(), Vect_rewrite_line(), Vect_delete_line() respect the last value of
- build used in this function.
+ If functions is called with build lower than current value of the Map, the level is downgraded to
+ requested value.
- Values lower than GV_BUILD_ALL are supported only by GV_FORMAT_NATIVE,
- other formats ignore build and build always GV_BUILD_ALL
+ All calls to Vect_write_line(), Vect_rewrite_line(), Vect_delete_line() respect the last value of
+ build used in this function.
- Note that the functions has effect only if requested level is higher than current level, to rebuild
- part of topology, call first downgrade and then upgrade, for example:
- Vect_build()
- Vect_build_partial(,GV_BUILD_BASE,)
- Vect_build_partial(,GV_BUILD_AREAS,)
+ Values lower than GV_BUILD_ALL are supported only by GV_FORMAT_NATIVE,
+ other formats ignore build and build always GV_BUILD_ALL
+ Note that the functions has effect only if requested level is higher than current level, to rebuild
+ part of topology, call first downgrade and then upgrade, for example:
+ Vect_build()
+ Vect_build_partial(,GV_BUILD_BASE,)
+ Vect_build_partial(,GV_BUILD_AREAS,)
- \param build highest level of build
- \param msgout file pointer for message output (stdout/stderr for example) or NULL
+ \param build highest level of build
+ \param msgout file pointer for message output (stdout/stderr for example) or NULL
int
Vect_build_partial ( struct Map_info *Map, int build, FILE *msgout )
@@ -132,7 +140,7 @@
Map->plus.Spidx_built = 1;
plus = &(Map->plus);
- prnmsg ( _("Building topology ...\n") );
+ prnmsg ( _("Building topology for vector map <%s>...\n"), Vect_get_name(Map));
plus->with_z = Map->head.with_z;
plus->spidx_with_z = Map->head.with_z;
@@ -145,7 +153,7 @@
if ( ret == 0 ) { return 0; }
- prnmsg (_("Topology was built.\n"));
+ prnmsg (_("Topology was built\n"));
Map->level = LEVEL_2;
plus->mode = GV_MODE_WRITE;
@@ -226,16 +234,17 @@
- \fn int Vect_save_topo ( struct Map_info *Map )
- \brief save topology file for vector map
+ \brief Save topology file for vector map
int
struct Plus_head *plus ;
- char fname[1024], buf[1024];
+ char fname[GPATH_MAX], buf[GPATH_MAX];
GVFILE fp;
G_debug (1, "Vect_save_topo()");
@@ -249,15 +258,15 @@
dig_file_init ( &fp );
fp.file = fopen( fname, "w");
if ( fp.file == NULL) {
- G_warning(_("Can't open topo file for write <%s>"), fname);
- return 0;
+ G_warning(_("Unable to open topo file for write <%s>"), fname);
+ return 0;
/* set portable info */
dig_init_portable ( &(plus->port), dig__byte_order_out ());
if ( 0 > dig_write_plus_file (&fp, plus) ) {
- G_warning (_("Error writing out topo file."));
+ G_warning (_("Error writing out topo file"));
return 0;
@@ -267,11 +276,13 @@
- \fn int Vect_topo_dump ( struct Map_info *Map, FILE *out )
- \brief dump topology to file
- \param out file for output (stdout/stderr for example)
+ \brief Dump topology to file
+ \param out file for output (stdout/stderr for example)
int
@@ -366,16 +377,18 @@
- \fn int Vect_save_spatial_index ( struct Map_info *Map )
- \brief save spatial index file
+ \brief Save spatial index file
int
GVFILE fp;
G_debug (1, "Vect_save_spatial_index()");
@@ -389,15 +402,15 @@
- G_warning(_("Can't open spatial index file for write <%s>"), fname);
- return 0;
+ G_warning(_("Unable open spatial index file for write <%s>"), fname);
+ return 0;
dig_init_portable ( &(plus->spidx_port), dig__byte_order_out ());
if ( 0 > dig_write_spidx (&fp, plus) ) {
- G_warning (_("Error writing out spatial index file."));
+ G_warning (_("Error writing out spatial index file"));
return 0;
@@ -407,11 +420,13 @@
- \fn int Vect_spatial_index_dump ( struct Map_info *Map, FILE *out )
- \brief dump spatial index to file
+ \brief Dump spatial index to file
int
@@ -426,4 +441,3 @@
return 1;
Modified: grass/trunk/lib/vector/Vlib/build_nat.c
--- grass/trunk/lib/vector/Vlib/build_nat.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/build_nat.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,20 +1,21 @@
-* for details.
+ \file build_nat.c
+ \brief Vector library - Building topology for native format
+ for details.
+ \date 2001-2008
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
@@ -26,10 +27,15 @@
extern int prnmsg ( char *msg, ...) ;
- \fn int Vect_build_line_area ( struct Map_info *Map, int iline, int side )
- \brief build area on given side of line ( GV_LEFT or GV_RIGHT )
- \return > 0 : number of area, < 0 : number of isle, 0 : not created (may also already exist)
- \param Map_info structure, line number ?, side (left? right?)
+ \brief Build area on given side of line (GV_LEFT or GV_RIGHT)
+ \param Map_info vector map
+ \param iline line id
+ \param side side (GV_LEFT or GV_RIGHT)
+ \return > 0 number of area
+ \return < 0 number of isle
+ \return 0 not created (may also already exist)
int
@@ -84,7 +90,7 @@
area = dig_add_area (plus, n_lines, lines);
if ( area == -1 ) { /* error */
Vect_close ( Map );
- G_fatal_error ( _("Cannot add area (map closed, topo saved)") );
+ G_fatal_error ( _("Unable to add area (map closed, topo saved)") );
G_debug ( 3, " -> area %d", area );
return area;
@@ -92,7 +98,7 @@
isle = dig_add_isle (plus, n_lines, lines);
if ( isle == -1 ) { /* error */
Vect_close ( Map );
- G_fatal_error ( _("Cannot add isle (map closed, topo saved)") );
+ G_fatal_error ( _("Unable to add isle (map closed, topo saved)") );
G_debug ( 3, " -> isle %d", isle );
return -isle;
@@ -107,10 +113,13 @@
- \fn int Vect_isle_find_area ( struct Map_info *Map, int isle )
- \brief find area outside island
- \return number of area(s), 0 if not found
+ \brief Find area outside island
+ \return number of area(s)
+ \return 0 if not found
int
@@ -135,7 +144,7 @@
if ( plus->Isle[isle] == NULL ) {
- G_warning ("Request to find area outside nonexisting isle");
+ G_warning (_("Request to find area outside nonexisting isle"));
return 0;
@@ -224,10 +233,12 @@
- \fn int Vect_attach_isle ( struct Map_info *Map, int isle )
- \brief (Re)Attach isle to area
- \return ? not sure yet what should be returned
+ \brief (Re)Attach isle to area
+ \return 0
int
@@ -257,10 +268,12 @@
- \fn int Vect_attach_isles ( struct Map_info *Map, BOUND_BOX *box )
- \brief (Re)Attach isles to areas in given box
- \param Map_info structure, BOUND_BOX
+ \brief (Re)Attach isles to areas in given box
+ \param box bounding box
+ \return 0
int
@@ -290,10 +303,12 @@
- \fn int Vect_attach_centroids ( struct Map_info *Map, BOUND_BOX *box )
- \brief (Re)Attach centroids to areas in given box
+ \brief (Re)Attach centroids to areas in given box
+ \return 0
int
@@ -377,10 +392,14 @@
- \fn int Vect_build_nat ( struct Map_info *Map, FILE *msgout )
- \param Map_info structure, msgout - message output (stdout/stderr for example) or NULL
+ \param build build level
+ \param msgout message output (stdout/stderr for example) or NULL
int
Vect_build_nat ( struct Map_info *Map, int build, FILE *msgout )
@@ -470,7 +489,7 @@
type = Vect_read_next_line (Map, Points, Cats);
/* Note: check for dead lines is not needed, because they are skipped by V1_read_next_line_nat() */
if ( type == -1 ) {
- fprintf (stderr, "\nERROR: vector map - can't read\n" );
+ G_warning(_("Unable to read vector map"));
return 0;
} else if ( type == -2 ) {
break;
@@ -514,7 +533,7 @@
if ( plus->built < GV_BUILD_AREAS ) {
/* Build areas */
/* Go through all bundaries and try to build area for both sides */
- prnmsg ("Building areas: ");
+ prnmsg (_("Building areas: "));
for (i = 1; i <= plus->n_lines; i++) {
G_percent2 ( i, plus->n_lines, 1, msgout );
@@ -605,5 +624,3 @@
return 1;
Modified: grass/trunk/lib/vector/Vlib/build_ogr.c
--- grass/trunk/lib/vector/Vlib/build_ogr.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/build_ogr.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,18 +1,22 @@
-* AUTHOR(S): Radim Blazek, Piero Cavalieri
-* for details.
+ \file build_ogr.c
+ \brief Vector library - Building topology for OGR
+ for details.
+ \author Radim Blazek, Piero Cavalieri
+ \date 2001-2008
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
@@ -21,15 +25,14 @@
-* Line offset is
-* - centroids : FID
-* - other types : index of the first record (which is FID) in offset array.
-* Category: FID, not all layer have FID, OGRNullFID is defined (5/2004) as -1, so FID should be only >= 0
+ * Line offset is
+ * - centroids : FID
+ * - other types : index of the first record (which is FID) in offset array.
+ * Category: FID, not all layer have FID, OGRNullFID is defined (5/2004) as -1, so FID should be only >= 0
#ifdef HAVE_OGR
#include <ogr_api.h>
@@ -84,7 +87,7 @@
/* Add parts to offset */
-static void add_parts_to_offset ( struct Map_info *Map, GEOM_PARTS *parts, int line )
+static void add_parts_to_offset ( struct Map_info *Map, GEOM_PARTS *parts)
int i, j;
@@ -135,16 +138,12 @@
if ( type != GV_CENTROID ) /* because centroids are read from topology, not from layer */
- add_parts_to_offset ( Map, parts, line );
+ add_parts_to_offset ( Map, parts);
return line;
-/* Recursively add geometry to topology
+/* Recursively add geometry to topology */
static int add_geometry ( struct Map_info *Map, OGRGeometryH hGeom, int FID, GEOM_PARTS *parts )
struct Plus_head *plus;
@@ -255,7 +254,7 @@
/* create virtual centroid */
ret = Vect_get_point_in_poly_isl ( Points[0], Points+1, nRings-1, &x, &y );
if (ret < -1) {
- G_warning (_("Cannot calculate centroid for area %d"), outer_area );
+ G_warning (_("Unable to calculate centroid for area %d"), outer_area );
} else {
P_AREA *Area;
@@ -290,7 +289,7 @@
break;
default:
- G_warning (_("OGR feature type %d not supported)"), eType);
+ G_warning (_("OGR feature type %d not supported"), eType);
break;
@@ -298,10 +297,14 @@
- \fn int Vect_build_ogr ( struct Map_info *Map, FILE *msgout )
int
Vect_build_ogr (struct Map_info *Map, int build, FILE * msgout)
@@ -311,7 +314,8 @@
OGRFeatureH hFeature;
OGRGeometryH hGeom;
- if ( build != GV_BUILD_ALL ) G_fatal_error ("Partial build for OGR is not supported.");
+ if ( build != GV_BUILD_ALL )
+ G_fatal_error (_("Partial build for OGR is not supported"));
Msgout = msgout;
@@ -322,14 +326,14 @@
/* test layer capabilities */
if ( !OGR_L_TestCapability ( Map->fInfo.ogr.layer, OLCRandomRead ) ) {
- G_warning ("Random read is not supported by OGR for this layer, cannot build support." );
+ G_warning (_("Random read is not supported by OGR for this layer, cannot build support"));
return 0;
init_parts (&parts);
/* Note: Do not use OGR_L_GetFeatureCount (it may scan all features)!!! */
- prnmsg ("Feature: ");
+ prnmsg (_("Feature: "));
OGR_L_ResetReading ( Map->fInfo.ogr.layer );
count = iFeature = 0;
@@ -354,7 +358,7 @@
FID = (int) OGR_F_GetFID ( hFeature );
if ( FID == OGRNullFID ) {
- G_warning (_("OGR feature without ID ignored."));
+ G_warning (_("OGR feature without ID ignored"));
OGR_F_Destroy( hFeature );
continue;
Modified: grass/trunk/lib/vector/Vlib/cats.c
--- grass/trunk/lib/vector/Vlib/cats.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/cats.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -5,16 +5,19 @@
* Higher level functions for reading/writing/manipulating vectors.
- * \author Original author CERL, probably Dave Gerdes or Mike
- * Higgins. Update to GRASS 5.7 Radim Blazek and David D. Gray.
+ * (C) 2001-2008 by the GRASS Development Team
- * (C) 2001 by the GRASS Development Team
* for details.
+ * \author Original author CERL, probably Dave Gerdes or Mike
+ * Higgins. Update to GRASS 5.7 Radim Blazek and David D. Gray.
+ * \date 2001-2008
#include <stdlib.h>
#include <string.h>
@@ -26,12 +29,10 @@
- \fn struct line_cats *Vect_new_cats_struct ()
\brief Creates and initializes line_cats structure.
- This structure is
- used for reading and writing vector cats. The library routines handle
- all memory allocation.
+ This structure is used for reading and writing vector cats. The
+ library routines handle all memory allocation.
\return struct line_cats *
\return NULL on error
@@ -48,12 +49,10 @@
- \fn struct line_cats *Vect__new_cats_struct ()
- This structure is
@@ -75,12 +74,11 @@
- \fn int Vect_destroy_cats_struct (struct line_cats *p)
- \brief Frees all memory associated with line_cats structure, including the struct itself.
+ \brief Frees all memory associated with line_cats structure, including the struct itself.
- \param p line_cats structure
+ \param p line_cats structure
- \return 0
+ \return 0
int
@@ -99,17 +97,16 @@
- \fn int Vect_cat_set (struct line_cats *Cats, int field, int cat)
- \brief Add new field/cat to category structure if doesn't exist yet.
- \param[in] Cats line_cats structure
- \param[in] field layer number
- \param[in] cat category number
- \return number of categories
- \return 0 if no space for new category in structure, n_cats would be > GV_NCATS_MAX
- \return -1 on out of memory
- \return -2 if field out of range: 1 - GV_FIELD_MAX or cat out of range: 1 - GV_CAT_MAX
+ \brief Add new field/cat to category structure if doesn't exist yet.
+ \param[in] Cats line_cats structure
+ \param[in] field layer number
+ \param[in] cat category number
+ \return number of categories
+ \return 0 if no space for new category in structure, n_cats would be > GV_NCATS_MAX
+ \return -1 on out of memory
+ \return -2 if field out of range: 1 - GV_FIELD_MAX or cat out of range: 1 - GV_CAT_MAX
int
@@ -152,17 +149,16 @@
- \fn int Vect_cat_get (struct line_cats *Cats, int field, int *cat)
- \brief Get first found category of given field.
- 'cat' is set to first category found or -1 if field was not found
- \param[in] cat pointer to variable where cat will be written
- \return 1 found
- \return 0 layer does not exist
+ \brief Get first found category of given field.
+ 'cat' is set to first category found or -1 if field was not found
+ \param[in] cat pointer to variable where cat will be written
+ \return 1 found
+ \return 0 layer does not exist
int
@@ -192,14 +188,13 @@
- \fn int Vect_cat_del (struct line_cats *Cats, int field)
- \brief Delete all categories of given layer
- \return 1 deleted
+ \brief Delete all categories of given layer
+ \return 1 deleted
int
@@ -229,15 +224,14 @@
- \fn int Vect_field_cat_del (struct line_cats *Cats, int field, int cat)
- \brief Delete field/cat from line_cats structure
- \param[in] cat category to be deleted or -1 to delete all cats of given field
- \return 1 deleted
- \return 0 field/category number does not exist
+ \brief Delete field/cat from line_cats structure
+ \param[in] cat category to be deleted or -1 to delete all cats of given field
+ \return 1 deleted
+ \return 0 field/category number does not exist
int
@@ -266,15 +260,14 @@
- \fn int Vect_reset_cats (struct line_cats *Cats)
- \brief Reset category structure to make sure cats structure is clean to be re-used.
- I.e. it has no cats associated with it. Cats must have
- previously been created with Vect_new_cats_struct()
- \param[out] Cats line_cats structure
- \return 0
+ \brief Reset category structure to make sure cats structure is clean to be re-used.
+ I.e. it has no cats associated with it. Cats must have
+ previously been created with Vect_new_cats_struct()
+ \param[out] Cats line_cats structure
+ \return 0
int
@@ -285,11 +278,10 @@
- \fn struct cat_list *Vect_new_cat_list ()
- \brief Allocate memory for cat_list structure.
- \return poiter to allocated structure
- \return NULL on out of memory
+ \brief Allocate memory for cat_list structure.
+ \return poiter to allocated structure
+ \return NULL on out of memory
struct cat_list *
@@ -312,12 +304,11 @@
- \fn int Vect_destroy_cat_list (struct cat_list *p)
- \brief Frees allocated cat_list memory.
- \param[in] p line_cats structure
- \return 0
+ \brief Frees allocated cat_list memory.
+ \param[in] p line_cats structure
+ \return 0
int
@@ -337,15 +328,14 @@
- \fn int Vect_str_to_cat_list (char *str, struct cat_list *list)
- \brief Convert string of categories and cat ranges separated by commas to cat_list.
- Examples of string: 2,3,5-9,20. str - input string
- \param[in] str cat list string
- \param[out] list result cat_list structure
- \return number of errors in ranges
+ \brief Convert string of categories and cat ranges separated by commas to cat_list.
+ Examples of string: 2,3,5-9,20. str - input string
+ \param[in] str cat list string
+ \param[out] list result cat_list structure
+ \return number of errors in ranges
int
@@ -422,14 +412,13 @@
- \fn int Vect_array_to_cat_list (int *vals, int nvals, struct cat_list *list)
- \brief Convert ordered array of integers to cat_list structure.
- \param[in] vals array of integers
- \param[in] nvals number of values
- \return number of ranges
+ \brief Convert ordered array of integers to cat_list structure.
+ \param[in] vals array of integers
+ \param[in] nvals number of values
+ \return number of ranges
int
@@ -466,14 +455,13 @@
- \fn int Vect_cat_in_cat_list (int cat, struct cat_list *list)
- \brief Check if category number is in list.
- \param[in] list cat_list structure
- \return TRUE if cat is in list
- \return FALSE if it is not
+ \brief Check if category number is in list.
+ \param[in] list cat_list structure
+ \return TRUE if cat is in list
+ \return FALSE if it is not
int
@@ -488,15 +476,14 @@
- \fn int Vect_cat_in_array (int cat, int *array, int ncats)
- \brief Check if category is in ordered array of integers.
- \param[in] array ordered array of integers
- \param[in] ncats number of categories in array
+ \brief Check if category is in ordered array of integers.
+ \param[in] array ordered array of integers
+ \param[in] ncats number of categories in array
int
@@ -511,7 +498,6 @@
return (FALSE);
static int cmp ( const void *pa, const void *pb)
int *p1 = (int *) pa;
Modified: grass/trunk/lib/vector/Vlib/clean_nodes.c
--- grass/trunk/lib/vector/Vlib/clean_nodes.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/clean_nodes.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,33 +1,40 @@
- * PURPOSE: Clean boundaries at nodes
- * for details.
+ \file clean_nodes.c
+ \brief Vector library - Clean boundaries at nodes
+ for details.
+ \date 2001-2008
#include <stdlib.h>
- \fn void Vect_clean_small_angles_at_nodes ( struct Map_info *Map, int type, struct Map_info *Err, FILE *msgout)
- \brief It may happen that even if the angle between 2 boundaries at node is very small,
- the calculated angle is 0 because of representation error.
- The map must be built at least on level GV_BUILD_BASE
+ \brief Clean small angles at nodes.
- \param Err vector map where error line segments are written
- \return number of line modifications
+ It may happen that even if the angle between 2 boundaries at node is
+ very small, the calculated angle is 0 because of
+ representation error. The map must be built at least on level
+ GV_BUILD_BASE
+ \param Err vector map where error line segments are written
+ \return number of line modifications
int
Vect_clean_small_angles_at_nodes ( struct Map_info *Map, int otype, struct Map_info *Err, FILE *msgout)
@@ -42,7 +49,7 @@
LCats = Vect_new_cats_struct ();
OCats = Vect_new_cats_struct ();
- if ( msgout ) fprintf (msgout, "Modifications: %5d", nmodif );
+ if ( msgout ) fprintf (msgout, "%s: %5d", _("Modifications"), nmodif );
for ( node = 1; node <= Vect_get_num_nodes(Map); node++ ){
int i, nlines;
@@ -206,7 +213,7 @@
if ( msgout ) {
- fprintf (msgout, "\rModifications: %5d", nmodif );
+ fprintf (msgout, "\r%s: %5d", _("Modifications"), nmodif );
fflush ( msgout );
@@ -220,4 +227,3 @@
return (nmodif);
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/close.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,20 +1,23 @@
-* for details.
+ \file close.c
+ \brief Vector library - Close map
+ for details.
+ \date 2001-2008
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
@@ -22,6 +25,7 @@
#include <sys/stat.h>
#include <unistd.h>
static int
clo_dummy () {
@@ -29,7 +33,7 @@
#ifndef HAVE_OGR
-static int format () { G_fatal_error ("Requested format is not compiled in this version"); return 0; }
+static int format () { G_fatal_error (_("Requested format is not compiled in this version")); return 0; }
#endif
static int (*Close_array[][2]) () =
@@ -44,10 +48,12 @@
- \fn int Vect_close (struct Map_info *Map)
- \brief close vector data file
- \return 0 on success, non-zero on error
+ \brief Close vector data file
+ \param Map vector map to be closed
+ \return 0 on success
+ \return non-zero on error
int
@@ -59,8 +65,8 @@
/* Store support files if in write mode on level 2 */
if ( strcmp(Map->mapset,G_mapset()) == 0 && Map->support_updated && Map->plus.built == GV_BUILD_ALL) {
- char buf[1000];
- char file_path[2000];
+ char buf[GPATH_MAX];
+ char file_path[GPATH_MAX];
struct stat info;
/* Delete old support files if available */
@@ -117,16 +123,18 @@
/* Close level 1 files / data sources if not head_only */
if ( !Map->head_only ) {
if ( ((*Close_array[Map->format][1]) (Map)) != 0 ) {
- G_warning ("Cannot close vector '%s'", Vect_get_full_name(Map) );
+ G_warning (_("Unable close vector <%s>"),
+ Vect_get_full_name(Map) );
return 1;
- free (Map->name); Map->name = NULL;
- free (Map->mapset); Map->mapset = NULL;
+ G_free ((void *) Map->name);
+ Map->name = NULL;
+ G_free ((void *) Map->mapset);
+ Map->mapset = NULL;
Map->open = VECT_CLOSED_CODE;
return 0;
Modified: grass/trunk/lib/vector/Vlib/constraint.c
--- grass/trunk/lib/vector/Vlib/constraint.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/constraint.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,37 +1,52 @@
-* for details.
+ \file constraint.c
+ \brief Vector library - constraints
+ These routines can affect the read_next_line funtions
+ by restricting what they return.
+ They are applied on a per map basis.
+ These do not affect the lower level direct read functions.
+ Normally, All 'Alive' lines will be returned unless overridden
+ by this function. You can specified all the types you are interested
+ in (by oring their types together). You can use this to say
+ exclude Area type lines.
+ By default all DEAD lines are ignored by the read_next_line () functions
+ This too can be overridden by including their types.
+ Refer to dig_defines for the line type Defines
+ All lines can be forced to be read by setting type = -1
+ for details.
+ \date 2001-2008
- ** These routines can affect the read_next_line funtions
- ** by restricting what they return.
- ** They are applied on a per map basis.
- ** These do not affect the lower level direct read functions.
+ \brief Set constraint region
- \fn int Vect_set_constraint_region ( struct Map_info *Map,
- double n, double s, double e, double w, double t, double b )
- \brief ADD
- \return 0 on success, -1 on error
- \param Map_info structure, north, south, east, west, top, bottom coordinates
+ \param n,s,e,w,t,b north, south, east, west, top, bottom coordinates
int
@@ -52,14 +67,15 @@
Map->proj = G_projection ();
return (0);
-} /* dig_init_box() */
- \fn int Vect_get_constraint_box ( struct Map_info *Map,
- BOUND_BOX *Box )
- \brief ADD
+ \brief Get constraint box
+ \param Box bounding box
int
Vect_get_constraint_box ( struct Map_info *Map, BOUND_BOX *Box )
@@ -73,28 +89,14 @@
return 0;
- ** Normally, All 'Alive' lines will be returned unless overridden
- ** by this function. You can specified all the types you are interested
- ** in (by oring their types together). You can use this to say
- ** exclude Area type lines.
- ** By default all DEAD lines are ignored by the read_next_line () functions
- ** This too can be overridden by including their types.
- ** Refer to dig_defines for the line type Defines
- ** All lines can be forced to be read by setting type = -1
- \fn int Vect_set_constraint_type (
- int type)
- \brief ADD
- \param Map_info structure, constraint type
+ \brief Set constraint type
+ \param type constraint type
int
@@ -108,10 +110,11 @@
- \fn int Vect_remove_constraints (struct Map_info *Map)
- \brief ADD
+ \brief Remove constraints
int
Modified: grass/trunk/lib/vector/Vlib/dangles.c
--- grass/trunk/lib/vector/Vlib/dangles.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/dangles.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,31 +1,33 @@
- * for details.
+ \file dangles.c
+ \brief Vector library - clean geometry (dangles)
+ for details.
+ \date 2001-2008
#include <stdlib.h>
-void remove_dangles ( struct Map_info *Map, int type, int chtype, double maxlength,
+static void remove_dangles ( struct Map_info *Map, int type, int chtype, double maxlength,
- \fn void Vect_remove_dangles ( struct Map_info *Map, int type, double maxlength,
- struct Map_info *Err, FILE *msgout)
- \brief Remove dangles from vector map.
+ \brief Remove dangles from vector map.
Remove dangles of given type shorter than maxlength from vector map.
Line is considered to be a dangle if on at least one end node is no other line of given type(s).
If a dangle is formed by more lines, such string of lines is taken as one dangle and
@@ -33,11 +35,13 @@
Optionaly deleted dangles are written to error map.
Input map must be opened on level 2 for update.
- \param Map input map where have to be deleted
- \param type type of dangles
- \param maxlength maxlength of dangles or -1 for all dangles
- \param Err vector map where deleted dangles are written or NULL
+ \param Map input map where have to be deleted
+ \param type type of dangles
+ \param maxlength maxlength of dangles or -1 for all dangles
+ \param Err vector map where deleted dangles are written or NULL
+ \return
void
Vect_remove_dangles ( struct Map_info *Map, int type, double maxlength, struct Map_info *Err, FILE *msgout )
@@ -46,28 +50,29 @@
- \fn void Vect_chtype_dangles ( struct Map_info *Map, double maxlength,
- \brief Change boundary dangles to lines.
+ \brief Change boundary dangles to lines.
Boundary is considered to be a dangle if on at least one end node is no other boundary.
If a dangle is formed by more boundaries, such string of boundaries is taken as one dangle and
either deleted are all parts or nothing.
+ \return
void
Vect_chtype_dangles ( struct Map_info *Map, double maxlength, struct Map_info *Err, FILE *msgout )
remove_dangles ( Map, 0, 1, maxlength, Err, msgout );
@@ -86,7 +91,7 @@
-void
+static void
remove_dangles ( struct Map_info *Map, int type, int chtype, double maxlength, struct Map_info *Err, FILE *msgout )
struct line_pnts *Points;
@@ -113,8 +118,8 @@
List = Vect_new_list ();
- if ( msgout ) fprintf (msgout, "Removed dangles: %5d %s: %5d",
- dangles_removed, lmsg, lines_removed );
+ _("Removed dangles"), dangles_removed, lmsg, lines_removed );
nnodes = Vect_get_num_nodes (Map);
G_debug (2, "nnodes = %d", nnodes );
@@ -202,16 +207,16 @@
if ( msgout ) {
- if ( msgout ) fprintf (msgout, "\rRemoved dangles: %5d %s: %5d",
+ if ( msgout ) fprintf (msgout, "\r%s: %5d %s: %5d",
fflush ( msgout );
dangles_removed++;
if ( msgout ) {
Modified: grass/trunk/lib/vector/Vlib/dbcolumns.c
--- grass/trunk/lib/vector/Vlib/dbcolumns.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/dbcolumns.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,18 +1,22 @@
-* AUTHOR(S): Markus Neteler
-* PURPOSE: DB info on vectors maps
-* COPYRIGHT: (C) 2005 by the GRASS Development Team
-* for details.
+ \file dbcolumns.c
+ \brief Vector library - DB info on vectors maps
+ (C) 2005-2008 by the GRASS Development Team
+ for details.
+ \author Markus Neteler
+ \date 2005-2008
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
@@ -25,12 +29,14 @@
- \fn char *Vect_get_column_names(struct Map_info *Map, int field)
- \brief fetches list of DB column names of vector map attribute table
- \return list of column(s) names on success, NULL on error
- \param vector map
+ \brief Fetches list of DB column names of vector map attribute table
+ \return list of column(s) names on success
+ \return NULL on error
int num_dblinks, ncols, col;
@@ -86,10 +92,13 @@
- \fn char *Vect_get_column_types(struct Map_info *Map, int field)
- \brief fetches list of DB column types of vector map attribute table
- \return list of column(s) types on success, NULL on error
- \param vector map
+ \brief Fetches list of DB column types of vector map attribute table
+ \return list of column(s) types on success
@@ -147,10 +156,13 @@
- \fn char *Vect_get_column_names_types(struct Map_info *Map, int field)
- \brief fetches list of DB column names and types of vector map attribute table
- \param vector map
+ \brief Fetches list of DB column names and types of vector map attribute table
+ \retutn NULL on error
Modified: grass/trunk/lib/vector/Vlib/error.c
--- grass/trunk/lib/vector/Vlib/error.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/error.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,20 +1,23 @@
-* for details.
+ \file error.c
+ \brief Vector library - error management
+ for details.
+ \date 2001-2008
#include <string.h>
@@ -22,12 +25,15 @@
static int fatal_err = GV_FATAL_EXIT;
- \fn int Vect_set_fatal_error (int err)
- \brief set behaviour if fatal error occurs in some functions
- \param GV_FATAL_EXIT(default): print error message and exit,
- GV_FATAL_PRINT: print error message and return error,
- GV_FATAL_RETURN: return error
+ \brief Set behaviour if fatal error occurs in some functions
+ - GV_FATAL_EXIT(default): print error message and exit,
+ - GV_FATAL_PRINT: print error message and return error,
+ - GV_FATAL_RETURN: return error
+ \param err error type
int
@@ -37,15 +43,16 @@
- \fn int Vect_get_fatal_error (void)
- \brief get behaviour for fatal error
- \return GV_FATAL_EXIT(default): print error message and exit,
- \param void
+ \brief Get behaviour for fatal error
+ \param
+ \return GV_FATAL_EXIT(default): print error message and exit,
+ \return GV_FATAL_PRINT: print error message and return error,
+ \return GV_FATAL_RETURN: return error
int
-Vect_get_fatal_error ()
+Vect_get_fatal_error (void)
return (fatal_err);
Modified: grass/trunk/lib/vector/Vlib/field.c
--- grass/trunk/lib/vector/Vlib/field.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/field.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,21 +1,26 @@
-* for details.
-* TODO: see Vect_read_dblinks; activate auto-FID detection once
-* OGR_L_GetFIDColumn() is working or solution found if FID not available
+ \file field.c
+ \brief Vector library - field(layer) related fns.
+ TODO: see Vect_read_dblinks; activate auto-FID detection once
+ OGR_L_GetFIDColumn() is working or solution found if FID not available
+ for details.
+ \date 2001-2008
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
@@ -27,10 +32,11 @@
#include <gdal_version.h> /* needed for FID detection */
- \fn struct dblinks *Vect_new_dblinks_struct ( void )
- \brief create and init new dblinks ctructure
- \return pointer to new dblinks structure
- \param void
+ \brief Create and init new dblinks ctructure
+ \param void
+ \return pointer to new dblinks structure
struct dblinks *
@@ -48,10 +54,11 @@
- \fn void Vect_reset_dblinks ( struct dblinks *p )
- \brief reset dblinks structure
- \return void
- \param pointer to existing dblinks structure
+ \brief Reset dblinks structure
+ \param p pointer to existing dblinks structure
+ \return void
void
@@ -60,11 +67,18 @@
- \fn int Vect_map_add_dblink ( struct Map_info *Map, int number, char *name, char *table, char *key,
- char *db, char *driver )
- \brief add new db connection to Map_info structure
- \return 0 OK; -1 error
- \param pointer to existing Map structure
+ \brief Add new db connection to Map_info structure
+ \param number layer number
+ \param name layer name
+ \param table table name
+ \param key key name
+ \param db database name
+ \param driver driver name
+ \return 0 OK
+ \return -1 error
int
@@ -73,34 +87,37 @@
int ret;
if (number == 0) {
- G_warning (_("Field number must be 1 or greater."));
+ G_warning (_("Layer number must be 1 or greater"));
return -1;
if (Map->mode != GV_MODE_WRITE && Map->mode != GV_MODE_RW) {
- G_warning (_("Cannot add database link, map is not opened in WRITE mode."));
+ G_warning (_("Unable to add database link, map is not opened in WRITE mode"));
return -1;
ret = Vect_add_dblink ( Map->dblnk, number, name, table, key, db, driver );
if ( ret == -1 ) {
- G_warning (_("Cannot add database link."));
+ G_warning (_("Unable to add database link"));
return -1;
/* write it immediately otherwise it is lost if module crashes */
ret = Vect_write_dblinks ( Map );
if ( ret == -1 ) {
- G_warning (_("Cannot write database links."));
+ G_warning (_("Unable to write database links"));
return -1;
return 0;
- \fn int Vect_map_del_dblink ( struct Map_info *Map, int number)
- \brief delete db connection from Map_info structure
- \return 0 deleted, -1 error
- \param pointer to existing Map structure, field number
+ \brief Delete db connection from Map_info structure
+ \return 0 deleted
+ \return -1 error
int
Vect_map_del_dblink ( struct Map_info *Map, int field)
@@ -133,7 +150,7 @@
if ( ret == -1 ) {
return -1;
@@ -141,10 +158,13 @@
- \fn int Vect_map_check_dblink ( struct Map_info *Map, int field )
- \brief check if db connection exists in dblinks structure
- \return 1 dblink for field exists; 0 dblink does not exist for field
- \param pointer to Map structure, field number
+ \brief Check if db connection exists in dblinks structure
+ \return 1 dblink for field exists
+ \return 0 dblink does not exist for field
int
@@ -153,10 +173,13 @@
- \fn int Vect_check_dblink ( struct dblinks *p, int field )
- \param pointer to existing dblinks structure, field number
int
@@ -175,11 +198,17 @@
- \fn int Vect_add_dblink ( struct dblinks *p, int number, char *name, char *table, char *key,
- \brief add new db connection to dblinks structure
+ \brief Add new db connection to dblinks structure
+ \return 0 OK
+ \return -1 error
int
Vect_add_dblink ( struct dblinks *p, int number, char *name, char *table, char *key, char *db, char *driver )
@@ -189,7 +218,7 @@
G_debug (3, "Field number <%d>, name <%s>", number, name);
ret = Vect_check_dblink ( p, number );
if ( ret == 1 ) {
- G_warning (_("Field number <%d> or name <%s> already exists"), number, name);
+ G_warning (_("Layer number %d or name <%s> already exists"), number, name);
return -1;
@@ -222,17 +251,21 @@
- \fn struct field_info *Vect_default_field_info ( struct Map_info *Map, int field, char *field_name, int type)
- \brief get default information about link to database for new dblink
- \return pointer to new field_info structure
- \param pointer to map structure, category field
+ \brief Get default information about link to database for new dblink
+ \param field_name layer name
+ \param type how many tables are linked to map: GV_1TABLE / GV_MTABLE
+ \return pointer to new field_info structure
struct field_info
- struct Map_info *Map, /* pointer to map structure */
- int field, /* category field */
- char *field_name, /* field name or NULL */
- int type ) /* how many tables are linked to map: GV_1TABLE / GV_MTABLE */
+ struct Map_info *Map,
+ int field,
+ char *field_name,
+ int type )
struct field_info *fi;
char buf[1000], buf2[1000];
@@ -250,7 +283,7 @@
if ( !connection.driverName && !connection.databaseName ) { /* Set default values and create dbf db dir */
G_warning ( _("Default driver / database set to:\n"
- "driver: dbf\ndatabase: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/") );
+ "driver: dbf\ndatabase: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/") );
connection.driverName = "dbf";
connection.databaseName = "$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/";
@@ -298,11 +331,15 @@
- \fn struct field_info *Vect_get_dblink ( struct Map_info *Map, int link)
- \brief get information about link to database, variables are substituted by values,
- link is index to array of dblinks
- \param pointer Map_info structure, link number
+ \brief Get information about link to database.
+ Variables are substituted by values, link is index to array of
+ dblinks
+ \param link link id
struct field_info
*Vect_get_dblink ( struct Map_info *Map, int link )
@@ -312,7 +349,7 @@
G_debug (1, "Vect_get_dblink(): link = %d", link);
if ( link >= Map->dblnk->n_fields ) {
- G_warning ( _("Requested dblink %d, maximum link number %d"), link, Map->dblnk->n_fields - 1 );
+ G_warning (_("Requested dblink %d, maximum link number %d"), link, Map->dblnk->n_fields - 1 );
return NULL;
@@ -333,11 +370,16 @@
- \fn struct field_info *Vect_get_field ( struct Map_info *Map, int field )
- field is number of requested field
- \return pointer to new field_info structure or NULL
- \param pointer Map_info structure, field number
+ field is number of requested field
+ \return NULL if not found
struct field_info
@@ -358,10 +400,14 @@
- \fn int *Vect_read_dblinks ( struct Map_info *Map)
- \brief read dblinks to existing structure, variables are not substituted by values
- \return number of links read or -1 on error
+ \brief Read dblinks to existing structure.
+ Variables are not substituted by values.
+ \return number of links read
+ \return -1 on error
int
Vect_read_dblinks ( struct Map_info *Map )
@@ -438,7 +484,7 @@
driver = db_start_driver_open_database ( "ogr", Map->fInfo.ogr.dsn );
- G_warning (_("Cannot open OGR DBMI driver."));
+ G_warning (_("Unable to open OGR DBMI driver"));
return -1;
@@ -467,7 +513,8 @@
if (db_open_select_cursor(driver, &sql, &cursor, DB_SEQUENTIAL) != DB_OK) {
/* neither FID nor ogc_fid nor ogr_fid nor gid available */
- G_warning ("All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table");
+ G_warning (_("All FID tests failed. Neither 'FID' nor 'ogc_fid' "
+ "nor 'ogr_fid' nor 'gid' available in OGR DB table"));
return 0;
} else
@@ -561,17 +608,19 @@
- \fn int *Vect_write_dblinks ( struct Map_info *Map )
- \brief write dblinks to file
- \return 0 OK, -1 on error
- \param pointer to map name, pointer to mapset name, pointer to dblinks structure
+ \brief Write dblinks to file
+ \return 0 OK
int
int i;
FILE *fd;
- char file[1024], buf[1024];
+ char file[GPATH_MAX], buf[GPATH_MAX];
struct dblinks *dbl;
G_debug (1, "Vect_write_dblinks(): map = %s, mapset = %s", Map->name, Map->mapset );
@@ -584,7 +633,7 @@
fd = fopen ( file, "w" );
if ( fd == NULL ) { /* This may be correct, no tables defined */
- G_warning ( "Cannot open vector database definition file: '%s'", file);
+ G_warning (_("Unable to open vector database definition file '%s'"), file);
return (-1);
@@ -606,10 +655,12 @@
- \fn chart *Vect_subst_var ( char *in, struct Map_info *Map )
- \brief substitute variable in string
- \return pointer to new string
+ \brief Substitute variable in string
+ \param in current string
+ \return pointer to new string
char *
@@ -654,16 +705,21 @@
- \brief rewrite 'dbln' file, should be used by GRASS modules which update
- database tables, so that other applications know that tables
- were changed and can reload data
+ \brief Rewrite 'dbln' file
+ Should be used by GRASS modules which update
+ database tables, so that other applications know that tables
+ were changed and can reload data.
+ \return void
void Vect_set_db_updated ( struct Map_info *Map )
if ( strcmp(Map->mapset,G_mapset() ) != 0 ) {
- G_fatal_error ( _("Bug: attempt to update map which is not in current mapset." ) );
+ G_fatal_error (_("Bug: attempt to update map which is not in current mapset"));
Vect_write_dblinks ( Map ) ;
Modified: grass/trunk/lib/vector/Vlib/graph.c
--- grass/trunk/lib/vector/Vlib/graph.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/graph.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,24 +1,31 @@
-* MODULE: Vector library
-* PURPOSE: Higher level functions for reading/writing/manipulating vectors.
-* This program is free software under the GNU General Public
-* License (>=v2). Read the file COPYING that comes with GRASS
-* for details.
+ \file graph.c
+ \brief Vector library - graph manipulation
+ Higher level functions for reading/writing/manipulating vectors.
+ TODO: Vect_graph_free ( GRAPH *graph )
+ (C) 2001-2008 by the GRASS Development Team
+ This program is free software under the
+ GNU General Public License (>=v2).
+ Read the file COPYING that comes with GRASS
+ for details.
+ \date 2001-2008
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
#include <grass/Vect.h>
+#include <grass/glocale.h>
-/* TODO: Vect_graph_free ( GRAPH *graph ) */
static int From_node; /* from node set in SP and used by clipper for first arc */
static int clipper ( dglGraph_s *pgraph ,
@@ -57,12 +64,12 @@
- \fn Vect_graph_init ( GRAPH *graph, int nodes_costs )
- \brief Build network graph. Internal format for edge costs is integer, costs are multiplied
- before conversion to int by 1000.
- Costs -1 for infinity i.e. arc or node is closed and cannot be traversed.
- \param GRAPH *graph
- \param nodes_costs use node costs
+ \brief Initialize graph structure
+ \param graph poiter to graph structure
+ \param nodes_costs use node costs
+ \return void
void
@@ -78,12 +85,15 @@
+ \brief Build network graph.
+ Internal format for edge costs is integer, costs are multiplied
+ before conversion to int by 1000.
+ Costs -1 for infinity i.e. arc or node is closed and cannot be traversed.
+ \return void
void
Vect_graph_build ( GRAPH *graph )
@@ -93,19 +103,24 @@
G_debug (3, "Vect_graph_build()" );
ret = dglFlatten ( graph );
- if ( ret < 0 ) G_fatal_error ("GngFlatten error");
+ if ( ret < 0 )
+ G_fatal_error (_("GngFlatten error"));
- \fn Vect_graph_add_edge ( GRAPH *graph, int from, int to, double costs, int id )
- \brief Add edge to graph.
- Internal format for edge costs is integer, costs are multiplied before conversion to int by 1000.
- \param from from node
- \param to to node
- \param costs
+ \brief Add edge to graph.
+ before conversion to int by 1000. Costs -1 for infinity i.e. arc or
+ node is closed and cannot be traversed.
+ \param from from node
+ \param to to node
+ \param costs costs value
\param id edge id
+ \return void
void
@@ -118,17 +133,22 @@
dglcosts = (dglInt32_t) costs * 1000;
ret = dglAddEdge ( graph, (dglInt32_t)from, (dglInt32_t)to, dglcosts, (dglInt32_t)id );
- if ( ret < 0 ) G_fatal_error ("Cannot add network arc");
+ if ( ret < 0 )
+ G_fatal_error (_("Unable to add network arc"));
- \fn Vect_graph_set_node_costs ( GRAPH *graph, int node, double costs )
- \brief Set node costs
- \param node
- \param costs
+ \brief Set node costs
+ \param node node id
+ \return void
void
@@ -144,17 +164,21 @@
- \fn int Vect_graph_shortest_path ( GRAPH *graph, int from, int to, struct ilist *List, double *cost )
- \brief Find shortest path. Costs for 'from' and 'to' nodes are not considered (SP found even if
- 'from' or 'to' are 'closed' (costs = -1) and costs of these nodes are not added to SP costs result.
- \return number of segments : ( 0 is correct for from = to, or List == NULL ),
- ? sum of costs is better return value,
- -1 : destination unreachable
- \param graph
- \param from
- \param to
- \param List
- \param cost
+ \brief Find shortest path.
+ Costs for 'from' and 'to' nodes are not considered (SP found even if
+ 'from' or 'to' are 'closed' (costs = -1) and costs of these
+ nodes are not added to SP costs result.
+ \param graph pointer to graph structure
+ \param to to node
+ \param List list of line ids
+ \param cost costs value
+ \return number of segments
+ \return 0 is correct for from = to, or List == NULL ), ? sum of costs is better return value,
+ \return -1 destination unreachable
int
@@ -191,7 +215,7 @@
return -1;
else if ( nRet < 0 ) {
- fprintf( stderr , "dglShortestPath error: %s\n", dglStrerror( graph ) );
+ G_warning(_("dglShortestPath error: %s"), dglStrerror( graph ) );
return -1;
@@ -224,4 +248,3 @@
return (cArc);
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/header.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,35 +1,38 @@
-* AUTHOR(S): Original author CERL, probably Dave Gerdes or Mike Higgins.
-* Update to GRASS 5.7 Radim Blazek and David D. Gray.
-* COPYRIGHT: (C) 2001 by the GRASS Development Team
-* for details.
+ \file header.c
+ \brief Vector library - header manipulation
+ for details.
+ \author Original author CERL, probably Dave Gerdes or Mike Higgins.
+ Update to GRASS 5.7 Radim Blazek and David D. Gray.
+ \date 2001-2008
#include <stdlib.h>
#include <string.h>
static int lookup(char *file, char *key, char *value, size_t len);
- \fn int Vect_print_header (struct Map_info *Map)
- \brief print vector map header
+ \brief Print vector map header
int
@@ -45,10 +48,11 @@
- \fn int Vect_read_header (struct Map_info *Map)
- \brief read vector map header from map head file
+ \brief Read vector map header from map head file
int
@@ -59,10 +63,11 @@
- \fn int Vect_write_header (struct Map_info *Map)
- \brief write vector map header to map head file
+ \brief Write vector map header to map head file
int
@@ -73,10 +78,14 @@
-/* Vect__write_head () writes head information to text file.
- * returns: GRASS_OK - success
- * GRASS_ERR - error
+ \brief Writes head information to text file.
+ \return GRASS_OK - success
+ \return GRASS_ERR - error
int
Vect__write_head (struct Map_info *Map)
@@ -88,7 +97,7 @@
head_fp = G_fopen_new (buf, GRASS_VECT_HEAD_ELEMENT);
if ( head_fp == NULL)
- G_warning ("Cannot Open Vector %s@%s Head File\n", Map->name, Map->mapset);
+ G_warning (_("Unable to open header file of vector <%s>"), Vect_get_full_name(Map));
return (GRASS_ERR);
@@ -106,10 +115,14 @@
return (GRASS_OK);
-/* Vect__read_head () reads head information from text file (GRASS_VECT_HEAD_ELEMENT).
+ \brief Reads head information from text file (GRASS_VECT_HEAD_ELEMENT).
int
Vect__read_head (struct Map_info *Map)
@@ -133,14 +146,14 @@
head_fp = G_fopen_old (buff, GRASS_VECT_HEAD_ELEMENT, Map->mapset);
- G_warning ("Cannot Open Vector %s Head File\n", Map->name);
return (GRASS_ERR);
while ( G_getl2 (buff, 2000, head_fp) ) {
if (!(ptr = G_index (buff, ':'))) {
- G_warning ( "Corrupted row in head: %s\n", buff );
+ G_warning (_("Corrupted row in head: %s"), buff );
continue;
@@ -171,20 +184,19 @@
else if (strncmp (buff, "MAP THRESH:", sizeof(char)*11) == 0)
Vect_set_thresh ( Map, atof (ptr) );
else
- G_warning("Unknown keyword %s in vector head\n", buff);
+ G_warning(_("Unknown keyword %s in vector head"), buff);
fclose (head_fp);
return (GRASS_OK);
-/* set and get header informations */
-/* name, mapset, full name */
- \fn char *Vect_get_name (struct Map_info *Map)
- \brief get map name
- \return on success
+ \brief Get map name
+ \return poiter to map name
char *
@@ -193,10 +205,11 @@
- \fn char *Vect_get_mapset (struct Map_info *Map)
- \brief get mapset name
+ \brief Get mapset name
+ \return poiter to mapset name
char *
@@ -205,26 +218,29 @@
- \fn char *Vect_get_full_name (struct Map_info *Map)
- \brief get full name
+ \brief Get full map name
+ \return poiter to map name (name at mapset)
char *
char *ptr;
- ptr = G_malloc ( strlen(Map->name) + strlen(Map->mapset) + 2 );
+ ptr = (char *) G_malloc ( strlen(Map->name) + strlen(Map->mapset) + 2 );
sprintf (ptr, "%s@%s", Map->name, Map->mapset);
return (ptr);
- \fn int Vect_is_3d (struct Map_info *Map)
- \brief check if vector map is 3D (with z)
- \return 1 on success, 0 of not 3D
+ \brief Check if vector map is 3D (with z)
+ \return 1 map is 3D
+ \return 0 map is not 3D
int
Vect_is_3d (struct Map_info *Map )
@@ -233,24 +249,28 @@
- \fn int Vect_set_organization (struct Map_info *Map, char *str )
- \brief set organization string in map header
- \param Map_info structure, organization string
+ \brief Set organization string in map header
+ \param str organization name
+ \return 0
int
G_free ( Map->head.organization );
Map->head.organization = G_store ( str );
- return (0);
+ return 0;
- \fn char *Vect_get_organization (struct Map_info *Map)
- \brief get organization string from map header
- \return organization string
+ \brief Get organization string from map header
+ \return organization string
char *
@@ -259,12 +279,16 @@
- \fn int Vect_set_date (struct Map_info *Map, char *str )
- \brief set date of digitization string in map header
- \param Map_info structure, date of digitization string
+ \brief Set date of digitization string in map header
+ SUGGESTION: this should be coupled to DateTime functions to support
+ time series
+ \param str data string
-/* SUGGESTION: this should be coupled to DateTime functions to support time series*/
int
@@ -274,12 +298,15 @@
- \fn char *Vect_get_date (struct Map_info *Map)
- \brief get date of digitization string from map header
- \return date of digitization string
+ \brief Get date of digitization string from map header
+ time series
+ \return date of digitization string
char *
@@ -287,10 +314,12 @@
- \fn int Vect_set_person (struct Map_info *Map, char *str )
- \brief set user name string who digitized the map in map header
- \param Map_info structure, user name string
+ \brief Set user name string who digitized the map in map header
+ \param str user name string
int
@@ -301,10 +330,11 @@
- \fn char *Vect_get_person (struct Map_info *Map)
- \brief get user name string who digitized the map from map header
- \return user name string
+ \brief Get user name string who digitized the map from map header
+ \return user name string
char *
@@ -313,10 +343,12 @@
- \fn int Vect_set_map_name (struct Map_info *Map, char *str )
- \brief set map name string in map header
- \param Map_info structure, map name string
+ \brief Set map name string in map header
+ \param str map name string
int
@@ -327,10 +359,11 @@
- \fn char *Vect_get_map_name (struct Map_info *Map)
- \brief get map name string in map header
- \return map name string
+ \brief Get map name string in map header
+ \return map name string
char *
@@ -339,10 +372,12 @@
- \fn int Vect_set_map_date (struct Map_info *Map, char *str )
- \brief set date string when the source map was originally produced in map header
- \param Map_info structure, date when the source map was originally produced string
+ \brief Set date string when the source map was originally produced in map header
+ \param str date when the source map was originally produced string
int
@@ -353,10 +388,11 @@
- \fn char *Vect_get_map_date (struct Map_info *Map)
- \brief get date string when the source map was originally produced in map header
- \return date when the source map was originally produced string
+ \brief Get date string when the source map was originally produced in map header
+ \return date when the source map was originally produced string
char *
@@ -365,10 +401,12 @@
- \fn int Vect_set_scale (struct Map_info *Map, int scale)
- \brief set map scale in map header
- \param Map_info structure, map scale
+ \brief Set map scale in map header
+ \param map scale
int
Vect_set_scale (struct Map_info *Map, int scale )
@@ -378,10 +416,11 @@
- \fn int Vect_get_scale (struct Map_info *Map)
- \brief get map scale from map header
- \return map scale
+ \brief Get map scale from map header
+ \return map scale
int
@@ -390,10 +429,12 @@
- \fn int Vect_set_comment (struct Map_info *Map, char *str )
- \brief set comment or other info string in map header
- \param Map_info structure, comment or other info string
+ \brief Set comment or other info string in map header
+ \param str comment or other info string
int
@@ -404,10 +445,11 @@
- \fn char *Vect_get_comment (struct Map_info *Map )
- \brief get comment or other info string from map header
- \return comment or other info string
+ \brief Get comment or other info string from map header
+ \return comment or other info string
char *
Vect_get_comment (struct Map_info *Map)
@@ -416,10 +458,12 @@
- \fn int Vect_set_zone (struct Map_info *Map, int zone )
- \brief set projection zone in map header
- \param Map_info structure, projection zone
+ \brief Set projection zone in map header
+ \param zone projection zone
int
@@ -430,10 +474,11 @@
- \fn int Vect_get_zone (struct Map_info *Map)
- \brief get projection zone from map header
- \return projection zone
+ \brief Get projection zone from map header
+ \return projection zone
int
@@ -442,14 +487,14 @@
- \fn int Vect_get_proj (struct Map_info *Map)
- \brief get projection from map header
- \return Returns the projection type of map
- PROJECTION_XY 0 - x,y (Raw imagery),
- PROJECTION_UTM 1 - UTM Universal Transverse Mercator,
- PROJECTION_SP 2 - State Plane (in feet),
- PROJECTION_LL 3 - Latitude-Longitude
+ \brief Get projection from map header
+ \return PROJECTION_XY 0 - x,y (Raw imagery),
+ \return PROJECTION_UTM 1 - UTM Universal Transverse Mercator,
+ \return PROJECTION_SP 2 - State Plane (in feet),
+ \return PROJECTION_LL 3 - Latitude-Longitude
int
@@ -459,17 +504,17 @@
- \fn char *Vect_get_proj_name (struct Map_info *Map)
- \brief query cartographic projection name of vector map
+ \brief Query cartographic projection name of vector map
- Returns a pointer to a string which is a printable name for
- projection code <b>proj</b> (as returned by <i>Vect_get_proj()</i>). Returns
- NULL if <b>proj</b> is not a valid projection.
+ Returns a pointer to a string which is a printable name for
+ projection code <b>proj</b> (as returned by <i>Vect_get_proj()</i>). Returns
+ NULL if <b>proj</b> is not a valid projection.
- \param proj
- \return char *
+ \return poiter to projection name
int n;
@@ -489,12 +534,13 @@
return name;
+ \brief Set threshold used for digitization in map header
- \fn int Vect_set_thresh (struct Map_info *Map, double thresh )
- \brief set threshold used for digitization in map header
- \param Map_info structure, threshold used for digitization
+ \param thresh threshold used for digitization
int
@@ -505,10 +551,11 @@
- \fn double Vect_get_zone (struct Map_info *Map )
- \brief get threshold used for digitization from map header
- \return threshold used for digitization
+ \brief Get threshold used for digitization from map header
+ \return threshold used for digitization
double
Vect_get_thresh (struct Map_info *Map)
@@ -521,7 +568,7 @@
/* from lib/gis/proj3.c */
- char path[1024];
+ char path[GPATH_MAX];
G__file_name (path, "", file, "PERMANENT");
return G_lookup_key_value_from_file(path, key, value, (int)len) == 1;
Modified: grass/trunk/lib/vector/Vlib/hist.c
--- grass/trunk/lib/vector/Vlib/hist.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/hist.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,29 +1,34 @@
-* for details.
+ \file hist.c
+ \brief Vector library - history manipulation
+ for details.
+ \date 2001-2008
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
- \fn int Vect_hist_command ( struct Map_info *Map )
- \brief write command info to history file
- \return 0 OK, -1 error
- \param struct Map_info *Map
+ \brief Write command info to history file
+ \return 0 OK
+ \return -1 error
int
@@ -49,10 +54,12 @@
- \fn int Vect_hist_write ( struct Map_info *Map, char *str )
- \brief write string to history file
- \return the number of characters printed
- \param struct Map_info *Map, char *str
+ \brief Write string to history file
+ \param str string to write
+ \return the number of characters printed
int
@@ -67,12 +74,15 @@
- \fn char Vect_hist_read ( char *s, int size, struct Map_info *Map )
- \brief reads one line from history file without newline character
- \return return s on success, and NULL on error or EOF
- \param s buffer, allocated space must be size+1
- \param size maximum number of character
- \param Map
+ \brief Reads one line from history file without newline character
+ \param s buffer, allocated space must be size+1
+ \param size maximum number of character
+ \return return s on success
+ \return EOF end of file
char *
@@ -90,10 +100,11 @@
- \fn int Vect_hist_rewind ( struct Map_info *Map )
- \brief rewind history file
+ \brief Rewind history file
+ \return void
void
@@ -105,10 +116,13 @@
- \fn int Vect_hist_copy ( struct Map_info *In, struct Map_info *Out )
- \brief copy history from one map to another
- \param struct Map_info *In, struct Map_info *Out
+ \brief Copy history from one map to another
+ \param In input vector map
+ \param Out output vector map
+ \return 0 OK
+ \return -1 error
int
@@ -145,4 +159,3 @@
Vect_hist_write ( Out, "---------------------------------------------------------------------------------\n");
return ( 0 );
Modified: grass/trunk/lib/vector/Vlib/init_head.c
--- grass/trunk/lib/vector/Vlib/init_head.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/init_head.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,31 +1,37 @@
-* for details.
+ \file init_head.c
+ \brief Vector library - init header of vector map
+ Initialize Head structure. To make sure that we are not writing
+ out garbage to a file.
+ for details.
+ \date 2001-2008
#include <string.h>
- ** Initialize Head structure. To make sure that we are not writing
- ** out garbage to a file.
+ \brief Initialize head structure
+ \return 0
int
Vect__init_head (struct Map_info *Map)
@@ -58,10 +64,12 @@
- \fn int Vect_copy_head_data (struct Map_info *from, struct Map_info *to)
- \brief copy header data from one to another map
- \return 0 on success, ?? on error
- \param from Map_info structure, to Map_info structure
+ \brief Copy header data from one to another map
+ \param from target vector map
+ \param to destination vector map
int
Modified: grass/trunk/lib/vector/Vlib/intersect.c
--- grass/trunk/lib/vector/Vlib/intersect.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/intersect.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,35 +1,22 @@
- * \file intersect.c
- * \brief Higher level functions for reading/writing/manipulating vectors.
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
- * \author Original author CERL, probably Dave Gerdes or Mike Higgins. Radim Blazek
+ \file intersect.c
+ \brief Vector library - intersection
-* Radim Blazek
-* for details.
+ for details.
+ Update to GRASS 5.7 Radim Blazek.
+ \date 2001-2008
#include <stdlib.h>
#include <math.h>
@@ -103,27 +90,20 @@
- * \fn int Vect_segment_intersection (
- double ax1, double ay1, double az1, double ax2, double ay2, double az2,
- double bx1, double by1, double bz1, double bx2, double by2, double bz2,
- double *x1, double *y1, double *z1,
- double *x2, double *y2, double *z2,
- int with_z)
* \brief Check for intersect of 2 line segments.
+ * \param[in] ax1,ay1,az1,ax2,ay2,az2 input line a
+ * \param[in] bx1,by1,bz1,bx2,by2,bz2 input line b
+ * \param[out] x1,y1,z1 intersection point1 (case 2-4)
+ * \param[out] x2,y2,z2 intersection point2 (case 2-4)
+ * \param[in] with_z use z coordinate (3D) (TODO)
* \return 0 - do not intersect,
* \return 1 - intersect at one point,
* \return 2 - partial overlap,
* \return 3 - a contains b,
* \return 4 - b contains a,
* \return 5 - identical
- * \param[in] ax1,ay1,az1,ax2,ay2,az2 input line a
- * \param[in] bx1,by1,bz1,bx2,by2,bz2 input line b
- * \param[out] x1,y1,z1 intersection point1 (case 2-4)
- * \param[out] x2,y2,z2 intersection point2 (case 2-4)
- * \param[in] with_z use z coordinate (3D) (TODO)
@@ -484,24 +464,12 @@
- * \fn int Vect_line_intersection (
- struct line_pnts *APoints,
- struct line_pnts *BPoints,
- struct line_pnts ***ALines,
- struct line_pnts ***BLines,
- int *nalines,
- int *nblines,
- int with_z)
* \brief Intersect 2 lines.
* Creates array of new lines created from original A line, by
* intersection with B line. Points (Points->n_points == 1) are not
* supported.
- * \return 0 no intersection
- * \return 1 intersection found
* \param[in] APoints first input line
* \param[in] BPoints second input line
* \param[out] ALines array of new lines created from original A line
@@ -509,6 +477,9 @@
* \param[out] nalines number of new lines (ALines)
* \param[out] nblines number of new lines (BLines)
* \param[in] with_z 3D, not supported!
+ * \return 0 no intersection
+ * \return 1 intersection found
int
@@ -950,18 +921,16 @@
- * \fn int Vect_line_check_intersection ( struct line_pnts *APoints, struct line_pnts *BPoints, int with_z)
* \brief Check if 2 lines intersect.
* Points (Points->n_points == 1) are also supported.
* \param[in] with_z 3D, not supported (only if one or both are points)!
int
Modified: grass/trunk/lib/vector/Vlib/legal_vname.c
--- grass/trunk/lib/vector/Vlib/legal_vname.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/legal_vname.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -3,23 +3,24 @@
\brief Vector library - Check if map name is legal vector map name
- \author Radim Blazek
- (C) 2001 by the GRASS Development Team
for details.
+ \date 2001-2008
#include <string.h>
- \fn int Vect_legal_filename (char *s)
\brief Check if output is legal vector name.
Rule: [A-Za-z][A-Za-z0-9_@]*
@@ -70,7 +71,6 @@
- \fn int Vect_check_input_output_name ( char * input, char * output, int error )
\brief Check for input and output vector map name.
Check
Modified: grass/trunk/lib/vector/Vlib/level.c
--- grass/trunk/lib/vector/Vlib/level.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/level.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,27 +1,34 @@
-* for details.
+ \file level.c
+ \brief Vector library - level info
+ for details.
+ \date 2001-2008
- \fn int Vect_level (struct Map_info *Map)
- \brief returns level that Map is opened at
- \return open level (1: no topology, or 2: topology support) or -1 on error
+ \brief Returns level that Map is opened at
+ - 1: no topology
+ - 2: topology support
+ \return open level
int
@@ -29,9 +36,9 @@
if (Map->open != VECT_OPEN_CODE)
if (Map->open != VECT_CLOSED_CODE)
- fprintf (stderr, "VECT_LEVEL: Map structure was never initialized\n");
+ G_warning ("Vect_level(): %s", _("Map structure was never initialized"));
else
- fprintf (stderr, "VECT_LEVEL: Map structure has been closed\n");
+ G_warning ("Vect_level(): %s", _("Map structure has been closed"));
return (-1);
return (Map->level);
Modified: grass/trunk/lib/vector/Vlib/level_two.c
--- grass/trunk/lib/vector/Vlib/level_two.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/level_two.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,31 +1,32 @@
-* for details.
+ \file level_two.c
+ \brief Vector library - topo level
+ for details.
+ \date 2001-2008
+#include <stdlib.h>
-#include <stdlib.h>
-/* INTERFACE LEVEL II */
+ \brief Get number of nodes
- \fn int Vect_get_num_nodes (struct Map_info *map)
- \brief get number of nodes
- \return number of nodes
+ \return number of nodes
int
@@ -34,10 +35,12 @@
- \fn int Vect_get_num_primitives (struct Map_info *map, int type)
- \brief get number of primitives
- \return number of primitives of given type
+ \brief Get number of primitives
+ \param map vector map
+ \patam type feature type
+ \return number of primitives of given type
int
@@ -55,10 +58,11 @@
- \fn int Vect_get_num_lines (struct Map_info *map)
- \brief get number of line vectors (points, lines, centroids)
- \return number of line vectors
+ \brief Fet number of line vectors (points, lines, centroids)
+ \return number of line vectors
int
@@ -67,10 +71,11 @@
- \fn int Vect_get_num_areas (struct Map_info *map)
- \brief get number of areas
- \return number of areas
+ \brief Get number of areas
+ \return number of areas
int
@@ -79,12 +84,12 @@
- * \fn int Vect_get_num_faces (struct Map_info *map)
- * \brief get number of faces
- * \return number of faces
- * \param Map_info structure
+ \brief Get number of faces
+ \return number of faces
int
@@ -92,10 +97,11 @@
- \fn int Vect_get_num_islands (struct Map_info *map)
- \brief get number of islands
- \return number of islands
+ \brief Get number of islands
+ \return number of islands
int
@@ -104,10 +110,11 @@
- \fn int Vect_get_num_dblinks (struct Map_info *map)
- \brief get number of defined dblinks
- \return number of dblinks
+ \brief Get number of defined dblinks
+ \return number of dblinks
int
@@ -116,10 +123,11 @@
- \fn int Vect_get_num_updated_lines (struct Map_info *map)
- \brief get number of updated lines
- \return number of updated lines
+ \brief Get number of updated lines
+ \return number of updated lines
int
@@ -128,10 +136,12 @@
- \fn int Vect_get_updated_line (struct Map_info *map, int idx)
- \brief get updated line by index
- \return updated line
+ \brief Get updated line by index
+ \param idx index
+ \return updated line
int
@@ -140,10 +150,11 @@
- \fn int Vect_get_num_updated_nodes (struct Map_info *map)
- \brief get number of updated nodes
- \return number of updated nodes
+ \brief Get number of updated nodes
+ \return number of updated nodes
int
@@ -152,10 +163,12 @@
- \fn int Vect_get_updated_node (struct Map_info *map, int idx)
- \brief get updated node by index
- \return updated node
+ \brief Get updated node by index
+ \param idx index
+ \return updated node
int
@@ -164,10 +177,13 @@
- \fn int Vect_get_node_coor (struct Map_info *map, int num, double *x, double *y, double *z)
- \brief get 2D/3D coordinates of node
- \return 2D/3D coordinates of node
- \param Map_info structure, node number, xyz coordinates values
+ \brief Get 2D/3D coordinates of node
+ \param num
+ \param x,y,z coordinates values
+ \return 2D/3D coordinates of node
int
@@ -185,17 +201,20 @@
- \fn int Vect_get_line_nodes ( struct Map_info *Map, int line, int *n1, int *n2)
- \brief get starting and ending node of line
- \return numbers of line nodes
- \param Map_info structure, line number, numbers of line nodes
+ \brief Get starting and ending node of line
+ \param line line id
+ \param n1, n2 ids of line nodes
+ \return numbers of line nodes
int
if ( Map->level < 2 )
- G_fatal_error ("Map %s@%s is not open on level >= 2\n", Map->name, Map->mapset);
+ G_fatal_error (_("Vector map <%s> is not open on level >= 2"), Vect_get_full_name(Map));
if ( n1 != NULL )
*n1 = Map->plus.Line[line]->N1;
@@ -207,17 +226,20 @@
- \fn int Vect_get_line_areas ( struct Map_info *Map, int line, int *left, int *right)
- \brief get areas/isles on the left and right
- \return numbers of areas/isles on the left and right
- \param Map_info structure, line number, numbers of areas/isles on the left and right
+ \brief Get areas/isles on the left and right
+ \param line
+ \param[out] left,right numbers of areas/isles on the left and right
+ \return numbers of areas/isles on the left and right
int
if ( left != NULL )
*left = Map->plus.Line[line]->left;
@@ -229,67 +251,75 @@
- \fn int Vect_get_node_n_lines ( struct Map_info *Map, int node )
- \brief returns number of lines for node
- \return numbers of line for a node ??
+ \brief Returns number of lines for node
+ \return numbers of lines for a node
int
return ( Map->plus.Node[node]->n_lines );
- \fn int Vect_get_node_line ( struct Map_info *Map, int node, int line )
- \brief returns line number for node line index
- \return line number for node line index
- \param Map vector map
- \param node node number
- \param line line index, range : 0 - Vect_get_node_n_lines()
+ \brief Returns line number for node line index
+ \param node node number
+ \param line line index, range : 0 - Vect_get_node_n_lines()
+ \return line number for node line index
int
return ( Map->plus.Node[node]->lines[line] );
- \fn int Vect_get_node_line_angle ( struct Map_info *Map, int node, int line )
- \brief angle of segment of the line connected to the node
- \return angle of segment of the line connected to the node
+ \brief Angle of segment of the line connected to the node
+ \return angle of segment of the line connected to the node
float
return ( Map->plus.Node[node]->angles[line] );
- \fn int Vect_get_centroid_area ( struct Map_info *Map, int centroid )
- \brief returns ID of area the centroid is within
- \return ID of area the centroid is within, 0 for not in area, negative ID if area/centroid (?) is duplicate
- \param Map_info structure, centroid number
+ \brief Returns ID of area the centroid is within
+ \param centroid centroid id
+ \return ID of area the centroid is within
+ \return 0 for not in area
+ \return negative ID if area/centroid (?) is duplicate
int
return ( Map->plus.Line[centroid]->left );
Modified: grass/trunk/lib/vector/Vlib/line.c
--- grass/trunk/lib/vector/Vlib/line.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/line.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,35 +1,56 @@
-* for details.
+ \file line.c
+ \brief Vector library - geometry manipulation
+ for details.
+ \date 2001-2008
#include <stdlib.h>
#include <math.h>
+ \brief Creates and initializes a struct line_pnts.
+ Use Vect_new_line_struct() instead.
+ This structure is used for reading and writing vector lines and
+ polygons. The library routines handle all memory allocation. If
+ 3 lines in memory are needed at the same time, then simply 3
+ line_pnts structures have to be used
+ \param void
+ \return pointer to line_pnts
struct line_pnts *Vect__new_line_struct (void);
- \fn struct line_pnts *Vect_new_line_struct (void)
- \brief creates and initializes a struct line_pnts. This structure is
- used for reading and writing vector lines and polygons. The library
- routines handle all memory allocation. If 3 lines in memory are needed
- at the same time, then simply 3 line_pnts structures have to be used
- \return struct line_pnts * or NULL on error
- \param void
+ \param void
struct line_pnts *
Vect_new_line_struct ()
@@ -37,7 +58,7 @@
struct line_pnts *p;
if (NULL == (p = Vect__new_line_struct ()))
- G_fatal_error ("New_line: Out of memory");
+ G_fatal_error ("Vect_new_line_struct(): %s", _("Out of memory"));
return p;
@@ -60,10 +81,11 @@
- \fn int Vect_destroy_line_struct (struct line_pnts *p)
- \brief frees all memory associated with a struct line_pnts, including the struct itself
- \return no return value
- \param line_pnts * structure
+ \brief Frees all memory associated with a struct line_pnts, including the struct itself
+ \param p pointer to line_pnts structure
+ \return 0
int
@@ -72,22 +94,25 @@
if (p->alloc_points)
- free ((char *) p->x);
- free ((char *) p->y);
- free ((char *) p->z);
+ G_free ((char *) p->x);
+ G_free ((char *) p->y);
+ G_free ((char *) p->z);
- free ((char *) p);
+ G_free ((char *) p);
return 0;
- \fn int Vect_copy_xyz_to_pnts (
- struct line_pnts *Points, double *x, double *y, double *z, int n)
- \brief ADD
- \return 0 on success, -1 on out of memory
- \param line_pnts * structure, x, y, z, number of points
+ \brief Copy points from array to line structure
+ \param Points line structure
+ \param number of points to be copied
int
@@ -114,14 +139,16 @@
- \fn int Vect_reset_line (struct line_pnts *Points)
- \brief ADD. Make sure line structure is clean to be re-used, i.e. it
- has no points associated with it Points must have previously been
- created with Vect_new_line_struct ()
+ \brief Reset line
+ Make sure line structure is clean to be re-used, i.e. it
+ has no points associated with it Points must have previously been
+ created with Vect_new_line_struct().
+ \param Points line to be reset
+ \return 0
-/* NEW after 4.0 alpha */
int
@@ -131,13 +158,17 @@
- \fn int Vect_append_point (struct line_pnts *Points, double x, double y, double z)
- \brief appends one point to the end of a Points structure returns new
- number of points or -1 on out of memory Note, this will append to
- whatever is in line struct. If you are re-using a line struct, be
- sure to clear out old data first by calling Vect_reset_line ()
- \return number of points
+ \brief Appends one point to the end of a line.
+ Returns new number of points or -1 on out of memory Note, this will
+ append to whatever is in line struct. If you are re-using a line
+ struct, be sure to clear out old data first by calling
+ Vect_reset_line().
+ \param x,y,z point coordinates to be added
+ \return number of points
int
@@ -151,18 +182,19 @@
Points->x[n] = x;
Points->y[n] = y;
Points->z[n] = z;
return ++(Points->n_points);
- \fn int Vect_line_insert_point (struct line_pnts *Points, int index, double x, double y, double z)
- \brief insert new point at index position and move all old points at that position and above up
- \return number of points or -1 on error (alocation)
- \param Points line structure
- \param index (from 0 to Points->n_points-1)
- \param x
- \param y
- \param z
+ \brief Insert new point at index position and move all old points at that position and above up
+ \param index (from 0 to Points->n_points-1)
+ \return -1 on error (alocation)
int
@@ -170,7 +202,7 @@
register int n;
if ( index < 0 || index > Points->n_points-1 )
- G_fatal_error ("Index out of range in Vect_line_insert_point()");
+ G_fatal_error ("%s Vect_line_insert_point()", _("Index out of range in"));
if (0 > dig_alloc_points (Points, Points->n_points + 1))
return (-1);
@@ -189,11 +221,12 @@
- \fn int Vect_line_delete_point (struct line_pnts *Points, int index)
- \brief delete point at given index and move all points above down
+ \brief Delete point at given index and move all points above down
int
@@ -201,7 +234,7 @@
register int n;
- G_fatal_error ("Index out of range in Vect_line_delete_point()");
if ( Points->n_points == 0 )
return 0;
@@ -217,10 +250,11 @@
- \fn int Vect_line_prune (struct line_pnts *Points)
- \brief remove duplicate points, i.e. zero length segments
+ \brief Remove duplicate points, i.e. zero length segments
int
@@ -246,10 +280,12 @@
- \fn int Vect_line_prune_thresh (struct line_pnts *Points, double threshold )
- \brief remove points in threshold
- \return number of points in result
+ \brief Remove points in threshold
+ \param threshold threshold value
+ \return number of points in result
int
Vect_line_prune_thresh (struct line_pnts *Points, double threshold)
@@ -265,18 +301,22 @@
- \fn int Vect_append_points (struct line_pnts *Points, struct line_pnts *APoints,
- int direction)
- \brief appends points to the end of a Points structure. Note, this
- will append to whatever is in line struct. If you are re-using a
- line struct, be sure to clear out old data first by calling
- Vect_reset_line ()
- \return new number of points, -1 on out of memory
- \param line_pnts * structure, line_pntsA * structure, direction (GV_FORWARD, GV_BACKWARD)
+ \brief Appends points to the end of a line.
+ Note, this will append to whatever is in line struct. If you are
+ re-using a line struct, be sure to clear out old data first by
+ calling Vect_reset_line().
+ \param APoints points to be included
+ \param direction direction (GV_FORWARD, GV_BACKWARD)
+ \return new number of points
+ \return -1 on out of memory
int
- int direction) /* GV_FORWARD, GV_BACKWARD */
+ int direction)
int i, n, on, an;
@@ -308,11 +348,17 @@
- \fn int Vect_copy_pnts_to_xyz (
- struct line_pnts *Points, double *x, double *y, double *z, int *n)
- \brief ADD. NOTE! x/y arrays MUST be at least as large as Points->n_points
- \return number of points copied. Also note that n is a pointer to int.
+ \brief Copy points from line structure to array
+ x/y/z arrays MUST be at least as large as Points->n_points
+ Also note that n is a pointer to int.
+ \param x,y,z coordinates arrays
+ \param n number of points
+ \return number of points copied
int
@@ -333,23 +379,21 @@
- \fn int Vect_point_on_line ( struct line_pnts *Points, double distance,
- double *x, double *y, double *z, double *angle, double *slope )
- \brief Find point on line in the specified distance from the begining,
- measured along line.
+ \brief Find point on line in the specified distance.
+ From the begining, measured along line.
If the distance is greater than line length or negative, error is returned.
+ \param distance distance value
+ \param x,y,z pointers to point coordinates or NULL
+ \param angle pointer to angle of line in that point (radians, counter clockwise from x axis) or NULL
+ \param slope pointer to slope angle in radians (positive up)
- ( G_begin_distance_calculations() must be called before. - Is not true
- because G_distance is not used (no 3D support) )
- *x, *y, *z - pointers to point coordinates or NULL
- *angle - pointer to angle of line in that point (radians,
- counter clockwise from x axis) or NULL
- *slope - pointer to slope angle in radians (positive up)
- \return number of segment the point is on (first is 1),
- 0 error when point is outside the line
- \param line_pnts * structure, distance, x, y, z, angle, slope
+ \return number of segment the point is on (first is 1),
+ \return 0 error when point is outside the line
int
@@ -429,17 +473,21 @@
- \fn int Vect_line_segment ( struct line_pnts *InPoints,
- double start, double end,
- struct line_pnts *OutPoints )
- \brief Create segment of InPoints from start to end measured along the line
- and write it to OutPoints.
+ \brief Create line segment.
- If the distance is greater than line length or negative, error is returned.
+ Creates segment of InPoints from start to end measured along the
+ line and write it to OutPoints.
- \return 1 success
- 0 error when start > length or end < 0 or start < 0 or end > length
- \param line_pnts * structure, start, end, line_pnts * structure
+ If the distance is greater than line length or negative, error is
+ returned.
+ \param InPoints input line
+ \param start segment number
+ \param end segment number
+ \param OutPoints output line
+ \return 1 success
+ \return 0 error when start > length or end < 0 or start < 0 or end > length
int
Vect_line_segment ( struct line_pnts *InPoints, double start, double end,
@@ -471,7 +519,7 @@
G_debug ( 3, " -> seg1 = %d seg2 = %d", seg1, seg2);
if ( seg1 == 0 || seg2 == 0 ) {
- G_warning ("Segment outside line, no segment created");
+ G_warning (_("Segment outside line, no segment created"));
return 0;
@@ -487,17 +535,20 @@
- \fn double Vect_line_length ( struct line_pnts *Points )
- \brief calculate line length, 3D-length in case of 3D vector line
- \return line length
+ \brief Calculate line length, 3D-length in case of 3D vector line
+ For Lat-Long use Vect_line_geodesic_length() instead.
+ \return line length
double
int j;
double dx, dy, dz, len = 0;
if ( Points->n_points < 2 ) return 0;
for ( j = 0; j < Points->n_points - 1; j++) {
@@ -512,10 +563,13 @@
- \fn double Vect_line_geodesic_length ( struct line_pnts *Points )
- \brief calculate line length. If projection is LL, the length is measured along the geodesic.
+ \brief Calculate line length.
+ If projection is LL, the length is measured along the geodesic.
double
@@ -544,34 +598,33 @@
-\fn int Vect_line_distance ( struct line_pnts *points,
- double ux, double uy, double uz,
- int with_z,
- double *px, double *py, double *pz,
- double *dist,
- double *spdist,
- double *lpdist)
- \brief calculate line distance. Sets (if not null):
- px, py - point on line,
- dist - distance to line,
- spdist - distance to point on line from segment beginning,
- sldist - distance to point on line form line beginning along line
- \return nearest segment (first is 1)
- \param line_pnts * structure, x, y, z of point, flag if to use z
- coordinate, (3D calculation), point on line, distance to line,
- distance of point from segment beginning, distance of point from line
- beginning
+ \brief calculate line distance.
+ Sets (if not null):
+ - px, py - point on line,
+ - dist - distance to line,
+ - spdist - distance to point on line from segment beginning,
+ - sldist - distance to point on line form line beginning along line
+ \param points line
+ \param ux,uy,uz point coordinates
+ \param with_z flag if to use z coordinate (3D calculation)
+ \param[out] px,py,pz point on line
+ \param[out] dist distance to line,
+ \param[out] spdist distance of point from segment beginning
+ \param[out] lpdist distance of point from line
+ \return nearest segment (first is 1)
-/* original dig__check_dist () in grass50 */
int
- struct line_pnts *points, /* line */
- double ux, double uy, double uz, /* point */
- int with_z, /* use z coordinate, (3D calculation) */
- double *px, double *py, double *pz, /* point on line */
- double *dist, /* distance to line */
- double *spdist, /* distance of point from segment beginning */
- double *lpdist) /* distance of point from line beginning */
+ struct line_pnts *points,
+ double ux, double uy, double uz,
+ int with_z,
+ double *px, double *py, double *pz,
+ double *dist,
+ double *spdist,
+ double *lpdist)
register int i;
register double distance;
@@ -655,12 +708,15 @@
- \fn double Vect_points_distance ( double x1, double y1, double z1,
- double x2, double y2, double z2,
- int with_z)
- \brief distance of 2 points. with_z - use z coordinate
- \return distance
- \param x1, y1, z1, x2, y2, z2, with_z
+ \brief Calculate distance of 2 points
+ Simply uses Pythagoras.
+ \param x1,y1,z1 first point
+ \param x2,y2,z2 second point
+ \param with_z use z coordinate
+ \return distance
double
@@ -683,10 +739,12 @@
- \fn int Vect_line_box ( struct line_pnts *Points, BOUND_BOX *Box )
- \brief get bounding box of line
- \return 0 on success, ADD on error
- \param line_pnts * structure, BOUND_BOX
+ \brief Get bounding box of line
+ \param[out] Box bounding box
+ \return 0
int
@@ -696,11 +754,12 @@
- \fn void Vect_line_reverse ( struct line_pnts *Points )
- \brief reverse the order of vertices
- \param Points line to be changed
+ \brief Reverse the order of vertices
+ \param Points line to be changed
+ \return void
-/* reverse_line - reverse order of Points ( direction of line ) */
int i, j, np;
@@ -722,14 +781,15 @@
+ \brief Fetches FIRST category number for given vector line and field
-\brief fetches FIRST category number for given vector line and field
-\param vmap: Map input
-\param varea: line number
-\param vfield: field number
-\return -1 no category
-\return category number (>=0)
+ \param Map vector map
+ \param field layer number
+ \return -1 no category
+ \return category number (>=0)
int
Vect_get_line_cat ( struct Map_info *Map, int line, int field ) {
@@ -746,4 +806,3 @@
return cat;
Modified: grass/trunk/lib/vector/Vlib/list.c
--- grass/trunk/lib/vector/Vlib/list.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/list.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,44 +1,27 @@
* \file list.c
- * \brief Vector library
+ * \brief Vector library - list definition
* Higher level functions for reading/writing/manipulating vectors.
+ * (C) 2001-2008 by the GRASS Development Team
* for details.
+ * \date 2001-2008
-* for details.
#include <stdlib.h>
-/* ADD comment what and why a list */
- * \fn struct ilist *Vect_new_list (void)
* \brief Creates and initializes a struct ilist.
* This structure is used as container for integer values. The
@@ -64,15 +47,14 @@
- * \fn int Vect_reset_list (struct ilist *list)
+ * \brief Reset ilist structure.
- * \brief Reset ilist structure to make sure ilist structure is clean
- * to be re-used. List must have previously been created with
- * Vect_new_list()
- * \return 0
+ * To make sure ilist structure is clean to be re-used. List must have
+ * previously been created with Vect_new_list().
* \param[in,out] list pointer to struct ilist
+ * \return 0
int
@@ -83,14 +65,12 @@
- * \fn int Vect_destroy_list (struct ilist *list)
* \brief Frees all memory associated with a struct ilist, including
* the struct itself
- * \return 0
* \param[in,out] list pointer to ilist structure
+ * \return 0
int
@@ -109,15 +89,13 @@
- * \fn int Vect_list_append (struct ilist *list, int val )
* \brief Append new item to the end of list if not yet present
- * \return 0 on success
- * \return 1 on error
* \param[in] val new item to append to the end of list
+ * \return 0 on success
+ * \return 1 on error
int
Vect_list_append ( struct ilist *list, int val )
@@ -146,15 +124,13 @@
- * \fn int Vect_list_append_list (struct ilist *alist, struct ilist *blist )
* \brief Append new items to the end of list if not yet present
* \param[in,out] alist pointer to ilist structure where items will be appended
* \param[in] blist pointer to ilist structure with new items
int
Vect_list_append_list ( struct ilist *alist, struct ilist *blist )
@@ -171,15 +147,13 @@
- * \fn int Vect_list_delete (struct ilist *list, int val )
* \brief Remove a given value (item) from list
* \param[in] val to remove
int
Vect_list_delete ( struct ilist *list, int val )
@@ -203,15 +177,13 @@
- * \fn int Vect_list_delete_list ( struct ilist *alist, struct ilist *blist )
* \brief Delete list from existing list
* \param[in,out] alist pointer to original ilist structure,
* \param[in] blist pointer to ilist structure with items to delete
int
@@ -228,15 +200,13 @@
- * \fn int Vect_val_in_list ( struct ilist *list, int val )
* \brief Find a given item in the list
- * \return 1 if an item is found
- * \return 0 no found item in the list
* \param[in] list pointer to ilist structure
* \param[in] val value of item
+ * \return 1 if an item is found
+ * \return 0 no found item in the list
int
Modified: grass/trunk/lib/vector/Vlib/map.c
--- grass/trunk/lib/vector/Vlib/map.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/map.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -5,16 +5,19 @@
- * Higgins. Update to GRASS 5.7 Radim Blazek and David D. Gray.
- * (C) 2001 by the GRASS Development Team
* GNU General Public License (>=v2).
* Read the file COPYING that comes with GRASS
* for details.
+ * \author Original author CERL, probably Dave Gerdes or Mike
+ * Higgins. Update to GRASS 5.7 Radim Blazek and David D. Gray.
+ * \date 2001-2008
#include <stdlib.h>
#include <stdio.h>
#include <dirent.h>
@@ -28,8 +31,8 @@
#include <grass/dbmi.h>
- \fn int Vect_copy_map_lines ( struct Map_info *In, struct Map_info *Out )
\brief Copy all alive elements of opened vector map to another opened vector map
\param[in] In input vector map
@@ -49,7 +52,7 @@
Cats = Vect_new_cats_struct ();
if ( Vect_level ( In ) < 1 )
- G_fatal_error ("Vect_copy_map_lines(): input vector map is not open");
+ G_fatal_error ("Vect_copy_map_lines(): %s", _("input vector map is not open"));
ret = 0;
/* Note: sometimes is important to copy on level 2 (pseudotopo centroids)
@@ -59,7 +62,7 @@
for ( i = 1; i <= nlines; i++ ) {
type = Vect_read_line (In, Points, Cats, i);
if ( type == -1 ) {
- G_warning (_("Unable to read vector map <%s%s>"), In->name, In->mapset);
+ G_warning (_("Unable to read vector map <%s>"), Vect_get_full_name(In));
ret = 1;
break;
@@ -72,7 +75,7 @@
while ( 1 ) {
type = Vect_read_next_line (In, Points, Cats);
if ( type == -1 ) {
ret = 1;
break;
} else if ( type == -2 ) { /* EOF */
@@ -133,7 +136,6 @@
- \fn int Vect_copy ( char *in, char *mapset, char *out, FILE *msgout )
\brief Copy a map including attribute tables
Old vector is deleted
@@ -152,7 +154,7 @@
int i, n, ret, type;
struct Map_info In, Out;
struct field_info *Fi, *Fin;
- char old_path[1000], new_path[1000], buf[1000];
+ char old_path[GPATH_MAX], new_path[GPATH_MAX], buf[GPATH_MAX];
struct stat info;
char *files[] = { GRASS_VECT_FRMT_ELEMENT, GRASS_VECT_COOR_ELEMENT,
GRASS_VECT_HEAD_ELEMENT, GRASS_VECT_HIST_ELEMENT,
@@ -262,18 +264,19 @@
- \fn int Vect_rename ( char *in, char *out, FILE *msgout )
- \brief Rename a map, attribute tables are created in the same database where input tables were stored.
+ \brief Rename a map.
- The original format (native/OGR) is used.
- Old map ('out') is deleted!!!
+ Attribute tables are created in the same database where input tables were stored.
- \param[in] in input vector map name
- \param[in] out output vector map name
- \param[in] msgout output file for messages or NULL
+ The original format (native/OGR) is used.
+ Old map ('out') is deleted!!!
- \return -1 error
- \return 0 success
+ \param[in] in input vector map name
+ \param[in] out output vector map name
+ \param[in] msgout output file for messages or NULL
+ \return -1 error
+ \return 0 success
int
@@ -388,13 +391,12 @@
- \fn int Vect_delete ( char *map )
- \brief Delete vector map including attribute tables
- \param[in] map vector map name
- \return -1 error
- \return 0 success
+ \brief Delete vector map including attribute tables
+ \param[in] map vector map name
+ \return -1 error
+ \return 0 success
int
@@ -402,7 +404,7 @@
int i, n, ret;
struct Map_info Map;
struct field_info *Fi;
- char buf[5000];
+ char buf[GPATH_MAX];
DIR *dir;
struct dirent *ent;
char *tmp;
@@ -412,7 +414,7 @@
G_chop ( map );
if ( map == NULL || strlen ( map ) == 0 ) {
- G_warning ( "Invalid vector map name <%s>", map ? map : "null");
+ G_warning (_("Invalid vector map name <%s>"), map ? map : "null");
return -1;
@@ -428,7 +430,7 @@
Vect_set_open_level (1); /* Topo not needed */
ret = Vect_open_old_head (&Map, map, G_mapset());
if ( ret < 1 ) {
- G_warning ( "Unable to open header file for vector map <%s>", map );
+ G_warning (_("Unable to open header file for vector map <%s>"), map );
return -1;
@@ -462,7 +464,7 @@
return -1;
} else {
- G_warning ( "Table <%s> linked to vector map <%s> does not exist",
+ G_warning (_("Table <%s> linked to vector map <%s> does not exist"),
Fi->table, map);
@@ -520,17 +522,16 @@
- \fn int Vect_copy_tables ( struct Map_info *In, struct Map_info *Out, int field )
- \brief Copy tables linked to vector map.
- All if field = 0, or table defined by given field if field > 0
- \param[in] In input vector map
- \param[out] Out output vector map
- \param[in] field layer number
- \return -1 on error
+ \brief Copy tables linked to vector map.
+ All if field = 0, or table defined by given field if field > 0
+ \param[in] In input vector map
+ \param[out] Out output vector map
+ \param[in] field layer number
+ \return 0 on success
int
@@ -589,19 +590,17 @@
- \fn int Vect_copy_table ( struct Map_info *In, struct Map_info *Out, int field_in,
- int field_out, char *field_name, int type )
- \brief Copy table linked to vector map based on type.
- \param[in] field_in input layer number
- \param[in] field_out output layer number
- \param[in] field_name layer name
- \param[in] type feature type
+ \brief Copy table linked to vector map based on type.
+ \param[in] field_in input layer number
+ \param[in] field_out output layer number
+ \param[in] field_name layer name
+ \param[in] type feature type
int
@@ -611,21 +610,19 @@
- \fn int Vect_copy_table_by_cats ( struct Map_info *In, struct Map_info *Out, int field_in,
- int field_out, char *field_name, int type, int *cats, int ncats )
- \brief Copy table linked to vector map based on category numbers.
- \param[in] cats pointer to array of cats or NULL
- \param[in] ncats number of cats in 'cats'
+ \brief Copy table linked to vector map based on category numbers.
+ \param[in] cats pointer to array of cats or NULL
+ \param[in] ncats number of cats in 'cats'
int
Modified: grass/trunk/lib/vector/Vlib/net.c
--- grass/trunk/lib/vector/Vlib/net.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/net.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,26 +1,30 @@
-* AUTHOR(S): Radim Blazek
-* for details.
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/dbmi.h>
-#include <grass/Vect.h>
-#include <grass/glocale.h>
+ * \file map.c
+ * \brief Vector library - net releated fns
+ * Higher level functions for reading/writing/manipulating vectors.
+ * This program is free software under the
+ * GNU General Public License (>=v2).
+ * Read the file COPYING that comes with GRASS
+ * for details.
+ * \author Radim Blazek
+ * \date 2001-2008
+#include<stdlib.h>
+#include<string.h>
+#include<fcntl.h>
+#include<grass/gis.h>
+#include<grass/dbmi.h>
+#include<grass/Vect.h>
+#include<grass/glocale.h>
@@ -59,43 +63,38 @@
- \fn Vect_net_build_graph ( struct Map_info *Map,
- int ltype,
- int afield,
- int nfield,
+ before conversion to int by 1000 and for lenghts LL without geo flag by 1000000.
+ The same multiplication factor is used for nodes.
+ Costs in database column may be 'integer' or 'double precision' number >= 0
+ or -1 for infinity i.e. arc or node is closed and cannot be traversed
+ If record in table is not found for arcs, arc is skip.
+ If record in table is not found for node, costs for node are set to 0.
+ \param ltype line type for arcs
+ \param afield arc costs field (if 0, use length)
+ \param nfield node costs field (if 0, do not use node costs)
+ \param afcol column with forward costs for arc
+ \param abcol column with backward costs for arc (if NULL, back costs = forward costs),
+ \param ncol column with costs for nodes (if NULL, do not use node costs),
+ \param geo use geodesic calculation for length (LL),
+ \param algorithm not used (in future code for algorithm)
+ \return 0 on success, 1 on error
+int
+Vect_net_build_graph ( struct Map_info *Map,
+ int ltype,
+ int afield,
+ int nfield,
char *afcol,
char *abcol,
char *ncol,
- int geo,
- int algorithm )
- before conversion to int by 1000 and for lenghts LL without geo flag by 1000000.
- The same multiplication factor is used for nodes.
- Costs in database column may be 'integer' or 'double precision' number >= 0
- or -1 for infinity i.e. arc or node is closed and cannot be traversed
- If record in table is not found for arcs, arc is skip.
- If record in table is not found for node, costs for node are set to 0.
- \return 0 on success, 1 on error
- line type for arcs,
- arc costs field,
- node costs field,
- column with forward costs for arc (if NULL use length),
- column with backward costs for arc (if NULL, back costs = forward costs),
- column with costs for nodes (if NULL, do not use node costs),
- use geodesic calculation for length (LL),
- not used (in future code for algorithm)
-int
-Vect_net_build_graph ( struct Map_info *Map,
- int ltype, /* line type for arcs */
- int afield, /* arc costs field (if 0, use length) */
- int nfield, /* node costs field (if 0, do not use node costs) */
- char *afcol, /* column with forward costs for arc */
- char *abcol, /* column with backward costs for arc (if NULL, back = forward) */
- char *ncol, /* column with costs for nodes */
- int geo, /* use geodesic calculation for length (LL) */
- int algorithm ) /* not used, in future code for algorithm */
+ int geo,
+ int algorithm )
int i, j, from, to, line, nlines, nnodes, ret, type, cat, skipped, cfound;
int dofw, dobw;
@@ -117,7 +116,7 @@
G_debug (1, "Vect_build_graph(): ltype = %d, afield = %d, nfield = %d", ltype, afield, nfield);
G_debug (1, " afcol = %s, abcol = %s, ncol = %s", afcol, abcol, ncol);
- G_message (_("Building graph ..."));
+ G_message (_("Building graph..."));
Map->graph_line_type = ltype;
@@ -153,7 +152,7 @@
else
dglInitialize(gr, (dglByte_t)1, (dglInt32_t)0, (dglInt32_t)0, opaqueset);
- if ( gr == NULL ) G_fatal_error (_("Cannot build network graph"));
+ if ( gr == NULL ) G_fatal_error (_("Unable build network graph"));
db_init_handle (&handle);
db_init_string ( &stmt);
@@ -167,22 +166,26 @@
/* Get field info */
if ( afield < 1 ) G_fatal_error (_("Arc field < 1"));
Fi = Vect_get_field( Map, afield);
- if ( Fi == NULL ) G_fatal_error (_("Cannot get field info"));
+ if ( Fi == NULL )
+ G_fatal_error (_("Database connection not defined for layer %d"),
+ afield);
/* Open database */
driver = db_start_driver_open_database ( Fi->driver, Fi->database );
if ( driver == NULL )
- G_fatal_error(_("Cannot open database <%s> by driver <%s>"),
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
Fi->database, Fi->driver) ;
/* Load costs to array */
if ( db_get_column ( driver, Fi->table, afcol, &Column ) != DB_OK)
- G_fatal_error(_("Cannot get column info"));
+ G_fatal_error(_("Column <%s> not found in table <%s>"),
+ afcol, Fi->table);
fctype = db_sqltype_to_Ctype ( db_get_column_sqltype(Column) );
if ( fctype != DB_C_TYPE_INT && fctype != DB_C_TYPE_DOUBLE )
- G_fatal_error (_("Column type not supported"));
+ G_fatal_error (_("Data type of column <%s> not supported (must be numeric)"),
+ afcol);
db_CatValArray_init ( &fvarr );
nrec = db_select_CatValArray ( driver, Fi->table, Fi->key, afcol, NULL, &fvarr );
@@ -190,12 +193,14 @@
if ( abcol != NULL ) {
if ( db_get_column ( driver, Fi->table, abcol, &Column ) != DB_OK)
+ abcol, Fi->table);
bctype = db_sqltype_to_Ctype ( db_get_column_sqltype(Column) );
if ( bctype != DB_C_TYPE_INT && bctype != DB_C_TYPE_DOUBLE )
+ abcol);
db_CatValArray_init ( &bvarr );
nrec = db_select_CatValArray ( driver, Fi->table, Fi->key, abcol, NULL, &bvarr );
@@ -205,7 +210,7 @@
skipped = 0;
- G_message (_("Registering arcs ..."));
+ G_message (_("Registering arcs..."));
G_percent ( i, nlines, 1 ); /* must be before any continue */
@@ -296,24 +301,28 @@
G_debug ( 2, "Set nodes' costs");
if ( nfield < 1 ) G_fatal_error ("Node field < 1");
- G_message (_("Setting node costs ..."));
+ G_message (_("Setting node costs..."));
Fi = Vect_get_field( Map, nfield);
+ if ( Fi == NULL )
+ nfield);
if ( db_get_column ( driver, Fi->table, ncol, &Column ) != DB_OK)
+ ncol, Fi->table);
+ ncol);
nrec = db_select_CatValArray ( driver, Fi->table, Fi->key, ncol, NULL, &fvarr );
@@ -365,9 +374,10 @@
db_CatValArray_free ( &fvarr);
- G_message (_("Flattening the graph ..."));
+ G_message (_("Flattening the graph..."));
ret = dglFlatten ( gr );
- if ( ret < 0 ) G_fatal_error (_("GngFlatten error"));
+ if ( ret < 0 )
/* init SP cache */
/* Disabled because of BUG1 in dglib. Without cache it is terribly slow, but with cache there
@@ -381,15 +391,23 @@
- \fn int Vect_net_shortest_path ( struct Map_info *Map, int from, int to, struct ilist *List, double *cost )
- \param Map_info structure, from?, to?, ilist? cost
+ \param to to node
+ \param[out] List list of line ids (path)
+ \param[out] cost costs value
+ \return 0 is correct for from = to, or List == NULL ) ? sum of costs is better return value,
+ \return -1 : destination unreachable
-#include<fcntl.h>
int
@@ -428,7 +446,7 @@
return -1;
- fprintf( stderr , "dglShortestPath error: %s\n", dglStrerror( &(Map->graph) ) );
+ G_warning(_("dglShortestPath error: %s"), dglStrerror( &(Map->graph) ) );
return -1;
@@ -462,11 +480,17 @@
return (cArc);
-* Returns in cost for given direction (GV_FORWARD,GV_BACKWARD) in *cost.
-* cost is set to -1 if closed.
-* Return : 1 : OK
-* 0 : does not exist (was not inserted)
+ \brief Returns in cost for given direction in *cost.
+ cost is set to -1 if closed.
+ \return 1 OK
+ \return 0 does not exist (was not inserted)
int
Vect_net_get_line_cost ( struct Map_info *Map, int line, int direction, double *cost )
@@ -504,9 +528,14 @@
return 1;
-* Returns in cost for given node in *cost.
-* Return : 1 : OK
+ \brief Get cost of node
+ \return 1
int
Vect_net_get_node_cost ( struct Map_info *Map, int node, double *cost )
@@ -521,27 +550,22 @@
- \fn int Vect_net_nearest_nodes ( struct Map_info *Map, double x, double y, double z,
- int direction, double maxdist,
- int *node1, int *node2, int *ln, double *costs1, double costs2,
- struct line_pnts *Points1, struct line_pnts *Points1 )
- \brief Find nearest node(s) on network.
- \return number of nodes found (0,1,2)
- \param Map
- \param x point x coordinate
- \param y point y coordinate
- \param z point z coordinate (NOT USED !)
- \param direction (GV_FORWARD - from point to net, GV_BACKWARD - from net to point)
- \param maxdist maximum distance to the network
- \param node1 pointer where to store the node number (or NULL)
- \param node2 pointer where to store the node number (or NULL)
- \param ln pointer where to store the nearest line number (or NULL)
- \param costs1 pointer where to store costs on nearest line to node1 (not costs from x,y,z to the line) (or NULL)
- \param costs2 pointer where to store costs on nearest line to node2 (not costs from x,y,z to the line) (or NULL)
- \param Points1 pointer to structure where to store vertices on nearest line to node1 (or NULL)
- \param Points2 pointer to structure where to store vertices on nearest line to node2 (or NULL)
- \param pointer where to distance to the line (or NULL)
+ \brief Find nearest node(s) on network.
+ \param Map vetor map
+ \param x,y,z point coordinates (z coordinate NOT USED !)
+ \param direction (GV_FORWARD - from point to net, GV_BACKWARD - from net to point)
+ \param maxdist maximum distance to the network
+ \param node1 pointer where to store the node number (or NULL)
+ \param node2 pointer where to store the node number (or NULL)
+ \param ln pointer where to store the nearest line number (or NULL)
+ \param costs1 pointer where to store costs on nearest line to node1 (not costs from x,y,z to the line) (or NULL)
+ \param costs2 pointer where to store costs on nearest line to node2 (not costs from x,y,z to the line) (or NULL)
+ \param Points1 pointer to structure where to store vertices on nearest line to node1 (or NULL)
+ \param Points2 pointer to structure where to store vertices on nearest line to node2 (or NULL)
+ \param pointer where to distance to the line (or NULL)
+ \return number of nodes found (0,1,2)
@@ -706,31 +730,22 @@
- \fn int Vect_net_shortest_path_coor ( struct Map_info *Map,
- double fx, double fy, double fz, double tx, double ty, double tz,
- double fmax, double tmax,
- double *costs, struct line_pnts *Points,
- double *fdist, double *tdist )
- \brief Find shortest path on network between 2 points given by coordinates.
+ \brief Find shortest path on network between 2 points given by coordinates.
+ \param fx,fy,fz from point x coordinate (z ignored)
+ \param tx,ty,tz to point x coordinate (z ignored)
+ \param fmax maximum distance to the network from 'from'
+ \param tmax maximum distance to the network from 'to'
+ \param costs pointer where to store costs on the network (or NULL)
+ \param Points pointer to the structure where to store vertices of shortest path (or NULL)
+ \param List pointer to the structure where list of lines on the network is stored (or NULL)
+ \param FPoints pointer to the structure where to store line from 'from' to first network node (or NULL)
+ \param TPoints pointer to the structure where to store line from last network node to 'to' (or NULL)
+ \param fdist distance from 'from' to the net (or NULL)
+ \param tdist distance from 'to' to the net (or NULL)
- \return 1 OK, 0 not reachable
- \param Map
- \param fx from point x coordinate
- \param fy from point y coordinate
- \param fz from point z coordinate (ignored)
- \param tx to point x coordinate
- \param ty to point y coordinate
- \param tz to point z coordinate (ignored)
- \param fmax maximum distance to the network from 'from'
- \param tmax maximum distance to the network from 'to'
- \param costs pointer where to store costs on the network (or NULL)
- \param Points pointer to the structure where to store vertices of shortest path (or NULL)
- \param List pointer to the structure where list of lines on the network is stored (or NULL)
- \param FPoints pointer to the structure where to store line from 'from' to first network node (or NULL)
- \param TPoints pointer to the structure where to store line from last network node to 'to' (or NULL)
- \param fdist distance from 'from' to the net (or NULL)
- \param tdist distance from 'to' to the net (or NULL)
+ \return 1 OK, 0 not reachable
int
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/open.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -5,15 +5,17 @@
* for details.
+ * \date 2001-2008
#include <stdlib.h>
#include <stdio.h>
@@ -44,7 +46,7 @@
#endif
-void
+static void
fatal_error ( int ferror, char *errmsg )
switch ( ferror ) {
@@ -61,8 +63,6 @@
- * \fn int Vect_set_open_level (int level)
* \brief Predetermine level at which a map will be opened for
* reading.
@@ -100,8 +100,6 @@
- * \fn Vect__open_old (struct Map_info *Map, char *name, char *mapset, int update, int head_only)
* \brief Open old vector for reading.
* In case of error, the functions respect fatal error settings.
@@ -363,8 +361,6 @@
- * \fn int Vect_open_old ( struct Map_info *Map, char *name, char *mapset)
* \brief Open existing vector for reading
@@ -386,8 +382,6 @@
- * \fn int Vect_open_update ( struct Map_info *Map, char *name, char *mapset)
* \brief Open existing vector for reading/writing
@@ -424,8 +418,6 @@
- * \fn Vect_open_old_head (struct Map_info *Map,char *name, char *mapset)
* \brief Reads only info about vector from headers of 'head', 'dbln',
* 'topo' and 'cidx' file.
@@ -445,8 +437,6 @@
- * \fn int Vect_open_update_head ( struct Map_info *Map, char *name, char *mapset)
* \brief Open old vector head for updating (mostly for database link updates)
@@ -480,8 +470,6 @@
- * \fn int Vect_open_new ( struct Map_info *Map, char *name, int with_z)
* \brief Open new vector for reading/writing
* \param[out] Map vector map
@@ -565,8 +553,6 @@
- * \fn int Vect_coor_info ( struct Map_info *Map, struct Coor_info *Info )
* \brief Update Coor_info structure
* \param[in] Map vector map
@@ -615,8 +601,6 @@
- * \fn char * Vect_maptype_info ( struct Map_info *Map )
* \brief Gets maptype (native, shape, postgis)
@@ -646,8 +630,6 @@
- * \fn int Vect_open_topo (struct Map_info *Map, int head_only)
* \brief Open topo file
* \param[in,out] Map vector map
@@ -728,8 +710,6 @@
- * \fn int Vect_open_spatial_index (struct Map_info *Map)
* \brief Open spatial index file
Modified: grass/trunk/lib/vector/Vlib/overlay.c
--- grass/trunk/lib/vector/Vlib/overlay.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/overlay.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,33 +1,40 @@
-* MODULE: Vector library
-* PURPOSE: Higher level functions for reading/writing/manipulating vectors.
-* COPYRIGHT: (C) 2001 by the GRASS Development Team
-* This program is free software under the GNU General Public
-* License (>=v2). Read the file COPYING that comes with GRASS
-* for details.
+ \file overlay.c
+ \brief Vector library - overlays
+ Higher level functions for reading/writing/manipulating vectors.
+ This is file is just example and starting point for writing overlay
+ functions!!!
+ (C) 2001-2008 by the GRASS Development Team
+ This program is free software under the
+ GNU General Public License (>=v2).
+ Read the file COPYING that comes with GRASS
+ for details.
+ \author Radim Blazek
+ \date 2001
#include <string.h>
+#include <grass/glocale.h>
-/* This is file is just example and starting point for writing overlay functions!!! */
-int Vect_overlay_and ( struct Map_info *, int, struct ilist *, struct ilist *,
- struct Map_info *, int, struct ilist *, struct ilist *,
- struct Map_info *);
+int Vect_overlay_and (struct Map_info *, int, struct ilist *, struct ilist *,
+ struct Map_info *, int, struct ilist *, struct ilist *,
+ struct Map_info *);
+ \brief Get operator code from string
- \fn int Vect_overlay_str_to_operator ( char *str )
- \brief Get operator code from string
- \return operator code, -1 on error
- \param operator code string
+ \param str operator code string
+ \return operator code
int
@@ -41,16 +48,19 @@
return -1;
- \fn int Vect_overlay ( struct Map_info *AMap, int atype, struct ilist *AList, struct ilist *AAList,
- struct Map_info *BMap, int btype, struct ilist *BList, struct ilist *BAList,
- int operator, struct Map_info *OMap )
+ \brief Overlay 2 vector maps and create new one
- \brief Overlay 2 maps and create new one
- \return 0 on success,?? on error
- \param AMap, atype, AList, AAList, BMap, btype, BList, BAList,
- operator, OMap
+ \param AMap vector map A
+ \param AList unused ?
+ \param AAList unused ?
+ \param BMap vector map B
+ \param BList unused ?
+ \param BAList unused ?
+ \param operator operator code
+ \param OMap output vector map
int
Vect_overlay ( struct Map_info *AMap, int atype, struct ilist *AList, struct ilist *AAList, /* map A */
@@ -63,23 +73,32 @@
Vect_overlay_and ( AMap, atype, AList, AAList, BMap, btype, BList, BAList, OMap );
break;
default:
- G_fatal_error (" Vect_overlay(): unknown operator" );
+ G_fatal_error ("Vect_overlay(): %s", _("unknown operator"));
return 0;
- \fn int Vect_overlay_and ( struct Map_info *AMap, int atype, struct ilist *AList, struct ilist *AAList,
- struct Map_info *OMap )
- \brief overlay 2 vector maps with AND. AND supports: point line area
+ \brief Overlay 2 vector maps with AND.
+ AND supports:point line area
point + - +
line - - -
area + - -
- \return 1 on success, 0 on error
- OMap )
+ \param atype feature type for A
+ \param btype feature type for B
+ \return 1 on success
+ \return 0 on error
int
@@ -102,10 +121,10 @@
/* TODO: support all types; at present only point x point, area x point and point x area supported */
if ( ( atype & GV_LINES ) || (btype & GV_LINES) )
- G_warning ("overlay: line/boundary types not supported by AND operator");
+ G_warning (_("Overlay: line/boundary types not supported by AND operator"));
if ( ( atype & GV_AREA ) && (btype & GV_AREA) )
- G_warning ("overlay: area x area types not supported by AND operator");
+ G_warning (_("Overlay: area x area types not supported by AND operator"));
/* TODO: more points in one node in one map */
@@ -213,4 +232,3 @@
return 0;
Modified: grass/trunk/lib/vector/Vlib/poly.c
--- grass/trunk/lib/vector/Vlib/poly.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/poly.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,25 +1,29 @@
-* AUTHOR(S): Original author CERL, probably Dave Gerdes or Mike Higgins.
-* Update to GRASS 5.7 Radim Blazek and David D. Gray.
-* for details.
+ \file poly.c
+ \brief Vector library - polygon related fns
+ for details.
+ \author Original author CERL, probably Dave Gerdes or Mike Higgins.
+ Update to GRASS 5.7 Radim Blazek and David D. Gray.
+ \date 2001
#include <math.h>
#include <stdlib.h>
#include <grass/linkm.h>
struct Slink
@@ -38,14 +42,19 @@
- \fn int Vect_get_point_in_area ( struct Map_info *Map, int area, double *X, double *Y)
- \brief get point inside area and outside all islands
- Take a line and intersect it with the polygon and any islands.
- sort the list of X values from these intersections. This will
- be a list of segments alternating IN/OUT/IN/OUT of the polygon.
- Pick the largest IN segment and take the midpoint.
- \return 0 on success, -1 on error
- \param Map_info structure, area number, x, y
+ \brief Get point inside area and outside all islands.
+ Take a line and intersect it with the polygon and any islands.
+ sort the list of X values from these intersections. This will
+ be a list of segments alternating IN/OUT/IN/OUT of the polygon.
+ Pick the largest IN segment and take the midpoint.
+ \param area area id
+ \param[out] X,Y point coordinateds
int
@@ -113,15 +122,20 @@
- ** For each intersection of a polygon w/ a line, stuff the
- ** X value in the Inter Points array. I used line_pnts, just
- ** cuz the memory management was already there. I am getting real
- ** tired of managing realloc stuff.
- ** Assumes that no vertex of polygon lies on Y
- ** This is taken care of by functions calling this function
- ** returns 0 or -1 on error
+ \brief Intersects line with polygon
+ For each intersection of a polygon w/ a line, stuff the X value in
+ the Inter Points array. I used line_pnts, just cuz the memory
+ management was already there. I am getting real tired of managing
+ realloc stuff. Assumes that no vertex of polygon lies on Y This is
+ taken care of by functions calling this function
+ \param y ?
+ \param Iter intersection ?
int
Vect__intersect_line_with_poly (
@@ -157,10 +171,15 @@
- \fn int Vect_get_point_in_poly (struct line_pnts *Points, double *X, double *Y)
- \brief get point inside polygon. This does NOT consider ISLANDS!
- \param line_pnts structure
+ \brief Get point inside polygon.
+ This does NOT consider ISLANDS!
+ \param Points polygon
+ \param[out] X,Y point coordinates
int
@@ -221,28 +240,36 @@
if (ret < 0)
- fprintf (stderr, "Could not find point in polygon\n");
+ G_warning ("Vect_get_point_in_poly(): %s", _("Unable to find point in polygon"));
return -1;
-/*DEBUG fprintf (stderr, "Found point in %d iterations\n", 10 - ret); */
+ G_debug(3, "Found point in %d iterations", 10 - ret);
return 0;
- ** provide a breadth first binary division of real space along line segment
- ** looking for a point w/in the polygon.
- ** This routine walks along the list of points on line segment
- ** and divides each pair in half. It sticks that new point right into
- ** the list, and then checks to see if it is inside the poly.
- ** after going through the whole list, it calls itself. The list
- ** now has a whole extra set of points to divide again.
- ** returns # levels it took or -1 if exceeded # of levels
+ \brief Provide a breadth first binary division of real space along line segment.
+ Looking for a point w/in the polygon.
+ This routine walks along the list of points on line segment
+ and divides each pair in half. It sticks that new point right into
+ the list, and then checks to see if it is inside the poly.
+ After going through the whole list, it calls itself. The list
+ now has a whole extra set of points to divide again.
+ \param Head
+ \param Points
+ \param Token
+ \param X,Y
+ \param levels
+ \return # levels it took
+ \return -1 if exceeded # of levels
static int
Vect__divide_and_conquer (
@@ -254,7 +281,7 @@
struct Slink *A, *B, *C;
-/*DEBUG fprintf (stderr, " LEVEL %d\n", levels); */
+ G_debug (3, "Vect__divide_and_conquer(): LEVEL %d", levels);
A = Head;
B = Head->next;
@@ -288,7 +315,6 @@
return Vect__divide_and_conquer (Head, Points, Token, X, Y, --levels);
static void
destroy_links (struct Slink *Head)
@@ -306,11 +332,13 @@
- \fn int Vect_find_poly_centroid ( struct line_pnts *points,
- double *cent_x, double *cent_y)
- \brief get centroid of polygon
- \param line_pnts * structure, x, y of centroid
+ \brief Get centroid of polygon
+ \param points polygon
+ \param[out] cent_x,cent_y centroid coordinates
int
@@ -393,16 +421,20 @@
- \fn int Vect_get_point_in_poly_isl ( struct line_pnts *Points, struct line_pnts **IPoints,
- int n_isles,
- double *att_x, double *att_y)
- \brief get point inside polygon but outside the islands specifiled in IPoints.
- be a list of segments alternating IN/OUT/IN/OUt of the polygon.
+ \brief Get point inside polygon but outside the islands specifiled in IPoints.
+ be a list of segments alternating IN/OUT/IN/OUt of the polygon.
+ \param IPoints isles
+ \param n_isles number of isles
+ \param[out] att_x,att_y point coordinates
int
@@ -458,7 +490,7 @@
return 0;
-/* guess we have to do it the hard way... */
+ /* guess we have to do it the hard way... */
/* first find att_y close to cent_y so that no points lie on the line */
/* find the point closest to line from below, and point close to line
@@ -543,7 +575,7 @@
* Returns: -1 point exactly on segment
* number of intersections
-int
+static int
segments_x_ray ( double X, double Y, struct line_pnts *Points)
double x1, x2, y1, y2;
@@ -625,19 +657,22 @@
/* should not be reached (one condition is not necessary, but it is may be better readable
* and it is a check) */
- G_warning ( "segments_x_ray() conditions failed:" );
- G_warning ( "X = %f Y = %f x1 = %f y1 = %f x2 = %f y2 = %f", X, Y, x1, y1, x2, y2 );
+ G_warning ("segments_x_ray() %s: X = %f Y = %f x1 = %f y1 = %f x2 = %f y2 = %f",
+ _("conditions failed"), X, Y, x1, y1, x2, y2 );
return n_intersects;
- * Determines if a point (X,Y) is inside a polygon.
- * Returns: 0 - outside
- * 1 - inside
- * 2 - on the boundary (exactly may be said only for vertex of vertical/horizontal line)
+ \brief Determines if a point (X,Y) is inside a polygon.
+ \param X,Y point coordinates
+ \return 0 - outside
+ \return 1 - inside
+ \return 2 - on the boundary (exactly may be said only for vertex of vertical/horizontal line)
int
Vect_point_in_poly ( double X, double Y, struct line_pnts *Points)
@@ -656,13 +691,17 @@
return 0;
- * Determines if a point (X,Y) is inside an area outer ring. Islands are not considered.
- * 1 - inside
+ \brief Determines if a point (X,Y) is inside an area outer ring. Islands are not considered.
int
Vect_point_in_area_outer_ring ( double X, double Y, struct Map_info *Map, int area)
@@ -713,13 +752,17 @@
return 0;
- * Determines if a point (X,Y) is inside an island.
- * 1 - inside
+ \brief Determines if a point (X,Y) is inside an island.
+ \param isle isle id
int
Vect_point_in_island ( double X, double Y, struct Map_info *Map, int isle)
@@ -764,4 +807,3 @@
else
return 0;
Modified: grass/trunk/lib/vector/Vlib/read.c
--- grass/trunk/lib/vector/Vlib/read.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/read.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,27 +1,30 @@
-* for details.
+ \file read.c
+ \brief Vector library - reading data
+ for details.
+ \date 2001
static int read_next_dummy () { return -1; }
#ifndef HAVE_OGR
-static int format () { G_fatal_error ("Requested format is not compiled in this version"); return 0; }
+static int format () { G_fatal_error (_("Requested format is not compiled in this version")x); return 0; }
#endif
static int (*Read_next_line_array[][3]) () =
@@ -45,14 +48,16 @@
- \fn int Vect_read_next_line ( struct Map_info *Map,
- struct line_pnts *line_p,
- struct line_cats *line_c)
- \brief get next vector line ?
- \return line type,
- -1 on Out of memory,
- -2 on EOF
- \param Map_info structure, line_pnts structure, line_cats structure
+ \brief Get next vector line
+ \param[out] line_p line geometry
+ \param[out] line_c line categories
+ \return line type,
+ \return -1 on Out of memory,
+ \return -2 on EOF
int
@@ -60,9 +65,8 @@
-#ifdef GDEBUG
G_debug (3, "Vect_read_next_line()");
-#endif
if (!VECT_OPEN (Map))
return -1;
@@ -71,15 +75,15 @@
- \fn int Vect_read_line ( struct Map_info *Map,
- struct line_cats *line_c,
- int line)
- \brief get vector line ?
- -2 on EOF
- \param Map_info structure, line_pnts structure, line_cats structure, line number
+ \brief Get vector line
+ \return -2 on EOF
int
Vect_read_line (
@@ -92,20 +96,23 @@
G_debug (3, "Vect_read_line()");
- G_fatal_error ( "Vect_read_line(): vector is not opened" );
+ G_fatal_error ("Vect_read_line(): %s", _("vector map is not opened"));
if (line < 1 || line > Map->plus.n_lines)
- G_fatal_error ( "Vect_read_line(): line '%d' is not reasonable (max line in map: %d)",
- line, Map->plus.n_lines );
+ G_fatal_error (_("Vect_read_line(): line %d is not reasonable (max line in vector map: %d)"),
+ line, Map->plus.n_lines );
return (*V2_read_line_array[Map->format]) (Map, line_p, line_c, line);
- \fn int Vect_line_alive ( struct Map_info *Map, int line )
- \brief check if line is alive or dead
- \return 1 if line alive, 0 if line is dead
+ \brief Check if line is alive or dead
+ \return 1 if line alive
+ \return 0 if line is dead
int
@@ -116,10 +123,13 @@
- \fn int Vect_node_alive ( struct Map_info *Map, int node )
- \brief check if node is alive or dead
- \return 1 if node alive, 0 if node is dead
+ \brief Check if node is alive or dead
+ \param node node id
+ \return 1 if node alive
+ \return 0 if node is dead
int
@@ -130,10 +140,13 @@
- \fn int Vect_area_alive ( struct Map_info *Map, int area )
- \brief check if area is alive or dead
- \return 1 if area alive, 0 if area is dead
+ \brief Check if area is alive or dead
+ \return 1 if area alive
+ \return 0 if area is dead
int
@@ -144,10 +157,13 @@
- \fn int Vect_isle_alive ( struct Map_info *Map, int isle )
- \brief check if isle is alive or dead
- \return 1 if isle alive, 0 if isle is dead
- \param Map_info structure, isle number
+ \brief Check if isle is alive or dead
+ \return 1 if isle alive
+ \return 0 if isle is dead
int
@@ -156,4 +172,3 @@
return 0;
Modified: grass/trunk/lib/vector/Vlib/read_nat.c
--- grass/trunk/lib/vector/Vlib/read_nat.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/read_nat.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,59 +1,50 @@
-* for details.
- *V1_read_next_line (Map, line_p)
- * reads thru digit file looking for next line within window,
- * stores info in struct instead of args.
- * NOTE: line_p->alloc_points better be set to 0 for the first call.
- * returns: -1 on error
- * -2 EOF
- * line type (positive value) if it found a line
+ \file read_nat.c
+ \brief Vector library - reading data (native format)
- ** The action of this routine can be modified by:
- ** Vect_read_constraint_region ()
- ** Vect_read_constraint_type ()
- ** Vect_remove_constraints ()
+ The action of this routine can be modified by:
+ - Vect_read_constraint_region()
+ - Vect_read_constraint_type()
+ - Vect_remove_constraints()
+ for details.
+ \date 2001
-int Vect__Read_line_nat (struct Map_info *, struct line_pnts *, struct line_cats *, long);
+static int
+Vect__Read_line_nat (struct Map_info *,
+ struct line_pnts *,
+ struct line_cats *,
+ long);
- * \fn int V1_read_line_nat (struct Map_info *Map, struct line_pnts *Points, struct line_cats *Cats, long offset)
* \brief Read line from coor file on given offset.
+ * \param Map vector map
+ * \param Points container used to store line points within
+ * \param Cats container used to store line categories within
+ * \param offset given offset
* \return line type
* \return 0 dead line
* \return -2 end of table (last row)
* \return -1 out of memory
- * \param Map vector map layer
- * \param Points container used to store line points within
- * \param Cats container used to store line categories within
- * \param offset given offset
int
V1_read_line_nat (
@@ -66,18 +57,16 @@
- * \fn int V1_read_next_line_nat (struct Map_info *Map, struct line_pnts *line_p, struct line_cats *line_c)
* \brief Read next line from coor file.
+ * \param Map vector map layer
+ * \param line_p container used to store line points within
+ * \param line_c container used to store line categories within
* \return line type
- * \param line_p container used to store line points within
- * \param line_c container used to store line categories within
int
@@ -124,23 +113,20 @@
return (itype);
/* NOTREACHED */
-} /* dig_read_line_struct_in_box() */
- * \fn int V2_read_line_nat (struct Map_info *Map, struct line_pnts *line_p, struct line_cats *line_c, int line)
* \brief Reads any specified line, this is NOT affected by constraints
- * \return line type ( > 0 )
- * \return 0 dead line
- * \return -1 out of memory
- * \return -2 end of file
* \param line line id
+ * \return line type ( > 0 )
+ * \return 0 dead line
+ * \return -1 out of memory
+ * \return -2 end of file
int
V2_read_line_nat (
@@ -157,24 +143,22 @@
Line = Map->plus.Line[line];
if ( Line == NULL )
- G_fatal_error (_("Attempt to read dead line [%d]"), line );
+ G_fatal_error ("V2_read_line_nat(): %s %d", _("Attempt to read dead line"), line );
return Vect__Read_line_nat (Map, line_p, line_c, Line->offset);
- * \fn int V2_read_next_line_nat (struct Map_info *Map, struct line_pnts *line_p, struct line_cats *line_c)
* \brief Reads next unread line each time called. Use Vect_rewind to reset.
int
@@ -222,24 +206,21 @@
return V2_read_line_nat (Map, line_p, line_c, Map->next_line++);
- /* NOTREACHED */
+ /* NOTREACHED */}
- * \fn int Vect__Read_line_nat (struct Map_info *Map, struct line_pnts *p, struct line_cats *c, long offset)
* \param p container used to store line points within
* \param c container used to store line categories within
int
@@ -331,9 +312,7 @@
if (0 >= dig__fread_port_I (&n_points, 1, &(Map->dig_fp) )) return (-2);
-#ifdef GDEBUG
G_debug (3, " n_points = %d", n_points);
-#endif
if ( p != NULL ) {
if (0 > dig_alloc_points (p, n_points + 1))
@@ -364,4 +343,3 @@
return (type);
Modified: grass/trunk/lib/vector/Vlib/read_ogr.c
--- grass/trunk/lib/vector/Vlib/read_ogr.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/read_ogr.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,18 +1,22 @@
-* AUTHOR(S): Radim Blazek, Piero Cavalieri
-* for details.
+ \file read_ogr.c
+ \brief Vector library - reading data (OGR format)
+ for details.
+ \author Radim Blazek, Piero Cavalieri
+ \date 2001
@@ -21,18 +25,16 @@
#include <ogr_api.h>
- * \fn int cache_feature ( struct Map_info *Map, OGRGeometryH hGeom, int ftype )
* \brief Recursively read feature and add all elements to points_cache and types_cache.
* ftype : if > 0 use this type (because parts of Polygon are read as wkbLineString)
- * \return 0 OK
- * \return 1 error
* \param hGeom OGR geometry
* \param ftype feature type
+ * \return 0 OK
+ * \return 1 error
static int cache_feature ( struct Map_info *Map, OGRGeometryH hGeom, int ftype )
@@ -107,29 +109,27 @@
break;
default:
- G_warning (_("OGR feature type [%d] not supported"), type);
+ G_warning (_("OGR feature type %d not supported"), type);
return 1;
break;
- * \fn int V1_read_next_line_ogr (struct Map_info *Map, struct line_pnts *line_p, struct line_cats *line_c)
* \brief Read next line from OGR layer. Skip empty features.
- * Vect_read_constraint_region ()
- * Vect_read_constraint_type ()
- * Vect_remove_constraints ()
+ * - Vect_read_constraint_region()
+ * - Vect_read_constraint_type()
+ * - Vect_remove_constraints()
- * \return -2 no more features (EOF)
+ * \return -2 no more features (EOF)
int
@@ -162,7 +162,7 @@
Map->fInfo.ogr.feature_cache_id = (int) OGR_F_GetFID ( hFeature );
if ( Map->fInfo.ogr.feature_cache_id == OGRNullFID ) {
- G_warning (_("OGR feature without ID."));
+ G_warning (_("OGR feature without ID"));
/* Cache the feature */
@@ -212,17 +212,15 @@
- * \fn int V2_read_next_line_ogr (struct Map_info *Map, struct line_pnts *line_p, struct line_cats *line_c)
int
@@ -233,17 +231,15 @@
- * \fn int read_line ( struct Map_info *Map, OGRGeometryH hGeom, long offset, struct line_pnts *Points )
* \brief Recursively descend to feature and read the part
- * \return 0 OK
- * \return 1 error
* \param Points container used to store line pointes within
+ * \return 0 OK
+ * \return 1 error
static int read_line ( struct Map_info *Map, OGRGeometryH hGeom, long offset, struct line_pnts *Points )
@@ -286,25 +282,23 @@
break;
default:
- G_warning (_("OGR feature type [%d] not supported"), eType);
+ G_warning (_("OGR feature type %d not supported"), eType);
break;
return 1;
- * \fn int V2_read_line_ogr (struct Map_info *Map, struct line_pnts *line_p, struct line_cats *line_c, int line)
* \brief Read line from layer on given offset.
- * \return -2 end of table (last row)
+ * \return -2 end of table (last row)
int
@@ -355,14 +349,14 @@
Map->fInfo.ogr.feature_cache = OGR_L_GetFeature ( Map->fInfo.ogr.layer, FID );
if ( Map->fInfo.ogr.feature_cache == NULL ) {
- G_fatal_error("Cannot read feature, FID = %ld", FID);
+ G_fatal_error(_("Unable to get feature geometry, FID %ld"), FID);
Map->fInfo.ogr.feature_cache_id = FID;
hGeom = OGR_F_GetGeometryRef ( Map->fInfo.ogr.feature_cache );
if (hGeom == NULL) {
- G_fatal_error(_("Cannot get feature geometry, FID [%ld]"), FID);
read_line ( Map, hGeom, Line->offset + 1, line_p );
Modified: grass/trunk/lib/vector/Vlib/remove_areas.c
--- grass/trunk/lib/vector/Vlib/remove_areas.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/remove_areas.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,35 +1,40 @@
- * MODULE: vector library
- * AUTHOR(S): Radim Blazek
- * PURPOSE: Clean areas
- * COPYRIGHT: (C) 2001 by the GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
-#include <stdlib.h>
+ \file remove_areas.c
+ \brief Vector library - clean geometry (remove small areas)
+ for details.
+ \date 2001
- \fn void Vect_remove_small_areas ( struct Map_info *Map, double thresh, struct Map_info *Err, FILE *msgout)
- \brief Remove small areas from the map map. Centroid of the area and the longest boundary
- with adjacent area is removed.
- Map topology must be built GV_BUILD_CENTROIDS
+ \brief Remove small areas from the map map.
- \param Map input map
- \param thresh maximum area size for removed areas
- \param Err vector map where removed lines and centroids are written
- \param msgout file pointer where messages will be written or NULL
- \param removed_area pointer to where total size of removed area is stored or NULL
- \return number of removed areas
+ Centroid of the area and the longest boundary
+ with adjacent area is removed.
+ Map topology must be built GV_BUILD_CENTROIDS.
+ \param thresh maximum area size for removed areas
+ \param Err vector map where removed lines and centroids are written
+ \param msgout file pointer where messages will be written or NULL
+ \param removed_area pointer to where total size of removed area is stored or NULL
+ \return number of removed areas
int
Vect_remove_small_areas ( struct Map_info *Map, double thresh, struct Map_info *Err, FILE *msgout,
@@ -48,7 +53,7 @@
Points = Vect_new_line_struct ();
- if ( msgout ) fprintf (msgout, "Removed areas: %5d", nremoved );
+ if ( msgout ) fprintf (msgout, "%s: %5d", _("Removed areas"), nremoved );
for ( area = 1; area <= Vect_get_num_areas(Map); area++ ){
int i, j, centroid, dissolve_neighbour;
@@ -85,7 +90,7 @@
line = List->value[i];
if ( !Vect_line_alive(Map,abs(line)) ) /* Should not happen */
- G_fatal_error ("Area is composed of dead boundary" );
+ G_fatal_error (_("Area is composed of dead boundary"));
Vect_get_line_areas ( Map, abs(line), &left, &right );
if ( line > 0 ) neighbour = left;
@@ -160,7 +165,7 @@
nremoved++;
if ( msgout ) {
- fprintf (msgout, "\rRemoved areas: %5d", nremoved );
+ fprintf (msgout, "\r%s: %5d", _("Removed areas"), nremoved );
fflush ( stderr );
@@ -171,4 +176,3 @@
return (nremoved);
Modified: grass/trunk/lib/vector/Vlib/remove_duplicates.c
--- grass/trunk/lib/vector/Vlib/remove_duplicates.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/remove_duplicates.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,35 +1,39 @@
- * PURPOSE: Clean lines
- * for details.
+ \file remove_duplicates.c
+ \brief Vector library - clean geometry (remove duplicates)
+ for details.
+ \date 2001
#include <stdlib.h>
- \fn void Vect_remove_duplicates ( struct Map_info *Map, int type, struct Map_info *Err, FILE *msgout)
- \brief Remove duplicate lines from vector map.
+ \brief Remove duplicate lines from vector map.
+ Remove duplicate lines of given types from vector map. Duplicate lines may be optionaly
+ written to error map. Input map must be opened on level 2 for update. Categories are merged.
+ \param Map vector map where duplicate lines will be deleted
+ \param type type of line to be delete
+ \param Err vector map where duplicate lines will be written or NULL
- Remove duplicate lines of given types from vector map. Duplicate lines may be optionaly
- written to error map. Input map must be opened on level 2 for update. Categories are merged.
- \param Map input map where duplicate lines will be deleted
- \param type type of line to be delete
- \param Err vector map where duplicate lines will be written or NULL
- \return
+ \return void
void
Vect_remove_duplicates ( struct Map_info *Map, int type, struct Map_info *Err, FILE *msgout )
@@ -60,7 +64,7 @@
/* TODO: 3D */
ndupl = 0;
- if ( msgout ) fprintf (msgout, "Duplicates: %5d", ndupl );
+ if ( msgout ) fprintf (msgout, "%s: %5d", _("Duplicates"), ndupl );
for ( i = 1; i <= nlines; i++ ){
if ( !Vect_line_alive ( Map, i ) ) continue;
@@ -122,7 +126,7 @@
ndupl++;
if ( msgout ) {
- fprintf (stderr, "\rDuplicates: %5d", ndupl );
+ fprintf (stderr, "\r%s: %5d", _("Duplicates"), ndupl );
fflush ( stderr );
@@ -135,4 +139,3 @@
return;
Modified: grass/trunk/lib/vector/Vlib/rewind.c
--- grass/trunk/lib/vector/Vlib/rewind.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/rewind.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,20 +1,23 @@
-* for details.
+ \file rewind.c
+ \brief Vector library - rewind data
+ for details.
+ \date 2001
@@ -28,7 +31,7 @@
#ifndef HAVE_OGR
+static int format () { G_fatal_error (_("Requested format is not compiled in this version")); return 0; }
#endif
@@ -44,10 +47,12 @@
- \fn int Vect_rewind (struct Map_info *Map)
- \brief Rewind vector data file to cause reads to start at beginning
+ \brief Rewind vector data file to cause reads to start at beginning
int
Modified: grass/trunk/lib/vector/Vlib/select.c
--- grass/trunk/lib/vector/Vlib/select.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/select.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,33 +1,38 @@
-* for details.
+ \file rewind.c
+ \brief Vector library - select vector features
+ for details.
+ \date 2001
#include <stdlib.h>
- \fn int Vect_select_lines_by_box (struct Map_info *Map, BOUND_BOX *Box,
- int type, struct ilist *list)
- \brief Select lines by box. Select lines whose boxes overlap specified box!!!
+ \brief Select lines by box.
+ Select lines whose boxes overlap specified box!!!
It means that selected line may or may not overlap the box.
- \return number of lines
- \param Map
- \param Box
- \param type line type
- \param output list, must be initialized
+ \param Box bounding box
+ \param type line type
+ \param[out] list output list, must be initialized
+ \return number of lines
int
@@ -69,13 +74,16 @@
- \fn int Vect_select_areas_by_box (struct Map_info *Map, BOUND_BOX *Box, struct ilist *list)
- \brief Select areas by box. Select areas whose boxes overlap specified box!!!
+ \brief Select areas by box.
+ Select areas whose boxes overlap specified box!!!
It means that selected area may or may not overlap the box.
- \return number of areas
- \param Map
- \param Box
+ \param[out] output list, must be initialized
+ \return number of areas
int
@@ -103,13 +111,16 @@
- \fn int Vect_select_isles_by_box (struct Map_info *Map, BOUND_BOX *Box, struct ilist *list)
- \brief Select isles by box. Select isles whose boxes overlap specified box!!!
- It means that selected isle may or may not overlap the box.
- \return number of isles
- \param Map
- \param Box
+ \brief Select isles by box.
+ Select isles whose boxes overlap specified box!!!
+ It means that selected isle may or may not overlap the box.
+ \return number of isles
int
@@ -130,12 +141,13 @@
- \fn int Vect_select_nodes_by_box (struct Map_info *Map, BOUND_BOX *Box, struct ilist *list)
- \brief Select nodes by box.
- \param Map
- \param Box
+ \brief Select nodes by box.
int
@@ -162,17 +174,18 @@
- \fn int Vect_select_lines_by_polygon (struct Map_info *Map, struct line_pnts *Polygon, int nisles,
- struct line_pnts **Isles, int type, struct ilist *list)
- \brief Select lines by Polygon with optional isles.
- Polygons should be closed, i.e. first and last points must be identical.
- \param Map
- \param Polygon outer ring
- \param nisles number of islands or 0
- \param Isles array of islands or NULL
- \param list output list, must be initialised
+ \brief Select lines by Polygon with optional isles.
+ Polygons should be closed, i.e. first and last points must be identical.
+ \param Polygon outer ring
+ \param nisles number of islands or 0
+ \param Isles array of islands or NULL
+ \param[out] list output list, must be initialised
int
Vect_select_lines_by_polygon ( struct Map_info *Map, struct line_pnts *Polygon, int nisles,
@@ -252,17 +265,20 @@
- \fn int Vect_select_areas_by_polygon (struct Map_info *Map, struct line_pnts *Polygon, int nisles,
- struct line_pnts **Isles, struct ilist *list)
- \brief Select areas by Polygon with optional isles.
- Warning : values in list may be duplicate!
- \param Map
+ \brief Select areas by Polygon with optional isles.
+ Warning : values in list may be duplicate!
int
Vect_select_areas_by_polygon ( struct Map_info *Map, struct line_pnts *Polygon, int nisles,
@@ -315,4 +331,3 @@
return List->n_values;
Modified: grass/trunk/lib/vector/Vlib/sindex.c
--- grass/trunk/lib/vector/Vlib/sindex.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/sindex.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,28 +1,35 @@
-* PURPOSE: Lower level functions for reading/writing/manipulating vectors.
-* for details.
+ \file sindex.c
+ \brief Vector library - spatial index
+ for details.
+ \date 2001
#include <stdlib.h>
#include <string.h>
- \fn void Vect_spatial_index_init ( SPATIAL_INDEX *si )
- \brief init spatial index
- \param si pointer to spatial index structure
+ \brief Init spatial index
+ \param si pointer to spatial index structure
+ \return void
void
@@ -33,9 +40,13 @@
- \fn void Vect_spatial_index_destroy ( SPATIAL_INDEX *si )
- \brief destroy existing spatial index, Vect_spatial_index_init() must be call before new use
+ \brief Destroy existing spatial index
+ Vect_spatial_index_init() must be call before new use.
+ \return void
void
@@ -46,11 +57,13 @@
- \fn void Vect_spatial_index_add_item ( SPATIAL_INDEX *si, int id, BOUND_BOX *box )
\brief Add a new item to spatial index
\param id item identifier
\param box pointer to item bounding box
+ \return void
void
@@ -65,10 +78,12 @@
- \fn void Vect_spatial_index_del_item ( SPATIAL_INDEX *si, int id )
\brief Delete item from spatial index
+ \return void
void
@@ -79,7 +94,7 @@
G_debug(3, "Vect_spatial_index_del_item(): id = %d", id );
/* TODO */
- G_fatal_error ( "Vect_spatial_index_del_item() not implemented" );
+ G_fatal_error ("Vect_spatial_index_del_item() %s", _("not implemented"));
/* Bounding box of item would be needed, which is not stored in si. */
@@ -90,14 +105,18 @@
ret = RTreeDeleteRect( &rect, id, &(si->root) );
- if ( ret ) G_fatal_error ( "Cannot delete item %d from spatial index", id );
+ if ( ret ) G_fatal_error (_("Unable to delete item %d from spatial index"), id );
- \brief Create spatial index if necessary. To be used in modules.
- Map must be opened on level 2.
- \param Map pointer to map
+ \brief Create spatial index if necessary.
+ To be used in modules.
+ Map must be opened on level 2.
+ \param Map pointer to vector map
\param out print progress here
\return 0 OK
\return 1 error
@@ -105,7 +124,8 @@
Vect_build_spatial_index ( struct Map_info *Map, FILE *msgout )
if ( Map->level < 2 ) {
- G_fatal_error ( _( "Cannot build spatial index from topology, the map is not opened on level2"));
+ G_fatal_error ( _("Unable to build spatial index from topology, "
+ "vector map is not opened at topo level 2"));
if ( !(Map->plus.Spidx_built) ) {
return ( Vect_build_sidx_from_topo ( Map, msgout ) );
@@ -115,8 +135,10 @@
\brief Create spatial index from topo if necessary
- \param out print progress here
+ \param msgout print progress here
\return 0 OK
\return 1 error
@@ -144,7 +166,7 @@
G_percent2 ( i, total, 1, msgout );
Node = plus->Node[i];
- if ( !Node ) G_fatal_error ("BUG (Vect_build_sidx_from_topo): node does not exist");
+ if ( !Node ) G_fatal_error (_("BUG (Vect_build_sidx_from_topo): node does not exist"));
dig_spidx_add_node ( plus, i, Node->x, Node->y, Node->z );
@@ -155,7 +177,7 @@
G_percent2 ( done+i, total, 1, msgout );
Line = plus->Line[i];
- if ( !Line ) G_fatal_error ("BUG (Vect_build_sidx_from_topo): line does not exist");
+ if ( !Line ) G_fatal_error (_("BUG (Vect_build_sidx_from_topo): line does not exist"));
box.N = Line->N;
box.S = Line->S;
@@ -173,7 +195,7 @@
Area = plus->Area[i];
- if ( !Area ) G_fatal_error ("BUG (Vect_build_sidx_from_topo): area does not exist");
+ if ( !Area ) G_fatal_error (_("BUG (Vect_build_sidx_from_topo): area does not exist"));
box.N = Area->N;
box.S = Area->S;
@@ -191,7 +213,7 @@
Isle = plus->Isle[i];
- if ( !Isle ) G_fatal_error ("BUG (Vect_build_sidx_from_topo): isle does not exist");
+ if ( !Isle ) G_fatal_error (_("BUG (Vect_build_sidx_from_topo): isle does not exist"));
box.N = Isle->N;
box.S = Isle->S;
@@ -219,12 +241,13 @@
- \fn int Vect_spatial_index_select ( SPATIAL_INDEX *si, BOUND_BOX *box, struct ilist *list )
\brief Select items by bounding box to list
- \return number of selected items
\param box bounding box
\param list pointer to list where selected items are stored
+ \return number of selected items
int
@@ -242,4 +265,3 @@
G_debug(3, " %d items selected", list->n_values );
return ( list->n_values );
Modified: grass/trunk/lib/vector/Vlib/snap.c
--- grass/trunk/lib/vector/Vlib/snap.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/snap.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -3,15 +3,20 @@
* \brief Vector library - Clean vector map (snap lines)
- * \author Radim Blazek
* for details.
+ * \date 2001
#include <math.h>
@@ -40,16 +45,13 @@
return 1;
- * \fn void Vect_snap_lines_list (struct Map_info *Map, struct ilist *List_lines, double thresh, struct Map_info *Err, FILE *msgout)
* \brief Snap selected lines to existing vertex in threshold.
* Snap selected lines to existing vertices.
* \warning Lines are not necessarily snapped to nearest vertex, but to vertex in threshold!
* Lines showing how vertices were snapped may be optionaly written to error map.
* Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
@@ -58,7 +60,8 @@
* \param[in] thresh threshold in which snap vertices
* \param[out] Err vector map where lines representing snap are written or NULL
* \param[out] msgout file pointer where messages will be written or NULL
- \return
+ * \return void
/* As mentioned above, lines are not necessarily snapped to nearest vertex! For example:
@@ -72,7 +75,6 @@
| 2
void
@@ -114,7 +116,7 @@
XPnts = NULL;
printed = 0;
- if ( msgout ) fprintf (msgout, "%s ...", _("Registering points"));
+ if ( msgout ) fprintf (msgout, "%s...", _("Registering points"));
for ( line_idx = 0; line_idx < List_lines -> n_values; line_idx++ ){
int v;
@@ -154,7 +156,7 @@
if ( msgout && printed > 1000 ) {
- fprintf (msgout, "\r%s ... %d", _("Registering points"), point - 1);
+ fprintf (msgout, "\r%s... %d", _("Registering points"), point - 1);
fflush ( msgout );
printed = 0;
@@ -392,8 +394,6 @@
- * \fn void Vect_snap_lines (struct Map_info *Map, int type, double thresh, struct Map_info *Err, FILE *msgout )
* \brief Snap lines in vector map to existing vertex in threshold.
* For details see Vect_snap_lines_list()
@@ -403,7 +403,8 @@
- \return
+ * \return void
void
Modified: grass/trunk/lib/vector/Vlib/tin.c
--- grass/trunk/lib/vector/Vlib/tin.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/tin.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,30 +1,36 @@
-* for details.
+ \file tin.c
+ \brief Vector library - TIN
+ for details.
+ \date 2001
- \fn int Vect_tin_get_z ( struct Map_info *Map,
- double tx, double ty,
- double *tz, double *angle, double *slope)
- \brief calculates z coordinate for point from TIN
- 0 point is not in area,
- -1 area has not 4 points or has island
+ \brief Calculates z coordinate for point from TIN
+ \param tx,ty point coordinates
+ \param[out] tz z-coordinate of point
+ \param[out] angle angle
+ \param[out] slope slope
+ \return 1 on success,
+ \return 0 point is not in area,
+ \return -1 area has not 4 points or has island
int
Vect_tin_get_z (
@@ -85,5 +91,3 @@
return 1;
Modified: grass/trunk/lib/vector/Vlib/type.c
--- grass/trunk/lib/vector/Vlib/type.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/type.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,26 +1,32 @@
-* for details.
+ \file type.c
+ \brief Vector library - feature type
+ for details.
+ \date 2001
- \fn int Vect_option_to_types (struct Option *type_opt )
- \brief get types from options
- \return types, -1 on error
- \param Option structure
+ \brief Get types from options
+ \param type_opt Option structure
+ \return types
+ \return -1 on error
int
@@ -60,4 +66,3 @@
return type;
Modified: grass/trunk/lib/vector/Vlib/write.c
--- grass/trunk/lib/vector/Vlib/write.c 2008-01-13 12:05:46 UTC (rev 29692)
+++ grass/trunk/lib/vector/Vlib/write.c 2008-01-13 12:41:21 UTC (rev 29693)
@@ -1,34 +1,36 @@
-* for details.
+ \file type.c
+ \brief Vector library - write data
+ for details.
+ \date 2001
static long write_dummy () {
- G_warning ( _("Vect_write_line() for this format/level not supported") );
+ G_warning ("Vect_write_line() %s", _("for this format/level not supported") );
return -1;
static int rewrite_dummy () {
- G_warning ( _("Vect_rewrite_line() for this format/level not supported") );
+ G_warning ("Vect_rewrite_line() %s", _("for this format/level not supported") );
return -1;
static int delete_dummy () {
- G_warning ( _("Vect_delete_line() for this format/level not supported") );
+ G_warning ("Vect_delete_line() %s", _("for this format/level not supported") );
return -1;
@@ -67,18 +69,16 @@
- \fn long Vect_write_line (
- struct Map_info *Map,
- int type,
- struct line_pnts *points,
- struct line_cats *cats)
- \brief writes new line to the end of file (table)
- the function calls fatal error on error
- \param vector type
- \param line_cats structure
- \return offset into file where the line starts
+ \brief Writes new line to the end of file (table)
+ The function calls G_fatal_error() on error.
+ \param type vector type
+ \param points line geometry
+ \param cats line categories
+ \return offset into file where the line starts
long
Vect_write_line (
@@ -93,7 +93,7 @@
Map->name, Map->format, Map->level);
- G_fatal_error ( _("Cannot write line, the map is not opened") );
+ G_fatal_error ( _("Unable to write line, vector map is not opened") );
dig_line_reset_updated ( &(Map->plus) );
dig_node_reset_updated ( &(Map->plus) );
@@ -104,28 +104,28 @@
offset = (*Write_line_array[Map->format][Map->level]) (Map, type, points, cats);
if ( offset == -1 )
- G_fatal_error ( _("Cannot write line (negative offset)") );
+ G_fatal_error ( _("Unable to write line (negative offset)") );
return offset;
- \fn int Vect_rewrite_line (
- int line,
- int type,
- \brief rewrites line info at the given offset. The number of points
- or cats or type may change. If necessary, the old line is deleted and
- new is written.
- \param line number
- \return number of new line, -1 on error
+ \brief Rewrites line info at the given offset.
+ The number of points or cats or type may change. If necessary, the
+ old line is deleted and new is written.
+ This function calls G_fatal_error() on error.
+ \param line line id
+ \return number of new line
int
Vect_rewrite_line (
@@ -140,7 +140,7 @@
G_debug (3, "Vect_rewrite_line(): name = %s, line = %d", Map->name, line);
- G_fatal_error ( _("Cannot rewrite line, the map is not opened") );
+ G_fatal_error ( _("Unable to rewrite line, vector map is not opened") );
@@ -151,7 +151,7 @@
ret = (*Vect_rewrite_line_array[Map->format][Map->level]) (Map, line, type, points, cats);
if ( ret == -1 )
- G_fatal_error ( _("Cannot rewrite line") );
+ G_fatal_error ( _("Unable to rewrite line %d"), line);
return ret;
@@ -176,29 +176,35 @@
- \ fn int Vect_delete_line (
- int line)
- \brief deletes line of given number. Map must be opened on level 2.
+ \brief Deletes line of given number.
+ Vector map must be opened on topo level 2.
int
Vect_delete_line (
- int line)
+ struct Map_info *Map,
+ int line)
int ret;
G_debug (3, "Vect_delete_line(): name = %s, line = %d", Map->name, line);
- G_fatal_error ( _("Cannot delete the line, map '%s' is not opened on level 2"), Map->name );
+ G_fatal_error ( _("Unable to delete line %d, "
+ "vector map <%s> is not opened on topo level 2"), line, Map->name );
if ( Map->mode != GV_MODE_RW && Map->mode != GV_MODE_WRITE ) {
- G_fatal_error ( _("Cannot delete the line, map '%s' is not in opened in 'write' mode"), Map->name );
+ "vector map <%s> is not in opened in 'write' mode"), line, Map->name );
@@ -210,8 +216,7 @@
ret = (*Vect_delete_line_array[Map->format][Map->level]) (Map, line);
if ( ret == -1 )
- G_fatal_error ( _("Cannot delete line") );
+ G_fatal_error ( _("Unable to delete line %d from vector map <%s>"), line, Map->name );
return ret;
