[GRASS-SVN] r29836 - grass/trunk/scripts/d.vect.thematic
svn_grass at osgeo.org
Fri Jan 25 13:09:57 EST 2008
Author: cmbarton
Date: 2008-01-25 13:09:57 -0500 (Fri, 25 Jan 2008)
New Revision: 29836
grass/trunk/scripts/d.vect.thematic/d.vect.thematic
Fix to make thematic mapping work in the GIS Manager GUI under Windows
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic 2008-01-25 17:31:56 UTC (rev 29835)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic 2008-01-25 18:09:57 UTC (rev 29836)
@@ -334,7 +334,9 @@
trap "exitprocedure" 2 3 15
# identify current monitor or start monitor
-currmon=`eval d.mon -L | grep "(selected)" | awk '{print $1}'`
+if [ "$GIS_FLAG_S" -ne 1 ] ; then
+ currmon=`eval d.mon -L | grep "(selected)" | awk '{print $1}'`
+fi
if [ -z "$currmon" -a "$GIS_FLAG_S" -ne 1 ] ; then
g.message -e message='*** You must open a display monitor ***'
@@ -342,6 +344,19 @@
exit 2
fi
+# if running in the GUI, do not create a graphic legend in an xmon
+if [ "$GIS_FLAG_S" -eq 1 ] ; then
+ GIS_FLAG_L=0
+ # if running in GUI, turn off immediate mode rendering so that the
+ # iterated d.vect commands will composite using the display driver
+ rendermode=$GRASS_RENDER_IMMEDIATE
+ pngread=$GRASS_PNG_READ
+ GRASS_PNG_READ=TRUE
+ export GRASS_PNG_READ
+ GRASS_PNG_AUTO_WRITE=FALSE
+ export GRASS_PNG_AUTO_WRITE
+fi
table=`v.db.connect $GIS_OPT_MAP -g | grep -w $GIS_OPT_LAYER | awk '{print $2}'`
database=`v.db.connect $GIS_OPT_MAP -g | grep -w $GIS_OPT_LAYER | awk '{print $4}'`
driver=`v.db.connect $GIS_OPT_MAP -g | grep -w $GIS_OPT_LAYER | awk '{print $5}'`
@@ -472,7 +487,6 @@
g.message message="Value range: $min - $max"
# graduated color thematic mapping
if [ "$GIS_OPT_THEMETYPE" = "graduated_colors" ] ; then
# set color schemes for graduated color maps
case "$GIS_OPT_COLORSCHEME" in
@@ -622,18 +636,6 @@
i=1
first="true"
- # if running in GUI, turn off immediate mode rendering so that the
- # iterated d.vect commands will composite using the display driver
- if [ "$GIS_FLAG_S" -eq 1 ] ; then
- rendermode=$GRASS_RENDER_IMMEDIATE
- autowrite=$GRASS_PNG_AUTO_WRITE
- GRASS_RENDER_IMMEDIATE=FALSE
- export GRASS_RENDER_IMMEDIATE
- GRASS_PNG_AUTO_WRITE=FALSE
- export GRASS_PNG_AUTO_WRITE
- d.mon start=PNG
- fi
while [ $i -le $numint ]
do
if [ "$GIS_FLAG_M" -eq 1 ] ; then
@@ -869,17 +871,6 @@
line3=`expr $line3 - 4`
done
- # reset rendering for GUI use
- d.mon stop=PNG
- if [ -n "$currmon" ] ; then
- d.mon select=$currmon
- fi
- GRASS_RENDER_IMMEDIATE=$rendermodeexport
- GRASS_PNG_AUTO_WRITE=$autowrite
- fi
fi
#graduated points and line widths thematic mapping
@@ -970,18 +961,6 @@
i=$numint
ptsize=$GIS_OPT_MAXSIZE
- d.mon start=PNG
- fi
while [ $i -ge 1 ]
do
@@ -1166,20 +1145,18 @@
line2=`expr $line2 - $lineht`
i=`expr $i - 1`
done
- d.mon stop=PNG
- fi
- fi
fi
+ # reset display parameters
+ #GRASS_PNG_READ=$pngread
+ GRASS_PNG_READ=FALSE
+ GRASS_RENDER_IMMEDIATE=$rendermode
+ export GRASS_RENDER_IMMEDIATE
+fi
# Create graphic legend
if [ "$GIS_FLAG_L" -eq 1 -a "$GIS_OPT_MONITOR" != "none" ] ; then
if [ `eval d.mon -L | grep $GIS_OPT_MONITOR | awk '{print $5}'` = "not" ] ; then
