[GRASS-SVN] r29694 - grass/trunk/vector/v.to.db
svn_grass at osgeo.org
Sun Jan 13 08:35:14 EST 2008
Author: martinl
Date: 2008-01-13 08:35:14 -0500 (Sun, 13 Jan 2008)
New Revision: 29694
grass/trunk/vector/v.to.db/description.html
grass/trunk/vector/v.to.db/main.c
grass/trunk/vector/v.to.db/parse.c
v.to.db: cosmetics in module description (use standardized option, use guisection)
Modified: grass/trunk/vector/v.to.db/description.html
--- grass/trunk/vector/v.to.db/description.html 2008-01-13 12:41:21 UTC (rev 29693)
+++ grass/trunk/vector/v.to.db/description.html 2008-01-13 13:35:14 UTC (rev 29694)
@@ -1,10 +1,11 @@
<H2>DESCRIPTION</H2>
-<em>v.to.db</em> loads vector map features or metrics into a database table,
-or prints them (or the SQL queries used to obtain them) in a form of a
-human-readable report.
+<em>v.to.db</em> loads vector map features or metrics into a database
+table, or prints them (or the SQL queries used to obtain them) in a
+form of a human-readable report. For uploaded/printed category values
+'-1' is used for 'no category' and 'null'/'-' if category cannot be
+found or multiple categories were found.
<H2>NOTES</H2>
The units <em>miles</em>, <em>feet</em>, <em>meters</em> and
<em>kilometers</em> are square for <em>option=area</em>.
@@ -35,7 +36,6 @@
<em><a href=v.db.addcol.html>v.db.addcol</a></em> to add new columns if
needed.
<H2>EXAMPLES</H2>
<h3>Updating attribute tables</h3>
@@ -163,16 +163,16 @@
<h2>REFERENCES</h2>
-Mandelbrot, B. B. (1982). The fractal geometry of nature. New York: W. H. Freeman.
+<ul>
+ <li>Mandelbrot, B. B. (1982). The fractal geometry of nature. New York: W. H. Freeman.</li>
+ <li>Xu, Y. F. & Sun, D. A. (2005). Geotechnique 55, No. 9, 691-695</li>
+</ul>
-<p>
-Xu, Y. F. & Sun, D. A. (2005). Geotechnique 55, No. 9, 691-695
+<H2>AUTHOR</H2>
+Radim Blazek, ITC-irst, Trento, Italy<br>
+Line sinuousity implemented by Wolf Bergenheim
-<H2>AUTHOR</H2>
-Radim Blazek
<p>
<i>Last changed: $Date$</i>
Modified: grass/trunk/vector/v.to.db/main.c
--- grass/trunk/vector/v.to.db/main.c 2008-01-13 12:41:21 UTC (rev 29693)
+++ grass/trunk/vector/v.to.db/main.c 2008-01-13 13:35:14 UTC (rev 29694)
@@ -30,12 +30,7 @@
module = G_define_module();
module->keywords = _("vector, database, attribute table");
- module->label = _("Populate database values from vector features.");
- module->description =
- _("Load values from vector to database. For "
- "uploaded/printed category values '-1' is used for 'no category' "
- "and 'null'/'-' if category cannot be found or multiple categories "
- "were found.");
+ module->description = _("Populate database values from vector features.");
parse_command_line (argc, argv);
Modified: grass/trunk/vector/v.to.db/parse.c
--- grass/trunk/vector/v.to.db/parse.c 2008-01-13 12:41:21 UTC (rev 29693)
+++ grass/trunk/vector/v.to.db/parse.c 2008-01-13 13:35:14 UTC (rev 29694)
@@ -27,20 +27,19 @@
struct Flag *p, *s, *t;
} flags;
- parms.vect = G_define_standard_option(G_OPT_V_INPUT);
- parms.vect->key = "map";
+ parms.vect = G_define_standard_option(G_OPT_V_MAP);
parms.type = G_define_standard_option(G_OPT_V_TYPE) ;
parms.type->options = "point,line,boundary,centroid";
parms.type->answer = "point,line,boundary,centroid";
- parms.type->description = _("Type of elements (for coor valid point/centroid, "
- "for length valid line/boundary)");
+ parms.type->label = _("Type of elements (for coor valid point/centroid, "
+ "for length valid line/boundary)");
parms.field = G_define_standard_option(G_OPT_V_FIELD);
parms.qfield = G_define_standard_option(G_OPT_V_FIELD);
parms.qfield->key = "qlayer";
- parms.qfield->description = _("Query layer. Used by 'query' option.");
+ parms.qfield->label = _("Query layer (used by 'query' option)");
parms.option = G_define_option();
parms.option->key = "option";
@@ -67,7 +66,7 @@
"query;result of a database query for all records of the geometry"
"(or geometries) from table specified by 'qlayer' option;"
"slope;slope steepness of vector line or boundary;"
- "sinuous;Line Sinuousity. Calculated as line length / distance between end points;";
+ "sinuous;line sinuousity, calculated as line length / distance between end points;";
parms.units = G_define_option();
parms.units->key = "units";
@@ -78,34 +77,27 @@
parms.units->label = _("Units");
parms.units->description = _("mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)");
- parms.col = G_define_option();
- parms.col->key = "column";
- parms.col->type = TYPE_STRING ;
- parms.col->required = NO ;
- parms.col->multiple = YES ;
- parms.col->gisprompt = "column(s)" ;
- parms.col->description = _("Column(s)");
+ parms.col = G_define_standard_option(G_OPT_COLUMNS);
- parms.qcol = G_define_option();
+ parms.qcol = G_define_standard_option(G_OPT_COLUMN);
parms.qcol->key = "qcolumn";
- parms.qcol->type = TYPE_STRING ;
- parms.qcol->required = NO ;
- parms.qcol->multiple = NO ;
- parms.qcol->gisprompt = "query column";
- parms.qcol->label = _("Query column used for 'query' option");
+ parms.qcol->label = _("Name of attribute column used for 'query' option");
parms.qcol->description = _("E.g. 'cat', 'count(*)', 'sum(val)'");
flags.p = G_define_flag();
flags.p->key = 'p';
flags.p->description = _("Print only");
+ flags.p->guisection = _("Print");
flags.s = G_define_flag();
flags.s->key = 's';
flags.s->description = _("Only print sql statements");
+ flags.s->guisection = _("Print");
flags.t = G_define_flag();
flags.t->key = 'c';
flags.t->description = _("In print mode prints totals for options: length,area,count");
+ flags.t->guisection = _("Print");
if (G_parser(argc,argv)) exit(EXIT_FAILURE);
