[GRASS-SVN] r29872 - grass/trunk/lib/edit
svn_grass at osgeo.org
Mon Jan 28 01:46:01 EST 2008
Author: hamish
Date: 2008-01-28 01:46:01 -0500 (Mon, 28 Jan 2008)
New Revision: 29872
grass/trunk/lib/edit/edit_cellhd.c
move help info here for safe keeping
Modified: grass/trunk/lib/edit/edit_cellhd.c
--- grass/trunk/lib/edit/edit_cellhd.c 2008-01-28 05:00:53 UTC (rev 29871)
+++ grass/trunk/lib/edit/edit_cellhd.c 2008-01-28 06:46:01 UTC (rev 29872)
@@ -45,6 +45,64 @@
* 0 ok
+/* Documentation moved here from the g.region man page:
+ * (g.region no longer does interactive; lib/init/set_data.c is the
+ * only thing left using E_edit_cellhd() AFAICT. --HB 28 Jan 2008)
+ * <h2>REGION EDIT PROMPT</h2>
+ * Most of the options will require the user to edit a
+ * geographic region, be it the current geographic region or
+ * one stored in the user's named region definitions
+ * (the <kbd>windows</kbd> directory). A standard prompt is
+ * used to perform this edit. An example is shown below:
+ * <pre>
+ * | IDENTIFY REGION |
+ * | =========== DEFAULT REGION ========== |
+ * | | Default North: 3402025.00 | |
+ * | | ===YOUR REGION=== | |
+ * | | | NORTH EDGE | | |
+ * | | | 3402025.00_ | | |
+ * | Def West: |WEST EDGE | |EAST EDGE | Def.East: |
+ * | 233975.00 |233975.00_| |236025.00_| 236025.00 |
+ * | | | SOUTH EDGE | | |
+ * | | | 3399975.00_ | | |
+ * | | Default South: 3399975.00 | |
+ * | Default GRID RESOLUTION Region |
+ * | 50.00 --- East-West --- 50.00__ |
+ * | 50.00 -- North-South -- 50.00__ |
+ * | AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE |
+ * </pre>
+ * The fields NORTH EDGE, SOUTH EDGE, WEST EDGE and EAST EDGE,
+ * are the boundaries of the geographic region that the user
+ * can change. The fields Default North, Default South, Def
+ * West and Def East are the boundaries of the default
+ * geographic region that are displayed for reference and
+ * <em>cannot</em> be changed. The two GRID RESOLUTION Region
+ * fields (east-west, and north-south) are the geographic
+ * region's cell resolutions that the user can change. The
+ * two GRID RESOLUTION Default fields list the resolutions of
+ * the default geographic region; these are displayed for
+ * reference and cannot be changed here by the user.
#include <string.h>
#include <stdlib.h>
#include <grass/vask.h>
