[GRASS-SVN] r29835 - grass/trunk/raster/r.cats
svn_grass at osgeo.org
Fri Jan 25 12:31:57 EST 2008
Author: epatton
Date: 2008-01-25 12:31:56 -0500 (Fri, 25 Jan 2008)
New Revision: 29835
grass/trunk/raster/r.cats/description.html
Corrected typo
Modified: grass/trunk/raster/r.cats/description.html
--- grass/trunk/raster/r.cats/description.html 2008-01-25 16:42:23 UTC (rev 29834)
+++ grass/trunk/raster/r.cats/description.html 2008-01-25 17:31:56 UTC (rev 29835)
@@ -14,7 +14,7 @@
using <EM><A HREF="r.describe.html">r.describe</A></EM>, to determine which
categories occur in the <EM>map</EM>. If a listing of categories is
specified, then the labels for those categories only are printed. The
-<EM>cats</EM> may be specified as single category value, or as ranges of
+<EM>cats</EM> may be specified as single category values, or as ranges of
values. The user may also (optionally) specify that a field separator other
than a space or tab be used to separate the category value from its
corresponding category label in the output, by using the
