[GRASS-SVN] r29873 - grass/trunk/general/g.region/cmd
svn_grass at osgeo.org
Mon Jan 28 01:47:32 EST 2008
Author: hamish
Date: 2008-01-28 01:47:32 -0500 (Mon, 28 Jan 2008)
New Revision: 29873
grass/trunk/general/g.region/cmd/description.html
remove old GRASS 5 interactive menu help text
Modified: grass/trunk/general/g.region/cmd/description.html
--- grass/trunk/general/g.region/cmd/description.html 2008-01-28 06:46:01 UTC (rev 29872)
+++ grass/trunk/general/g.region/cmd/description.html 2008-01-28 06:47:32 UTC (rev 29873)
@@ -85,128 +85,9 @@
stored under other mapsets in the current location, if
these mapsets are included in the user's mapset search
path or the '@' operator is used (<tt>region_name at mapset</tt>).
</dl>
-<!-- interactive mode no longer available, moved to startup ...?
-<h2>REGION EDIT PROMPT</h2>
-Most of the options will require the user to edit a
-geographic region, be it the current geographic region or
-one stored in the user's data base of region definitions
-(the <kbd>windows</kbd> directory). A standard prompt is
-used to perform this edit. An example is shown below:
-<pre>
-| IDENTIFY REGION |
-| =========== DEFAULT REGION ========== |
-| | Default North: 3402025.00 | |
-| | ===YOUR REGION=== | |
-| | | NORTH EDGE | | |
-| | | 3402025.00_ | | |
-| Def West: |WEST EDGE | |EAST EDGE | Def.East: |
-| 233975.00 |233975.00_| |236025.00_| 236025.00 |
-| | | SOUTH EDGE | | |
-| | | 3399975.00_ | | |
-| | Default South: 3399975.00 | |
-| Default GRID RESOLUTION Region |
-| 50.00 --- East-West --- 50.00__ |
-| 50.00 -- North-South -- 50.00__ |
-| AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE |
-</pre>
-The fields NORTH EDGE, SOUTH EDGE, WEST EDGE and EAST EDGE,
-are the boundaries of the geographic region that the user
-can change. The fields Default North, Default South, Def
-West and Def East are the boundaries of the default
-geographic region that are displayed for reference and
-<em>cannot</em> be changed. The two GRID RESOLUTION Region
-fields (east-west, and north-south) are the geographic
-region's cell resolutions that the user can change. The
-two GRID RESOLUTION Default fields list the resolutions of
-the default geographic region; these are displayed for
-reference and cannot be changed here by the user.
-<h2>REGION MANAGEMENT MENU OPTIONS</h2>
-<ol>
-<li>Modify the current geographic region directly Allows
-the user to edit the current region.
-<li>Set current geographic region from default region
-Copies the default region to the current geographic region,
-and then lets the user edit the current geographic region.
-<li>Set current geographic region from a data base
-geographic region Allows the user to select a geographic
-region by name from the data base of geographic regions to
-become the current geographic region, and then lets the
-user edit the current geographic region.
-<br>
-Note: geographic region definition files may be selected
-from other mapsets as well, if accessible and in the user's
-mapset search path.
-<li>Set current geographic region from a raster map
-layer Allows the user to select a raster map layer, copies
-the cell header for this map layer to the current
-geographic region, and then lets the user edit the current
-geographic region. This option is useful when subsequent
-GRASS operations will be used to produce a raster map layer
-from one input raster map layer and it is necessary that
-the result coincide with the input raster map layer.
-<li>Save the current geographic region (window) in the data
-base Allows the user to save the current geographic region
-settings in the user's data base of such settings. These
-files are stored in the <kbd>windows</kbd> directory under
-the user's current mapset. This option is useful when the
-current geographic region is set directly using option 2,
-or even by another GRASS program
-(e.g., <em><a HREF="gis.m.html">gis.m</a></em>).
-This option installs an otherwise temporary geographic
-region setting into the geographic region definition data
-base for recall when needed.
-<li>Create a new data base geographic region setting
-Creates a new geographic region definition in the user's
-data base of such settings in the <kbd>windows</kbd>
-directory under the current mapset, using the geographic
-region edit prompt described above. After the geographic
-region definition is created, the user is asked if this
-geographic region setting should also be used as the
-current geographic region.
-<li>Modify a data base geographic region setting Modifies a
-geographic region setting (in the data base of such
-settings in the <kbd>windows</kbd> directory of the current
-mapset), using the geographic region edit prompt. After
-the changes have been made, the user is asked if this
-</ol>
<h2>NOTES</h2>
After all updates have been applied, the current region's
@@ -601,7 +482,8 @@
<a HREF="g.access.html">g.access</a><br>
<a HREF="g.mapsets.html">g.mapsets</a><br>
<a HREF="g.proj.html">g.proj</a><BR>
-<a HREF="variables.html#internal">GRASS_REGION and WIND_OVERRIDE environment variables</a><BR>
+<a HREF="g.setproj.html">g.setproj</a><BR>
+environment variables: <a HREF="variables.html#internal">GRASS_REGION and WIND_OVERRIDE</a>
</em>
