[GRASS-SVN] r29791 - grass/trunk/raster/r.circle
svn_grass at osgeo.org
Mon Jan 21 18:25:27 EST 2008
Author: hamish
Date: 2008-01-21 18:25:27 -0500 (Mon, 21 Jan 2008)
New Revision: 29791
grass/trunk/raster/r.circle/description.html
explain -b flag a little more
Modified: grass/trunk/raster/r.circle/description.html
--- grass/trunk/raster/r.circle/description.html 2008-01-21 19:26:37 UTC (rev 29790)
+++ grass/trunk/raster/r.circle/description.html 2008-01-21 23:25:27 UTC (rev 29791)
@@ -9,11 +9,13 @@
The <EM>mult</EM>parameter can be used to multiply the output raster cells by a common factor.
Note that this parameter does not affect the output raster position or size; only the z-values
are changed with this parameter.
-Binary output raster values can be created with the <B>-b</B> flag. Raster maps so created
-can be used to create binary filters for use in <EM>i.ifft</EM> (inverse Fourier transformations;
+<P>
+Binary-output raster maps (solid circles of one value) can be created
+with the <B>-b</B> flag. Raster maps so created can be used to create
+binary filters for use in <EM>i.ifft</EM> (inverse Fourier transformations;
apply filter with <EM>r.mask</EM>).
<H2>EXAMPLES</H2>
Generate a raster circle at current map center with a radius of 300m and outwardly
@@ -34,16 +36,21 @@
r.circle -b output=circle coordinate=${EASTCENTER},${NORTHCENTER} min=500 max=1000
</PRE>
<H2>SEE ALSO</H2>
-<EM><A HREF="g.region.html">g.region</A></EM>,
-<EM><A HREF="g.remove.html">g.remove</A></EM>,
-<EM><A HREF="g.rename.html">g.rename</A></EM>,
-<EM><A HREF="i.fft.html">i.fft</A></EM>,
-<EM><A HREF="i.ifft.html">i.ifft</A></EM>,
-<EM><A HREF="r.mask">r.mask</A></EM>
+<EM>
+<A HREF="g.region.html">g.region</A>,
+<A HREF="g.remove.html">g.remove</A>,
+<A HREF="g.rename.html">g.rename</A>,
+<A HREF="i.fft.html">i.fft</A>,
+<A HREF="i.ifft.html">i.ifft</A>,
+<A HREF="r.mask">r.mask</A>
+</EM>
<H2>AUTHOR</H2>
Bill Brown, U.S. Army Construction Engineering Research Laboratory<br>
Additional flag/min/max parameter by Markus Neteler, University of Hannover
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
