[GRASS-SVN] r29789 - in grass/trunk/gui/wxpython: gui_modules vdigit
svn_grass at osgeo.org
Mon Jan 21 13:29:06 EST 2008
Author: martinl
Date: 2008-01-21 13:29:06 -0500 (Mon, 21 Jan 2008)
New Revision: 29789
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/digit.py
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/vdigit/Makefile.in
grass/trunk/gui/wxpython/vdigit/dig_types.i
grass/trunk/gui/wxpython/vdigit/digit.h
grass/trunk/gui/wxpython/vdigit/line.cpp
wxGUI: vdigit interface improved (vedit is still default). Basic exceptions defined (vdigit, gcmd).
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-01-21 18:20:44 UTC (rev 29788)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-01-21 18:29:06 UTC (rev 29789)
@@ -2670,9 +2670,12 @@
wx.MessageBox(parent=self.parent,
message=_("No attribute table linked to "
- "vector map <%s> found.%s"
- "%s") % (self.map, os.linesep, label),
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ "vector map <%s> found. %s "
+ "%sYou can disable this message from digitization settings. Or "
+ "you can create and link attribute table to the vector map "
+ "using Attribute Table Manager.") % \
+ (self.map, label, os.linesep),
+ caption=_("Message"), style=wx.OK | wx.ICON_EXCLAMATION | wx.CENTRE)
self.mapDBInfo = None
return
@@ -2994,8 +2997,8 @@
"""Check DB connection"""
layerCommand = gcmd.Command(cmd=["v.db.connect",
"-g", "--q",
- "map=%s" % self.map,],
- log=None)
+ "map=%s" % self.map,],
+ rerr=None, stderr=None)
if layerCommand.returncode != 0:
return False
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py 2008-01-21 18:20:44 UTC (rev 29788)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py 2008-01-21 18:29:06 UTC (rev 29789)
@@ -59,18 +59,6 @@
USEVEDIT = True
-class DigitError(Exception):
- def __init__(self, message):
- self.message = message
- def __str__(self):
- wx.MessageBox(parent=None,
- caption=_("Error in digitization tool"),
- message=self.message,
- style=wx.ICON_ERROR)
- return ''
class AbstractDigit:
Abstract digitization class
@@ -181,10 +169,10 @@
ret = self.driver.Reset(self.map)
if map and ret == -1:
- raise DigitError(_('Unable to open vector map <%s> for editing. The vector map is probably broken. '
+ raise gcmd.DigitError(_('Unable to open vector map <%s> for editing. The vector map is probably broken. '
'Try to run v.build for rebuilding the topology.') % map)
if not map and ret != 0:
- raise DigitError(_('Closing vector map <%s> failed. The vector map is probably broken. '
+ raise gcmd.DigitError(_('Closing vector map <%s> failed. The vector map is probably broken. '
if not USEVEDIT:
@@ -192,7 +180,22 @@
self.digit.InitCats()
except:
pass
+ def SelectLinesByQueryThresh(self):
+ """Generic method used for SelectLinesByQuery()
+ -- to get threshold value"""
+ thresh = 0.0
+ if self.settings['query'][0] == "length":
+ thresh = self.settings['queryLength'][1]
+ if self.settings["queryLength"][0] == "shorter than":
+ thresh = -1 * thresh
+ else:
+ thresh = self.settings['queryDangle'][1]
+ if self.settings["queryDangle"][0] == "shorter than":
+ return thresh
class VEdit(AbstractDigit):
Prototype of digitization class based on v.edit command
@@ -640,15 +643,8 @@
@param pos1, pos2 bounding box definition
- if self.settings['query'][0] == "length":
- thresh = self.settings['queryLength'][1]
- if self.settings["queryLength"][0] == "shorter than":
- thresh = -1 * thresh
- else:
- thresh = self.settings['queryDangle'][1]
- if self.settings["queryDangle"][0] == "shorter than":
+ thresh = self.SelectLinesByQueryThresh()
w, n = pos1
e, s = pos2
@@ -674,10 +670,6 @@
'query=%s' % self.settings['query'][0],
'thresh=%f' % thresh])
- if self.settings['query'] == "length" and \
- self.settings['queryLength'][0] == "longer than":
- vEdit.append('-r') # FIXBUG: reverse selection regardless of bbox
vEditCmd = gcmd.Command(vEdit)
try:
@@ -736,7 +728,7 @@
str(self.settings["backgroundMap"]), snap, thresh)
if ret == -1:
- raise DigitError, _("Adding new feature to vector map <%s> failed.") % map
+ raise gcmd.DigitError, _("Adding new feature to vector map <%s> failed.") % map
def AddLine (self, map, line, coords):
"""Add line/boundary
@@ -767,7 +759,7 @@
if ret == -1:
def DeleteSelectedLines(self):
@@ -840,8 +832,18 @@
@param line id of line to be modified
@param coords list of coordinates of modified line
- return self.digit.RewriteLine(line, coords)
+ try:
+ lineid = line[0]
+ except:
+ lineid = -1
+ listCoords = []
+ for c in coords:
+ for x in c:
+ listCoords.append(x)
+ return self.digit.RewriteLine(lineid, listCoords)
def FlipLine(self):
"""Flip selected lines/boundaries"""
return self.digit.FlipLines()
@@ -856,11 +858,13 @@
def SnapLine(self):
"""Snap selected lines/boundaries"""
- return self.digit.SnapLines()
+ snap, thresh = self.__getSnapThreshold()
+ return self.digit.SnapLines(thresh)
def ConnectLine(self):
"""Connect selected lines/boundaries"""
- return self.digit.ConnectLines()
+ return self.digit.ConnectLines(thresh)
def CopyLine(self, ids=None):
"""Copy features from (background) vector map
@@ -880,6 +884,32 @@
return self.digit.CopyCats(cats, ids)
+ def SelectLinesByQuery(self, pos1, pos2):
+ """Select features by query
+ @param pos1, pos2 bounding box definition
+ w, n = pos1
+ e, s = pos2
+ query = vdigit.QUERY_UNKNOWN
+ if self.settings['query'][0] == 'length':
+ query = vdigit.QUERY_LENGTH
+ elif self.settings['query'][0] == 'dangle':
+ query = vdigit.QUERY_DANGLE
+ type = vdigit.GV_POINTS | vdigit.GV_LINES # TODO: 3D
+ ids = self.digit.SelectLinesByQuery(w, n, 0.0, e, s, 1000.0, self.settings['query'][1],
+ query, type, thresh)
+ Debug.msg(4, "VDigit.SelectLinesByQuery(): %s" % \
+ ",".join(["%d" % v for v in ids]))
+ return ids
def __getSnapThreshold(self):
"""Get snap mode and threshold value
@@ -998,10 +1028,13 @@
if map:
name, mapset = map.split('@')
- if USEVEDIT:
- ret = self.__display.OpenMap(str(name), str(mapset), False)
- else:
- ret = self.__display.OpenMap(str(name), str(mapset), True)
+ try:
+ if USEVEDIT:
+ ret = self.__display.OpenMap(str(name), str(mapset), False)
+ else:
+ ret = self.__display.OpenMap(str(name), str(mapset), True)
+ except SystemExit:
+ ret = -1
else:
ret = self.__display.CloseMap()
@@ -1108,7 +1141,8 @@
@param id line id to be selected
- Debug.msg(4, "CDisplayDriver.SetSelected(): id=%s" % id)
+ Debug.msg(4, "CDisplayDriver.SetSelected(): id=%s" % \
+ ",".join(["%d" % v for v in id]))
self.__display.SetSelected(id)
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-01-21 18:20:44 UTC (rev 29788)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-01-21 18:29:06 UTC (rev 29789)
@@ -1,21 +1,24 @@
-MODULE: gcmd
+ at package gcmd
-CLASSES:
- * Popen
- * Command
- * CommandThread
+ at brief GRASS command interface
-PURPOSE: GRASS command interface
+Classes:
+ * GException
+ * DigitError
+ * Popen
+ * Command
+ * CommandThread
-AUTHORS: The GRASS Development Team
- Original author: Jachym Cepicky
- Various updates: Martin Landa <landa.martin gmail.com>
+(C) 2007-2008 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
-COPYRIGHT: (C) 2007 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
+ at author Jachym Cepicky
+Martin Landa <landa.martin gmail.com>
+ at date 2007-2008
import os
@@ -25,8 +28,8 @@
try:
import subprocess
except:
- CompatPath = os.path.join(os.getenv("GISBASE"), "etc", "wx", "compat")
- sys.path.append(CompatPath)
+ compatPath = os.path.join(os.getenv("GISBASE"), "etc", "wx", "compat")
+ sys.path.append(compatPath)
import subprocess
if subprocess.mswindows:
from win32file import ReadFile, WriteFile
@@ -37,14 +40,55 @@
import fcntl
from threading import Thread
-import wx # GUI dialogs...
+import wx
-GuiModulePath = os.path.join(os.getenv("GISBASE"), "etc", "wx", "gui_modules")
-sys.path.append(GuiModulePath)
-# debugging & log window
-import wxgui_utils
+guiModulePath = os.path.join(os.getenv("GISBASE"), "etc", "wx", "gui_modules")
+sys.path.append(guiModulePath)
+import wxgui_utils # log window
from debug import Debug as Debug
+class GException(Exception):
+ """Generic exception"""
+ def __init__(self, message):
+ self.message = message
+ def __str__(self):
+ wx.MessageBox(parent=None,
+ caption=_("Error"),
+ message=self.message,
+ style=wx.ICON_ERROR)
+ return ''
+class CmdError(GException):
+ """Exception used for GRASS commands.
+ See Command class (command exits with EXIT_FAILURE,
+ G_fatal_error() is called)."""
+ def __init(self, cmd, message):
+ GException.__init__(message)
+ caption=_("Error in command execution"),
+ return ''
+class DigitError(GException):
+ """Exception raised during digitization session"""
+ def __init(self, message):
+ caption=_("Error in digitization tool"),
+ return ''
class Popen(subprocess.Popen):
"""Subclass subprocess.Popen"""
def recv(self, maxsize=None):
@@ -152,9 +196,10 @@
Run GRASS command in separate thread
- If stdout/err is redirected, write() method is required for the given classes
+ If stdout/err is redirected, write() method is required for the
+ given classes.
- Usage:
+ @code
cmd = Command(cmd=['d.rast', 'elevation.dem'], verbose=3, wait=True)
if cmd.returncode == None:
@@ -163,20 +208,24 @@
print 'SUCCESS'
else:
print 'FAILURE (%d)' % cmd.returncode
+ @endcode
@param cmd command given as list
@param stdin standard input stream
@param verbose verbose level [0, 3] (--q, --v)
@param wait wait for child execution terminated
- @param log logging type (None, gui, txt), only if wait is True
+ @param rerr error handling (when CmdError raised).
+ True for redirection to stderr, False for GUI dialog,
+ None for no operation (quiet mode)
@param stdout redirect standard output or None
@param stderr redirect standard error output or None
def __init__ (self, cmd, stdin=None,
- verbose=None, wait=True, log='gui',
+ verbose=None, wait=True, rerr=False,
stdout=None, stderr=sys.stderr):
self.cmd = cmd
+ self.stderr = stderr
# set verbosity level
@@ -221,20 +270,23 @@
if self.returncode is not None:
Debug.msg (3, "Command(): cmd='%s', wait=%s, returncode=%d, alive=%s" % \
(' '.join(cmd), wait, self.returncode, self.cmdThread.isAlive()))
- if log and self.returncode != 0:
- if log == 'gui': # GUI dialog
- dlg = wx.MessageDialog(None,
- ("Execution failed: '%s'\n\n"
- "Details:\n%s") % (' '.join(self.cmd),
- self.PrintModuleOutput()),
- ("Error"), wx.OK | wx.ICON_ERROR)
- dlg.ShowModal()
- dlg.Destroy()
- else: # otherwise 'txt'
- print >> sys.stderr, "Execution failed: '%s'" % (' '.join(self.cmd))
- print >> sys.stderr, "\nDetails:\n%s" % self.PrintModuleOutput()
+ if rerr is not None and self.returncode != 0:
+ if rerr is False: # GUI dialog
+ try:
+ raise CmdError, _("Execution failed: '%s'%s%s"
+ "Details:%s%s") % (' '.join(self.cmd),
+ os.linesep, os.linesep,
+ os.linesep,
+ self.PrintModuleOutput())
+ except CmdError, e:
+ print e
+ elif rerr == sys.stderr: # redirect message to sys
+ stderr.write("Execution failed: '%s'" % (' '.join(self.cmd)))
+ stderr.write("%sDetails:%s%s" % (os.linesep,
+ self.PrintModuleOutput(),
+ os.linesep))
else:
- pass
+ pass # nop
else:
Debug.msg (3, "Command(): cmd='%s', wait=%s, returncode=?, alive=%s" % \
(' '.join(cmd), wait, self.cmdThread.isAlive()))
@@ -254,6 +306,8 @@
"""Read stream and return list of lines
Note: Remove os.linesep from output
+ @param stream stream to be read
lineList = []
@@ -270,8 +324,7 @@
return lineList
def ReadStdOutput(self):
- """Read standard output and return list"""
+ """Read standard output and return list of lines"""
if self.cmdThread.stdout:
stream = self.cmdThread.stdout # use redirected stream instead
stream.seek(0)
@@ -281,16 +334,21 @@
return self.__ReadOutput(stream)
def ReadErrOutput(self):
- """Read standard error output and return list"""
+ """Read standard error output and return list of lines"""
return self.__ReadOutput(self.cmdThread.module.stderr)
def __ProcessStdErr(self):
Read messages/warnings/errors from stderr
+ @return list of (type, message)
- lines = self.ReadErrOutput()
+ if self.stderr is None:
+ lines = self.ReadErrOutput()
+ else:
+ lines = self.cmdThread.rerr.strip('%s' % os.linesep). \
+ split('%s' % os.linesep)
msg = []
type = None
@@ -316,25 +374,38 @@
return msg
def PrintModuleOutput(self, error=True, warning=True, message=True):
- """Store module errors, warnings, messages to output string"""
+ """Print module errors, warnings, messages to output
+ @param error print errors
+ @param warning print warnings
+ @param message print messages
+ @return string
msgString = ""
for type, msg in self.__ProcessStdErr():
if type:
if (type == 'ERROR' and error) or \
(type == 'WARNING' and warning) or \
(type == 'MESSAGE' and message):
- msgString += " " + type + ": " + msg + "\n"
+ msgString += " " + type + ": " + msg + "%s" % os.linesep
else:
- msgString += " " + msg + "\n"
+ msgString += " " + msg + "%s" % os.linesep
return msgString
class CommandThread(Thread):
- """Run command in separate thread"""
+ """Run command in separate thread
+ @param cmd GRASS command (given as list)
+ @param stdin standard input stream
+ @param stdout redirect standard output or None
+ @param stderr redirect standard error output or None
- stdout=None, stderr=None):
+ stdout=None, stderr=sys.stderr):
Thread.__init__(self)
@@ -344,6 +415,7 @@
self.module = None
+ self.rerr = ''
def run(self):
"""Run command"""
@@ -383,7 +455,9 @@
# wx.PostEvent(self.stdout, evt)
# wx.PostEvent(self.stderr, evt)
try:
- streamTo.write(streamFrom.read())
+ line = streamFrom.read()
+ # self.rerr = self.__parseString(line)
+ streamTo.write(line)
except IOError:
pass
@@ -391,10 +465,30 @@
# get the last output
try:
+ self.rerr = self.__parseString(line)
except IOError:
pass
+ def __parseString(self, string):
+ """Parse line
+ @param line line to parsed, all GRASS_INFO
+ messages are removed from line
+ @return string with GRASS_INFO messages
+ err = ''
+ for line in string.split('%s' % os.linesep):
+ if 'GRASS_INFO_ERROR' in line:
+ err += line + '%s' % os.linesep
+ elif err != '' and 'GRASS_INFO_END' in line:
+ err += line
+ return err
# testing ...
if __name__ == "__main__":
SEP = "-----------------------------------------------------------------------------"
@@ -404,7 +498,7 @@
# d.rast verbosely, wait for process termination
print "Running d.rast..."
- cmd = Command(cmd=["d.rast", "elevation.dem"], verbose=True, wait=True, log='txt')
+ cmd = Command(cmd=["d.rast", "elevation.dem"], verbose=True, wait=True, rerr=True)
print "RUNNING"
@@ -421,7 +515,7 @@
cmd = Command(cmd=["v.net.path", "in=roads at PERMANENT", "out=tmp", "dmax=100000", "--o"],
stdin="0 593527.6875 4925297.0625 602083.875 4917545.8125",
verbose=False,
- wait=True, log='txt')
+ wait=True, rerr=None)
print "RUNNING"
@@ -436,7 +530,7 @@
# returncode will be None
print "Running d.vect tmp..."
- cmd = Command(["d.vect", "tmp"], verbose=False, wait=False, log='txt')
+ cmd = Command(["d.vect", "tmp"], verbose=False, wait=False, rerr=None)
print "RUNNING"
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-01-21 18:20:44 UTC (rev 29788)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-01-21 18:29:06 UTC (rev 29789)
@@ -910,6 +910,7 @@
point = True
else:
point = False
digitClass.AddPoint(map, point, east, north)
self.UpdateMap(render=False) # redraw map
@@ -1179,7 +1180,7 @@
else: # no vector object found
- #self.UpdateMap(render=False)
+ self.UpdateMap(render=False, renderVector=False)
pass
elif digitToolbar.action in ["splitLine", "addVertex", "removeVertex"]:
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2008-01-21 18:20:44 UTC (rev 29788)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2008-01-21 18:29:06 UTC (rev 29789)
@@ -23,10 +23,9 @@
gmpath = os.path.join( os.getenv("GISBASE"),"etc","wx","icons")
sys.path.append(gmpath)
-import gcmd as cmd
+import gcmd
import grassenv
from digit import Digit as Digit
-from digit import DigitError as DigitError
from digit import DigitSettingsDialog as DigitSettingsDialog
from icon import Icons as Icons
@@ -582,7 +581,7 @@
try:
self.parent.digit.SetMapName(mapLayer.name)
- except DigitError, e:
+ except gcmd.DigitError, e:
self.layerSelectedID = None
print e # wxMessageBox
return False
Modified: grass/trunk/gui/wxpython/vdigit/Makefile.in
--- grass/trunk/gui/wxpython/vdigit/Makefile.in 2008-01-21 18:20:44 UTC (rev 29788)
+++ grass/trunk/gui/wxpython/vdigit/Makefile.in 2008-01-21 18:29:06 UTC (rev 29789)
@@ -15,7 +15,7 @@
LDFLAGS=-shared -fpic -L$(ARCH_LIBDIR) $(VECTLIB) $(GISLIB) $(GDALLIBS) $(VEDITLIB) `wx-config --libs` -lgdi
LOCAL_HEADERS=digit.h driver.h
-SOURCES=driver.cpp digit.cpp cats.cpp line.cpp vertex.cpp
+SOURCES=driver.cpp digit.cpp cats.cpp line.cpp vertex.cpp select.cpp
OBJARCH=OBJ.$(ARCH)
OBJ := $(patsubst %.cpp, $(OBJARCH)/%.o, $(SOURCES))
Modified: grass/trunk/gui/wxpython/vdigit/dig_types.i
--- grass/trunk/gui/wxpython/vdigit/dig_types.i 2008-01-21 18:20:44 UTC (rev 29788)
+++ grass/trunk/gui/wxpython/vdigit/dig_types.i 2008-01-21 18:29:06 UTC (rev 29789)
@@ -17,3 +17,7 @@
#define NO_SNAP 0 /* snapping disabled */
#define SNAP 1 /* snapping enabled for nodes */
#define SNAPVERTEX 2 /* snapping enabled for vertex also */
+#define QUERY_UNKNOWN -1
+#define QUERY_LENGTH 0 /* select by line length */
+#define QUERY_DANGLE 1 /* select dangles */
Modified: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h 2008-01-21 18:20:44 UTC (rev 29788)
+++ grass/trunk/gui/wxpython/vdigit/digit.h 2008-01-21 18:29:06 UTC (rev 29789)
@@ -43,6 +43,10 @@
int ModifyLineVertex(int, double, double, double,
double);
+ std::vector<int> SelectLinesByQuery(double, double, double,
+ double, double, double, bool,
+ int, int, double);
int CopyCats(std::vector<std::vector<int> >, std::vector<int>);
int GetCategory(int);
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp 2008-01-21 18:20:44 UTC (rev 29788)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2008-01-21 18:29:06 UTC (rev 29789)
@@ -321,9 +321,7 @@
return -1;
- ret = Vedit_merge_lines(display->mapInfo, display->selected);
+ ret = Vedit_merge_lines(display->mapInfo, display->selected);
return ret;
@@ -342,10 +340,8 @@
return -1;
ret = Vect_break_lines_list(display->mapInfo, display->selected,
GV_LINES, NULL, NULL);
return ret;
@@ -366,10 +362,9 @@
return -1;
Vect_snap_lines_list (display->mapInfo, display->selected,
- thresh, NULL, NULL);
+ thresh, NULL, NULL);
return ret;
@@ -388,10 +383,9 @@
return -1;
- ret = Vedit_connect_lines(&Map, List,
+ ret = Vedit_connect_lines(display->mapInfo, display->selected,
thresh);
return ret;
@@ -416,10 +410,8 @@
return -1;
ret = Vedit_bulk_labeling (display->mapInfo, display->selected,
x1, y1, x2, y2, start, step);
return ret;
@@ -454,21 +446,23 @@
Vect_open_old(bgMap, (char *) bgmap_name, (char *) mapset); /* TODO */
- if (!ids.empty) {
- list = Vect_new_list_struct();
+ if (!ids.empty()) {
+ list = Vect_new_list();
+ for (std::vector<int>::const_iterator b = ids.begin(), e = ids.end();
+ b != e; ++b) {
+ Vect_list_append(list, *b);
else {
list = display->selected;
- int Vedit_copy_lines (display->mapInfo, bgMap,
- list);
+ Vedit_copy_lines (display->mapInfo, bgMap,
+ list);
if (list != display->selected) {
- Vect_destroy_list_struct(list);
+ Vect_destroy_list(list);
if (bgMap) {
Vect_close(bgMap);
@@ -476,5 +470,4 @@
return ret;
